foo_dsp_xgeq, Graphic Equalizer
xnor
post May 7 2011, 23:15
Heya,
here's another creation of mine, a graphic equalizer.
As of the current version it features:
  • 31 bands (1/3rd octave width)
  • boost/cut range of +-12 dB in .1 dB steps
  • master gain (can be set manually or automatically => prevents clipping for the most part)
  • minimum phase (=> no pre-echo)
  • approximates a smooth frequency response (=> no 'steps' between the bands)
  • import/export presets
  • mono and stereo mode
Since this is my first fb2k plugin that's a bit more complex this plugin should be considered experimental, use it at your own risk.
Please let me know if you encounter any bugs, thanks.
Download
Usage
1) Install the downloaded zip file using the Components preferences page.
2) Add "Graphic Equalizer" to the list of active DSPs (Playback - DSP Manager preferences page).
3) Configure it.
Screenshot:
Example frequency response in green (compared to built-in EQ in red):
Note that the boost in the lowest octaves isn't possible with the built-in EQ.
This post has been edited by xnor: Jan 24 2012, 15:56
Sighted evaluation without blind testing is blind.
SASN
post May 20 2011, 19:17
From the "components" section, I installed the EQ from some folder where the dll was located. I though maybe I had to apply some admin right for this to work but apparantly that was not necessary.
I did not know about the DSP part, no wonder I could not make it work. Since I intend to rarely change the EQ it is not a bother to have to go into the preferences.
Edit: Ah, I now see that the master gain thing work automatically, by correcting for adjustment values above 0db. Nice! I guess that is to prevent adding any extra gain that might perhaps damage the speakers.
This post has been edited by SASN: May 20 2011, 19:21
- xnor   foo_dsp_xgeq   May 7 2011, 23:15
- - mudlord   Does this use the Shibatch EQ?   May 8 2011, 06:08
|- - xnor   QUOTE (mudlord @ May 8 2011, 07:08) Does ...   May 8 2011, 11:04
- - romor   Thanks, so many users lamented over this missing c...   May 8 2011, 08:53
- - romor   QUOTE (xnor @ May 8 2011, 00:15) Resultin...   May 8 2011, 17:56
|- - xnor   QUOTE (romor @ May 8 2011, 18:56) Would i...   May 8 2011, 18:41
- - romor   None, it's just too perfect Same as you, I no...   May 8 2011, 20:56
- - lvqcl   "Save/load preset" buttons (as in built-...   May 8 2011, 21:08
- - Yegor   QUOTE option to 'draw on' sliders with mou...   May 9 2011, 05:39
|- - xnor   Sure Yegor, I could start today what do you pay me...   May 9 2011, 12:13
- - Yegor   Yes, sure. What about making the window resizable?...   May 9 2011, 16:00
|- - xnor   QUOTE (Yegor @ May 9 2011, 17:00) Yes, su...   May 9 2011, 18:22
- - romor   Thanks for the update xnor Impulse looks great, ...   May 10 2011, 00:30
- - Bob Brines   This plug-in looks like it has real promise. It ne...   May 10 2011, 01:46
|- - xnor   QUOTE (Bob Brines @ May 10 2011, 02:46) T...   May 10 2011, 22:32
|- - Bob Brines   QUOTE (xnor @ May 10 2011, 16:32) Anyway ...   May 11 2011, 03:08
- - ustas   xnor, thank you for the good job! I have an id...   May 10 2011, 06:16
- - tribaljet   Congrats on your work, xnor. I'm glad that alt...   May 14 2011, 05:14
- - Chipicui   Thanks for your wonderful EQ! :-) In my humble...   May 15 2011, 01:39
|- - xnor   QUOTE (Chipicui @ May 15 2011, 02:39) I d...   May 15 2011, 18:52
