> Upload forum rules
6 Pages V   1 2 3 > »
Winamp FhG AAC encoder with gapless fix, Updates from the 5.62 release
benski
post Jul 4 2011, 18:51
Winamp Developer
Steve from the AAC listening test topic found a bug related to gapless information in m4a files encoded with Winamp/FhG's new AAC encoder.
* Fixed a bug that was preventing gapless playback information from being written to the encoded file in some circumstances
* Fixed compatibility issue that was preventing HE-AAC files from being used with iTunes
* Fixed a bug that was causing the ADTS encoder to fail with the default settings
To install, just unzip this to your Winamp plugins folder. It should overwrite an existing file (unless you are using an older version of Winamp).
This will be released with 5.63 (or 5.621 depending on what version number we decide upon)
Attached File(s)
lvqcl
post Jul 7 2011, 15:41
I noticed that this encoder produces 88.2 kHz .m4a files when the input is 44.1 and bitrate>=320kpbs. 48kHz remains untouched.
Is it a bug or a feature?
benski
post Jul 7 2011, 17:20
Winamp Developer
QUOTE (lvqcl @ Jul 7 2011, 10:41) *
A little bit of both. One issue is that the configuration dialog currently has no idea what the input samplerate / channel count is going to be. And the encoder must be trying really hard to honor the bitrate request. I'll do a bit more checking on it - is it all bitrates >320kbps, even 324kbps? I'll check myself also.
lvqcl
post Jul 7 2011, 18:08
QUOTE (benski @ Jul 7 2011, 20:20) *
All bitrates >= 320. Even 320 kbps. (2 channels, 16 bit).
Alex B
post Jul 7 2011, 23:14
By chance I noticed a serious encoding artifact (I'd actually describe it as a bug) when I tested this encoder with some gapless albums. The album is Transatlantic's The Whirlwind. I noticed that the track #4 (A Man Can Feel) has a suspicious track peak value of 2.46 after encoding it using the FhG AAC VBR preset 3. The track has a loud artifact in the left channel at about 2 min 1 s.
I tried to create a 30 s sample in which the artifact would occur at 25 s, but the cut source file did not produce the same artifact. Apparently only the complete track triggers it.
I verified the problem with two different computers.
I created samples of the reference file and the decoded file (decoded to float and cut). I reduced the volume levels by -8 dB to prevent clipping before I saved the samples in the 16-bit integer format. The artifact occurs at about 5 s.
The reference sample: Attached File  A_Man_Can_Feel__reference.flac ( 754.23K ) Number of downloads: 258
The decoded sample: Attached File  A_Man_Can_Feel__decoded_aac.flac ( 689.35K ) Number of downloads: 265
Here is how the decoded sample looks in Audition:
EDIT
benski and C.R.Helmrich, I have posted a PM to you.
This post has been edited by Alex B: Jul 7 2011, 23:38
lvqcl
post Jul 8 2011, 04:22
QUOTE (Alex B @ Jul 8 2011, 02:14) *
Maybe removing first N*1024 samples will help?
Alex B
post Jul 8 2011, 12:46
So you think that the AAC frame border position may have an effect on this. That would be a logical explanation because I don't think a VBR encoder would take into account the past audio content from tens of seconds or minutes before the current frame.
This post has been edited by Alex B: Jul 8 2011, 12:57
Alex B
post Jul 8 2011, 14:18
That did the trick. I removed N*1024 samples from the beginning. Here is a ~15 s sample that produces the same artifact when encoded (using Winamp/FhG AAC v.1.01, VBR preset 3). The problem occurs at about 12.6 s. It is clearly audible when replay gain is set to prevent clipping.
This post has been edited by Alex B: Jul 8 2011, 14:26
MrSinatra
post Jul 13 2011, 02:31
Benski,
i wish you were posting this at the winamp forums!
C.R.Helmrich
post Aug 23 2011, 11:59
QUOTE (Alex B @ Jul 8 2011, 00:14) *
Thanks a lot, Alex, for this report! This is a very rare bug which has been fixed in a newer release of Fraunhofer's AAC encoder (version 03.02.03) a few weeks ago and should reach Winamp soon.
QUOTE (lvqcl @ Jul 7 2011, 16:41) *
Thanks for reporting! It's a bug (because it was trivial to solve) and is also fixed in the new version.
