Dynamic range question, Dynamic range of hearing vs. equipment
thesurfingalien
post Jun 8 2011, 01:16
Hi All,
I am having problems understanding the concept of dynamic range, and more specific how the dynamic range of human hearing relates to the dynamic range as specified for audio equipment.
What I have read on the Net is that the dynamic range of human hearing is, on average, 135 dB (the pain limit / threshold?).
I also understand that the dynamic range of a CD (16 bit) is limited to 96 dB, and for HD (24 bit) recordings 144 dB. This dynamic range is calculated by the bit-depth.
For playback of music (I use 44.1/16 flac only) I use a E-MU 1820 that has a dynamic range of about 115 dB (or so). I am not sure what my amp can do...
However, when I play music I hardly pass 80 dB (or so) listening volume, so the 96 dB CD data (if the recording makes full use of the range that is) gets "compressed", while the relative dynamic range remains.
After the long intro my question in essence is:
Does the human hearing have a similar "resolution" that is comparable to the resolution defined by the bit-depth in (digital) audio? Or am I just comparing apples and pears?
Regards,
Peter
thesurfingalien
post Jun 18 2011, 21:04
@All,
I am ashamed to tell that, although the discussion has been very informative, I hve not been able to distill an answer for my question from it.
Sticking to CD specs, the 16-bit signed integers (-32768 to 32767; 65536) in my mind represent the steps to map the analogue waveform to. Since CD specs also state a 96.### dB dynamic range, it seems logical to me that the same 65536 steps also have a relation to the dB scale.
I am sure that, if we would map a waveform into 4 bits and played that waveform back at 96 dB, everybody would hear it as a rather coarse sound, and if we would lover the sound to 15 dB (theoretically, not taking into account background noise ) that same coarseness would be significantly lower. At some point however, if we increase the number of bits in which the waveform is coded in, the coarseness disappears, and the sound gets smooth enough.
There must be research done by Philips / Sony that would prove the 16 bits coding / mapping and the 96 dB were good enough for CD playback.
Peter
This post has been edited by thesurfingalien: Jun 18 2011, 21:06
WernerO
post Jun 20 2011, 11:33
QUOTE (thesurfingalien @ Jun 18 2011, 21:04) *
You can give it a try yourself.
These are music excerpts reduced to an equivalent of 4 bits (or slightly more, IIRC).
Undithered:
http://www.audiochrome.net/clips/Venice_4b_nodither.mp3
Dithered:
http://www.audiochrome.net/clips/Venice_4b_dither.mp3
Noise-shaped:
http://www.audiochrome.net/clips/Venice_4b_noiseshapeE.mp3
And here are solo drums at 5 bit equivalent.
http://www.audiochrome.net/clips/drums_dither.html
dhromed
post Jun 20 2011, 20:34
QUOTE (WernerO @ Jun 20 2011, 12:33) *
I'm completely surprised at how good these clips sound.
Apart from the unlistenable noise, of course. I'd expected there to be nothing left.
Notat
post Jun 20 2011, 22:58
QUOTE (dhromed @ Jun 20 2011, 13:34) *
I'm completely surprised at how good these clips sound...I'd expected there to be nothing left.
We've only removed 3/4ths of the information. We know it's possible to remove much more than that through perceptual coding and still have happy ears.
This post has been edited by Notat: Jun 20 2011, 22:59
- thesurfingalien   Dynamic range question   Jun 8 2011, 01:16
- - Canar   QUOTE (thesurfingalien @ Jun 7 2011, 17:1...   Jun 8 2011, 01:44
