Wanted: util to add 2 wav files, simple command line prog needed
2Bdecided
post May 2 2003, 10:48
ReplayGain developer
Does anyone have (or would anyone be willing to write) a simple Dos/Win32 command line utility that can take two 16-bit .wav files, add them together, and output the sum as a third .wav file?
e.g.
wavadd a.wav b.wav c.wav
would go through a.wav, sample by sample, adding the same sample in b.wav, and outputing the result to c.wav.
This would really help with the digital radio listening test that I'm putting together. As well as the original, there are two further files that I must distribute losslessly, but since they're almost the same as the original, it would take much less space to losslessly pack the DIFFERENCE between the original and coded (giving a smaller FLAC), and then add it back to the original at the other end. I need to do this from a bat file, so need a command line utility to take care of this.
Can anyone help please?
EDIT: all files will be stereo, 16-bit, and either 44.1kHZ or 48kHz sampled. c.wav will never clip, so this doesn't need to be checked for. wavadd needs to be a small program.
This post has been edited by 2Bdecided: May 2 2003, 10:51
HansHeijden
post May 2 2003, 11:02
Case has this tiny little commandline thingy up: http://www.saunalahti.fi/~cse/files/wavmerge.zip
To confuse you, there's also an old installer software around with the same name, that works through a GUI.
2Bdecided
post May 2 2003, 11:57
This sounded great, but...
I tried wavmerge a.wav b.wav c.wav
where a and b were 10 second long test files, 44.1kHz 16-bit, and c.wav didn't exist.
WAVMERGE caused an invalid page fault in
module MSVCRT.DLL at 017f:7800d203.
Registers:
EAX=00650078 CS=017f EIP=7800d203 EFLGS=00010246
EBX=78001ec9 SS=0187 ESP=0063fc20 EBP=0063fc3c
ECX=00455844 DS=0187 ESI=00760ec2 FS=34af
EDX=00000ec6 ES=0187 EDI=00000000 GS=0000
Bytes at CS:EIP:
8b 14 31 8d 1c 31 89 55 f4 8b 56 fc 89 55 f8 8b
Stack dump:
7801270c 00760ec6 78001ec9 006501bc 7803b534 78001d9a 00455844 0063fc80 7800cc3f 0075000c 00760ec6 7801270c 00760e94 78001ec9 78001026 00000006
any ideas?
This post has been edited by 2Bdecided: May 2 2003, 11:57
john33
post May 2 2003, 12:25
xcLame and OggDropXPd Developer
David, are you saying that you want to add two stereo wav files together to produce a third stereo wav file? Or, two mono files to make a stereo file? I wrote a little prog to do the second of these (it's at RareWares, m2s), but it wouldn't take much to do the first, I guess.
John
Sunhillow
post May 2 2003, 12:31
Group: Members (Donating)
CopyAudio of the AFsp package can concatenate WAV files.
online documentation at: http://www.tsp.ece.mcgill.ca/MMSP/Document.../AFsp/AFsp.html
download at: ftp://ftp.tnt.uni-hannover.de/pub/audio/AFsp
HansHeijden
post May 2 2003, 12:44
David, depending on your windows version, the msvcrt.dll (C++ runtimes) may be outdated. More here: http://support.microsoft.com/?kbid=190536
Wavmerge runs fine on this w2k sp2 work-PC.
Thanks Sunhillow, I didn't know the tools you mention!
2Bdecided
post May 2 2003, 12:49
QUOTE (john33 @ May 2 2003 - 11:25 AM)
I need the first, not the second.
This would perform the same process:
Load A.wav into Cool Edit.
Load B.wav into Cool Edit.
Swich to A.wav
Select All.
Copy.
Switch to B.wav
Mix paste 100% non-inverting.
Save As C.wav
It sounds trivial to me, but I can't program.
Subhillow,
I don't want to concatenate, but maybe CopyAudio will do the job - I'll try.
john33
post May 2 2003, 12:53
So you basically just want ((left channel + left channel) / 2) and the same for the right channel?
John
2Bdecided
post May 2 2003, 13:19
I don't even want the divided by 2 - just left+left! (and right plus right).
D.
2Bdecided
post May 2 2003, 13:32
The Microsoft Download didn't help with wavmerge. I wonder what's happening there?
Anyway, CopyAudio will do the job perfectly - thanks Sunhillow.
This does exactly what I want:
copyaudio --chanA="A+C" --chanB="B+D" a.wav b.wav c.wav
I've just got to figure out how little of the AFsp distribution I can get away with including in the download. Even the exe itself seems quite large for the job I want it to do.
So, if anyone can come up with a working 4.5kB (ish) file to do the same job, that would be even better!
Case
post May 2 2003, 13:51
Group: Developer (Donating)
I hadn't tested wavmerge under Win98, it seemed to crash there but work properly under NT. I fixed the bug, redownload using same link.
2Bdecided
post May 2 2003, 13:55
Thanks Case - that works now.
But now I see that it concatenates - I want to add!
Case
post May 2 2003, 13:57
Sorry about that, I didn't read the whole thread, the crash caught my attention. I made Wavmix the other day, if your files have 44 byte headers it should work.
2Bdecided
post May 2 2003, 14:30
QUOTE (Case @ May 2 2003 - 12:57 PM)
Perfect!!!!
If no problems crop up, that's what I'll use - it's exactly what I'm looking for.
Thanks Case. Are there any known "issues" with this?
Case
post May 2 2003, 14:39
Post #15
QUOTE (2Bdecided @ May 2 2003 - 04:30 PM)
It will work fine on most common wavs with 44 byte header, if you extract files from CDs or use Cool Edit to write wavs there won't be issues. Foobar and dBPowerAMP both write 2 bytes longer headers which will not be handled correctly and mixed wav will have two wrong bytes in its header. I have been too lazy to improve it.
2Bdecided
post May 2 2003, 15:00
Post #16
That'll be fine for my purpose. Thanks for replying.
HansHeijden
post May 2 2003, 15:11
Post #17
Looks like your 'files' folder has many little goodies to discover, Case! Did you ever describe them somewhere or are they just waiting to be discovered?
Wavmix even can do inverse mixing, something I couldn't figured out with SoXmix.
Edit: David I'd be curious how that filesize reduction will end up with your method. Also wonder how you prevent people accidentaly (or purposely) playing the artefact files and start judging on that...
This post has been edited by HansHeijden: May 2 2003, 16:07
RSS Lo-Fi Version Time is now: 2nd June 2015 - 11:26
