2 Pages V   1 2 >
foo_seek.dll, Component
grimes
post May 16 2011, 09:29
Seek
foo_seek.dll
Works with CUI/DUI
actual version: 1.2
Features:
  • Preview - Listen to parts of consecutive tracks
  • Loop - Repeat part of current track
  • Rewind - Monitor during seek
  • Fast Forward - Monitor during seek
Mainmenu commands:
Menu | Playback | Seek Control | Preview length (6s-20s, Default)
Menu | Playback | Seek Control | Loop length (6s-20s, Default, End point mode, Set end point, Remove end point)
Menu | Playback | Seek Control | Preview (ON/OFF)
Menu | Playback | Seek Control | Loop (ON/OFF)
Menu | Playback | Seek Control | Rewind (5s-30s) (ON/OFF)
Menu | Playback | Seek Control | Fast Forward (5s-30s) (ON/OFF)
Advanced Preferences:
Preferences | Advanced | Playback | Seek | Automatic start/stop (ON/OFF)
Preferences | Advanced | Playback | Seek | FF/RW | FF/RW playback time [ms]
Preferences | Advanced | Playback | Seek | Loop | Loop length [ms]
Preferences | Advanced | Playback | Seek | Loop | Playback position loop [s]
Preferences | Advanced | Playback | Seek | Loop | Reset next track to playback position loop (ON/OFF)
Preferences | Advanced | Playback | Seek | Preview | Playback position preview [s]
Preferences | Advanced | Playback | Seek | Preview | Preview length [ms]
Preferences | Advanced | Playback | Seek | Preview | Reset next track to playback position preview (ON/OFF)
Preferences | Advanced | Playback | Seek | Preview | Skip shorter tracks in preview (ON/OFF)
This post has been edited by grimes: Sep 12 2014, 11:37
grimes
post May 19 2011, 21:41
Seek 0.2
FIX: "Playback position" bug
FIX: Various bugs
CHG: Commands moved to submenu "Seek Control"
grimes
post May 20 2011, 09:17
Seek 0.3
FIX: Various bugs
This post has been edited by grimes: May 20 2011, 09:19
grimes
post May 20 2011, 13:31
Seek 0.4
FIX: foobar2000 restart
CHG: individual Playback position variables for "preview" and "loop"
grimes
post May 21 2011, 10:02
Seek 0.5
FIX: Wrong preview playback position when position is greater than track length
CHG: 5x-60x -> 5s-30s
CHG: Default FF/RW playback time set to 2s (2000ms)
grimes
post May 22 2011, 15:37
Seek 0.6
ADD: Advanced Preferences option: Reset new track to playback position preview (for "Preview" only) (ON/OFF)
ADD: Advanced Preferences option: Automatic start/stop (ON/OFF)
This post has been edited by grimes: May 22 2011, 15:45
grimes
post May 25 2011, 16:52
Seek 0.7
ADD: Advanced Preferences | Playback | Seek | Skip shorter tracks in preview (ON/OFF)
(OFF(Default): playing the end of shorter tracks)
grimes
post Jun 1 2011, 17:23
Seek 0.8
FIX: Loop at end of track
ADD: Preferences | Advanced | Playback | Seek | Loop | Reset next track to playback position loop (ON/OFF)
ADD: Menu | Playback | Seek Control | Preview length (6s-20s) (ON/OFF)
ADD: Menu | Playback | Seek Control | Loop length (6s-20s) (ON/OFF)
CHG: reorganisation of Advanced Preferences entries
This post has been edited by grimes: Jun 1 2011, 17:24
grimes
post Jun 4 2011, 11:43
Seek 0.9
CHG: Preview stops now, if "stop after current" was enabled
CHG: Preview/Loop length radiobuttons
ADD: "Default" command for Preview/Loop length. "Default" takes value from Advanced Preferences "Preview/Loop length [ms]"
grimes
post Jul 23 2011, 13:41
Seek 1.0
ADD: New mode to set loop length manually:
commands
  • End point mode
  • Set end point
  • Remove end point
usage
  1. Enable end point mode
  2. Start loop
  3. Seek to start position of loop in seekbar
  4. wait
  5. Set end point of loop (with shortcut)
--> endless loop between start and end point
download: see first post
This post has been edited by grimes: Jan 29 2012, 06:18
JonSlaughter
post Jan 17 2012, 07:49
Great concept. I was looking for something just like this for foobar as I generally have to open up some other program to do it.