- - pdq   ...and with proper dither the dynamic range of 16 ...   Jun 8 2011, 01:51
- - Woodinville   In most any modern room, the lower limit of maskin...   Jun 8 2011, 02:28
- - knutinh   Given that background noise can have all kinds of ...   Jun 8 2011, 09:20
|- - Woodinville   QUOTE (knutinh @ Jun 8 2011, 01:20) Given...   Jun 8 2011, 09:30
|- - knutinh   QUOTE (Woodinville @ Jun 8 2011, 10:30) Y...   Jun 8 2011, 10:15
|- - saratoga   QUOTE (knutinh @ Jun 8 2011, 05:15) QUOTE...   Jun 8 2011, 19:15
|- - Woodinville   QUOTE (saratoga @ Jun 8 2011, 11:15) The ...   Jun 8 2011, 19:38
|- - saratoga   QUOTE (Woodinville @ Jun 8 2011, 14:38) Q...   Jun 8 2011, 20:58
|- - Woodinville   QUOTE (saratoga @ Jun 8 2011, 12:58) QUOT...   Jun 9 2011, 02:02
|- - MichaelW   QUOTE (Woodinville @ Jun 9 2011, 13:02) A...   Jun 9 2011, 04:42
|- - WernerO   QUOTE (MichaelW @ Jun 9 2011, 04:42) when...   Jun 9 2011, 10:12
|- - thesurfingalien   QUOTE (MichaelW @ Jun 9 2011, 00:42) QUOT...   Jun 9 2011, 13:02
- - DonP   For listening to high dynamic range material (say,...   Jun 8 2011, 10:50
|- - knutinh   QUOTE (DonP @ Jun 8 2011, 11:50) For list...   Jun 8 2011, 11:19
- - thesurfingalien   @All: Thanks so far for your replies, but it...   Jun 8 2011, 12:29
|- - knutinh   QUOTE (thesurfingalien @ Jun 8 2011, 13:2...   Jun 8 2011, 13:37
|- - drewfx   QUOTE (thesurfingalien @ Jun 8 2011, 06:2...   Jun 8 2011, 17:05
- - [JAZ]   Like others have said, the key is knowing that tal...   Jun 8 2011, 19:04
|- - DonP   QUOTE ([JAZ] @ Jun 8 2011, 13:04)...   Jun 9 2011, 00:17
- - DVDdoug   QUOTE The second question is if there is any relat...   Jun 8 2011, 19:37
- - Northpack   I guess room noise usually has the least amount of...   Jun 8 2011, 20:15
|- - knutinh   QUOTE (Northpack @ Jun 8 2011, 21:15) I g...   Jun 8 2011, 20:49
- - greynol   Let's not forget dBu and dBV.   Jun 9 2011, 00:32
- - drewfx   And to further clarify the use of "dB" v...   Jun 9 2011, 02:17
- - knutinh   I seem to remember that people who record ambient ...   Jun 10 2011, 10:31
|- - Kees de Visser   Absolutely ! Last year I've spent quite so...   Jun 10 2011, 22:18
|- - Arnold B. Krueger   QUOTE (knutinh @ Jun 10 2011, 05:31) I se...   Jun 16 2011, 13:05
- - thesurfingalien   @All, Although all info was useful and interestin...   Jun 11 2011, 10:59
|- - lvqcl   QUOTE (thesurfingalien @ Jun 11 2011, 13...   Jun 11 2011, 11:11
||- - thesurfingalien   QUOTE (lvqcl @ Jun 11 2011, 07:11) QUOTE ...   Jun 11 2011, 14:11
||- - lvqcl   QUOTE (thesurfingalien @ Jun 11 2011, 17...   Jun 11 2011, 14:19
||- - thesurfingalien   QUOTE (lvqcl @ Jun 11 2011, 10:19) QUOTE ...   Jun 11 2011, 15:37
||- - lvqcl   QUOTE (thesurfingalien @ Jun 11 2011, 18...   Jun 11 2011, 18:34
||- - DonP   QUOTE (lvqcl @ Jun 11 2011, 12:34) QUOTE ...   Jun 11 2011, 19:21
|- - drewfx   QUOTE (thesurfingalien @ Jun 11 2011, 04...   Jun 11 2011, 17:33
|- - Notat   QUOTE (thesurfingalien @ Jun 11 2011, 03...   Jun 12 2011, 18:10
|- - dhromed   QUOTE (Northpack @ Jun 14 2011, 09:15) An...   Jun 14 2011, 11:01
- - dv1989   1 bit represents 6 dB of amplitude (i.e. a doublin...   Jun 11 2011, 17:37
|- - Brand   I must admit I have the same questions as the OP r...   Jun 12 2011, 22:11
|- - DonP   QUOTE (Brand @ Jun 12 2011, 16:11) I must...   Jun 12 2011, 22:38
|- - lvqcl   QUOTE (Brand @ Jun 13 2011, 01:11) I...   Jun 12 2011, 22:47
|- - Brand   QUOTE (lvqcl @ Jun 12 2011, 23:47) QUOTE ...   Jun 13 2011, 10:25
|- - lvqcl   QUOTE (Brand @ Jun 13 2011, 13:25) Is the...   Jun 13 2011, 10:51
