Normalize Vs Volume increase
tinpanalley
post Jun 29 2011, 23:08
I'm having trouble figuring out which of the two is better for me to create a vinyl recording at the highest volume without clipping.
I capture a record via my preamp into Audacity, and I get what seem to be relatively low levels even though I make sure the levels are right when I record (Peak: -6.4db, RMS -24.6db). Am I doing something wrong? Or are those levels right? These recordings don't seem as loud as mastered CDs.
Anyway, to get the most accurate sound possible, should I use normalize or just increase the volume? If normalizing makes everything sound the same at a peak level, doesn't that completely screw with the dynamic range of the music?
tinpanalley
post Nov 12 2011, 23:24
If I'm going through a recording process with a mono record, where I'll be summing the two channels picked up by a stereo cartridge, where should the channel summing process happen? Basically, should I declick the raw 2-channel recording or declick-pop once the channels have been summed?
(Just in case, yes I know there are mono stylii, I know a stereo stylus on a mono record isn't true reproduction, I'm not buying a mono stylus, that level of fidelity doesn't interest me. Got heck elsewhere for even suggesting a stereo stylus on a mono record.)
This post has been edited by tinpanalley: Nov 12 2011, 23:28
botface
post Nov 13 2011, 10:24
QUOTE (tinpanalley @ Nov 12 2011, 23:24) *
Most people will advise declicking then summing to mono. However, I have achieved better results with some 78's that were in very poor condition by recoding them mono in the first place - by summing the channels before the preamp and recording to a mono track. So, I'd suggest trying both of the approaches you mention and seeing which one works best with your source material
- tinpanalley   Normalize Vs Volume increase   Jun 29 2011, 23:08
- - DVDdoug   Audacity's Amplify effect has an option of set...   Jun 30 2011, 00:43
|- - db1989   tinpanalley, your observation matches tracks that ...   Jun 30 2011, 12:31
- - tinpanalley   Thanks so much for the thorough reply. So, 2 quest...   Jun 30 2011, 01:06
- - DVDdoug   QUOTE 1. What do you recommend I do with my settin...   Jun 30 2011, 01:52
|- - tinpanalley   QUOTE (DVDdoug @ Jun 29 2011, 20:52) CDs ...   Jun 30 2011, 02:05
- - AndyH-ha   There is no "need" to amplify or normali...   Jun 30 2011, 02:55
- - tinpanalley   But doesn't normalizing in making all loudness...   Jun 30 2011, 03:09
|- - tropicalfish   QUOTE (tinpanalley @ Jun 29 2011, 21:09) ...   Jun 30 2011, 05:15
|- - tinpanalley   QUOTE (tropicalfish @ Jun 30 2011, 00:15)...   Jun 30 2011, 08:31
- - tinpanalley   Well here's what I have... I think this will h...   Jun 30 2011, 17:51
- - tropicalfish   Record with Audacity. Go to Normalize, and check O...   Jun 30 2011, 19:25
|- - db1989   QUOTE (tropicalfish @ Jun 30 2011, 19:25)...   Jun 30 2011, 19:43
|- - tropicalfish   QUOTE (db1989 @ Jun 30 2011, 13:43) QUOTE...   Jun 30 2011, 22:51
|- - db1989   QUOTE (tropicalfish @ Jun 30 2011, 22:51)...   Jul 1 2011, 13:25
- - tinpanalley   Perhaps I should have also stated that the way I r...   Jun 30 2011, 20:31
- - AndyH-ha   A recording made with proper equipment should not ...   Jun 30 2011, 20:51
|- - 2Bdecided   QUOTE (AndyH-ha @ Jun 30 2011, 20:51...   Jul 1 2011, 18:19
|- - musicollector   QUOTE (AndyH-ha @ Jun 30 2011, 12:51...   Nov 28 2011, 04:30
