Public AAC Listening Test @ ~96 kbps [July 2011], Nero, Apple, Fraunhofer and Coding Technologies (CT)
IgorC
post Jul 17 2011, 22:55
Today we have a chance to see the performance of well known AAC encoders like Nero, Apple and Coding Technologies (previous versions of Winamp).
Also Fraunhofer have released their totally new AAC encoder.
The following codecs are presented in this test:
Nero 1.5.4
Apple QuickTime 7.6.9 true VBR
Apple QuickTime 7.6.9 constrained VBR
Fraunhofer (Winamp 5.62)
Coding Technologies (Winamp 5.61)
ffmpeg's AAC (low anchor)
The homepage of the test:
There are 20 samples. Please, don't hurry. Take your time as there will be enough of it. It's better to do fewer samples per day and avoid a fatigue.
The test will be open during 10 days (until July 27)
As always every single result is helpful.
naylor83
post Jul 23 2011, 23:29
Have only had time to do two samples so far. (16 & 20) (I found this listening test just a few days ago.)
Igor, which samples should I focus on if I have to chose? Any with fewer results at the moment?
This post has been edited by naylor83: Jul 23 2011, 23:30
davidnaylor.org
IgorC
post Jul 24 2011, 10:54
QUOTE (naylor83 @ Jul 23 2011, 19:29) *
You can send a few results already now to be sure that everything is ok.
All of them.
It's very unlikely to have enough results during first 10 days so it's more likely (almost sure) that test will be extended for another 10 days.
The rules are the same as from previous test with the small change of possibilities for ranking the references (3 instead of 4) because now there are less samples .
If the listener ranked the reference worse than 4.5 on a sample, the listener's results for that sample were discarded.
If the listener ranked the low anchor at 5.0 on a sample, the listener's results for that sample were discarded.
If the listener ranked the reference below 5.0 on more than 3 samples, all of that listener's results were discarded.
These rules aren't extremely strict in order to allow for simple human
error while still excluding careless participants (*).
A stricter procedure to exclude all ranked references risks a systemic
bias against any codec which are very good on a few samples and thus
subject to more reference confusion by causing those samples to be excluded
and weighing the test towards other samples.
(*)During the previous test some listeners have made the reasonable errors by accident (for example, have forgotten to rank the samples accidentally). But next time the listener wouldn't do such errors again.
Some detailed description of the rules from previous test. http://www.hydrogenaudio.org/forums/index....st&p=749501
This post has been edited by IgorC: Jul 24 2011, 10:58
- IgorC   Public AAC Listening Test @ ~96 kbps [July 2011]   Jul 17 2011, 22:55
- - benski   Thanks so much, Igor. Hope you don't mind, bu...   Jul 18 2011, 17:53
|- - IgorC   QUOTE (benski @ Jul 18 2011, 13:53) Hope ...   Jul 18 2011, 20:01
- - Garf   I added the code to randomize the sample list, hop...   Jul 18 2011, 19:54
- - IgorC   Ok, some listeners have started to send their resu...   Jul 19 2011, 01:13
- - kennedyb4   Hello. I am trying to participate. I downloaded th...   Jul 20 2011, 12:11
|- - IgorC   QUOTE (kennedyb4 @ Jul 20 2011, 08:11) Ed...   Jul 20 2011, 22:34
|- - naylor83   Was a long time since I was here ... Just found ou...   Jul 21 2011, 16:48
|- - kennedyb4   QUOTE (IgorC @ Jul 20 2011, 17:34) QUOTE ...   Jul 21 2011, 17:30
|- - naylor83   QUOTE (kennedyb4 @ Jul 21 2011, 17:30) Fi...   Jul 21 2011, 18:06
