> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
sample source code
toyoPon3
post Jul 23 2011, 09:52
Hi.
I want to program a foobar2000 component which shows the album art.
And, I am searching the site which has the sample source codes of component.
Please tell me the URL of the site shown above.
I prepared the SDK by reading this site.
Replies (1 - 11)
Zao
post Jul 23 2011, 14:46
Group: Members (Donating)
There is a pinned thread named "Pinned: Developer Tutorials" in this forum.
toyoPon3
post Jul 25 2011, 15:36
To Zao.
Thank you for your reply.
Unfortunately, I could not find the site from the thread that you taught.
(Maybe, my reading skill was not good.)
But I found the URL shown in below.
http://foosion.foobar2000.org/components/
thank you.
mudlord
post Jul 25 2011, 16:01
Group: Developer (Donating)
Source code for components is also here:
https://github.com/mudlord/foobar2000
toyoPon3
post Aug 14 2011, 04:32
I wanted to add the dialog window to foobar2000 by using VC++ 2010 Express. (I can not buy the Professional Edition)
I post my memo for someone who is wondering like me.
Outline.
Step1:Add "pref.cpp" to your project.
Step2:Add "resource file" to your project.
pref.cpp and resource file are shown below.
I added my tag to "the Preferences pages" by the referring to the topic shown below.
Especially, pref.cpp(Mr.foosion exsample Post#3) was good help for me.
http://www.hydrogenaudio.org/forums/index....mp;#entry373489
And, I made the resource file by using the ResEdit(free tool).
ResEdit:http://www.resedit.net/
I modified two lines for changing from the parent window to the child window.
Note:VC++ Express dose not supply "the res Edit function" to the programer.
My resource file is shown below.
#include <windows.h>
#include <commctrl.h>
#include <richedit.h>
#include "resource.h"
// Dialog resources
LANGUAGE LANG_NEUTRAL, SUBLANG_NEUTRAL
IDD_DIALOG1 DIALOGEX 0, 0, 186, 95
STYLE DS_SETFONT | WS_CHILD // <- Change
//CAPTION "Dialog" <- Comment out
FONT 8, "Ms Shell Dlg", 0, 0, 1
DEFPUSHBUTTON "OK", IDOK, 129, 7, 50, 14
PUSHBUTTON "Cansel", IDCANCEL, 129, 24, 50, 14
CTEXT "This is test", IDC_STATIC, 13, 22, 50, 13, SS_CENTER
This post has been edited by toyoPon3: Aug 14 2011, 04:33
fbuser
post Aug 14 2011, 08:17
QUOTE (toyoPon3 @ Aug 14 2011, 04:32) *
Although this example is still working, it is outdated and the user will get a warning on this. To avoid this preferences_page_3 instead of preferences_page should be implemented.
Modifying anything manually is not necessary. Just set the Style to Child in the properties pane for the dialog.
This post has been edited by fbuser: Aug 14 2011, 08:37
toyoPon3
post Aug 14 2011, 12:03
To Mr.fbuser
Thanks for your reply.
I changed from preferences_page to preferences_page_v3 on your advice.
I read the topic shown below.
http://www.hydrogenaudio.org/forums/index....mp;#entry693611
But I think that this topic is written for VC++ Professional user.
Is it right?
Then, what should I insert "XXX"?
virtual preferences_page_instance::ptr instantiate(HWND parent, preferences_page_callback::ptr callback)
return XXXX;
This post has been edited by toyoPon3: Aug 14 2011, 12:57
fbuser
post Aug 14 2011, 12:46
QUOTE (toyoPon3 @ Aug 14 2011, 12:03) *
Please, tell me where is wrong.
With only the few code fragments you provided, it is difficult. By I guess with preferences_page_liveshowtagger you implemented preferences_page_v3. You also need to implement preferences_page_instance as shown in the thread you mentioned.
toyoPon3
post Aug 14 2011, 13:41
To Mr.fbuser
I understood that I need "implement preferences_page_instance".
And I found some sample codes.
But all sample codes are for VC++ Professional user.
