ReplayGain2, ReplayGain2 proposal
jukkap
post Jul 23 2011, 16:33
I suggest we discuss about possibility of creating ReplayGain2 specification that would replace the current ReplayGain.
ReplayGain2 would be playback compatible with the current ReplayGain (all current ReplayGain compatible players would work), but it should use ITU-R BS.1770/EBU R128 to calculate gain levels.
Current ReplayGain algorithm is odd and difficult and not properly specified. It also does not work for multichannel audio. ITU-R BS.1770/EBU R128 would overcome these issues.
Case
post Aug 6 2013, 13:42
Group: Developer (Donating)
Pbelkner's decision to write incompatible data has been criticized numerous times. It's like the guy doesn't even understand the problem of his decision. I could support use of REPLAYGAIN_ALGORITHM tag to let users and software know what tool generated the numbers but I see no reason to store any other data. Reference level must be 89 dB SPL as stated in the specs. If user wishes to use other target level he flips a switch in his player (switch being for example preamp slider, could be a dropdown menu to select R128 or ATSC or anything).
I recall original ReplayGain spec suggested storing the algorithm too and perhaps even the fact that user had manually altered the numbers. Perhaps manual adjustment could be identified by storing something like REPLAYGAIN_ALGORITHM=manual.
2Bdecided
post Aug 6 2013, 15:52
ReplayGain developer
QUOTE (Case @ Aug 6 2013, 13:42) *
I decided to stop reading that thread a long time ago because otherwise I would get annoyed every time.
Yes, it must - but it is fine (even useful) to store how the conversion from A.N.Other Algorithm to ReplayGain reference level was performed.
That's quite a good idea. With normal ReplayGain tags, using different "reference levels" in the player is entirely equivalent to different pre-amp settings. That's always been in ReplayGain from day one. It might confuse people to add labels though. It would be easy enough to write a table for "power users".
Another good idea. It wasn't in the original spec, but I suggested it about a year after...
http://www.hydrogenaudio.org/forums/index....st&p=154583
- jukkap   ReplayGain2   Jul 23 2011, 16:33
- - mobyduck   http://www.hydrogenaudio.org/forums/index....showt...   Jul 23 2011, 16:40
- - Notat   This has been discussed. I believe there's act...   Jul 23 2011, 17:36
- - C.R.Helmrich   QUOTE (jukkap @ Jul 23 2011, 17:33) Repla...   Jul 23 2011, 18:10
- - jukkap   So that is the way to go. I suggest someone will c...   Jul 23 2011, 18:40
- - nazgulord   If I may ask, how different are gain values betwee...   Jul 23 2011, 23:16
- - db1989   R128 versus ReplayGain   Jul 23 2011, 23:31
- - Notat   I've been contacted by jaynyy and we've di...   Oct 8 2012, 22:55
- - Pat_   Suggestion for ReplayGain specification 2.0 ... I...   Aug 2 2013, 15:17
- - 2Bdecided   Writing ReplayGain track and album gain tags with ...   Aug 5 2013, 11:35
- - Pat_   QUOTE (2Bdecided @ Aug 5 2013, 11:35) It ...   Aug 6 2013, 11:01
|- - 2Bdecided   QUOTE (Pat_ @ Aug 6 2013, 11:01) I believ...   Aug 6 2013, 15:40
- - Case   Pbelkner's decision to write incompatible data...   Aug 6 2013, 13:42
|- - 2Bdecided   QUOTE (Case @ Aug 6 2013, 13:42) Pbelkner...   Aug 6 2013, 15:52
|- - pbelkner   QUOTE (Case @ Aug 6 2013, 14:42) Pbelkner...   Aug 6 2013, 17:17
- - [JAZ]   @pbelkner: When you designed and implemented your ...   Aug 6 2013, 20:09
- - Pat_   Hi Guys, It was not my intention to stir things u...   Aug 7 2013, 11:13
|- - 2Bdecided   QUOTE (Pat_ @ Aug 7 2013, 11:13) I believ...   Aug 8 2013, 11:31
|- - [JAZ]   QUOTE (2Bdecided @ Aug 8 2013, 12:31) No ...   Aug 8 2013, 15:48
- - Pat_   QUOTE (2Bdecided @ Aug 8 2013, 11:31) If ...   Aug 8 2013, 14:59
- - greynol   The reference level is calibrated to pink noise wi...   Aug 8 2013, 15:23
- - Pat_   QUOTE (greynol @ Aug 8 2013, 15:23) The r...   Aug 8 2013, 15:38
- - Pat_   QUOTE ([JAZ] @ Aug 8 2013, 15:48)...   Aug 9 2013, 14:47
- - 2Bdecided   Just to be 100% clear: you can use ReplayGain tags...   Aug 9 2013, 17:15
RSS Lo-Fi Version Time is now: 3rd August 2015 - 17:54
