Public AAC Listening Test @ ~96 kbps [July 2011]: Results, Results and post-test discussion
IgorC
post Aug 23 2011, 19:56
After the long time of preparations, discussions and realization of the test the results are finally here.
http://listening-tests.hydrogenaudio.org/i...-a/results.html
Summary: Apple won, FhG is the second, Coding Technologies is the third and Nero is the last
I appreciate all people who has supported the test and participated in it.
This post has been edited by IgorC: Aug 23 2011, 20:12
Gecko
post Aug 25 2011, 20:24
First, thank you IgorC and everyone involved!
How do I perform and interpret the analysis on a different set of data (e.g. only my personal results)?. Here's what I got so far:
1. From the provided results.zip copy the "Sorted by sample" folder to a new location and delete all unwanted test results (e.g. keep only 34_GECKO_test??.txt).
2. Use chunky to gather the ratings: chunky.py --codecs=1,Nero;2,CVBR;3,TVBR;4,FhG;5,CT;6,ffmpeg -n --ratings=results --warn -p 0.05 --directory="d:\foo"
3. Take chunky's output "results.txt" and feed it to bootstrap: bootstrap.py --blocked --compare-all -p 100000 -s 100000 results.txt > bootstrapped.txt
a) Do I need to look at "Unadjusted p-values:" or "p-values adjusted for multiple comparison:" if I am just checking my own results? In other words: does the "multiple comparisons" refer to multiple listeners or multiple samples (or something else)?
b) Can step 1. be done more efficiently?
c) How do I run chunky over all results to get one merged results file like "results_AAC_2011.txt" in results.zip? Right now I get per sample results averaged over all listeners (and results for individual samples which could be merged by hand)
IgorC
post Aug 26 2011, 03:30
QUOTE (Gecko @ Aug 25 2011, 16:24) *
Thank You too for your complete 20 results.
a) Both are fine. Though I'm also interested to hear Garf on this subject.
b) Yes, there is easier way. There is "Sorted by listener" folder. Find folder with your results ("34_GECKO"), rename it to "Sample01" and run chunky on it.
c) You should copy-paste all results (results01, results02, ... , results20) to results_AAC_2011.txt. Without spaces or comments. You will have 280 results totally: sample01 - 21 results, sample02 - 20 results, ... etc. -> summary: 280 results. If you have any issues then see "results_AAC_2011.txt".
mjb2006
I do not accept the results after the closure of the test (evening 20 Aug).
Your results would be discarded anyway.
Your results for samples 03 and 04 are invalid. Two invalid results from your total 5 results (01,02,03,04,05)-> means complete discard. Read the rules.txt
I've repeated many times to send single results as soon as possible to re-do them in case of errors.
And your results are dated by 26 July. There is nobody to blame.
This post has been edited by IgorC: Aug 26 2011, 03:47
mjb2006
post Aug 26 2011, 05:18
QUOTE (IgorC @ Aug 25 2011, 20:30) *
I do not accept the results after the closure of the test (evening 20 Aug). Your results would be discarded anyway.
I'm not upset, and I did not wish to imply that I was arguing about whether my results should have been considered valid. Clearly they are not.
Besides, I see now what happened. On 20 Aug I realized I would not have time to do more tests, so I checked the thread, and you had not yet made your post saying the test was closed, so I RARed my old results (file modification time 16:04:09-0600) and sent them (email time 16:05:34). I see now that you posted in that very short interval (post time 16:04:xx).
And I didn't realize that you would be contacting people about errors and offering them the chance to re-do those tests. This meaning is not at all obvious when you said that sending results early "helps to prevent some simple errors related to ABC-HR application or any other at early stage," which sounds like you're referring to logistical issues and also seems to be the only time you mentioned it in the test thread, not something you "repeated many times."
Anyway, is it normal for ~27% of listeners to have their results discarded?
