TAK 2.2.0
TBeck
post Jul 10 2011, 23:46
TAK Developer
Final release of TAK 2.2.0 ((T)om's lossless (A)udio (K)ompressor)
This release brings support for multi-channel audio and speed optimizations for encoder and decoder.
It consists of:
  • TAK Applications 2.2.0.
  • TAK Winamp plugin 2.2.0.
  • TAK SDK 1.1.1.
  • TAK Decoding library 2.2.0.
Download
TBeck
post Jul 10 2011, 23:47
TAK Developer
What's new
New features:
  • Support for multi-channel audio. While the stream format supports up to 16 channels, the codec currently is restricted to a maximum of 6 channels.
  • Support for the "Wave Format Extensible" file format.
Improvements:
  • Encoding speed improvements of up to 10 percent for my primary file set. Most of it is achieved by a modification of the algorithm which selects the optimal predictor order for each subframe. It will now often use less predictors than before, what may on average result in about 0.01 percent worse compression. You will only notice an advantage, if your files benefit from high predictor orders.
  • Decoding speed improvements of up to 18 percent for my primary file set. Some of it is attributed to the above-noted modification of the encoder's predictor order selection algorithm. Therefore it will only take effect when decoding files encoded with this version and only, if they benefit from high predictor orders. Additionally SSSE3-instructions can be used for predictor counts of 32 and more. This affects the presets p3, p4 and sometimes p2, but only, if a particular file benefits from high predictor orders.
Fixes:
  • The wave file reader reported an error if a file contained additional (meta) data following the audio data.
  • The wave file writer didn't add an optional zero byte to make the audio data chunk size a multiple of 2. This was only relevant when decoding mono audio with 8- or 24-bit samples without restoring the wave meta data (-wm0 applied on encoding and/or decoding).
Known issues:
  • If you use pipe decoding and the application reading the pipe is beeing terminated before the whole file has been read, TAKC may get into an endless loop and has to be manually killed with the task manager. I don't think this is a big issue but i will try to fix it in one of the next versions. BTW: Big thanks to shnutils for testing the pipe decoding!
  • There seem to be some compatibility issues with pipe decoding to some other applications ("crc1632.exe" has been reported). I will try to fix it in the next release.
More information
You can find some useful information and comparisons in the Alpha thread.
Have fun...
Thomas
- TBeck   TAK 2.2.0   Jul 10 2011, 23:46
- - TBeck   What's new New features: Support for multi-ch...   Jul 10 2011, 23:47
- - TBeck   I took the freedom to compile an excerpt of the ex...   Jul 13 2011, 02:34
|- - _mē_   QUOTE (TBeck @ Jul 13 2011, 03:34) Would ...   Jul 13 2011, 08:24
|- - _mē_   QUOTE (_mē_ @ Jul 13 2011, 09:24) QUOTE (...   Jul 13 2011, 11:05
|- - TBeck   QUOTE (_mē_ @ Jul 13 2011, 12:05) BTW by ...   Jul 13 2011, 17:53
- - _mē_   Got the samples. Took some time...I didn't tak...   Jul 15 2011, 17:11
|- - TBeck   QUOTE (_mē_ @ Jul 15 2011, 18:11) Got the...   Jul 15 2011, 19:32
- - Corpulencio   This is really awesome. Thanks!   Jul 26 2011, 17:07
- - Steve Forte Rio   TBeck, do you plan to add a CUDA support for furth...   Aug 1 2011, 11:31
- - zerowalker   Is there plans to make it playable on any player? ...   Aug 6 2011, 22:52
- - CoRoNe   Unlike WinAMP and Foobar, Zoom Player is a DirectS...   Aug 7 2011, 15:54
|- - zerowalker   QUOTE (CoRoNe @ Aug 7 2011, 16:54) Unlike...   Aug 8 2011, 05:03
- - CoRoNe   Of course it does. That's the point of lossles...   Aug 8 2011, 09:07
|- - zerowalker   QUOTE (CoRoNe @ Aug 8 2011, 10:07) Of cou...   Aug 8 2011, 10:25
- - TBeck   QUOTE (TBeck @ Jul 15 2011, 20:32) QUOTE ...   Aug 11 2011, 01:07
- - Steve Forte Rio   Thanks for reply. Seem like now takc works fine w...   Aug 12 2011, 12:08
- - jaro1   request: Mr. Beckers own fb2k decoder, i'll be...   Sep 24 2011, 15:04
|- - lvqcl   But you can always update tak_deco_lib.dll yoursel...   Sep 24 2011, 16:23
|- - jaro1   QUOTE (lvqcl @ Sep 24 2011, 17:23) But yo...   Sep 24 2011, 18:46
- - boombaard   QUOTE (TBeck @ Jul 10 2011, 23:46) Final ...   Sep 25 2011, 17:54
