Audio CD Writer (foo_burninate) write offset correction and write spee
BrassDude
post May 2 2011, 15:00
I'm using the latest version of foobar2000 (v1.1.6) with the component foo_burninate (v3.0.3) to burn CDs from my ripped FLAC files (with AccurateRip). I would like to correct the write offset of my drive when burning. Is there a way to set this? Haven't found anything in the forum and under the settings in foobar2000. Also along the same line: is there a way to set the speed for writing the files to CD?
BrassDude
post May 4 2011, 17:02
I think I've found some indication that one can't adjust the write speed in foo_burninate. Can someone who knows for sure confirm this? Is there a reason for this?
Also, does anyone know about the write offset correction for foo_burninate? My drive (HP - BDDVDRW CT21L) has a read offset of -102 (=> read offset correction = +102). I've detected the write offset with Exact Audio Copy (EAC) and got +30 (=> write offset correction = -30). First I thought: Hmm is this the zero point offset of AccurateRip? But there it says that "the correction values are 30 samples too high". This would mean that my read offset correction with respect to the "correct" reference is actually +72 and the resulting write offset correction would then be -60. So it goes in the wrong direction. Do I see this correctly?
Anyway, if I set the write offset in EAC to +30 it gives, of course, the correct read offset that AccurateRip detects as well. An if I re-rip a with foo_burninate burned CD I get a correct rip but with an offset of 30 (kinda like a different pressing). So everything is fine and makes sense - except that I can't set and correct the write offset in foo_burninate.
BTW: Am I the only one that is sometimes confused when reading about offsets in the forum? People don't always clearly specify if they're talking about the read/write offset or the read/write offset correction. On top of this in EAC and Foobar2000 for example one has to specify the read offset correction when ripping but for writing one has to specify the write offset in EAC.
On another note: Why are the write offset corrections not listed on the AccurateRip drive offsets site? Is it simply not supported wide enough so that it is worth to do?
marc2003
post May 4 2011, 17:22
i don't know anything about write offsets but the developer did comment on the lack of speed options in this thread.
http://www.hydrogenaudio.org/forums/index....showtopic=87324
RSS Lo-Fi Version Time is now: 30th July 2015 - 06:49
