TAK 2.2.0 - Alpha release
TBeck
post Jun 6 2011, 15:03
TAK Developer
Alpha release 1 of TAK 2.2.0 ((T)om's lossless (A)udio (K)ompressor)
It consists of:
- TAK Applications 2.2.0 Alpha 1 b in "\Applications".
- TAK Winamp plugin 2.2.0 Alpha 1 in "\WinAmp".
- TAK Decoding library 2.2.0 Alpha 1 in "\Deco_Lib".
The final release will additionally contain the SDK.
Download:
Download link removed. TAK 2.2.0 Final has been released.
What's new
This release brings support for multi-channel audio and speed optimizations for encoder and decoder.
New features:
- Support for multi-channel audio. While the stream format supports up to 16 channels, the codec currently is restricted to a maximum of 6 channels.
- Support for the "Wave Format Extensible" file format.
Improvements:
- Encoding speed improvements of up to 10 percent for my primary file set. Most of it is achieved by a modification of the algorithm which selects the optimal predictor order for each subframe. It will now often use less predictors than before, what may on average result in about 0.01 percent worse compression. You will only notice an speed advantage, if your files benefit from high predictor orders.
- Decoding speed improvements of up to 18 percent for my primary file set. Some of it is attributed to the above-noted modification of the encoder's predictor order selection algorithm. Therefore it will only take effect when decoding files encoded with this version and only, if they benefit from high predictor orders. Additionally SSSE3-instructions can be used for predictor counts of 32 and more. This affects the presets p3, p4 and sometimes p2, but only, if a particular file benefits from high predictor orders.
Known issues:
- If you use pipe decoding and the application reading the pipe is beeing terminated before the whole file has been read, TAKC may get into an endless loop and has to be manually killed with the task manager. I don't think this is a big issue but i will try to fix it in one of the next versions. BTW: Big thanks to shnutils for testing the pipe decoding!
- There seem to be some compatibility issues with pipe decoding to some other applications ("crc1632.exe" has been reported). I will try to fix it in the next release.
Alpha testing
This alpha release has already gone through extensive testing performed by my automatic scripts. Nevertheless there may be bugs left. Especially because i had to write a lot of new code for the support of multi-channel audio. This also involved a lot of minor modifications of the existing code. Therefore i would like you to verify the proper function of the codec: Compress -> Decompress -> Compare resulting wave with the original file, either by a binary compare or by the use MD5-check sums.
Certainly i am very interested into efficiency comparisons of the new multi-channel audio codec and other compressors.
Some remarks:
The most time consuming part of the new codec is it's channel decorrelation mechanism. The strongest presets sometimes check any possible channel combination. Principially you have n * (n - 1) (n = channel count) possible combinations, if you count "A predicts B" and "B predicts A" as two combinations.
Some figures:
2 channels -> 2 combinations
4 channels -> 12 combinations
5 channels -> 20 combinations
6 channels -> 30 combinations
8 channels -> 56 combinations
This rapid increase is the reason, why the codec currently is restricted to a maximum of 6 channels. I have to find and evaluate more heuristics for a fast estimation of optimal pairings which doesn't require a full evaluation of all possibilities.
Some are alreaday working. Most of them rely on the presence of a speaker assignment mask in the source wave file. If present, some faster presets will only test those combinations, which were most useful in my evaluations. A low frequency channel will never be evaluated.
But this only works, if the speaker assignment is known. Therefore the encoding time of the same audio data may differ considerably dependent on the presence of a speaker mask in the original wave file.
Im my evaluations the new codec often did beat Mpeg4Als -7 compressionwise, if a particular file provided good opportunities for channel decorrelation. Unfortunately for some files there are zero opportunities. My test corpus is still too small to make any generalized statement regarding the new codecs efficiency.
Therefore i am very interested into compression results and comparisons with other codecs.
Thanks for testing and have fun
Thomas
This post has been edited by TBeck: Jul 10 2011, 23:53
_mē_
post Jul 12 2011, 10:21
Updated my test with TTA, WavPack, TAK.
Generally, TAK looses to ALS, but is rocket fast.
I haven't decided which one do I want to use yet...Really, I expected TAK to do better.