- - Xire   Have you tried to compile it with 64bit Delphi or ...   Sep 25 2011, 19:35
|- - TBeck   QUOTE (Xire @ Sep 25 2011, 20:35) Have yo...   Sep 27 2011, 22:45
- - boombaard   It appears as though the encoder refuses to encode...   Sep 25 2011, 20:09
|- - boombaard   QUOTE (boombaard @ Sep 25 2011, 20:09) It...   Sep 26 2011, 09:34
- - boombaard   (PS. Is it normal that I get different RG numbers ...   Sep 26 2011, 07:39
|- - anishbenji   If you used a recent version of foobar2000 (v1.1.6...   Sep 26 2011, 08:17
|- - boombaard   QUOTE (anishbenji @ Sep 26 2011, 08:17) I...   Sep 26 2011, 09:00
- - TBeck   QUOTE (Steve Forte Rio @ Aug 12 2011, 13...   Sep 27 2011, 22:31
- - boombaard   Yes, the fact that piping worked got me confused. ...   Sep 29 2011, 13:23
- - boombaard   Just a heads-up: I haven't kept any statistics...   Oct 3 2011, 11:49
- - tuxman   Just out of curiousity: How far is Linux support f...   Oct 25 2011, 22:49
- - lvqcl   Win32 binaries + WINE.   Oct 26 2011, 04:25
- - tuxman   Hmm, that would add quite some overhead ...   Oct 26 2011, 09:44
- - Destroid   Linux platform was touched on numerous times and t...   Oct 26 2011, 11:43
- - tuxman   Linux does not require its software to be open.   Oct 26 2011, 11:55
|- - viktor   QUOTE (tuxman @ Oct 26 2011, 12:55) Linux...   Oct 26 2011, 12:52
|- - _mē_   QUOTE (viktor @ Oct 26 2011, 13:52) QUOTE...   Oct 26 2011, 13:44
- - tuxman   My preferred Android media player is not open sour...   Oct 26 2011, 13:06
- - Anakunda   Is there a Linux player support yet? Banshee or Am...   Oct 26 2011, 13:11
- - PPeti66x   Hi! It is possible to decode multiple TAK file...   Dec 14 2011, 23:28
- - Anakunda   Any chance to get decoding support for Banshee or ...   Dec 17 2011, 20:13
- - pikashi   I set my command-line options of EAC like this and...   Feb 3 2012, 12:35
- - temp1   any news about new version?   Mar 16 2012, 16:52
- - TBeck   Sorry for the lack of active participation. I have...   Mar 20 2012, 01:27
- - Dario   Tom, could you please document the function that ...   Mar 25 2012, 10:15
- - lvqcl   About TAK and foobar2000... From http://www.foobar...   Mar 25 2012, 10:38
- - CoRoNe   Could someone who has access to TAK's Wiki pag...   Apr 30 2012, 11:42
- - Dario   Are there any updates regarding TAK?   May 7 2012, 10:49
- - Mr.Duck   How do you use the md5 data? It gets written into ...   May 11 2012, 06:23
|- - lvqcl   QUOTE (Mr.Duck @ May 11 2012, 09:23) The ...   May 11 2012, 16:01
|- - Mr.Duck   QUOTE (lvqcl @ May 11 2012, 16:01) QUOTE ...   May 12 2012, 21:55
- - marc2003   you are using -d to decode, right?   May 12 2012, 22:25
|- - Mr.Duck   QUOTE (marc2003 @ May 12 2012, 22:25) you...   May 14 2012, 02:04
- - Destroid   Yes, I could find no internal conversion either (i...   May 14 2012, 06:39
- - 06_taro   CODED:\Program Files\Media\Foob...   May 14 2012, 08:54
- - Destroid   @06_taro - Ok, it works for me too, now. Can't...   May 14 2012, 16:56
- - Mr.Duck   Ah that's helpful, thanks. But all the tags g...   May 15 2012, 01:18
- - marc2003   using foobar2000 would preserve tags (except embed...   May 15 2012, 01:30
- - Mr.Duck   If anyone knows of a (command line) tool that can ...   May 20 2012, 15:40
- - CoRoNe   Tool: Mp3tag Command line tool: Tag 2.0.52 (with -...   May 20 2012, 16:27
- - e354412   TAK is really a great codec which compresses much ...   Jun 21 2012, 01:59
- - Mr.Duck   So I finally got round to writing this batch file ...   Nov 11 2012, 23:54
- - hmasterwang   This version doesn't support wav file exceeded...   Jun 11 2013, 13:48
- - lvqcl   CODEtakc.exe -e -p2 -ihs - outfile.tak < infil...   Jun 11 2013, 14:49
|- - hmasterwang   QUOTE (lvqcl @ Jun 11 2013, 07:49) CODEta...   Jun 12 2013, 15:13
- - naturfreak   According to the official specifications the size ...   Jun 12 2013, 15:20
- - db1989   All signs point to that being a problem with WAV, ...   Jun 12 2013, 15:25
|- - hmasterwang   QUOTE (db1989 @ Jun 12 2013, 08:25) All s...   Jun 12 2013, 15:41
- - lvqcl   Unfortunately TAK itself doesn't support RIFF6...   Jun 12 2013, 15:43
- - hmasterwang   QUOTE (lvqcl @ Jun 12 2013, 08:43) Unfort...   Jun 12 2013, 16:01
RSS Lo-Fi Version Time is now: 19th April 2015 - 05:15
