60 Pages V  « < 22 23 24 25 26 > »
foo_uie_lyrics3, An update of foo_uie_lyrics2
Sashka78
post Feb 17 2012, 13:41
Post #576
In foo_uie_lyrics3 preferences there is an option 'Select how to query these sources':
- Query all and pick the best result
- Only query the next source if no valid lyric is found
I want foobar2000 to look for lyrics in tags and display it immediately if it finds any. If it doesn't, I want it to query all other sources and pick the best result.
Is there currently a way to do that?
Alex
The vern
post Feb 17 2012, 19:37
Post #577
In your scenario there is actually no difference between the two (in terms of the result displayed), as the 'best' result is determined by:
a) The type of lyric - synced or not.
b) The search order (in preferences).
c) The rating of the lyric (which is currently redundant as none of the sources provide rating info).
Query next searches the sources in the order you put them, and if one of the results matches the type of lyric you've requested it will stop searching and display that lyric.
The only difference between the two options is that query all takes a lot longer, but allows you to use the 'Next lyric' option properly.
Therefore I would recommend that you use the query next option.
Incidentally all this is going to change in the next version - these options won't be there and it will essentially always be query next, but the next lyric option will actually search for and download lyrics from other sources (rather than just cycling through lyrics that have already been downloaded). Unfortunately due to work commitments this release might not be for a while - but we'll see.
Hope that helps, feel free to ask if it's not clear
johnsonlam
post Feb 17 2012, 20:12
Post #578
Thanks for rewritten the foo_uie_lyrics, it's been a long time, and it's working great. Thank you very much!
Maybe the only improvement is the text effect transition between normal and highlight color, or fade into background.
Hong Kong - International Joke Center (after 1997-06-30)
The vern
post Feb 17 2012, 20:21
Post #579
What sort of improvements would you like?
johnsonlam
post Feb 18 2012, 02:16
Post #580
QUOTE (The vern @ Feb 18 2012, 03:21) *
Maybe ... Inverse the background color of the active lyric, or from a dimmed normal color to a highlight bright color scheme.
I almost forgot, how to export the configuration?
This post has been edited by johnsonlam: Feb 18 2012, 02:22
Sai Kyou
post Feb 18 2012, 10:08
Post #581
I couldn't find any mention of adding lyrics manually (in case none are found) via lyrics 3 so hereby I would like to request a "add and edit lyrics" button.
I know I could just make a .txt file myself, but having the button seems faster. I also feel like it would add to the completeness of the plugin.
I'm not lazy. :|
Also an option enabling double clicking the Lyrics Show Panel to edit the lyrics (either in the built-in editor or an external one) would be sweet.
This post has been edited by Sai Kyou: Feb 18 2012, 10:13
The vern
post Feb 18 2012, 17:00
Post #582
QUOTE (Sai Kyou @ Feb 18 2012, 09:08) *
Sure.
Not possible, but you can use the copy & paste panels functions in both DUI and CUI.
I'm not sure about inverting the background colour - I'll give it some thought.
D-Shadow
post Feb 19 2012, 05:36
Post #583
Is there an option to make the background transparent somewhere? Could you consider adding it if that's not the case, to make this component pluggable into certain themes which rely on transparency?
neothe0ne
post Feb 20 2012, 09:37
Post #584
Is it possible to add save-able config/templates for Panel Preferences? I'd like to use this in a Dockable Panel, but a dockable lyrics3 panel's preferences don't get saved after restarting foobar2000. Being able to easily recover a configuration with one click would be great.
This post has been edited by neothe0ne: Feb 20 2012, 09:37
q-stankovic
post Feb 20 2012, 14:09
Post #585
Why at all you want to use the lyric show window in a dockable panel? Do you think it is really worth the effort just to have a window without borders?
WilB
post Feb 20 2012, 17:08
Post #586
I agree with q-stankovic in that I do not really see why you would want to use a dockable panel since foo_uie_lyrics3 can be used as a proper integrated panel with both DUI or CUI plus foo_uie_lyrics3 has its own popup panel accessible from the view menu.