- - ustas   QUOTE (xnor @ May 15 2011, 19:52) QUOTE (...   May 15 2011, 19:30
- - lvqcl   It is possible to do something like this with foo_...   May 15 2011, 19:48
- - SASN   I tried installing the dll for this thing via Foob...   May 19 2011, 13:51
|- - xnor   QUOTE (SASN @ May 19 2011, 14:51) Should ...   May 20 2011, 16:05
- - SASN   Thanks! The equalizer now appear to work. Fr...   May 20 2011, 19:17
|- - kode54   QUOTE (SASN @ May 20 2011, 11:17) I guess...   May 21 2011, 00:03
|- - xnor   QUOTE (SASN @ May 20 2011, 20:17) From th...   May 24 2011, 00:26
- - xnor   New minor version released. Drawing the desired f...   May 24 2011, 23:45
- - SASN   Thank you. A fun little update (for me anyway, I c...   May 28 2011, 13:48
|- - xnor   QUOTE (SASN @ May 28 2011, 14:48) I wonde...   May 28 2011, 14:33
- - Bob Brines   You are making good progress on an excellent EQ. G...   May 28 2011, 15:09
|- - xnor   QUOTE (Bob Brines @ May 28 2011, 16:09) Y...   May 28 2011, 15:18
|- - Jackal29a   Just wanted to say thanks, been waiting for this f...   May 28 2011, 17:41
|- - Bob Brines   QUOTE (xnor @ May 28 2011, 09:18) Would y...   May 29 2011, 03:52
- - pro_optimizer   Good work, xnor! Now I can finally switch over...   May 29 2011, 09:07
- - SASN   I think I have found an issue but I am not really ...   May 30 2011, 12:58
- - lvqcl   It's not an issue. Every DSP plugin works this...   May 30 2011, 13:25
|- - xnor   Heh, I always considered this to be a fb2k feature...   May 30 2011, 19:24
- - mitchjs   could you add programatic control to this? meaning...   Jun 6 2011, 17:26
- - andrewhof   Thanks and I love the ability to access 20-40Hz B...   Jun 19 2011, 00:05
- - tpijag   you can not.   Jun 19 2011, 00:28
- - xnor   Maybe in the future. Right now I'm quite busy ...   Jun 19 2011, 11:29
- - Christiaan   hey xnor, just a quick thank-you from a fellow Mon...   Jun 20 2011, 18:05
|- - tribaljet   QUOTE (Christiaan @ Jun 20 2011, 17:05) h...   Jun 20 2011, 22:07
- - DigitalMan   Outstanding work, xnor. BTW - curious if anyone e...   Jun 21 2011, 01:51
- - groen   Hi great work on this DSP. It would be great if th...   Jun 26 2011, 14:20
- - Ken Saunders   Hey this really rocks. I was born with a visual im...   Jul 31 2011, 00:29
- - bludogbeats   Hi Xnor, I'm a newby to foobar. I have what s...   Aug 17 2011, 14:43
|- - db1989   QUOTE (bludogbeats @ Aug 17 2011, 14:43) ...   Aug 17 2011, 16:15
|- - bludogbeats   Thatís the intended behaviour. Ah, ok, thanks. ...   Aug 19 2011, 09:43
- - White_Shadow   Hey Xnor! Thanks for this great equalizer...   Sep 2 2011, 10:55
- - xnor   Does anyone actually need the full range of +-18 d...   Sep 8 2011, 18:32
- - klonuo   Under wine it seems impossible to use this compone...   Sep 8 2011, 20:05
|- - xnor   Interesting. Does pressing tab to focus sliders an...   Sep 8 2011, 20:33
- - klonuo   Yes, keyboard seems to handle sliders fine   Sep 8 2011, 21:11
- - White_Shadow   I'm not using the full range of +/-18dB. My Sl...   Sep 9 2011, 07:55
- - xnor   Yeah I think an edit box with the selected band...   Sep 9 2011, 13:37
|- - Bob Brines   Are you making any progress on implementing saved ...   Sep 17 2011, 15:06
- - xnor   You're right, I spent most of the time on the ...   Sep 17 2011, 15:20
|- - tribaljet   QUOTE (xnor @ Sep 17 2011, 14:20) You...   Sep 17 2011, 19:40