http://www.hydrogenaudio.org/forums/index....showtopic=89649
- TBeck   TAK 2.2.0 - Alpha release   Jun 6 2011, 15:03
- - _mē_   I get "Wave file not supported" on all f...   Jun 6 2011, 17:17
|- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 18:17) I get ...   Jun 6 2011, 17:31
- - lvqcl   QUOTE Hm, works for me. Works here too.   Jun 6 2011, 17:52
- - TBeck   Although there is no hint, i just looked at my wav...   Jun 6 2011, 17:54
- - _mē_   The file was created with sox. I just tried Tak in...   Jun 6 2011, 18:06
|- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 19:06) The file...   Jun 6 2011, 18:14
- - lvqcl   QUOTE The file was created with sox. What version?...   Jun 6 2011, 18:09
- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 19:06) I can on...   Jun 6 2011, 18:28
- - lvqcl   I decoded d2.flac to 2 wav files with SoX 14.3.1 a...   Jun 6 2011, 18:40
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 19:40) I decod...   Jun 6 2011, 18:57
- - lvqcl   --   Jun 6 2011, 19:09
- - TBeck   QUOTE (TBeck @ Jun 6 2011, 19:57) QUOTE (...   Jun 6 2011, 19:10
- - _mē_   Sorry, my bad, seems to be a flake bug, the flac d...   Jun 6 2011, 19:13
- - TBeck   QUOTE (_mē_ @ Jun 6 2011, 20:13) Sorry, m...   Jun 6 2011, 19:34
- - lvqcl   From SoX changelog: "Fix bug where FACT chu...   Jun 6 2011, 19:51
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 20:51) From So...   Jun 6 2011, 20:00
- - [JAZ]   Indeed, that last check shouldn't be made. Mi...   Jun 6 2011, 20:05
|- - TBeck   QUOTE ([JAZ] @ Jun 6 2011, 21:05)...   Jun 6 2011, 20:14
- - lvqcl   QUOTE Read up to chunk size, and if you are not at...   Jun 6 2011, 20:11
|- - TBeck   QUOTE (lvqcl @ Jun 6 2011, 21:11) QUOTE R...   Jun 6 2011, 20:16
- - Destroid   I managed to finish a preview of a TAK benchmark d...   Jun 7 2011, 00:18
- - lvqcl   QUOTE Anyone give me hint at fixing this (possibly...   Jun 7 2011, 01:27
|- - TBeck   QUOTE (lvqcl @ Jun 7 2011, 02:27) takc.ex...   Jun 7 2011, 03:13
|- - lvqcl   QUOTE (TBeck @ Jun 7 2011, 06:13) Good id...   Jun 7 2011, 13:02
|- - TBeck   QUOTE (lvqcl @ Jun 7 2011, 14:02) What ca...   Jun 7 2011, 14:54
|- - Destroid   QUOTE (TBeck @ Jun 7 2011, 13:54) QUOTE (...   Jun 14 2011, 03:12
|- - TBeck   QUOTE (Destroid @ Jun 14 2011, 04:12) I a...   Jun 14 2011, 17:08
|- - bryant   QUOTE (TBeck @ Jun 14 2011, 09:08) Maybe ...   Jun 14 2011, 21:07
|- - Destroid   QUOTE (bryant @ Jun 14 2011, 20:07) QUOTE...   Jun 16 2011, 10:48
- - TBeck   QUOTE (Destroid @ Jun 7 2011, 01:18) I ma...   Jun 7 2011, 02:57
|- - Destroid   QUOTE (TBeck @ Jun 7 2011, 01:57) Well, a...   Jun 7 2011, 07:40
- - Destroid   Didn't have doubt about data integrity of TAK,...   Jun 7 2011, 18:47
- - Destroid   And here's some test results Not sure exactly...   Jun 8 2011, 03:18
- - TBeck   QUOTE (Destroid @ Jun 7 2011, 19:47) Didn...   Jun 8 2011, 17:07
- - Destroid   The -p4m results: CODE6ch 48KHz 16bit TAK 2.2.0...   Jun 8 2011, 18:32
|- - TBeck   QUOTE (Destroid @ Jun 8 2011, 19:32) The ...   Jun 8 2011, 18:48
|- - Destroid   QUOTE (TBeck @ Jun 8 2011, 17:48) Ok, nev...   Jun 8 2011, 20:04
- - RastaMan   Tested TAK 2.2.0 Alpha on an HDCD album "Sara...   Jun 16 2011, 09:56
|- - bryant   QUOTE (RastaMan @ Jun 16 2011, 01:56) Ran...   Jun 17 2011, 07:17
- - TBeck   QUOTE (bryant @ Jun 14 2011, 22:07) Maybe...   Jun 16 2011, 23:18
- - RastaMan   The original tests were run using the highest comp...   Jun 17 2011, 13:34
- - Ljubo44   Any chance to play tak format with windows media p...   Jun 17 2011, 15:48
- - lvqcl   Ljubo44: http://liviocavallo.altervista.org/   Jun 17 2011, 15:51
- - Ljubo44   Tired before, installed from C:/Temp from bat as a...   Jun 18 2011, 02:13
- - TBeck   I want to prepare a final release. Therefore, if ...   Jun 30 2011, 21:11
|- - Destroid   QUOTE (TBeck @ Jun 30 2011, 20:11) Theref...   Jul 3 2011, 00:05
- - Manlord   I dont have any multichannel file, but if any test...   Jun 30 2011, 21:34
- - CoRoNe   *bump* QUOTE (http://www.hydrogenaudio.org/forums/...   Jul 2 2011, 21:42
- - TBeck   QUOTE (Manlord @ Jun 30 2011, 22:34) I do...   Jul 5 2011, 20:57
- - TBeck   TAK 2.2.0 Final has been released.   Jul 10 2011, 23:55
- - Steve Forte Rio   surprisingly! Very good news! Thank you...   Jul 11 2011, 11:32
- - CoRoNe   QUOTE (TBeck @ Jun 6 2011, 16:03) Therefo...   Jul 11 2011, 20:28
|- - TBeck   QUOTE (CoRoNe @ Jul 11 2011, 21:28) I hav...   Jul 13 2011, 02:50
|- - CoRoNe   QUOTE (TBeck @ Jul 13 2011, 03:50) Strang...   Jul 13 2011, 17:28
|- - TBeck   Thank you for the info! I will look into it fo...   Jul 13 2011, 17:40
- - _mē_   Updated my test with TTA, WavPack, TAK. Generally,...   Jul 12 2011, 10:21
- - TBeck   QUOTE (_mē_ @ Jul 12 2011, 11:21) Updated...   Jul 13 2011, 02:37
- - _mē_   QUOTE (TBeck @ Jul 13 2011, 03:37) QUOTE ...   Jul 13 2011, 08:21
RSS Lo-Fi Version Time is now: 6th May 2015 - 15:52
