Normalize Vs Volume increase
tinpanalley
post Jun 29 2011, 23:08
I'm having trouble figuring out which of the two is better for me to create a vinyl recording at the highest volume without clipping.
I capture a record via my preamp into Audacity, and I get what seem to be relatively low levels even though I make sure the levels are right when I record (Peak: -6.4db, RMS -24.6db). Am I doing something wrong? Or are those levels right? These recordings don't seem as loud as mastered CDs.
Anyway, to get the most accurate sound possible, should I use normalize or just increase the volume? If normalizing makes everything sound the same at a peak level, doesn't that completely screw with the dynamic range of the music?
tinpanalley
post Jul 1 2011, 04:08
All the 24 and 32 bit stuff still has me really confused. It's fine, I just need to do the research and studying myself. It's frustrating for me because as with video I have this thing where I NEED to know what is happening technically throughout the process but I don't have enough background or experience with audio to get my head around it.
There's an analog signal being turned into something digital via the preamp which is also boosting the signal. That newly amplified signal is then being sent digitally (as 1s and 0s) via a USB cable into a computer which takes the input and copies those 1s and 0s onto a harddrive. The software represents that digitized analog signal as a waveform which I can save in various containers (.wav, .flac, etc) and with various filters, settings, and processes applied. I get all of that (IF that was all correct). It's the bits I don't get.
I don't get:
- if the signal looks like it's clipping on the light of the preamp, why is it only hitting -7 on the meter in Sound Forge? Is there another variable somewhere? The Windows input level or something? Why aren't they equal?
- How does the bit amount affect the recording?
- Is the bit depth something the RECORDING HAS or something the SIGNAL COMES WITH from the turntable?
Look, I've got this great turntable and the guys at needledoctor.com helped me pick the best stylus and cartridge for my setup. I don't wanna get so-so sound. I'm the guy that will only use FLAC on his media player (a Cowon). I use gapless. I like my classical having the appropriately low levels. I own Sinatra's Capitol albums on mono because I don't like the duophonic crap that was produced in the 50s when the labels wanted everyone to buy a stereo hifi. I can't be ok with "yeah, that sounds pretty good". I wanna have the best I can and understand why it's the best that I can do with my vinyl captures. Does that make sense? Am I being too picky? sad.gif ...geez, whiney dude, huh?
- tinpanalley   Normalize Vs Volume increase   Jun 29 2011, 23:08
- - DVDdoug   Audacity's Amplify effect has an option of set...   Jun 30 2011, 00:43
|- - db1989   tinpanalley, your observation matches tracks that ...   Jun 30 2011, 12:31
- - tinpanalley   Thanks so much for the thorough reply. So, 2 quest...   Jun 30 2011, 01:06
- - DVDdoug   QUOTE 1. What do you recommend I do with my settin...   Jun 30 2011, 01:52
|- - tinpanalley   QUOTE (DVDdoug @ Jun 29 2011, 20:52) CDs ...   Jun 30 2011, 02:05
- - AndyH-ha   There is no "need" to amplify or normali...   Jun 30 2011, 02:55
- - tinpanalley   But doesn't normalizing in making all loudness...   Jun 30 2011, 03:09
|- - tropicalfish   QUOTE (tinpanalley @ Jun 29 2011, 21:09) ...   Jun 30 2011, 05:15
|- - tinpanalley   QUOTE (tropicalfish @ Jun 30 2011, 00:15)...   Jun 30 2011, 08:31
- - tinpanalley   Well here's what I have... I think this will h...   Jun 30 2011, 17:51
- - tropicalfish   Record with Audacity. Go to Normalize, and check O...   Jun 30 2011, 19:25