I also believe that the original dockable panel component is no longer being developed. There is a replacement, foo_popup_panels, that is basically a stripped down version of dockable panels that is still being developed and available at http://www.foobar2000.org/components/view/foo_popup_panels. This component does save the foo_uie_lyrics3 panel preferences after restarting foobar2000.
This post has been edited by WilB: Feb 20 2012, 17:41
neothe0ne
post Feb 21 2012, 09:01
Post #587
QUOTE (q-stankovic @ Feb 20 2012, 09:09) *
Maybe I have foobar2000 on one monitor and want the lyrics in a second monitor? I have no idea what your second question is talking about.
Mayonezo
post Feb 21 2012, 19:00
Post #588
QUOTE (The vern @ Feb 15 2012, 22:40) *
QUOTE (Mayonezo @ Feb 15 2012, 19:56) *
Sadly the automatic save option doesn't work for me. Anything I can do about it?
It's difficult for me to help you without more information about your settings. Can you provide some?
Currently you can't change the tag that you save to with different codecs. The simplest way for me to allow this would be to enable titleformatting for those fields (which keeps the UI simple and is really easy for me to do tongue.gif).
Sounds great!
Here come the settings in tab lyric saving:
filename format: $if(%artist%,%artist% - )$if2(%title%,%_filename%)
save Settings:
- Enable automatic save is checked
- Save method: Save to tag
synced lyrics: LYRICS
unsynced lyrics: LYRICS
BrutuZ
post Feb 22 2012, 21:43
Post #589
Probably never going to happen, but I'll ask for it anyway: Custom Lyrics Sources.
A new kind of source where you determine the URL mask using foobar's formating (for example: http://www.vagalume.com.br/%artist%/%title%.html) and a textarea in which you could script a way to fetch the lyric from the page (RegEx maybe). For this particular site it would be the content from the DIV element with the property "itemprop=description".
It would allow power-users to script and share their own lyrics sources besides the preset ones.
This post has been edited by BrutuZ: Feb 22 2012, 21:46
http://www.last.fm/user/BrutuZ
SUPERCOOLMAN
post Feb 25 2012, 11:11
Post #590
1. cannot drop Local File Search to Available Sources (not a big deal)
2. would be good if we can specify lyric file search pattern for both the directory and file name. you let us define file name for auto save already. It's funny that auto saved filename cannot be used by Local File Search
I use "%directory%/lyrics" for directory and "%title%.lrc" for file name with the old lyric panel2. would be good to get all the good things in lyric panel3 without having to rename and reorganize thousands of lyric files
The vern
post Feb 25 2012, 15:06
Post #591
@Mayonezo:
I'm not sure why the automatic saving isn't working for you, but could it be something simple for example that your files are read only? Or maybe lyrics already exist in the LYRICS tag? Does it work if you right click->Save?
@BrutuZ:
As you suggest this unlikely to happen anytime soon, but in the next release (maybe) I'll allow other fb2k components to create their own lyric sources to be used within the component.
@SUPERCOOLMAN:
1. This is because you are saving lyrics to file (it has to check if one exists already).
2. What do you mean by "specify lyric file search pattern for the directory"? Assuming I've understood correctly, this can already be done in local file search properties. Several people have asked about customising the local file search pattern, and I think I've finally decided how I'm going to do it. Essentially, if the directory to be searched contains %artist%, %album artist% or %album%, only the title will be required in the filename for a lyric to be loaded.
Mayonezo
post Feb 25 2012, 16:34
Post #592
QUOTE (The vern @ Feb 25 2012, 15:06) *
@Mayonezo:
Nvm, I just realized that it only saves when the song reaches the end. I'd like to have it saved immediately though tongue.gif, but that's really no high priority thing.
Anyways, I'd love to help you improve the plugin by programming stuff or updating the lyrics databases.
