TAK 2.2.0
TBeck
post Jul 10 2011, 23:46
TAK Developer
Final release of TAK 2.2.0 ((T)om's lossless (A)udio (K)ompressor)
This release brings support for multi-channel audio and speed optimizations for encoder and decoder.
It consists of:
  • TAK Applications 2.2.0.
  • TAK Winamp plugin 2.2.0.
  • TAK SDK 1.1.1.
  • TAK Decoding library 2.2.0.
Download
TBeck
post Jul 13 2011, 02:34
TAK Developer
I took the freedom to compile an excerpt of the extensive compression results which mē has posted in the Alpha thread.
His notes:
All samples come from DVD-A discs and are 5.1
Albums:
Sting       - Brand New Day           (samples d*, r*), 24/48
Nightwish   - Dark Passion Play       (a*),             24/48
Ton Koopman - Bach: Organ Spectacular (t*),             24/96
Foreigner   - 4                       (u*, v*, w*),     24/96
Codecs:
als rm23 (-7, other switches as indicated)
flake SVN r264 (-12)
wavpack 4.60.1
ttaenc 3.4.1
tak 2.2.0 (-p4m -wm0)
The 24/48 results:
                   a0     a1     a3     a4     d0     d2     d3     d4     d5     d6     r0     r1     r2     r3
WavPack -hx4       58,88  66,86  60,53  67,12  33,08  39,28  48,57  48,81  47,97  52,46  41,06  49,60  52,68  52,42
WavPack -hx6       58,84  66,86  60,49  67,12  32,98  39,07  48,18  47,98  47,40  51,61  40,84  48,79  51,63  51,52
WavPack -hhx6      58,79  66,83  60,44  67,09  32,76  38,79  47,74  47,58  47,09  51,12  40,51  48,37  51,18  51,07
Flake -12          58,33  66,01  60,25  66,25  32,82  37,46  47,63  47,59  46,96  50,97  40,77  48,45  51,11  51,16
TTA                65,76  74,80  66,77  74,94  51,35  55,96  67,49  66,45  66,50  71,47  63,61  70,14  72,08  73,33
TAK -p4m           56,78  64,59  58,36  64,93  30,79  34,68  44,71  43,74  44,20  47,94  37,92  45,99  47,80  49,42
Als -7 -o160 -t6   56,61  64,45  58,23  64,78  30,52  34,24  44,44  44,02  43,84  47,85  38,30  46,02  47,89  48,87
Als -7 -o1023 -t6  56,43  64,37  58,13  64,72  30,18  33,99  44,43  43,99  43,78  47,84  38,25  45,98  47,83  48,79
Als -z3 -t6        57,55  65,68  59,62  65,89  42,89  47,52  58,93  57,99  57,91  61,81  50,45  59,03  61,46  63,11
Compression ratio expressed as percentage of the original size.
The 24/96 results:
                   t0     t1     t2     t3     u0     u1     u2     u3     v0     v1     w0     w1     w2     w3     w4
WavPack -hx4       47,91  48,00  46,94  48,16  58,05  59,77  59,43  60,70  47,34  55,27  50,10  57,34  59,08  60,37  61,71
WavPack -hx6       47,89  47,99  46,94  48,16  57,97  59,69  59,33  60,57  47,23  55,22  50,00  57,26  58,98  60,31  61,68
WavPack -hhx6      47,88  47,97  46,93  48,16  57,32  59,11  58,77  59,92  46,66  54,70  49,49  56,86  58,52  59,92  61,37
Flake -12          47,73  47,87  46,96  48,21  56,79  58,62  58,18  59,36  46,01  53,91  48,81  55,89  57,48  59,00  60,81
TTA                49,61  49,66  48,69  49,87  66,98  69,26  68,71  70,62  55,04  63,73  59,10  66,16  67,55  69,29  71,25
TAK -p4m           42,80  43,10  41,94  43,01  55,73  57,72  57,33  58,46  45,23  52,62  47,82  54,92  56,30  57,94  59,95
Als -7 -o160 -t6   45,60  46,03  45,01  45,98  54,97  56,91  56,34  57,43  44,97  52,18  47,63  54,40  55,65  57,22  59,07
Als -7 -o511  -t6  45,26  45,76  44,78  45,53  54,97  56,91  56,34  57,42  44,94  52,19  47,27  54,36  55,65  57,17  59,05
Als -z3 -t6        41,22  41,96  41,07  41,92  60,96  62,86  62,30  63,24  50,94  58,03  53,28  60,33  61,66  63,11  64,85
mē's comment:
Generally, TAK looses to ALS, but is rocket fast.
