Vinyl Care & Dust Removal, How to make vinyl sound good??
ViPER1313
post May 4 2003, 20:11
After reading the thread found here [ http://www.hydrogenaudio.org/forums/index....t=7953&hl=vinyl ] I was blown away by the recording quality of the sandra.mpc sample. How do you get vinyl to sound so dust free and rich? All the vinyl that I have recorded has at least some dust crackling in the background, and some recordings sound extremely harsh (especially in the vocals - almost like clipping except there is no clipping going on.....) Do you use digital correction? Filtering? I use the following equipment -
Marantz TT1060 Turntable w/ unknown cartridge/needle (the cartridge/needle are replacements, less than 6 months old - I have no idea what brand / model they are, but they seem to be of decent quality.)
Marantz PM325 Receiver
SB-Live soundcard fed from phono -> receiver -> line-in (This is not the weak link I am concerned over - I know it has crappy quality recording, but I am worried about the record playback quality itself . I have also tried phono -> line-in directly and was not impressed with the quality at all.)
The cartridge seems to have good frequency response and be of decent quality, but I can not get rid of dust no matter what I try - I have a diskwasher and have tried a 1:5 alcohol/water solution, but the dust persists. Any tips?
vraxoin
post May 5 2003, 21:47
The brushes from the Discwasher kits are designed to remove heavier surface grime, but they don't effectively sweep out particles caught deeper in the grooves and thus I would also second Pio2001's suggestion regarding a carbon fiber brush. I've been using the Hunt EDA brushes for years and they are very effective. A slightly less expensive carbon fiber brush which had also been recommended to me, but that I haven't used, is from Audioquest. Either of those will certainly outperform the Discwasher brush.
Also, you mentioned creating your own vinyl cleaning solution and I just wanted to make sure that you were using distilled water and not tap water which will usually do more to foul up your records than help. Plus, make sure that you use absolutely pure Isopropyl alcohol.
Finally, if you are having no luck and still want dead silent records, get one of these. biggrin.gif
- ViPER1313   Vinyl Care & Dust Removal   May 4 2003, 20:11
- - Pio2001   QUOTE Do you do digital correction? Filtering? No...   May 4 2003, 23:31
- - vraxoin   The brushes from the Discwasher kits are designed ...   May 5 2003, 21:47
- - ViPER1313   Thanks for the advice! I think I need to buy a...   May 6 2003, 01:40
- - Continuum   What do you think about playing wet? I recall to h...   May 6 2003, 06:56
- - Pio2001   Good.mpc sounds technically perfect, though I don...   May 6 2003, 14:21
- - 2Bdecided   1 thing to add: dust.mpc has a loud LF tone/noise ...   May 6 2003, 15:24
- - Lev   QUOTE What do you think about playing wet? I recal...   May 6 2003, 15:30
- - ViPER1313   By: Pio2001 (Posted on May 6 2003 - 09:21 AM) QUOT...   May 6 2003, 16:40
- - vraxoin   Regardless of EQ being used, the "good" ...   May 6 2003, 18:34
- - Pio2001   QUOTE Bass was probably set to +0db, midrange was ...   May 6 2003, 19:29
- - ViPER1313   QUOTE The tone settings on the ampli should not af...   May 7 2003, 05:49
- - boojum   QUOTE (Continuum @ May 5 2003 - 09:56 PM)What...   May 7 2003, 06:03
- - ViPER1313   Here is a sample using the PM325's tape output...   May 7 2003, 06:51
- - 2Bdecided   That one sounds fine to me. I'd just do some g...   May 7 2003, 11:32
- - Continuum   QUOTE (vraxoin @ May 6 2003 - 07:34 PM)Regard...   May 7 2003, 18:48
- - Continuum   QUOTE (boojum @ May 7 2003 - 07:03 AM)Soon yo...   May 7 2003, 18:54
- - nmpaulcp   I start with products from www.lastfactory.com (so...   May 20 2003, 01:05
|- - Shamray   QUOTE (nmpaulcp @ May 20 2003, 01:05) I s...   Apr 6 2011, 09:29
- - DVDdoug   What software? DCART32? Does the documentation s...   Apr 6 2011, 18:20
- - cyberdux   For dust and grime removal: Vaccuum LP cleaners ...   Apr 7 2011, 02:13
|- - cliveb   QUOTE (cyberdux @ Apr 7 2011, 02:13) Vacc...   Apr 7 2011, 08:53
- - Apesbrain   This is a great site for an assortment of relative...   Apr 7 2011, 17:38
RSS Lo-Fi Version Time is now: 1st September 2015 - 07:34
