How to Clean up Cassette to Digital, Need Help
cupelix
post May 3 2003, 00:27
Thanks in Advance for any help one of you might offer.
I am far from an Audio Pro, yet have been trying to take some old cassette tapes and restore the sound quality they originally had, and enhance it even. As for this file in particular it seems to have lost its high's and mids. When I run it through a simple EQ plugin I just dont get the clarity I need, it just sounds worse.
Here is the steps I took in recording this tape.
#1 - Used a brand new Sony Tape deck , with preamp mixer and got the sound quality as close to 0 DB as I could (as reccomended by many audio recording sites I have read). I recorded at 44.1 hz, 16 bit through my SBLIVE card. I saw no loss in quality from tape to digital.
#2 - I then loaded Wavlab and watched the spectrum analyser and saw the highs and some mids were very low. I tried to raise this up in value but it just made the sound even more distorted than it already was.
I have many tapes like this I would like to restore, re-master (or whatever the term is). I have attached this file (in original .wav format) and uploaded it to the alt.binaries.sound.mp3 newsgroup. The topic is called:
"Sound Pro's can you give tips on how to fix this Audio File? Email - Trick@lvcm.com"
You can also download the .wav file clip at - http://www.lvcm.com/trick/badwav/badwav.wav
Any help on cleanup (what software/settings to use), examples , web links on fixing this sorta of stuff is GREATLY appreciated!!!! Heck if someone wants to clean it up themselves and email it back with the steps you used to do it, that would even be better.
This advice would be Pricessless, thanks again in advance to anyone who can help this audio newbie.
Email - trick@lvcm.com
Thanks,
Trick
PS - I have read about the CEDAR system, is this hardware based only???
raynault
post Oct 16 2013, 05:26
I do A LOT of Tapes, mine are all voice.
First use NO pre amp or amp. Tape directly into card or what ever is the DAC. The reason not to use the amps is they ad a tiny bit of there own noise. SO I personally prefer to go "raw" then you have that original to play with.
Also MAKE sure the tape heads are clean. Use Isopropyl Alcohol 99% so it leaves no residue.
In the sound program you can easily increase the volume. Also you can enhance what ever frequency range you desire.
I suggest use the equalizer settings. Then like you would on a stereo just play around until it sounds correct.
Once you have it. Apply the effect then save.
pdq
post Oct 16 2013, 13:33
QUOTE (raynault @ Oct 16 2013, 00:26) *
Just to clarify, you are not suggesting to take the signal directly from the tape head into the ADC. The tape deck has a built-in preamp whose output is perfectly compatible with the line in of a sound card.
- cupelix   How to Clean up Cassette to Digital   May 3 2003, 00:27
- - dreamliner77   JUst a thought If you are recording the wav's...   May 3 2003, 00:41
- - TwoJ   Hi Cupelix PSS - Cedar is a company that does aud...   May 3 2003, 01:49
- - Pio2001   24/96 soundcards should bring nothing for recordin...   May 3 2003, 02:17
- - cupelix   Thanks for the helpfuls replies guys. In response ...   May 3 2003, 02:49
- - TwoJ   Sorry Pio2001 - I didn't mean to imply that sw...   May 3 2003, 03:18
- - woody_woodward   This topic is fascinating to me. I've done se...   May 3 2003, 06:19
- - Andavari   I'm interested in what the results would and w...   May 3 2003, 06:48
- - JeanLuc   QUOTE (Pio2001 @ May 3 2003 - 01:17 AM)1-I sh...   May 3 2003, 09:37
- - Pio2001   QUOTE (cupelix @ May 3 2003 - 04:49 AM)As far...   May 3 2003, 14:39
- - cupelix   I dont know if any of you bothered to download the...   May 4 2003, 00:36
- - woody_woodward   I tried downloading the WAV from your original pos...   May 6 2003, 19:15
- - Xenion   Nakamichi Tapedeck + Nakamichi High Comp II => ...   May 6 2003, 19:21
- - Mac   I want to have a go with your file, but I also rec...   May 6 2003, 22:09
- - _Shorty   usually when it doesn't state which type of Do...   May 7 2003, 02:56
- - DickD   First, I'd agree that you should leave some he...   May 7 2003, 13:25
- - JeanLuc   QUOTE (Pio2001 @ May 3 2003 - 01:39 PM)An MA-...   May 7 2003, 14:43
- - 2Bdecided   I think the same name has been applied to differen...   May 7 2003, 17:19
|- - knutinh   QUOTE (2Bdecided @ May 7 2003, 17:19) IIR...   Oct 17 2013, 07:56
|- - 2Bdecided   QUOTE (knutinh @ Oct 17 2013, 07:56) QUOT...   Oct 17 2013, 12:47
- - gleib   QUOTE (Pio2001 @ May 3 2003 - 05:39 AM)QUOTE ...   May 7 2003, 18:48
- - raynault   I do A LOT of Tapes, mine are all voice. First u...   Oct 16 2013, 05:26
|- - pdq   QUOTE (raynault @ Oct 16 2013, 00:26) Fir...   Oct 16 2013, 13:33
- - 2Bdecided   As neither tapes decks nor soundcards universally ...   Oct 16 2013, 14:20
- - AndyH-ha   There is nothing in the signal path to vary the le...   Oct 16 2013, 22:01
- - raynault   Usually the "pre amp" in the tape player...   Oct 24 2013, 17:40
- - 2Bdecided   QUOTE (raynault @ Oct 24 2013, 17:40) Dav...   Oct 25 2013, 09:54
RSS Lo-Fi Version Time is now: 24th May 2015 - 14:49