SUPERCOOLMAN
post Feb 25 2012, 18:43
Post #593
QUOTE (The vern @ Feb 25 2012, 08:06) *
@SUPERCOOLMAN:
basically, I'm asking for the same function in lyric panel2 as shown below. fuzzy search is turned off.
this above configuration is able to find all of the corresponding lyric files, but the same setting in lyric panel3 can't find anything
Local File Search -> Search Sub-directories is checked unless this behaves differently from lyric panel2. the only thing I can think of is the search pattern for file name.
If there is anyway to enable debug logging to console, then I could check what pattern was searched and refine my search pattern/condition
I put lyrics under a directory call lyrics in the same directory as the music file, so title is always unique and you can't go wrong with just using title as file name.
example layout:
<directory A>/lyrics/sky.lrc
<directory A>/lyrics/blue.lrc
<directory A>/lyrics/fly.lrc
<directory A>/sky.mp3
<directory A>/blue.mp3
<directory A>/fly.m4a
<directory B>/lyrics/sea.lrc
<directory B>/lyrics/mountain.lrc
<directory B>/lyrics/salt.lrc
<directory B>/lyrics/water.lrc
<directory B>/lyrics/red.lrc
<directory B>/lyrics/apple.lrc
<directory B>/GGCC-1.flac
<directory B>/GGCC-1.cue
<directory B>/GGCC-2.flac
<directory B>/GGCC-2.cue
This post has been edited by db1989: Feb 25 2012, 21:26
Reason for edit: removing irrelevant two-thirds of quote
The vern
post Feb 25 2012, 20:54
Post #594
The changes I'm suggesting will do this.
As a quick fix, you can just make the artist search parameter a space, i.e. ' '.
SUPERCOOLMAN
post Feb 25 2012, 21:21
Post #595
QUOTE (The vern @ Feb 25 2012, 13:54) *
I tried deleting artist search parameter content and that didn't work. using single space as you suggested works
looking forward to a build with the changes
This post has been edited by SUPERCOOLMAN: Feb 25 2012, 21:21
mik9
post Feb 27 2012, 12:50
Post #596
Hi, in version 2 I hade last row in search patterns like this:
info: info
This found file "info.txt" in current directory (where audio file is). I have this file in a lot of directories, containing various info, esp. for audiobooks, dramas, etc. Would it be possible to set up search function the way that lyrics3 will be able to find info.txt in current directory?
StealthX
post Feb 27 2012, 20:51
Post #597
Could you add something so that when it finds songs that are instrumental it tells you instead of just being blank. Something like what lyrics wikia does for instrumental songs would be nice!
Example: http://lyrics.wikia.com/Dance_Gavin_Dance:..._Is_Royal_Ocean
BrutuZ
post Feb 27 2012, 21:22
Post #598
Just wondering why on Earth the plugin won't find my lyric files saved locally.
I've given up on the "online search" long ago, but not being able to find lyrics in files I already have? Come on!
My structure is pretty simple, the lyrics are always saved in a sub-folder named Lyrics (so original tongue.gif ) under the .mp3 folder with the same filename as the music files.
|Album
|-Lyrics
|--artist - album - 01 - trackname.txt
|--artist - album - 02 - trackname2.lrc
|-artist - album - 01 - trackname.mp3
|-artist - album - 02 - trackname2.mp3
EDIT: The "Local File Search" field is on the top of the list and set with $directory_path(%path%)\Lyrics
This post has been edited by BrutuZ: Feb 27 2012, 21:25
Sashka78
post Feb 27 2012, 21:39
Post #599
QUOTE (The vern @ Feb 17 2012, 21:37) *
That's the point: I'd like foobar to check tags first and if it finds any lyrics it should immediately stop searching and display the result.
Alex
Sashka78
post Feb 27 2012, 21:53
Post #600
I've noticed some characters display erratically.
Here is how the tags look like:
This is the text displayed by the plugin:
Alex
RSS Lo-Fi Version Time is now: 7th May 2015 - 10:03
