TAK 2.2.0 - Alpha release
TBeck
post Jun 6 2011, 15:03
TAK Developer
Alpha release 1 of TAK 2.2.0 ((T)om's lossless (A)udio (K)ompressor)
It consists of:
- TAK Applications 2.2.0 Alpha 1 b in "\Applications".
- TAK Winamp plugin 2.2.0 Alpha 1 in "\WinAmp".
- TAK Decoding library 2.2.0 Alpha 1 in "\Deco_Lib".
The final release will additionally contain the SDK.
Download:
Download link removed. TAK 2.2.0 Final has been released.
What's new
This release brings support for multi-channel audio and speed optimizations for encoder and decoder.
New features:
- Support for multi-channel audio. While the stream format supports up to 16 channels, the codec currently is restricted to a maximum of 6 channels.
- Support for the "Wave Format Extensible" file format.
Improvements:
- Encoding speed improvements of up to 10 percent for my primary file set. Most of it is achieved by a modification of the algorithm which selects the optimal predictor order for each subframe. It will now often use less predictors than before, what may on average result in about 0.01 percent worse compression. You will only notice an speed advantage, if your files benefit from high predictor orders.
- Decoding speed improvements of up to 18 percent for my primary file set. Some of it is attributed to the above-noted modification of the encoder's predictor order selection algorithm. Therefore it will only take effect when decoding files encoded with this version and only, if they benefit from high predictor orders. Additionally SSSE3-instructions can be used for predictor counts of 32 and more. This affects the presets p3, p4 and sometimes p2, but only, if a particular file benefits from high predictor orders.
Known issues:
- If you use pipe decoding and the application reading the pipe is beeing terminated before the whole file has been read, TAKC may get into an endless loop and has to be manually killed with the task manager. I don't think this is a big issue but i will try to fix it in one of the next versions. BTW: Big thanks to shnutils for testing the pipe decoding!
- There seem to be some compatibility issues with pipe decoding to some other applications ("crc1632.exe" has been reported). I will try to fix it in the next release.
Alpha testing
This alpha release has already gone through extensive testing performed by my automatic scripts. Nevertheless there may be bugs left. Especially because i had to write a lot of new code for the support of multi-channel audio. This also involved a lot of minor modifications of the existing code. Therefore i would like you to verify the proper function of the codec: Compress -> Decompress -> Compare resulting wave with the original file, either by a binary compare or by the use MD5-check sums.
Certainly i am very interested into efficiency comparisons of the new multi-channel audio codec and other compressors.
Some remarks:
The most time consuming part of the new codec is it's channel decorrelation mechanism. The strongest presets sometimes check any possible channel combination. Principially you have n * (n - 1) (n = channel count) possible combinations, if you count "A predicts B" and "B predicts A" as two combinations.
Some figures:
2 channels -> 2 combinations
4 channels -> 12 combinations
5 channels -> 20 combinations
6 channels -> 30 combinations
8 channels -> 56 combinations
This rapid increase is the reason, why the codec currently is restricted to a maximum of 6 channels. I have to find and evaluate more heuristics for a fast estimation of optimal pairings which doesn't require a full evaluation of all possibilities.
Some are alreaday working. Most of them rely on the presence of a speaker assignment mask in the source wave file. If present, some faster presets will only test those combinations, which were most useful in my evaluations. A low frequency channel will never be evaluated.
But this only works, if the speaker assignment is known. Therefore the encoding time of the same audio data may differ considerably dependent on the presence of a speaker mask in the original wave file.
Im my evaluations the new codec often did beat Mpeg4Als -7 compressionwise, if a particular file provided good opportunities for channel decorrelation. Unfortunately for some files there are zero opportunities. My test corpus is still too small to make any generalized statement regarding the new codecs efficiency.
Therefore i am very interested into compression results and comparisons with other codecs.
Thanks for testing and have fun
Thomas
This post has been edited by TBeck: Jul 10 2011, 23:53
RastaMan
post Jun 16 2011, 09:56
Tested TAK 2.2.0 Alpha on an HDCD album "Sara Evans - Stronger (2011)" [Peak extension disabled]
Original album size [compressed using Monkey's Audio High (-c3000)]
256 MB
Size of album after decompressing to 24-bit WAV, then compressed with TAK 2.2.0 Alpha (-p4m)
255 MB
Nice to know that you could listen to this type of HDCD album in foobar2000 without having to use the HDCD plugin, save 1 MB an album in the process, and also use ReplayGain with the TAK files as well.