Please, anyone, if you find such configuration problems or artifacts, report them here on HA along with the input file, just like Alex did, so we can reproduce and hopefully fix them.
Chris
This post has been edited by C.R.Helmrich: Aug 23 2011, 12:08
b66pak
post Aug 23 2011, 18:45
@C.R.Helmrich
hi, do you plan to add adts support for VBR mode too?
_
benski
post Aug 23 2011, 19:37
Winamp Developer
QUOTE (b66pak @ Aug 23 2011, 13:45) *
@C.R.Helmrich
_
The encoder supports VBR encoding in ADTS format. We (Winamp) have chosen not to implement it as there is no defined seek-table for ADTS files.
b66pak
post Aug 23 2011, 19:57
i hope you will reconsider...(may be as a silent option - for a CLI wrapper only!)...this would be very handy (with adts STDOUT support too! - may be as a silent option - for a CLI wrapper only!) for pipeing VBR/CBR aac from an audio decoder to an audio-video muxer...
_
sorry for OT...
_
This post has been edited by b66pak: Aug 23 2011, 19:58
punkrockdude
post Oct 13 2011, 16:16
I am looking forward to a fix for the upsampling issue. Regards.
punkrockdude
post Oct 13 2011, 17:58
Post #15
Are you considering higher bitrate VBR presets? I use Q 0.9 with Nero which result in ~375 kbps with modern music and around ~250 kbps with older less hifi music. You (Fhg) have constant bitrate up to 448 kbps for us who want some reassurance headroom when it comes to the bitrate but a VBR mode that uses the highest bitrates and results in maybe 320-375 kbps would be much appreciated. Regards.
C.R.Helmrich
post Oct 13 2011, 20:21
Post #16
QUOTE (punkrockdude @ Oct 13 2011, 18:58) *
Are you considering higher bitrate VBR presets? I use Q 0.9 with Nero which result in ~375 kbps with modern music and around ~250 kbps with older less hifi music. You (Fhg) have constant bitrate up to 448 kbps for us who want some reassurance headroom ...
I assume you like the idea of headroom in order to avoid non-transparent encodings. Actually I tuned FhG's encoder for precisely that, using also the most "killer" items I could find here on HA. At the highest VBR mode, any item should be transparent. If it is not, please notify me. Until then, I see little point in adding a very-high-rate VBR mode.
In any case, you'd have to ask benski since he decides (and has to implement) which modes are/will be available in the Winamp GUI.
Chris
Alex B
post Oct 14 2011, 09:10
Post #17
Am I correct to assume that the v. 03.02.03 is still not available?
Edit: Winamp 5.621 is still the latest build and its encoder version is 03.02.02. (at least in my installer, downloaded July 14)
This post has been edited by Alex B: Oct 14 2011, 09:43
Anakunda
post Oct 26 2011, 13:13
Post #18
Great! The only downside is I'm not using Winamp. Is therre a facet for foobar2k, or a plugin for f2k?
This post has been edited by Anakunda: Oct 26 2011, 13:13
benski
post Oct 26 2011, 14:09
Post #19
Winamp Developer
QUOTE (Alex B @ Oct 14 2011, 04:10) *
Winamp 5.622 with FhG AAC 3.2.3 just got released moments ago.
This post has been edited by benski: Oct 26 2011, 14:49
lvqcl
post Oct 26 2011, 15:16
Post #20
Thanks for the info!
b66pak
post Oct 27 2011, 17:28
Post #21
@benski can you update your attachement from the first post?
_
IgorC
post Oct 28 2011, 14:37
Post #22
Apparently new version 3.2.3 has not only bug fixes but also quality tunings.
http://listening-test.coresv.net/results.htm
Gainless
post Oct 28 2011, 14:49
Post #23
Chris
Depends on what you call "transparent".
The encoder is indeed very efficient and every detail is clear at the highest VBR mode, but the sound is still kinda "compact" and a bit unnatural compared to the lossless files.
320 kbps would be perhaps a bit overkill, but what speaks against a mode "6" at around 256 kbps?
Edit:
Sorry for the wrong quote I answered to at first!
This post has been edited by Gainless: Oct 28 2011, 15:28
b66pak
post Oct 28 2011, 17:47
Post #24
can anybody help with the new .dll?
_
A_Man_Eating_Duc...
post Oct 28 2011, 19:36
Post #25
Download the latest Winamp package.
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st February 2015 - 06:48
