How to Clean up Cassette to Digital, Need Help
cupelix
post May 3 2003, 00:27
Thanks in Advance for any help one of you might offer.
I am far from an Audio Pro, yet have been trying to take some old cassette tapes and restore the sound quality they originally had, and enhance it even. As for this file in particular it seems to have lost its high's and mids. When I run it through a simple EQ plugin I just dont get the clarity I need, it just sounds worse.
Here is the steps I took in recording this tape.
#1 - Used a brand new Sony Tape deck , with preamp mixer and got the sound quality as close to 0 DB as I could (as reccomended by many audio recording sites I have read). I recorded at 44.1 hz, 16 bit through my SBLIVE card. I saw no loss in quality from tape to digital.
#2 - I then loaded Wavlab and watched the spectrum analyser and saw the highs and some mids were very low. I tried to raise this up in value but it just made the sound even more distorted than it already was.
I have many tapes like this I would like to restore, re-master (or whatever the term is). I have attached this file (in original .wav format) and uploaded it to the alt.binaries.sound.mp3 newsgroup. The topic is called:
"Sound Pro's can you give tips on how to fix this Audio File? Email - Trick@lvcm.com"
You can also download the .wav file clip at - http://www.lvcm.com/trick/badwav/badwav.wav
Any help on cleanup (what software/settings to use), examples , web links on fixing this sorta of stuff is GREATLY appreciated!!!! Heck if someone wants to clean it up themselves and email it back with the steps you used to do it, that would even be better.
This advice would be Pricessless, thanks again in advance to anyone who can help this audio newbie.
Email - trick@lvcm.com
Thanks,
Trick
PS - I have read about the CEDAR system, is this hardware based only???
JeanLuc
post May 3 2003, 09:37
QUOTE (Pio2001 @ May 3 2003 - 01:17 AM)
1-I should first unscrew the cassette case and put the tape into a TDK MA case (or another good case), because I've found that my Teac V2030S deck have much less flutter with TDK MA cases than, for example, TDK SA. But I usually skip this. Anyway, the tapes were already recorded with flutter.
2-I know that some of my tapes were recorded on a deck with misaligned heads. I then put off the front of the deck, and screw the playback head while the tape is running until the sound is best (in this case, remember the old position in order to go back when the recording is done).
3 - Find the exact speed at which the tape should be played, looking for CDs with one track that was also recorded on the same cassette recorder at the same time. The speed correction needed to match the wav recorded from the tape and the wav ripped from the CD must be applied on the recording. I use a resampling function for this.
Say that I must set the speed to +2 % in order for the tape recording to have the same pitch as the CD. I resample then all the tapes recordings from the same recorder to 44100/1.03=42816 Hz, then reset the sample rate to 44100 in order to correct the pitch.
4 - I load all wav files in Samplitude 2496, then match volumes of each one (I sometimes need to compress dynamics), then the treble level. I use a parametric equalizer for the treble correction.
5 - I burn.
I never remove the hiss. My old tests with SoundForge noise reduction plugin were disappointing.
MA or MA-XG ?
IIRC, TDK MA used the same casing as TDK SA ... I would use an MA-XG case (remember that cast-iron frame ...)
Aligning (and cleaning, even on a brand new tape deck) the head should bring the most audible improvement ... misaligned heads will lose much treble and will implement ugly phase errors due to azimuth problems ...
Dolby circuits work as a compressor during recording and expand during playback so be sure that you choose the correct playback setting (B/C/S) ... this could be performed within a wav editor as well, but needs some more experience ...
I would record on single wav file per cassette side and listen to it ... pitch correction can be performed if necessary, parametric or paragraphic equalisation is mostly needed. A "subsonic" filter can be applied to remove low-frequency tape hiss ...
De-Hiss should be (if carried out at all) done very carefully ... Sonic Foundry's DirectX Noise Reduction allows to listen to "residual output" ... you can listen to what is removed and will be able to tell if de-hiss affects the music ...
The name was Plex The Ripper, not Jack The Ripper
- cupelix   How to Clean up Cassette to Digital   May 3 2003, 00:27
- - dreamliner77   JUst a thought If you are recording the wav's...   May 3 2003, 00:41
- - TwoJ   Hi Cupelix PSS - Cedar is a company that does aud...   May 3 2003, 01:49
- - Pio2001   24/96 soundcards should bring nothing for recordin...   May 3 2003, 02:17
- - cupelix   Thanks for the helpfuls replies guys. In response ...   May 3 2003, 02:49
- - TwoJ   Sorry Pio2001 - I didn't mean to imply that sw...   May 3 2003, 03:18
- - woody_woodward   This topic is fascinating to me. I've done se...   May 3 2003, 06:19
- - Andavari   I'm interested in what the results would and w...   May 3 2003, 06:48
- - JeanLuc   QUOTE (Pio2001 @ May 3 2003 - 01:17 AM)1-I sh...   May 3 2003, 09:37
- - Pio2001   QUOTE (cupelix @ May 3 2003 - 04:49 AM)As far...   May 3 2003, 14:39
- - cupelix   I dont know if any of you bothered to download the...   May 4 2003, 00:36
- - woody_woodward   I tried downloading the WAV from your original pos...   May 6 2003, 19:15
- - Xenion   Nakamichi Tapedeck + Nakamichi High Comp II => ...   May 6 2003, 19:21
- - Mac   I want to have a go with your file, but I also rec...   May 6 2003, 22:09
- - _Shorty   usually when it doesn't state which type of Do...   May 7 2003, 02:56
- - DickD   First, I'd agree that you should leave some he...   May 7 2003, 13:25
- - JeanLuc   QUOTE (Pio2001 @ May 3 2003 - 01:39 PM)An MA-...   May 7 2003, 14:43
- - 2Bdecided   I think the same name has been applied to differen...   May 7 2003, 17:19
|- - knutinh   QUOTE (2Bdecided @ May 7 2003, 17:19) IIR...   Oct 17 2013, 07:56
|- - 2Bdecided   QUOTE (knutinh @ Oct 17 2013, 07:56) QUOT...   Oct 17 2013, 12:47
- - gleib   QUOTE (Pio2001 @ May 3 2003 - 05:39 AM)QUOTE ...   May 7 2003, 18:48
- - raynault   I do A LOT of Tapes, mine are all voice. First u...   Oct 16 2013, 05:26
|- - pdq   QUOTE (raynault @ Oct 16 2013, 00:26) Fir...   Oct 16 2013, 13:33
- - 2Bdecided   As neither tapes decks nor soundcards universally ...   Oct 16 2013, 14:20
- - AndyH-ha   There is nothing in the signal path to vary the le...   Oct 16 2013, 22:01
- - raynault   Usually the "pre amp" in the tape player...   Oct 24 2013, 17:40
- - 2Bdecided   QUOTE (raynault @ Oct 24 2013, 17:40) Dav...   Oct 25 2013, 09:54
RSS Lo-Fi Version Time is now: 5th March 2015 - 00:32