MD5 - CRC Comparison:
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\01. Desperately.tak"
MD5: EA41B8E89DCF097D78D6F7F7A52F9CC4
CRC32: 99BB3CD7
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\01. Desperately.wav"
CRC32: 99BB3CD7
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\02. A Little Bit Stronger.tak"
MD5: F323EB8CC18FA1467A08BD966948A702
CRC32: 5D6CB218
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\02. A Little Bit Stronger.wav"
CRC32: 5D6CB218
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\03. My Heart Can't Tell You No.tak"
MD5: EFBDB2BA5D2CF4090CBBC52CB859BE60
CRC32: FF639028
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\03. My Heart Can't Tell You No.wav"
CRC32: FF639028
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\04. Anywhere.tak"
MD5: 486998CCBB67C144CE6786019371E036
CRC32: CD82EF1D
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\04. Anywhere.wav"
CRC32: CD82EF1D
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\05. Alone.tak"
MD5: 243DE8364D81FFC8FE33107273E65863
CRC32: B7F53113
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\05. Alone.wav"
CRC32: B7F53113
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\06. Ticket To Ride.tak"
MD5: C45F19A945CB72CCA8B81150851A932A
CRC32: 76B7E44F
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\06. Ticket To Ride.wav"
CRC32: 76B7E44F
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\07. Life Without Losing.tak"
MD5: B0526DE645D9B10EC1D2B63D1F6DBB3B
CRC32: 3A2723C1
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\07. Life Without Losing.wav"
CRC32: 3A2723C1
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\08. What That Drink Cost Me.tak"
MD5: B9E747A5210E29796CAF720035DF2809
CRC32: A5D464CE
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\08. What That Drink Cost Me.wav"
CRC32: A5D464CE
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\09. Wildfire.tak"
MD5: 045DAAC28BA8FBF5B6F06D84D2C42C5A
CRC32: 5739ECFE
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\09. Wildfire.wav"
CRC32: 5739ECFE
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\10. Born To Fly (Bluegrass Version).tak"
MD5: 1563D1F2FB08BAE898CDC1B3B3EDCE47
CRC32: 75AFC5AC
No problems found.
Item: "C:\Documents and Settings\Default User\My Documents\My Music\Sara Evans\2011 - Stronger (HDCD)\10. Born To Fly (Bluegrass Version).wav"
CRC32: 75AFC5AC
No problems found.
All items decoded successfully.
Bit Comparison:
CRC32: 99BB3CD7
No problems found.
CRC32: 99BB3CD7
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: FF639028
No problems found.
CRC32: FF639028
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: B7F53113
No problems found.
CRC32: B7F53113
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 75AFC5AC
No problems found.
CRC32: 75AFC5AC
No problems found.
Ran another test on another HDCD album "Carly Simon - Boys In The Trees (1978)' [Peak extension enabled] This time, though, I decompressed the original album into 24-bit WavPack files (Extra High) and compared it to TAK 2.2.0 Alpha to see how it handled block size
WavPack (Extra High)
254 MB
231 MB
That's a 23 MB difference in file size (in TAK 2.2.0 Alpha's favor)
CRC32: 99BB3CD7
No problems found.
CRC32: 99BB3CD7
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: FF639028
No problems found.
CRC32: FF639028
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: B7F53113
No problems found.
CRC32: B7F53113
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 75AFC5AC
No problems found.
CRC32: 75AFC5AC
No problems found.
Bit Comparison:
CRC32: 99BB3CD7
No problems found.
CRC32: 99BB3CD7
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: 5D6CB218
No problems found.
CRC32: FF639028
No problems found.
CRC32: FF639028
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: CD82EF1D
No problems found.
CRC32: B7F53113
No problems found.
CRC32: B7F53113
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 76B7E44F
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: 3A2723C1
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: A5D464CE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 5739ECFE
No problems found.
CRC32: 75AFC5AC
No problems found.
CRC32: 75AFC5AC
No problems found.
- TBeck   TAK 2.2.0 - Alpha release   Jun 6 2011, 15:03
- - _mē_   I get "Wave file not supported" on all f...   Jun 6 2011, 17:17
|- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 18:17) I get ...   Jun 6 2011, 17:31
- - lvqcl   QUOTE Hm, works for me. Works here too.   Jun 6 2011, 17:52
