ReplayGain2, ReplayGain2 proposal
jukkap
post Jul 23 2011, 16:33
I suggest we discuss about possibility of creating ReplayGain2 specification that would replace the current ReplayGain.
ReplayGain2 would be playback compatible with the current ReplayGain (all current ReplayGain compatible players would work), but it should use ITU-R BS.1770/EBU R128 to calculate gain levels.
Current ReplayGain algorithm is odd and difficult and not properly specified. It also does not work for multichannel audio. ITU-R BS.1770/EBU R128 would overcome these issues.
Pat_
post Aug 6 2013, 11:01
QUOTE (2Bdecided @ Aug 5 2013, 11:35) *
It is fine to use a new calculation method with a new reference loudness, but the values must be converted to the original reference loudness before being written to ReplayGain tags. That way, loudness matching will work on all ReplayGain compatible players across all ReplayGain tagged files.
Hi. I agree.
I watched this short clarification:
Florian Camerer (2012) ITU BS.1770-2 Gating Scheme, http://www.youtube.com/watch?v=Y-zhAEu5nVo
I believe much of the confusion is because loudness metering and loudness normalization scheme are confounded. These are two separate dimensions but are NOT presented in an orthogonal way. A system should clearly indicate which method was used for measuring loudness (loudness metering) and which gain adjustment scheme was used for loudness normalization (leveling).
After a forum exchange with Peter Belkner (author of R128GAIN) and reading the standards, this is my -tentative- understanding of loudness metering and normalization.
(1) LOUDNESS METERING
(1.1) PROGRAMME LOUDNESS = single value to indicate integrated loudness for duration of the programme (track / album)
Two options:
(1.1.1) Classic Replaygain algorithm (2001).
(1.2.1) ITU BS. 1770 algorithm. Including gating function when signal drops below a certain point, specified as of revision ITU-R BS.1770-2 (03/2011). Latest: ITU-R BS.1770-3 (08/2012).
(1.2) LOUDNESS RANGE
(1.2.1) EBU-128 specified as difference between low and high percentiles of distribution of loudness as measured with ITU BS. 1770 algorithm including gating
(2) LOUDNESS NORMALIZATION / LEVELING
Loudness leveling of programmes/music compliant to:
(2.1) EBU-R128 norm, using -23 LUFS as target level.
(2.2) Classic ReplayGain 1.0 spec, reference -89 dBFS. Only applicable if (1.1.1) was used.
(2.3) ReplayGain 2.0 spec ("RG2"), mapping Loudness (L) metered with (1.2.1) onto dB's using empirical formula: RG2gain = -18 - L
(2.4) ATSC-A/85, using -24 LUFS
Is that how you see it also?
This post has been edited by Pat_: Aug 6 2013, 11:09
- jukkap   ReplayGain2   Jul 23 2011, 16:33
- - mobyduck   http://www.hydrogenaudio.org/forums/index....showt...   Jul 23 2011, 16:40
- - Notat   This has been discussed. I believe there's act...   Jul 23 2011, 17:36
- - C.R.Helmrich   QUOTE (jukkap @ Jul 23 2011, 17:33) Repla...   Jul 23 2011, 18:10
- - jukkap   So that is the way to go. I suggest someone will c...   Jul 23 2011, 18:40
- - nazgulord   If I may ask, how different are gain values betwee...   Jul 23 2011, 23:16
- - db1989   R128 versus ReplayGain   Jul 23 2011, 23:31
- - Notat   I've been contacted by jaynyy and we've di...   Oct 8 2012, 22:55
- - Pat_   Suggestion for ReplayGain specification 2.0 ... I...   Aug 2 2013, 15:17
- - 2Bdecided   Writing ReplayGain track and album gain tags with ...   Aug 5 2013, 11:35
- - Pat_   QUOTE (2Bdecided @ Aug 5 2013, 11:35) It ...   Aug 6 2013, 11:01
|- - 2Bdecided   QUOTE (Pat_ @ Aug 6 2013, 11:01) I believ...   Aug 6 2013, 15:40
- - Case   Pbelkner's decision to write incompatible data...   Aug 6 2013, 13:42
|- - 2Bdecided   QUOTE (Case @ Aug 6 2013, 13:42) Pbelkner...   Aug 6 2013, 15:52
|- - pbelkner   QUOTE (Case @ Aug 6 2013, 14:42) Pbelkner...   Aug 6 2013, 17:17
- - [JAZ]   @pbelkner: When you designed and implemented your ...   Aug 6 2013, 20:09
- - Pat_   Hi Guys, It was not my intention to stir things u...   Aug 7 2013, 11:13
|- - 2Bdecided   QUOTE (Pat_ @ Aug 7 2013, 11:13) I believ...   Aug 8 2013, 11:31
|- - [JAZ]   QUOTE (2Bdecided @ Aug 8 2013, 12:31) No ...   Aug 8 2013, 15:48
- - Pat_   QUOTE (2Bdecided @ Aug 8 2013, 11:31) If ...   Aug 8 2013, 14:59
- - greynol   The reference level is calibrated to pink noise wi...   Aug 8 2013, 15:23
- - Pat_   QUOTE (greynol @ Aug 8 2013, 15:23) The r...   Aug 8 2013, 15:38
- - Pat_   QUOTE ([JAZ] @ Aug 8 2013, 15:48)...   Aug 9 2013, 14:47
- - 2Bdecided   Just to be 100% clear: you can use ReplayGain tags...   Aug 9 2013, 17:15
RSS Lo-Fi Version Time is now: 27th March 2015 - 06:34