|- - db1989   QUOTE (tropicalfish @ Jun 30 2011, 19:25)...   Jun 30 2011, 19:43
|- - tropicalfish   QUOTE (db1989 @ Jun 30 2011, 13:43) QUOTE...   Jun 30 2011, 22:51
|- - db1989   QUOTE (tropicalfish @ Jun 30 2011, 22:51)...   Jul 1 2011, 13:25
- - tinpanalley   Perhaps I should have also stated that the way I r...   Jun 30 2011, 20:31
- - AndyH-ha   A recording made with proper equipment should not ...   Jun 30 2011, 20:51
|- - 2Bdecided   QUOTE (AndyH-ha @ Jun 30 2011, 20:51...   Jul 1 2011, 18:19
|- - musicollector   QUOTE (AndyH-ha @ Jun 30 2011, 12:51...   Nov 28 2011, 04:30
- - tinpanalley   Ok, how about if I just control that from the phon...   Jun 30 2011, 20:55
- - mixminus1   I'll second AndyH's advice on recording bo...   Jun 30 2011, 21:01
- - tinpanalley   I basically already do what you're suggesting ...   Jun 30 2011, 21:06
- - AndyH-ha   The gain is normally set to leave plenty of headro...   Jun 30 2011, 21:24
|- - tinpanalley   QUOTE (AndyH-ha @ Jun 30 2011, 16:24...   Jun 30 2011, 21:30
- - DVDdoug   QUOTE How do I know if my sound card can handle 32...   Jun 30 2011, 21:36
- - mixminus1   Audacity has the option to export to bit depths gr...   Jun 30 2011, 21:40
|- - tinpanalley   QUOTE (mixminus1 @ Jun 30 2011, 16:40) Of...   Jun 30 2011, 21:43
- - AndyH-ha   Audacity is FREEware. If may also be adequate for...   Jun 30 2011, 22:15
- - tinpanalley   Ok, I'm trying Sound Forge now. Aiming for -6d...   Jun 30 2011, 22:16
|- - mixminus1   QUOTE (tinpanalley @ Jun 30 2011, 14:16) ...   Jun 30 2011, 22:36
- - AndyH-ha   It may be true that most editors work in floating ...   Jun 30 2011, 22:25
- - tinpanalley   No, just that when I choose 32-bit (IEEE float) it...   Jun 30 2011, 22:39
- - tinpanalley   You see, that's what I thought.   Jun 30 2011, 23:05
- - tropicalfish   There are no 32-bit devices, so why use it? You mi...   Jun 30 2011, 23:22
|- - tinpanalley   QUOTE (tropicalfish @ Jun 30 2011, 18:22)...   Jun 30 2011, 23:52
- - tropicalfish   So you want to record in floating point, and then ...   Jul 1 2011, 01:15
- - tinpanalley   I don't really care how I record. I just wanna...   Jul 1 2011, 01:28
- - DVDdoug   QUOTE 1. What do you recommend I do with my settin...   Jul 1 2011, 01:53
- - tinpanalley   All the 24 and 32 bit stuff still has me really co...   Jul 1 2011, 04:08
|- - 2Bdecided   QUOTE (tinpanalley @ Jul 1 2011, 04:08) I...   Jul 1 2011, 18:25
|- - tinpanalley   Thanks for the wonderful feedback. Just wanted to ...   Jul 1 2011, 19:51
- - AndyH-ha   There exist a continuously varying analogue signal...   Jul 1 2011, 06:06
- - AndyH-ha   QUOTE Come on Andy - think that one through proper...   Jul 1 2011, 20:36
|- - DVDdoug   QUOTE (AndyH-ha @ Jul 1 2011, 12:36)...   Jul 1 2011, 22:12
|- - 2Bdecided   QUOTE (DVDdoug @ Jul 1 2011, 22:12) We...   Jul 4 2011, 12:34
- - DVDdoug   QUOTE It's the bits I don't get.OK, I...   Jul 1 2011, 21:46
- - AndyH-ha   My experience is based on CoolEdit Statistics repo...   Jul 4 2011, 20:32
|- - 2Bdecided   I think you may think I might be being clever than...   Jul 4 2011, 23:34
- - AndyH-ha   Perhaps I am just too ignorant of what is involved...   Jul 5 2011, 08:38
- - 2Bdecided   Vinyl is an intrinsically AC-coupled format. It ha...   Jul 5 2011, 14:08
- - pdq   Think of it this way. If there is a DC offset in t...   Jul 5 2011, 16:14
- - tinpanalley   Hey all, I've been absorbing everything you g...   Jul 6 2011, 22:37
- - DVDdoug   QUOTE - 32-bit IEEE Float? - 32-bit PCM? Floating ...   Jul 7 2011, 01:34
|- - tinpanalley   QUOTE (DVDdoug @ Jul 6 2011, 20:34) [b]Do...   Jul 7 2011, 05:06
|- - AndyH-ha   I'm curious about this inability to record in ...   Jul 7 2011, 09:31