- - TBeck   Although there is no hint, i just looked at my wav...   Jun 6 2011, 17:54
- - _mē_   The file was created with sox. I just tried Tak in...   Jun 6 2011, 18:06
|- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 19:06) The file...   Jun 6 2011, 18:14
- - lvqcl   QUOTE The file was created with sox. What version?...   Jun 6 2011, 18:09
- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 19:06) I can on...   Jun 6 2011, 18:28
- - lvqcl   I decoded d2.flac to 2 wav files with SoX 14.3.1 a...   Jun 6 2011, 18:40
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 19:40) I decod...   Jun 6 2011, 18:57
- - lvqcl   --   Jun 6 2011, 19:09
- - TBeck   QUOTE (TBeck @ Jun 6 2011, 19:57) QUOTE (...   Jun 6 2011, 19:10
- - _mē_   Sorry, my bad, seems to be a flake bug, the flac d...   Jun 6 2011, 19:13
- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 20:13) Sorry, m...   Jun 6 2011, 19:34
- - lvqcl   From SoX changelog: "Fix bug where FACT chu...   Jun 6 2011, 19:51
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 20:51) From So...   Jun 6 2011, 20:00
- - [JAZ]   Indeed, that last check shouldn't be made. Mi...   Jun 6 2011, 20:05
|- - TBeck   QUOTE ([JAZ] @ Jun 6 2011, 21:05)...   Jun 6 2011, 20:14
- - lvqcl   QUOTE Read up to chunk size, and if you are not at...   Jun 6 2011, 20:11
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 21:11) QUOTE R...   Jun 6 2011, 20:16
- - Destroid   I managed to finish a preview of a TAK benchmark d...   Jun 7 2011, 00:18
- - lvqcl   QUOTE Anyone give me hint at fixing this (possibly...   Jun 7 2011, 01:27
|- - TBeck   QUOTE (lvqcl @ Jun 7 2011, 02:27) takc.ex...   Jun 7 2011, 03:13
|- - lvqcl   QUOTE (TBeck @ Jun 7 2011, 06:13) Good id...   Jun 7 2011, 13:02
|- - TBeck   QUOTE (lvqcl @ Jun 7 2011, 14:02) What ca...   Jun 7 2011, 14:54
|- - Destroid   QUOTE (TBeck @ Jun 7 2011, 13:54) QUOTE (...   Jun 14 2011, 03:12
|- - TBeck   QUOTE (Destroid @ Jun 14 2011, 04:12) I a...   Jun 14 2011, 17:08
|- - bryant   QUOTE (TBeck @ Jun 14 2011, 09:08) Maybe ...   Jun 14 2011, 21:07
|- - Destroid   QUOTE (bryant @ Jun 14 2011, 20:07) QUOTE...   Jun 16 2011, 10:48
- - TBeck   QUOTE (Destroid @ Jun 7 2011, 01:18) I ma...   Jun 7 2011, 02:57
|- - Destroid   QUOTE (TBeck @ Jun 7 2011, 01:57) Well, a...   Jun 7 2011, 07:40
- - Destroid   Didn't have doubt about data integrity of TAK,...   Jun 7 2011, 18:47
- - Destroid   And here's some test results Not sure exactly...   Jun 8 2011, 03:18
- - TBeck   QUOTE (Destroid @ Jun 7 2011, 19:47) Didn...   Jun 8 2011, 17:07
- - Destroid   The -p4m results: CODE6ch 48KHz 16bit TAK 2.2.0...   Jun 8 2011, 18:32
|- - TBeck   QUOTE (Destroid @ Jun 8 2011, 19:32) The ...   Jun 8 2011, 18:48
|- - Destroid   QUOTE (TBeck @ Jun 8 2011, 17:48) Ok, nev...   Jun 8 2011, 20:04
- - RastaMan   Tested TAK 2.2.0 Alpha on an HDCD album "Sara...   Jun 16 2011, 09:56
|- - bryant   QUOTE (RastaMan @ Jun 16 2011, 01:56) Ran...   Jun 17 2011, 07:17
- - TBeck   QUOTE (bryant @ Jun 14 2011, 22:07) Maybe...   Jun 16 2011, 23:18
- - RastaMan   The original tests were run using the highest comp...   Jun 17 2011, 13:34
- - Ljubo44   Any chance to play tak format with windows media p...   Jun 17 2011, 15:48
- - lvqcl   Ljubo44: http://liviocavallo.altervista.org/   Jun 17 2011, 15:51
- - Ljubo44   Tired before, installed from C:/Temp from bat as a...   Jun 18 2011, 02:13
- - TBeck   I want to prepare a final release. Therefore, if ...   Jun 30 2011, 21:11
|- - Destroid   QUOTE (TBeck @ Jun 30 2011, 20:11) Theref...   Jul 3 2011, 00:05
- - Manlord   I dont have any multichannel file, but if any test...   Jun 30 2011, 21:34
- - CoRoNe   *bump* QUOTE (http://www.hydrogenaudio.org/forums/...   Jul 2 2011, 21:42
- - TBeck   QUOTE (Manlord @ Jun 30 2011, 22:34) I do...   Jul 5 2011, 20:57
- - TBeck   TAK 2.2.0 Final has been released.   Jul 10 2011, 23:55
- - Steve Forte Rio   surprisingly! Very good news! Thank you...   Jul 11 2011, 11:32
- - CoRoNe   QUOTE (TBeck @ Jun 6 2011, 16:03) Therefo...   Jul 11 2011, 20:28
|- - TBeck   QUOTE (CoRoNe @ Jul 11 2011, 21:28) I hav...   Jul 13 2011, 02:50
|- - CoRoNe   QUOTE (TBeck @ Jul 13 2011, 03:50) Strang...   Jul 13 2011, 17:28
|- - TBeck   Thank you for the info! I will look into it fo...   Jul 13 2011, 17:40
- - _mē_   Updated my test with TTA, WavPack, TAK. Generally,...   Jul 12 2011, 10:21
- - TBeck   QUOTE (_mē_ @ Jul 12 2011, 11:21) Updated...   Jul 13 2011, 02:37
- - _mē_   QUOTE (TBeck @ Jul 13 2011, 03:37) QUOTE ...   Jul 13 2011, 08:21
RSS Lo-Fi Version Time is now: 30th May 2015 - 12:37