- - tinpanalley   Ok, how about if I just control that from the phon...   Jun 30 2011, 20:55
- - mixminus1   I'll second AndyH's advice on recording bo...   Jun 30 2011, 21:01
- - tinpanalley   I basically already do what you're suggesting ...   Jun 30 2011, 21:06
- - AndyH-ha   The gain is normally set to leave plenty of headro...   Jun 30 2011, 21:24
|- - tinpanalley   QUOTE (AndyH-ha @ Jun 30 2011, 16:24...   Jun 30 2011, 21:30
- - DVDdoug   QUOTE How do I know if my sound card can handle 32...   Jun 30 2011, 21:36
- - mixminus1   Audacity has the option to export to bit depths gr...   Jun 30 2011, 21:40
|- - tinpanalley   QUOTE (mixminus1 @ Jun 30 2011, 16:40) Of...   Jun 30 2011, 21:43
- - AndyH-ha   Audacity is FREEware. If may also be adequate for...   Jun 30 2011, 22:15
- - tinpanalley   Ok, I'm trying Sound Forge now. Aiming for -6d...   Jun 30 2011, 22:16
|- - mixminus1   QUOTE (tinpanalley @ Jun 30 2011, 14:16) ...   Jun 30 2011, 22:36
- - AndyH-ha   It may be true that most editors work in floating ...   Jun 30 2011, 22:25
- - tinpanalley   No, just that when I choose 32-bit (IEEE float) it...   Jun 30 2011, 22:39
- - tinpanalley   You see, that's what I thought.   Jun 30 2011, 23:05
- - tropicalfish   There are no 32-bit devices, so why use it? You mi...   Jun 30 2011, 23:22
|- - tinpanalley   QUOTE (tropicalfish @ Jun 30 2011, 18:22)...   Jun 30 2011, 23:52
- - tropicalfish   So you want to record in floating point, and then ...   Jul 1 2011, 01:15
- - tinpanalley   I don't really care how I record. I just wanna...   Jul 1 2011, 01:28
- - DVDdoug   QUOTE 1. What do you recommend I do with my settin...   Jul 1 2011, 01:53
- - tinpanalley   All the 24 and 32 bit stuff still has me really co...   Jul 1 2011, 04:08
|- - 2Bdecided   QUOTE (tinpanalley @ Jul 1 2011, 04:08) I...   Jul 1 2011, 18:25
|- - tinpanalley   Thanks for the wonderful feedback. Just wanted to ...   Jul 1 2011, 19:51
- - AndyH-ha   There exist a continuously varying analogue signal...   Jul 1 2011, 06:06
- - AndyH-ha   QUOTE Come on Andy - think that one through proper...   Jul 1 2011, 20:36
|- - DVDdoug   QUOTE (AndyH-ha @ Jul 1 2011, 12:36)...   Jul 1 2011, 22:12
|- - 2Bdecided   QUOTE (DVDdoug @ Jul 1 2011, 22:12) We...   Jul 4 2011, 12:34
- - DVDdoug   QUOTE It's the bits I don't get.OK, I...   Jul 1 2011, 21:46
- - AndyH-ha   My experience is based on CoolEdit Statistics repo...   Jul 4 2011, 20:32
|- - 2Bdecided   I think you may think I might be being clever than...   Jul 4 2011, 23:34
- - AndyH-ha   Perhaps I am just too ignorant of what is involved...   Jul 5 2011, 08:38
- - 2Bdecided   Vinyl is an intrinsically AC-coupled format. It ha...   Jul 5 2011, 14:08
- - pdq   Think of it this way. If there is a DC offset in t...   Jul 5 2011, 16:14
- - tinpanalley   Hey all, I've been absorbing everything you g...   Jul 6 2011, 22:37
- - DVDdoug   QUOTE - 32-bit IEEE Float? - 32-bit PCM? Floating ...   Jul 7 2011, 01:34
|- - tinpanalley   QUOTE (DVDdoug @ Jul 6 2011, 20:34) [b]Do...   Jul 7 2011, 05:06
|- - AndyH-ha   I'm curious about this inability to record in ...   Jul 7 2011, 09:31
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 7 2011, 04:31)...   Jul 7 2011, 17:56
- - tinpanalley   This is probably like asking if there is one way t...   Jul 7 2011, 18:37
- - AndyH-ha   There are many descriptions of the process publish...   Jul 7 2011, 19:20