I haven't decided which one do I want to use yet...Really, I expected TAK to do better.
I feel quite comfortable with your results.
For the 24/48 samples the performance of TAK -p4m is quite similar to Als -7 -o160 -t6. TAK compresses the t-set of the 24/96 samples better than Als -7 -o160 -t6, but indeed looses on the Foreigner 4 samples u, v and w.
Would it be possible to send me one or two 30 second snippets of the Foreigner files, where ALS's advantage manifests? I would like to look for tuning opportunities.
BTW: Thank you very much for such an extensive evaluation!
Thomas
- TBeck   TAK 2.2.0   Jul 10 2011, 23:46
- - TBeck   What's new New features: Support for multi-ch...   Jul 10 2011, 23:47
- - TBeck   I took the freedom to compile an excerpt of the ex...   Jul 13 2011, 02:34
|- - _mē_   QUOTE (TBeck @ Jul 13 2011, 03:34) Would ...   Jul 13 2011, 08:24
|- - _mē_   QUOTE (_mē_ @ Jul 13 2011, 09:24) QUOTE (...   Jul 13 2011, 11:05
|- - TBeck   QUOTE (_mē_ @ Jul 13 2011, 12:05) BTW by ...   Jul 13 2011, 17:53
- - _mē_   Got the samples. Took some time...I didn't tak...   Jul 15 2011, 17:11
|- - TBeck   QUOTE (_mē_ @ Jul 15 2011, 18:11) Got the...   Jul 15 2011, 19:32
- - Corpulencio   This is really awesome. Thanks!   Jul 26 2011, 17:07
- - Steve Forte Rio   TBeck, do you plan to add a CUDA support for furth...   Aug 1 2011, 11:31
- - zerowalker   Is there plans to make it playable on any player? ...   Aug 6 2011, 22:52
- - CoRoNe   Unlike WinAMP and Foobar, Zoom Player is a DirectS...   Aug 7 2011, 15:54
|- - zerowalker   QUOTE (CoRoNe @ Aug 7 2011, 16:54) Unlike...   Aug 8 2011, 05:03
- - CoRoNe   Of course it does. That's the point of lossles...   Aug 8 2011, 09:07
|- - zerowalker   QUOTE (CoRoNe @ Aug 8 2011, 10:07) Of cou...   Aug 8 2011, 10:25
- - TBeck   QUOTE (TBeck @ Jul 15 2011, 20:32) QUOTE ...   Aug 11 2011, 01:07
- - Steve Forte Rio   Thanks for reply. Seem like now takc works fine w...   Aug 12 2011, 12:08
- - jaro1   request: Mr. Beckers own fb2k decoder, i'll be...   Sep 24 2011, 15:04
|- - lvqcl   But you can always update tak_deco_lib.dll yoursel...   Sep 24 2011, 16:23
|- - jaro1   QUOTE (lvqcl @ Sep 24 2011, 17:23) But yo...   Sep 24 2011, 18:46
- - boombaard   QUOTE (TBeck @ Jul 10 2011, 23:46) Final ...   Sep 25 2011, 17:54
- - Xire   Have you tried to compile it with 64bit Delphi or ...   Sep 25 2011, 19:35
|- - TBeck   QUOTE (Xire @ Sep 25 2011, 20:35) Have yo...   Sep 27 2011, 22:45
- - boombaard   It appears as though the encoder refuses to encode...   Sep 25 2011, 20:09
|- - boombaard   QUOTE (boombaard @ Sep 25 2011, 20:09) It...   Sep 26 2011, 09:34
- - boombaard   (PS. Is it normal that I get different RG numbers ...   Sep 26 2011, 07:39
|- - anishbenji   If you used a recent version of foobar2000 (v1.1.6...   Sep 26 2011, 08:17
|- - boombaard   QUOTE (anishbenji @ Sep 26 2011, 08:17) I...   Sep 26 2011, 09:00
- - TBeck   QUOTE (Steve Forte Rio @ Aug 12 2011, 13...   Sep 27 2011, 22:31
- - boombaard   Yes, the fact that piping worked got me confused. ...   Sep 29 2011, 13:23
- - boombaard   Just a heads-up: I haven't kept any statistics...   Oct 3 2011, 11:49
- - tuxman   Just out of curiousity: How far is Linux support f...   Oct 25 2011, 22:49
- - lvqcl   Win32 binaries + WINE.   Oct 26 2011, 04:25