|- - Bob Brines   QUOTE (xnor @ Sep 17 2011, 09:20) Regardi...   Sep 18 2011, 03:45
|- - xnor   QUOTE (Bob Brines @ Sep 18 2011, 04:45) T...   Sep 20 2011, 16:13
|- - jgro   QUOTE (xnor @ Sep 20 2011, 17:13) QUOTE (...   Sep 21 2011, 16:28
- - tpijag   xnor crossfeed in search box   Sep 17 2011, 20:30
|- - tribaljet   QUOTE (tpijag @ Sep 17 2011, 19:30) xnor ...   Sep 18 2011, 04:30
- - chrome_waves   xnor- grus dich i am using some modded drivers f...   Sep 20 2011, 20:28
|- - xnor   chrome_waves, I don't know why the modded driv...   Sep 20 2011, 21:06
|- - chrome_waves   QUOTE (xnor @ Sep 20 2011, 14:06) chrome_...   Sep 21 2011, 02:58
- - touccer   Can you extend the frequency range of the dsp to 1...   Sep 20 2011, 22:08
|- - xnor   touccer, I don't really see the point. The fre...   Sep 20 2011, 22:47
|- - touccer   QUOTE (xnor @ Sep 20 2011, 22:47) touccer...   Sep 21 2011, 10:44
|- - xnor   QUOTE (touccer @ Sep 21 2011, 11:44) How ...   Sep 21 2011, 12:40
- - White_Shadow   Hey Xnor! Thanks for making the band values v...   Sep 21 2011, 10:02
- - xnor   I think so, but the fb sdk is imo not documented p...   Sep 21 2011, 16:48
|- - jgro   QUOTE (xnor @ Sep 21 2011, 17:48) I think...   Sep 21 2011, 18:20
- - darkandroid   This is great. I've had the Graphic Equalizer ...   Sep 30 2011, 05:57
- - xnor   Glad you like it. The smooth frequency response an...   Sep 30 2011, 12:23
- - darkandroid   So just to post a little observation, the Graphic ...   Sep 30 2011, 21:13
|- - xnor   QUOTE (darkandroid @ Sep 30 2011, 22:13) ...   Oct 4 2011, 17:43
- - astroidmist   Thank you so much for this component! This is...   Oct 8 2011, 05:47
- - SamDeRe81   I'm using this component too, although I'd...   Oct 23 2011, 18:58
|- - jmcturnan   Hi, I really like this. I am wondering if there i...   Oct 24 2011, 12:48
|- - xnor   QUOTE (SamDeRe81 @ Oct 23 2011, 19:58) I...   Oct 24 2011, 17:55
- - roded   Many thanks for this great component. A preset sha...   Nov 28 2011, 23:28
- - er_or   HI, at first - very good eq range from 20 to 20...   Nov 30 2011, 16:06
|- - xnor   QUOTE (er_or @ Nov 30 2011, 17:06) I...   Nov 30 2011, 18:24
|- - er_or   QUOTE (xnor @ Nov 30 2011, 18:24) QUOTE (...   Dec 1 2011, 21:02
|- - xnor   Tbh, 22 Hz - 35 kHz doesn't mean anything. The...   Dec 1 2011, 21:57
- - mhowie   Excellent plugin! I wonder if others might sh...   Dec 6 2011, 06:05
|- - Bob Brines   QUOTE (mhowie @ Dec 6 2011, 00:05) I wond...   Dec 7 2011, 21:56
|- - alkasar   Hello xnor, just found this Great plugin Until...   Dec 9 2011, 21:07
|- - Bob Brines   QUOTE (alkasar @ Dec 9 2011, 15:07) - add...   Dec 10 2011, 16:59
- - Bob Brines   I know, I know! I keep complaining about what ...   Dec 15 2011, 17:13
- - chucked   First of all, THANK YOU! I signed up just to b...   Jan 16 2012, 13:16
- - markanini   Since there is'nt a xgeq preset thread I thoug...   Jan 16 2012, 16:27
|- - chucked   QUOTE (markanini @ Jan 16 2012, 07:27) Si...   Jan 17 2012, 14:09
- - xnor   QUOTE (chucked @ Jan 17 2012, 15:09) than...   Jan 17 2012, 14:17
- - markanini   Basically The Diffuse-Field curve addresses the di...   Jan 17 2012, 14:32
- - xnor   Free field: a speaker is placed 3 meters in front ...   Jan 17 2012, 16:25
- - Jdlog   Nice job with this EQer! I can't use it fo...   Jan 20 2012, 15:49
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th May 2015 - 12:44