- IgorC   Public AAC Listening Test @ ~96 kbps [July 2011]: Results   Aug 23 2011, 19:56
- - benski   It would be interesting to do a rank-sum analysis ...   Aug 23 2011, 20:18
|- - Garf   QUOTE (benski @ Aug 23 2011, 21:18) It wo...   Aug 23 2011, 20:27
||- - benski   QUOTE (Garf @ Aug 23 2011, 15:27) QUOTE (...   Aug 23 2011, 20:54
||- - Garf   QUOTE (benski @ Aug 23 2011, 21:54) The F...   Aug 23 2011, 21:11
|- - C.R.Helmrich   QUOTE (benski @ Aug 23 2011, 21:18) ... w...   Aug 23 2011, 20:42
||- - Garf   QUOTE (C.R.Helmrich @ Aug 23 2011, 21:42)...   Aug 23 2011, 20:47
|||- - lvqcl   QUOTE (Garf @ Aug 23 2011, 23:47) Basical...   Aug 27 2011, 20:22
|||- - no404error   QUOTE (lvqcl @ Aug 27 2011, 22:22) CVBR, ...   Sep 4 2011, 04:01
||- - benski   QUOTE (C.R.Helmrich @ Aug 23 2011, 15:42)...   Aug 23 2011, 20:52
|- - IgorC   QUOTE (benski @ Aug 23 2011, 16:18) It wo...   Aug 23 2011, 21:01
|- - benski   QUOTE (IgorC @ Aug 23 2011, 16:01) QUOTE ...   Aug 23 2011, 21:07
|- - IgorC   QUOTE (benski @ Aug 23 2011, 17:07) Actua...   Aug 23 2011, 21:11
- - IgorC   I should also mention that I've participated i...   Aug 23 2011, 21:30
- - zima   Maybe there could be a legend for X-axis, the abbr...   Aug 23 2011, 21:37
- - lvqcl   It is interesting that QT tvbr and cvbr encoded fi...   Aug 23 2011, 22:05
- - IgorC   zima, will fix it later. QUOTE (lvqcl @ Au...   Aug 23 2011, 22:11
- - Alexxander   Thanks to all who participated in this test and to...   Aug 23 2011, 22:31
|- - Garf   QUOTE (Alexxander @ Aug 23 2011, 23:31) I...   Aug 23 2011, 23:02
- - Dakeryas   Many thanks for the test ! Interesting to not...   Aug 23 2011, 23:11
- - IgorC   I've noticed that previous version of Nero 1.0...   Aug 23 2011, 23:51
- - Gornot   To be perfectly honest, I am surprised that FhG di...   Aug 24 2011, 00:29
- - /mnt   Interesting results, I gotta see if the pre-echo h...   Aug 24 2011, 01:23
- - kennedyb4   If it is fair to say that many of the samples were...   Aug 24 2011, 01:42
- - Sebastian Mares   It appears to me that the low anchor was way too b...   Aug 24 2011, 07:29
|- - Garf   QUOTE (Sebastian Mares @ Aug 24 2011, 08...   Aug 24 2011, 09:35
|- - Nezmer   QUOTE (Garf @ Aug 24 2011, 10:35) Probabl...   Aug 24 2011, 11:35
|- - Garf   QUOTE (Nezmer @ Aug 24 2011, 12:35) QUOTE...   Aug 24 2011, 12:46
|- - Nezmer   QUOTE (Garf @ Aug 24 2011, 13:46) QUOTE (...   Aug 24 2011, 18:26
- - greynol   I was wondering the same thing.   Aug 24 2011, 07:49
- - C.R.Helmrich   Some bit-rate statistics which were presented in p...   Aug 24 2011, 18:27
|- - Garf   QUOTE (C.R.Helmrich @ Aug 24 2011, 19:27)...   Aug 25 2011, 07:29
- - Zarggg   Just looking for a quick verification on whether I...   Aug 25 2011, 18:06
|- - IgorC   QUOTE (Zarggg @ Aug 25 2011, 14:06) Am I ...   Aug 25 2011, 18:28
- - greynol   CVBR and TVBR are statistically tied. One did not...   Aug 25 2011, 18:12
|- - Zarggg   QUOTE (greynol @ Aug 25 2011, 13:12) CVBR...   Aug 25 2011, 22:47
|- - Garf   QUOTE (greynol @ Aug 25 2011, 19:12) CVBR...   Aug 26 2011, 07:20
- - greynol   That assumes facts not in evidence.   Aug 25 2011, 19:04
- - Gecko   First, thank you IgorC and everyone involved! ...   Aug 25 2011, 20:24
|- - IgorC   QUOTE (Gecko @ Aug 25 2011, 16:24) First,...   Aug 26 2011, 03:30
||- - mjb2006   QUOTE (IgorC @ Aug 25 2011, 20:30) I do n...   Aug 26 2011, 05:18
||- - IgorC   QUOTE (mjb2006 @ Aug 26 2011, 01:18) Anyw...   Aug 26 2011, 05:24
|- - Garf   QUOTE (Gecko @ Aug 25 2011, 21:24) a) Do ...   Aug 26 2011, 07:16
|- - IgorC   QUOTE (Garf @ Aug 26 2011, 03:16) Always ...   Aug 26 2011, 08:51
- - mjb2006   Even though I sent in results, they didn't get...   Aug 25 2011, 22:50
- - Gecko   Thank you IgorC and Garf for answering my question...   Aug 26 2011, 10:28
|- - IgorC   QUOTE (Gecko @ Aug 26 2011, 06:28) Given ...   Aug 26 2011, 11:20
||- - Garf   QUOTE (IgorC @ Aug 26 2011, 12:20) QUOTE ...   Aug 27 2011, 17:48
|- - Garf   QUOTE (Gecko @ Aug 26 2011, 11:28) In the...   Aug 27 2011, 17:39
- - IgorC   I found the first and the last graphs to be partic...   Aug 27 2011, 21:46
|- - lvqcl   QUOTE (IgorC @ Aug 28 2011, 00:46) I thin...   Aug 27 2011, 22:20
- - IgorC   Yeah   Aug 27 2011, 22:39
- - IgorC   BTW if someone want to organize the next public te...   Oct 1 2011, 20:21
- - jukkap   How about 48kbps HE AAC ? Or low bitrate multiform...   Oct 1 2011, 20:49
|- - IgorC   QUOTE (jukkap @ Oct 1 2011, 16:49) How ab...   Oct 10 2011, 23:17
|- - jukkap   QUOTE (IgorC @ Oct 10 2011, 23:17) The la...   Oct 20 2011, 10:04
- - IgorC   Well, the last time we have tested LC-AAC encoders...   Oct 1 2011, 21:58
- - jukkap   QUOTE (IgorC @ Oct 1 2011, 22:58) Can You...   Oct 2 2011, 05:10
- - IgorC   Late but still here. Some participants have answ...   Oct 23 2011, 07:14
RSS Lo-Fi Version Time is now: 27th January 2015 - 10:31