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 7 2011, 04:31)...   Jul 7 2011, 17:56
- - tinpanalley   This is probably like asking if there is one way t...   Jul 7 2011, 18:37
- - AndyH-ha   There are many descriptions of the process publish...   Jul 7 2011, 19:20
|- - 2Bdecided   QUOTE (AndyH-ha @ Jul 7 2011, 19:20)...   Jul 8 2011, 12:01
|- - tinpanalley   QUOTE (2Bdecided @ Jul 8 2011, 07:01) The...   Jul 8 2011, 15:49
- - DVDdoug   QUOTE but is there any series of processes that ar...   Jul 7 2011, 20:36
- - tinpanalley   Here's a comparison of the 32-bit, higher gain...   Jul 7 2011, 21:04
- - tinpanalley   This sounds great to me as I'm hearing it even...   Jul 7 2011, 22:16
- - greynol   No you're not crazy, just know that 32 bits fo...   Jul 7 2011, 22:34
- - DVDdoug   QUOTE And normalising... if I get good levels on t...   Jul 7 2011, 23:38
|- - tinpanalley   Couple of things: QUOTE (DVDdoug @ Jul 7 201...   Jul 7 2011, 23:48
- - greynol   No, they aren't contradictory at all. DVDdoug...   Jul 8 2011, 00:03
- - tinpanalley   Ok, my bad. I misunderstood. I have some people te...   Jul 8 2011, 00:08
|- - greynol   QUOTE (tinpanalley @ Jul 7 2011, 16:08) I...   Jul 8 2011, 00:55
- - DVDdoug   QUOTE Then what is the difference to just doing a ...   Jul 8 2011, 00:39
|- - tinpanalley   QUOTE (DVDdoug @ Jul 7 2011, 19:39) But a...   Jul 8 2011, 01:57
- - AndyH-ha   The Sonic Foundry Noise Reduction plugin 2.0 has b...   Jul 8 2011, 02:46
- - greynol   I simply wanted to let you know that I respect tha...   Jul 8 2011, 02:53
- - AndyH-ha   I made an inquiry elsewhere. I got back that your ...   Jul 8 2011, 03:04
- - tinpanalley   Ohhh!!! Well, why didn't someone j...   Jul 8 2011, 07:34
- - AndyH-ha   Because Sound Forge has such an unusual approach (...   Jul 8 2011, 08:19
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 8 2011, 03:19)...   Jul 8 2011, 15:45
- - tinpanalley   This is the info from a download from the site (wh...   Jul 8 2011, 16:08
- - 2Bdecided   Nothing automatic there, just "manual click r...   Jul 8 2011, 20:30
- - DVDdoug   QUOTE Is Audacity totally a lame program? Vinyl ca...   Jul 8 2011, 20:32
- - AndyH-ha   I 've paid no attention to Audacity for some y...   Jul 8 2011, 20:36
|- - tinpanalley   QUOTE (AndyH-ha @ Jul 8 2011, 15:36)...   Jul 8 2011, 21:09
|- - greynol   Um, no, The Beatles were recorded to tape and the ...   Jul 8 2011, 21:16
|- - tinpanalley   QUOTE (greynol @ Jul 8 2011, 16:16) Um, n...   Jul 8 2011, 22:46
||- - greynol   Denying that vinyl was the most common medium back...   Jul 9 2011, 00:07
|- - 2Bdecided   QUOTE (greynol @ Jul 8 2011, 21:16) Um, n...   Jul 9 2011, 12:30
- - Juha   Couple questions: Would normalization be more sec...   Jul 9 2011, 09:31
- - AndyH-ha   What one gets by normalization is independent of t...   Jul 9 2011, 09:40
- - tinpanalley   If I'm going through a recording process with ...   Nov 12 2011, 23:24
|- - mjb2006   Why did you bump this thread? Your question has no...   Nov 13 2011, 00:20
||- - tinpanalley   QUOTE (mjb2006 @ Nov 12 2011, 19:20) Why ...   Nov 13 2011, 05:09
|- - botface   QUOTE (tinpanalley @ Nov 12 2011, 23:24) ...   Nov 13 2011, 10:24
|- - tinpanalley   QUOTE (botface @ Nov 13 2011, 05:24) by s...   Nov 13 2011, 22:24
|- - 2Bdecided   QUOTE (tinpanalley @ Nov 13 2011, 22:24) ...   Nov 15 2011, 11:23
- - AndyH-ha   It also depends on the channel balance. Some cartr...   Nov 15 2011, 11:36
|- - 2Bdecided   QUOTE (AndyH-ha @ Nov 15 2011, 11:36...   Nov 16 2011, 13:43
- - botface   Yes, I wasn't suggesting recording in mono as ...   Nov 15 2011, 17:27
RSS Lo-Fi Version Time is now: 28th April 2015 - 04:03