The main issues is that the "usage" is not user friendly/convenient. Is it not possible to assign hot keys to assign the loop endpoints and some hot key to toggle the loop playing????
grimes
post Jan 17 2012, 12:05
Every menu item could be assigned.
Maybe your keyboard shortcut conflicts with another one?
This post has been edited by grimes: Jan 17 2012, 12:08
spockman
post Jan 27 2012, 00:30
Group: Members (Donating)
Is it possible with this component to loop a 30 second (or 10 or 20 or whatever seconds) section in the middle of a song?
If so, how do I set the start and end points?
Regards,
Spockman.
grimes
post Jan 27 2012, 11:36
loop length is predefined for 6,8,10,12,14,16,18,20 seconds.
Other values can be set in Advanced Preferences.
Alternatively set endpoint mode, seek to start point in seekbar manually, wait for x seconds and set end point by shortcut.
grimes
post Jan 27 2012, 15:12
Post #15
an example for first mode:
  1. Enable loop length 6s
  2. Enable "loop" (by shortcut)
  3. Seek to a start point in seekbar
tums16
post Feb 1 2012, 07:01
Post #16
thank
Speech
post Aug 6 2012, 17:29
Post #17
Is it possible to skip a part of an audio file, such as the first x seconds and the last y seconds? My podcasts contain advertisements at the beginning and at the end, but obviously they don't have the same length, so I can fix a specific moment when to skip only relative to the audio length minus y seconds.
Mon blog: http://piratefurieux.wordpress.com
grimes
post Aug 7 2012, 07:13
Post #18
Not possible with foo_seek.
Why do you not split the audio files in (three) parts.
You can hear this way only the middle part.
On the other hand, foobar2000 is able to play the three files without gap.
q-stankovic
post Aug 7 2012, 16:44
Post #19
foo_skip will allow to cut out a begiining and ending part out of a track.
booya
post Dec 28 2012, 17:05
Post #20
I'm sorry, but I really don't understand fully how to use this loop option.
For example, I need to loop one track between 48 min and 59 min 45 sec. What should i do?
Start loop
wait
(for what?)
Is that possible to select a time w/o waiting? I want to open Foobar2000, start selected track, immediately select required time/segment and then I need to minimize application and forget about it. And if yes, what time in advanced option should I set (and whether I should do it)?
I tried but did not achieve the desired outcome.
This post has been edited by booya: Dec 28 2012, 17:07
grimes
post Dec 28 2012, 18:56
Post #21
seek to 48 min and wait 11:45 and set end point.
It is an unusual long time for a loop, so this is not practicable.
Unusual loop length can be set in the advanced preferences
  • set default in main menu
  • advanced preferences: loop length 705000 ms
  • advanced preferences: playback position 2880 s
  • set loop in main menu
  • play
EpicForever
post May 28 2013, 22:22
Post #22
This plugin needs serious documentation, there are several things that I don't understand.
1. What is "automatic start/stop" in advanced preferences?
2. Why this plugin doesn't work for tracks played from results of Media Library Search?
3. Why "Loop/reset next track to loop position" doesn't work as it should? I can't understand the dependency - sometimes all tracks are starting form time given in advanced preferences even if this ckeckbox is unchecked, sometimes thety don't even if it's checked.
grimes
post May 29 2013, 08:32
Post #23
1. automatic start/stop: The loop starts with one click on main menu entry "loop" (otherwise two clicks: loop + play) (minor important option)
2. Can't reproduce.
3. I don't understand. Did you seek to another position and it is not reseted to advanced preferences value next cycle? Strange! Can't reproduce.
dfkt
post Mar 5 2014, 17:01
Post #24
I'm probably misunderstanding the functionality of this component - but would it be possible with it to simply emulate the FFWD/REW behavior of a CD player or portable MP3 player? I.e. long-press/press&hold keyboard buttons for FFWD/REW, and resume normal playback when releasing buttons?
So far my trials & errors didn't yield any results in that direction.
mikk
post Apr 22 2014, 21:15
Post #25
Hi!
Thanks for this component!
I have small problem with loop function A-B
I create shortcout, F11-Loop F12-Set End point
End Point mode enabled manually.
Play audio... if I want start point I press F11... and when I want end point, I press F12. After this, the A-B loop is work.
But, the problem, If I press pause under A-B loop, this is can't works really, because after few times the play is start himself again...
Sorry my poor english.
ps.: my foobar is latest, 1.3.2
This post has been edited by mikk: Apr 22 2014, 21:18
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th July 2015 - 11:36