|- - 2Bdecided   QUOTE (AndyH-ha @ Jul 7 2011, 19:20)...   Jul 8 2011, 12:01
|- - tinpanalley   QUOTE (2Bdecided @ Jul 8 2011, 07:01) The...   Jul 8 2011, 15:49
- - DVDdoug   QUOTE but is there any series of processes that ar...   Jul 7 2011, 20:36
- - tinpanalley   Here's a comparison of the 32-bit, higher gain...   Jul 7 2011, 21:04
- - tinpanalley   This sounds great to me as I'm hearing it even...   Jul 7 2011, 22:16
- - greynol   No you're not crazy, just know that 32 bits fo...   Jul 7 2011, 22:34
- - DVDdoug   QUOTE And normalising... if I get good levels on t...   Jul 7 2011, 23:38
|- - tinpanalley   Couple of things: QUOTE (DVDdoug @ Jul 7 201...   Jul 7 2011, 23:48
- - greynol   No, they aren't contradictory at all. DVDdoug...   Jul 8 2011, 00:03
- - tinpanalley   Ok, my bad. I misunderstood. I have some people te...   Jul 8 2011, 00:08
|- - greynol   QUOTE (tinpanalley @ Jul 7 2011, 16:08) I...   Jul 8 2011, 00:55
- - DVDdoug   QUOTE Then what is the difference to just doing a ...   Jul 8 2011, 00:39
|- - tinpanalley   QUOTE (DVDdoug @ Jul 7 2011, 19:39) But a...   Jul 8 2011, 01:57
- - AndyH-ha   The Sonic Foundry Noise Reduction plugin 2.0 has b...   Jul 8 2011, 02:46
- - greynol   I simply wanted to let you know that I respect tha...   Jul 8 2011, 02:53
- - AndyH-ha   I made an inquiry elsewhere. I got back that your ...   Jul 8 2011, 03:04
- - tinpanalley   Ohhh!!! Well, why didn't someone j...   Jul 8 2011, 07:34
- - AndyH-ha   Because Sound Forge has such an unusual approach (...   Jul 8 2011, 08:19
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 8 2011, 03:19)...   Jul 8 2011, 15:45
- - tinpanalley   This is the info from a download from the site (wh...   Jul 8 2011, 16:08
- - 2Bdecided   Nothing automatic there, just "manual click r...   Jul 8 2011, 20:30
- - DVDdoug   QUOTE Is Audacity totally a lame program? Vinyl ca...   Jul 8 2011, 20:32
- - AndyH-ha   I 've paid no attention to Audacity for some y...   Jul 8 2011, 20:36
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 8 2011, 15:36)...   Jul 8 2011, 21:09
|- - greynol   Um, no, The Beatles were recorded to tape and the ...   Jul 8 2011, 21:16
|- - tinpanalley   QUOTE (greynol @ Jul 8 2011, 16:16) Um, n...   Jul 8 2011, 22:46
||- - greynol   Denying that vinyl was the most common medium back...   Jul 9 2011, 00:07
|- - 2Bdecided   QUOTE (greynol @ Jul 8 2011, 21:16) Um, n...   Jul 9 2011, 12:30
- - Juha   Couple questions: Would normalization be more sec...   Jul 9 2011, 09:31
- - AndyH-ha   What one gets by normalization is independent of t...   Jul 9 2011, 09:40
- - tinpanalley   If I'm going through a recording process with ...   Nov 12 2011, 23:24
|- - mjb2006   Why did you bump this thread? Your question has no...   Nov 13 2011, 00:20
||- - tinpanalley   QUOTE (mjb2006 @ Nov 12 2011, 19:20) Why ...   Nov 13 2011, 05:09
|- - botface   QUOTE (tinpanalley @ Nov 12 2011, 23:24) ...   Nov 13 2011, 10:24
|- - tinpanalley   QUOTE (botface @ Nov 13 2011, 05:24) by s...   Nov 13 2011, 22:24
|- - 2Bdecided   QUOTE (tinpanalley @ Nov 13 2011, 22:24) ...   Nov 15 2011, 11:23
- - AndyH-ha   It also depends on the channel balance. Some cartr...   Nov 15 2011, 11:36
|- - 2Bdecided   QUOTE (AndyH-ha @ Nov 15 2011, 11:36...   Nov 16 2011, 13:43
- - botface   Yes, I wasn't suggesting recording in mono as ...   Nov 15 2011, 17:27
RSS Lo-Fi Version Time is now: 25th May 2015 - 05:08