|- - DonP   QUOTE (Brand @ Jun 13 2011, 04:25) QUOTE ...   Jun 13 2011, 12:13
|- - Soap   QUOTE (DonP @ Jun 13 2011, 07:13) I'm...   Jun 13 2011, 13:02
|- - Fedot L   QUOTE (Brand @ Jun 13 2011, 09:25) ...I t...   Jun 14 2011, 10:43
- - DVDdoug   QUOTE Given that (for CD) the 16 bit depth is limi...   Jun 13 2011, 21:52
- - Northpack   I think this relation 1bit to 6.02dB is where some...   Jun 14 2011, 08:15
|- - knutinh   QUOTE (Northpack @ Jun 14 2011, 09:15) I ...   Jun 14 2011, 09:13
|- - Northpack   QUOTE (knutinh @ Jun 14 2011, 09:13) Prop...   Jun 14 2011, 11:00
|- - knutinh   QUOTE (Northpack @ Jun 14 2011, 12:00) QU...   Jun 14 2011, 11:12
- - dc2bluelight   Very interesting discussion. I'd like to add ...   Jun 17 2011, 09:58
|- - Arnold B. Krueger   QUOTE (dc2bluelight @ Jun 17 2011, 04:58)...   Jun 17 2011, 14:20
- - pdq   Very nice first post. Thanks.   Jun 17 2011, 13:21
|- - Arnold B. Krueger   QUOTE (pdq @ Jun 17 2011, 08:21) Very nic...   Jun 17 2011, 14:02
|- - dc2bluelight   QUOTE (Arnold B. Krueger @ Jun 17 2011, 08...   Jun 18 2011, 00:53
|- - knutinh   QUOTE (dc2bluelight @ Jun 18 2011, 01:53)...   Jun 18 2011, 09:31
|- - Arnold B. Krueger   QUOTE (dc2bluelight @ Jun 17 2011, 19:53)...   Jun 18 2011, 18:58
|- - Notat   QUOTE (dc2bluelight @ Jun 17 2011, 17:53)...   Jun 19 2011, 01:21
- - dc2bluelight   Wow. You guys are tough here.   Jun 17 2011, 16:40
- - Woodinville   Just so it's clear, the 30dB number applies fo...   Jun 18 2011, 04:32
- - dc2bluelight   Yes, that clears it up. Critical band masking wou...   Jun 18 2011, 07:17
- - thesurfingalien   @All, I am ashamed to tell that, although the dis...   Jun 18 2011, 21:04
|- - knutinh   QUOTE (thesurfingalien @ Jun 18 2011, 22...   Jun 18 2011, 21:40
|- - lvqcl   QUOTE (thesurfingalien @ Jun 19 2011, 00...   Jun 18 2011, 21:45
|- - Arnold B. Krueger   QUOTE (thesurfingalien @ Jun 18 2011, 16...   Jun 19 2011, 11:44
|- - drewfx   QUOTE (thesurfingalien @ Jun 18 2011, 15...   Jun 19 2011, 18:56
|- - WernerO   QUOTE (thesurfingalien @ Jun 18 2011, 21...   Jun 20 2011, 11:33
|- - dhromed   QUOTE (WernerO @ Jun 20 2011, 12:33) You ...   Jun 20 2011, 20:34
||- - Notat   QUOTE (dhromed @ Jun 20 2011, 13:34) I...   Jun 20 2011, 22:58
|- - Woodinville   QUOTE (WernerO @ Jun 20 2011, 03:33) QUOT...   Jun 20 2011, 20:58
- - Wombat   QUOTE (Woodinville @ Jun 18 2011, 04:32) ...   Jun 19 2011, 00:55
|- - Woodinville   QUOTE (Wombat @ Jun 18 2011, 16:55) QUOTE...   Jun 20 2011, 02:43
- - Soap   I belive the problem thesurfingalien is having is ...   Jun 19 2011, 20:01
- - DigitalMan   @Soap - agree we've not given thesurfingalien ...   Jun 20 2011, 02:59
- - Soap   What I was going to say (please correct me where w...   Jun 20 2011, 03:45
- - DonP   This will probably add confusion to those already ...   Jun 20 2011, 14:48
|- - Woodinville   QUOTE (DonP @ Jun 20 2011, 06:48) This wi...   Jun 20 2011, 21:04
|- - DonP   QUOTE (Woodinville @ Jun 20 2011, 15:04) ...   Jun 21 2011, 02:18
|- - Woodinville   QUOTE (DonP @ Jun 20 2011, 18:18) QUOTE (...   Jun 21 2011, 03:49
|- - DonP   QUOTE (Woodinville @ Jun 20 2011, 21:49) ...   Jun 21 2011, 12:01
|- - Woodinville   QUOTE (DonP @ Jun 21 2011, 04:01) QUOTE (...   Jun 21 2011, 22:48
- - dhromed   QUOTE (DonP @ Jun 20 2011, 15:48) It turn...   Jun 20 2011, 20:41
- - Wombat   QUOTE (Woodinville @ Jun 20 2011, 02:43) ...   Jun 20 2011, 21:21
- - Woodinville   QUOTE (Wombat @ Jun 20 2011, 13:21) So pl...   Jun 20 2011, 22:02
RSS Lo-Fi Version Time is now: 31st July 2015 - 03:19