- - xnor   I've taken the liberty to mention this test ov...   Jul 20 2011, 15:53
- - guruboolez   My first listening tests since many years I proba...   Jul 21 2011, 21:57
|- - IgorC   QUOTE (guruboolez @ Jul 21 2011, 17:57) M...   Jul 22 2011, 19:24
|- - muaddib   QUOTE (IgorC @ Jul 22 2011, 20:24) The mo...   Jul 23 2011, 08:43
- - xnor   It's definitely not an easy test.   Jul 21 2011, 23:30
- - kennedyb4   Question. I have used a short selection in the abx...   Jul 22 2011, 00:28
|- - muaddib   QUOTE (kennedyb4 @ Jul 22 2011, 01:28) Qu...   Jul 22 2011, 09:19
|- - kennedyb4   QUOTE (muaddib @ Jul 22 2011, 04:19) QUOT...   Jul 22 2011, 14:02
- - kennedyb4   OK. Mission accomplished and results sent in. Did ...   Jul 22 2011, 15:37
- - Zarggg   I'm going to try finishing this one; I never f...   Jul 22 2011, 16:35
|- - kennedyb4   QUOTE (Zarggg @ Jul 22 2011, 11:35) I...   Jul 22 2011, 17:32
- - naylor83   Have only had time to do two samples so far. (16 ...   Jul 23 2011, 23:29
|- - IgorC   QUOTE (naylor83 @ Jul 23 2011, 19:29) Hav...   Jul 24 2011, 10:54
|- - naylor83   Ok, thanks.   Jul 24 2011, 11:35
- - jukkap   This is the 1st listening test that I am trying to...   Jul 25 2011, 18:50
|- - kennedyb4   QUOTE (jukkap @ Jul 25 2011, 13:50) This ...   Jul 25 2011, 22:09
- - IgorC   The test is extended until August 5. We need mor...   Jul 27 2011, 02:15
- - Zarggg   Just sent off my results.   Jul 27 2011, 03:27
- - mjb2006   If the deadline is approaching and we can't ge...   Jul 27 2011, 06:18
|- - IgorC   QUOTE (mjb2006 @ Jul 27 2011, 02:18) Is i...   Jul 28 2011, 03:52
- - Alexxander   Yes, every single result is very helpful. Haven...   Jul 27 2011, 11:09
|- - mjb2006   QUOTE (Alexxander @ Jul 27 2011, 04:09) H...   Jul 28 2011, 00:31
- - lvqcl   I noticed that faac doesn't support gapless de...   Jul 28 2011, 14:38
|- - IgorC   QUOTE (lvqcl @ Jul 28 2011, 10:38) I noti...   Jul 29 2011, 01:06
|- - lvqcl   QUOTE (IgorC @ Jul 29 2011, 04:06) The lo...   Jul 29 2011, 14:06
- - Alex B   ABC/HR for JAVA has the Calculate Offsets feature....   Jul 28 2011, 19:19
- - lvqcl   Thanks for clarification.   Jul 28 2011, 19:27
- - IgorC   Many listeners ask for some extra time. I guess it...   Aug 2 2011, 17:34
- - Larson   Just a note guys, Quicktime has been updated on Wi...   Aug 4 2011, 13:04
|- - no404error   QUOTE (Larson @ Aug 4 2011, 14:04) Just a...   Aug 4 2011, 23:22
- - Gecko   I'm through most samples but prematurely abort...   Aug 4 2011, 19:55
- - IgorC   The test is extended at least until August 8, Mon...   Aug 5 2011, 00:27
- - Alexxander   I have done 7 so far, but this week I have days of...   Aug 8 2011, 09:21
- - IgorC   The test is extended until August 20 as some liste...   Aug 8 2011, 12:54
- - albertoh   Hi. I am new in this forum. I'd like to know ...   Aug 8 2011, 13:30
|- - lvqcl   QUOTE (albertoh @ Aug 8 2011, 16:30) I...   Aug 8 2011, 15:02
- - albertoh   Thank you   Aug 8 2011, 16:44
- - dispatcher7007   Hi, this is the first listening test i participate...   Aug 13 2011, 11:57
|- - IgorC   QUOTE (dispatcher7007 @ Aug 13 2011, 07:5...   Aug 13 2011, 18:38
- - Gecko   See post #32 in this thread for some useful links ...   Aug 13 2011, 13:35
- - IgorC   Update: We need more results for samples 12,15,16...   Aug 15 2011, 20:41
- - IgorC   The test is closed. Thank You to ALL who have pa...   Aug 20 2011, 23:04
- - IgorC   I will ask the administrators to close this topic....   Aug 23 2011, 20:01
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 31st August 2015 - 15:17
