> Upload forum rules
Command-line WMA encoder, supports stdin
lvqcl
post Aug 30 2011, 21:13
Here is command-line WMA encoder. Inspired by this thread.
Requirements: Windows XP or later, Window Media Codecs installed.
Usage examples:
WmaEncode --codec lossless in.wav out.wma
WmaEncode -c lsl in.wav out.wma
WmaEncode --codec pro --quality 90 in.wav out.wma
WmaEncode -c pro -q 90 in.wav out.wma
WmaEncode --mode vbr2pass --bitrate 128 in.wav out.wma
WmaEncode -m vbr2pass -b 128 in.wav out.wma
...etc.
Sources included. Don't expect them to be well-commented though.
changelog:
0.2.9c: another minor fix in WAV parsing.
0.2.9b: minor fixes in WAV parsing. Sources are attached as a separate file.
0.2.9a: new switches -c, -m, -i, -s (short versions of --codec, --mode, --ignorelength, --silent)
0.2.9: maintenance update
0.2.8: allows 2-pass mode for stdin by default
0.2.7: progress indicator added
0.2.6: raw PCM input added
This post has been edited by lvqcl: Jan 15 2015, 23:10
Attached File(s)
b66pak
post Aug 31 2011, 19:23
thanks a lot...
_
- lvqcl   Command-line WMA encoder   Aug 30 2011, 21:13
- - mudlord   Any source?   Aug 30 2011, 23:02
|- - lvqcl   The sources will be uploaded later. Want to add co...   Aug 31 2011, 15:43
- - b66pak   thanks a lot... _   Aug 31 2011, 19:23
- - mudlord   Cool, just was wondering since it would be nice to...   Aug 31 2011, 23:42
- - lvqcl   Version 0.2.5 was uploaded. Several bugs were fixe...   Sep 2 2011, 16:24
- - b66pak   thanks a lot... _ please, could you enable (add) ...   Sep 3 2011, 17:40
|- - lvqcl   QUOTE (b66pak @ Sep 3 2011, 20:40) you do...   Sep 3 2011, 17:48
- - b66pak   with WMEncoder installed on WinXP i can do this: ...   Sep 3 2011, 18:03
- - lvqcl   All right, but my program doesn't use Windows ...   Sep 3 2011, 18:29
- - b66pak   please, can you add support for raw pcm input? su...   Sep 4 2011, 17:05
- - Nick.C   Mono now working. Thanks!   Sep 4 2011, 20:32
- - lvqcl   Version 0.2.6, with raw PCM input support.   Sep 6 2011, 15:18
- - b66pak   thanks a lot... _   Sep 6 2011, 18:00
- - lvqcl   Version 0.2.7: progress report was added by reques...   Sep 13 2011, 17:54
- - b66pak   thanks a lot... _   Sep 13 2011, 17:57
- - dpc666   Thank you so much! Microsoft inexplicably has ...   Sep 16 2011, 19:50
- - b66pak   thanks a lot... _   Sep 19 2011, 18:48
- - jaro1   Once more many thanks for this encoder, i use it v...   Sep 24 2011, 14:20
- - b66pak   thanks a lot...change log? _   Nov 3 2011, 18:28
- - Polosa   WMA TAG Does not support unicode (UTF-8) text   Nov 22 2011, 02:00
- - lvqcl   The tags are of type WMT_TYPE_STRING ("null-t...   Nov 22 2011, 15:39
- - b66pak   thanks a lot... _   Dec 25 2011, 19:35
- - jaro1   Thank you very much for development   Dec 25 2011, 19:52
- - jsheridan   Thanks alot, i was waiting for this type of app...   Dec 30 2011, 13:43
- - xorsyst   This is great, thanks. Any chance of adding a --s...   May 10 2012, 12:50
- - bernhold   I have made a small wrapper command line tool for ...   Mar 23 2013, 21:35
- - emte   Hi, Could you give me exact line I should give fo...   Apr 6 2013, 19:43
|- - lvqcl   CODE--codec pro --quality 50 - %d   Apr 6 2013, 20:25
- - eahm   EZ CD Audio Converter supports WMA 11. It that ver...   Apr 6 2013, 22:15
- - bernhold   QUOTE (eahm @ Apr 6 2013, 22:15) EZ CD Au...   Apr 10 2013, 22:38
- - eahm   bernhold, thanks for that. lvqcl, wha do I need t...   Apr 11 2013, 20:36
- - eahm   My bad I was using the wrong command, everything w...   Apr 11 2013, 22:09
- - temp1   thank u,lvqcl love it. fb2k+windows 8 pro works pe...   Apr 12 2013, 02:40
- - lixtary   Hi!lvqcl ,thank you very much ,your encode is ...   Jul 3 2013, 10:41
- - Kreisch   Thank you for making this handy tool available. I ...   Apr 23 2014, 15:04
- - lvqcl   a) WMAencode doesn't downmix itself. It asks W...   Apr 23 2014, 15:17
|- - Kreisch   Thank you for your prompt reply. It works as you...   Apr 23 2014, 17:26
- - CitizenInsomniac   lvqcl, I just wanted to say thank you for putting ...   Jan 15 2015, 23:40
- - CitizenInsomniac   I have a feature suggestion too: It'd be real...   Jan 16 2015, 03:45
|- - lvqcl   QUOTE (CitizenInsomniac @ Jan 16 2015, 05...   Jan 16 2015, 16:45
|- - CitizenInsomniac   QUOTE (lvqcl @ Jan 16 2015, 07:45) When I...   Jan 17 2015, 01:00
- - CitizenInsomniac   lvqcl, I have another question: Do you know which...   Jan 24 2015, 01:37
- - lvqcl   This program uses Windows Media Format SDK, not Me...   Jan 24 2015, 09:09
|- - CitizenInsomniac   QUOTE (lvqcl @ Jan 24 2015, 00:09) This p...   Jan 25 2015, 09:03
- - lvqcl   According to https://technet.microsoft.com/en-US/f...   Jan 25 2015, 12:18
- - CitizenInsomniac   QUOTE (lvqcl @ Jan 25 2015, 03:18) Availa...   Jan 26 2015, 11:50
- - lvqcl   QUOTE (CitizenInsomniac @ Jan 26 2015, 13...   Jan 26 2015, 16:44
RSS Lo-Fi Version Time is now: 2nd September 2015 - 12:46
