SL-J1 Problem, Issue with automatic tonearm
0sseus
post Sep 4 2011, 03:18
When I press play, the tonearm lowers onto the record as it should; but then the tonearm is dragged rapidly towards the end of the record.
I've made a video of it in action....
http://www.youtube.com/watch?v=58O1KE_3l88
This is my first turntable, go easy on me, guys! ;]
Glenn Gundlach
post Sep 4 2011, 03:57
Is the tracking force correct? Is there a setting for anti-skate? My guess is the stylus was a diamond mounted to an aluminum stud which is then press fitted into the stylus cantilever and the diamond is broken off. Take some VERY close up pix of the stylus. I bet its it's flat bottomed because of the damage.
G
cliveb
post Sep 4 2011, 13:49
WaveRepair developer
QUOTE (Glenn Gundlach @ Sep 4 2011, 03:57) *
This is a linear tracking turntable, so in theory there should be no need for anti-skate.
The video shows that the arms moves across the record surface at a constant speed, taking about 5 seconds to traverse the LP. My guess is that the arm on this turntable is moved by a little stepper motor, and whatever the monitoring device is that actuates the stepper is faulty, causing the stepper motor to be on continuously.
0sseus
post Sep 4 2011, 17:39
Well i believe cliveb is correct; but after messing with it for a while, I found that putting the "Size" switch to "manual" allowed me to use the turntable normally. Now it functions great!!
Thanks for your help, people! I finally get to listen to my vinyl!! biggrin.gif
cliveb
post Sep 5 2011, 10:08
QUOTE (0sseus @ Sep 4 2011, 17:39) *
OK, I understand now. With the size setting on auto, the turntable presumably has a method of detecting the edge of the record - probably some sort of photodetector and a LED. This appears not to work, so it fails to find the edge of the record, and therefore just carries on right to the centre, where it gives up.
RSS Lo-Fi Version Time is now: 2nd June 2015 - 21:20