- - tuxman   Hmm, that would add quite some overhead ...   Oct 26 2011, 09:44
- - Destroid   Linux platform was touched on numerous times and t...   Oct 26 2011, 11:43
- - tuxman   Linux does not require its software to be open.   Oct 26 2011, 11:55
|- - viktor   QUOTE (tuxman @ Oct 26 2011, 12:55) Linux...   Oct 26 2011, 12:52
|- - _mē_   QUOTE (viktor @ Oct 26 2011, 13:52) QUOTE...   Oct 26 2011, 13:44
- - tuxman   My preferred Android media player is not open sour...   Oct 26 2011, 13:06
- - Anakunda   Is there a Linux player support yet? Banshee or Am...   Oct 26 2011, 13:11
- - PPeti66x   Hi! It is possible to decode multiple TAK file...   Dec 14 2011, 23:28
- - Anakunda   Any chance to get decoding support for Banshee or ...   Dec 17 2011, 20:13
- - pikashi   I set my command-line options of EAC like this and...   Feb 3 2012, 12:35
- - temp1   any news about new version?   Mar 16 2012, 16:52
- - TBeck   Sorry for the lack of active participation. I have...   Mar 20 2012, 01:27
- - Dario   Tom, could you please document the function that ...   Mar 25 2012, 10:15
- - lvqcl   About TAK and foobar2000... From http://www.foobar...   Mar 25 2012, 10:38
- - CoRoNe   Could someone who has access to TAK's Wiki pag...   Apr 30 2012, 11:42
- - Dario   Are there any updates regarding TAK?   May 7 2012, 10:49
- - Mr.Duck   How do you use the md5 data? It gets written into ...   May 11 2012, 06:23
|- - lvqcl   QUOTE (Mr.Duck @ May 11 2012, 09:23) The ...   May 11 2012, 16:01
|- - Mr.Duck   QUOTE (lvqcl @ May 11 2012, 16:01) QUOTE ...   May 12 2012, 21:55
- - marc2003   you are using -d to decode, right?   May 12 2012, 22:25
|- - Mr.Duck   QUOTE (marc2003 @ May 12 2012, 22:25) you...   May 14 2012, 02:04
- - Destroid   Yes, I could find no internal conversion either (i...   May 14 2012, 06:39
- - 06_taro   CODED:\Program Files\Media\Foob...   May 14 2012, 08:54
- - Destroid   @06_taro - Ok, it works for me too, now. Can't...   May 14 2012, 16:56
- - Mr.Duck   Ah that's helpful, thanks. But all the tags g...   May 15 2012, 01:18
- - marc2003   using foobar2000 would preserve tags (except embed...   May 15 2012, 01:30
- - Mr.Duck   If anyone knows of a (command line) tool that can ...   May 20 2012, 15:40
- - CoRoNe   Tool: Mp3tag Command line tool: Tag 2.0.52 (with -...   May 20 2012, 16:27
- - e354412   TAK is really a great codec which compresses much ...   Jun 21 2012, 01:59
- - Mr.Duck   So I finally got round to writing this batch file ...   Nov 11 2012, 23:54
- - hmasterwang   This version doesn't support wav file exceeded...   Jun 11 2013, 13:48
- - lvqcl   CODEtakc.exe -e -p2 -ihs - outfile.tak < infil...   Jun 11 2013, 14:49
|- - hmasterwang   QUOTE (lvqcl @ Jun 11 2013, 07:49) CODEta...   Jun 12 2013, 15:13
- - naturfreak   According to the official specifications the size ...   Jun 12 2013, 15:20
- - db1989   All signs point to that being a problem with WAV, ...   Jun 12 2013, 15:25
|- - hmasterwang   QUOTE (db1989 @ Jun 12 2013, 08:25) All s...   Jun 12 2013, 15:41
- - lvqcl   Unfortunately TAK itself doesn't support RIFF6...   Jun 12 2013, 15:43
- - hmasterwang   QUOTE (lvqcl @ Jun 12 2013, 08:43) Unfort...   Jun 12 2013, 16:01
RSS Lo-Fi Version Time is now: 5th September 2015 - 18:20
