Any reason why FB2K fails to delete "VA" from album artist ?, Quick answer: delete ITUNESCOMPILATION at the same time
swayzak
post Jul 29 2011, 20:54
Hi
I have some albums that I've tried to remove the Various Artists tag from Album Artist field - but each time I do so & apply, it reappears again !
Any ideas ?
thanks
Robertina
post Jul 29 2011, 21:23
Group: Banned
Are these iTunes encoded files? foobar2000 v1.1.6 introduced some Metadata Compatibiliy changes.
What happens if you press shift + right-click -> Tagging -> Reload Info from files, as described in the mentioned WIKI article?
lvqcl
post Jul 29 2011, 21:31
Maybe you use CUE sheets. If yes: foobar2000 supports very limited set of tags in CUE files. And composer=album artist=band=original artist.
swayzak
post Jul 29 2011, 22:33
QUOTE (Robertina @ Jul 29 2011, 15:23) *
Not sure about iTunes - although there is a metadata field called ITUNES COMPILATION & value = 1.
Have tried Reload Info - nothing happened.
*UPDATE* Deleting the ITUNES COMPILATION field before deleting Various Artists from Album Artist field fixed it.
This post has been edited by swayzak: Jul 29 2011, 22:40
Robertina
post Jul 29 2011, 23:05
Group: Banned
QUOTE (swayzak @ Jul 29 2011, 10:33) *
I don't think that the order in which you delete the tags plays a role. Instead I assume that your ALBUM ARTIST field has been empty and therefore fetched its content from the ITUNESCOMPILATION tag. If I am right the deletion of the ITUNESCOMPILATION tag would have been sufficient.
If your ALBUM ARTIST tag would have had its own content, foobar2000 would have prioritized it over the ITUNESCOMPILATION tag.
swayzak
post Jul 29 2011, 23:26
QUOTE (Robertina @ Jul 29 2011, 17:05) *
Album Artist = Various Artists
ITUNESCOMPILATION = 1
So I had to delete the latter to make deleting the former work, if that makes sense ?
Robertina
post Jul 29 2011, 23:47
Group: Banned
Yes. The "1" indicates the existence of the ITUNESCOMPILATION tag. And from the WIKI article I mentioned above:
foobar2000 links the iTunes ITUNESCOMPILATION tag to the ALBUM ARTIST tag. In case an ITUNESCOMPILATION tag is found in a file, foobar2000 treats it as if ALBUM ARTIST was set to "Various Artists". If an ALBUM ARTIST tag is found, ITUNESCOMPILATION will be ignored.
This is want I meant, but I could be wrong.
kode54
post Jul 30 2011, 06:27
Group: Admin
You must delete them both at once. Deleting only the ITUNESCOMPILATION field will cause the Album Artist field to be written to the file as it was originally filled in when the tag was read.
Robertina
post Jul 30 2011, 12:05
Group: Banned
Thank you for the clarification, kode54.
Sorry for my misinformation, swayzak.
RSS Lo-Fi Version Time is now: 1st February 2015 - 20:32