* The code needs "CDialogImpl<>".
But I am VC++ Express user.
Then, must I make the function shown below by myself?
1.t_uint32 get_state();
2.void apply();
3.void reset();
4.HWND get_wnd();
Is it right?
Or is there the class for VC++ Express user?
toyoPon3
post Aug 15 2011, 08:32
I implemented my_preferences_page_instance(sub class of preferences_page_instance).
And I finish compiling.
It shows the tags "Sample Page".
But it dose not show the dialog.
I insert the debug line "console::info("Call ConfigProc");" in ConfigProc().
"Console window" shows "Call ConfigProc" only several times.
After that, "Console window" does not show any line.
Where is wrong?
#include "../SDK/foobar2000.h"
#include "../helpers/helpers.h"
static const GUID guid_prefs_tagging = { 0x563107c3, 0xfc7d, 0x4022, { 0xa8, 0x72, 0xa8, 0x2a, 0x2b, 0x3f, 0xd5, 0x25 } };
static preferences_branch_factory foo_preferences_branch_tagging(guid_prefs_tagging, preferences_page::guid_tools, "Tagging");
const char strText[] = "sample test";
static BOOL CALLBACK ConfigProc(HWND wnd, UINT msg, WPARAM wp, LPARAM lp)
switch (msg)
case WM_INITDIALOG:
uSetDlgItemText(wnd, IDC_EDIT1, strText);
break;
case WM_COMMAND:
break;
default:
return FALSE;
return TRUE;
class my_preferences_page_instance : public preferences_page_instance
protected:
t_uint32 m_state;
HWND m_parent;
preferences_page_callback::ptr m_callback;
public:
my_preferences_page_instance(HWND parent, preferences_page_callback::ptr callback) :
m_callback(callback),
m_parent(parent),
m_state(preferences_state::resettable){}
HWND get_wnd()
return m_parent;
return m_state;
// Applies preferences changes.
void apply()
console::info("Call apply");
m_state = preferences_state::resettable;
m_callback->on_state_changed();
// Resets this page's content to the default values.
// Does not apply any changes -
// lets user preview the changes before hitting "apply".
void reset()
m_state |= preferences_state::changed;
// m_callback->on_state_changed();
HWND Create(HWND parent)
console::info("Call create");
return uCreateDialog(IDD_DIALOG1, parent, ConfigProc, 0);
static const GUID guid_prefs_sample = { 0x13be3cd2, 0xbff3, 0x42cc, { 0x96, 0xda, 0x7f, 0xfc, 0x7a, 0x4a, 0x3d, 0x6 } };
class preferences_sample_page : public preferences_page_v3
public:
virtual const char * get_name()
return "Sample Page";
virtual GUID get_guid()
return guid_prefs_sample;
virtual GUID get_parent_guid()
return guid_prefs_tagging;
service_impl_t<my_preferences_page_instance> * p = new service_impl_t<my_preferences_page_instance>(parent,callback);
p->Create(parent);
return p;
static preferences_page_factory_t<preferences_sample_page> foo_preferences_sample_page;
fbuser
post Aug 15 2011, 09:01
You should call my_preferences_page_instance::Create() in the constructor of my_preferences_page_instance and assign the resulting Handle to a class member (e.g. m_wnd). my_preferences_page_instance::get_wnd() must return the handle of your dialog not the parent handle as in your code.
So, your code could look like this
switch (msg)
case WM_INITDIALOG:
break;
case WM_COMMAND:
break;
default:
return FALSE;
return TRUE;
protected:
t_uint32 m_state;
HWND m_parent;
HWND m_wnd;
public:
m_parent(parent),
m_state(preferences_state::resettable){m_wnd=Create(m_parent);}
HWND get_wnd()
return m_wnd;
return m_state;
void apply()
void reset()
public:
return new service_impl_t<my_preferences_page_instance>(parent,callback);
toyoPon3
post Aug 15 2011, 13:43
Mr.fbuser.
My program moves as planned.
I have to study about win32 API.
RSS Lo-Fi Version Time is now: 1st March 2015 - 14:23
