Tiny Decoder *read_stream implementation, How to use the tiny decoder on embedded hardware
TinyTron
post May 2 2011, 15:47
Group: Validating
Hi there,
I'm trying to implement a WavPack decoder on embedded hardware using a ARM Cortex-M3 hardware.
The code I use is from the Tiny Decoder package from the downloads page, version is 4.40. I'm using the C-version, no assembler code is used.
The wavpack file is on a FAT formatted SD-Card, I'm able to read both the SD card blockwise, as well as the FAT-system blockwise. Blocks are 512 bytes wide.
My implementation is incompatible to the format of the read_stream, so I try to implement a "translator" function.
I'm not sure, if I get it right:
typedef int32_t (*read_stream)(void *, int32_t);
This implements the stream access - I assume, my function has to return a int32-value of how many bytes it could read and write the bytes to a buffer, void* points to (should it be a char*), the number of bytes that should be read is passed to the function as int32_t?
Has anyone tried to get the decoder running on an ARM processor?
Is there a port of the assembler part to thumb2-instructions?
Thanks in advance!
Best regards
TinyTron
saratoga
post May 2 2011, 16:21
QUOTE (TinyTron @ May 2 2011, 10:47) *
Thats an interesting choice. Why such an odd ARM processor?
So you want to do something like we do in rockbox, where the file is streamed a few KB at a time from storage, decode it, then do the next few KB? Heres our code:
http://svn.rockbox.org/viewvc.cgi/trunk/ap...amp;view=markup
http://svn.rockbox.org/viewvc.cgi/trunk/ap...ecs/libwavpack/
I've never heard of someone using the Thumb2 processors for audio, but I think its not too different from standard ARMv4, so you could probably adapt our assembly.
RSS Lo-Fi Version Time is now: 1st February 2015 - 02:12
