SimPlaylist Manager (foo_simplaylist_manager), alternative playlist manager
Frank Bicking
post May 2 2011, 02:31
This new component is a replacement for the original playlist manager. I mainly created it to get the same look and feel as SimPlaylist, including smooth scrolling and automatic column resizing to use the full width.
SimPlaylist Manager adds columns for playback icons, autoplaylist status, and additional statistics known from the Facets component. Playlist sorting functions are available from the context menu. Additional features such as grouping may be added later.
Download
1.0 final
  • Automatically switch playlists on drag and drop.
  • Transparent mouse selection rectangle.
  • Drag and drop displays image of selected items.
1.0 beta 4:
  • Bug: Enter does not activate the focused playlist.
  • Glitch: Pasting multiple playlists at once opens and closes rename box for each one.
1.0 beta 3:
  • Glitch: Improved scrolling and edit box behaviour when adding new playlists.
  • Compatibility: Changed keyboard shortcut handling, see the SimPlaylist topic for details.
  • Renamed "autoplaylist status" column to "playlist lock".
1.0 beta 2:
This post has been edited by Frank Bicking: Aug 21 2011, 03:35
Reason for edit: Beta change log, known issues.
thi3nki3p
post May 2 2011, 14:44
Bug: PL manager with scroll bar. Start deleting playlist to the point where scroll bar auto hide. Everything goes blank, though quick resizing get thing back. It seems to be no redraws there.
Robertina
post May 3 2011, 04:43
Group: Banned
I hope this question isn't too stupid but can I use the SimPlaylist Manager as a Popup window also with Columns UI?
The question arose after having read that it includes the same statistics as the Facets plugin which does not support CUI.
kerpondile
post May 3 2011, 08:35
Bug: SimPlaylist Manager seems to change current selection (ui_selection_manager->get_selection) while drag&dropping playlist items.
More formal bug report follows:
Steps to reproduce:
1. Start drag of playlist items from a playlist
2. Hover drag over Sim playlist manager
-- at this point ui_selection_manager->get_selection is somehow changed --
3. Drop items to target (selection of ui_selection_manager still empty at drop the moment)
Expected:
ui_selection_manager->get_selection is not reset
Actual:
ui_selection_manager->get_selection is reset if the mouse curse is hovering over the sim playlist manager during the drap & drop operation.
Other notes:
The above behaviour does not occur with the standard playlist manager.
Well why does this matter? My queuecontents drag&drop operations will not queue the playlist items when the selection of ui_selection_manager is empty. Instead, the files are queued. The bug can be tested easily using foo_queuecontents: when the selection is reseted files are queued instead of the playlist items. I've also debugged my code to verify this is the actual issue.
Since the issue might be hard to grasp I made a screencast comparing Sim PlaylistManger with the standard one. It is available here http://www.screencast-o-matic.com/watch/cXheivbXQ
foosion
post May 3 2011, 08:46
Group: FB2K Moderator (Donating)
kerpondile: No offense intended, but that sounds like you are relying on undocumented behaviour to get the playlist selection, which makes your implementation rather fragile. If I understand your description correctly, your foo_queuecontents grabs data from the ui_selection_manager when it handles a drop operation. For me a more robust solution would be to use a drag&drop data format that describes the playlist position of the dragged items. Of course that would require cooperation from Peter and the authors of third-party playlist views. What is your opinion on that?
kerpondile
post May 3 2011, 09:24
foosion:
Yes you hit the nail on the head with that one: it is very fragile but there was no other way to do it really.
I would certainly implement support for custom drag & drop data format if such would become available. It would certainly be the most clean way to implement the functionality. However, I think it is unlikely that the columns_ui playlist ui element developers will implement it but anyways it is better than nothing.
This post has been edited by kerpondile: May 3 2011, 09:42
Robertina
post May 3 2011, 21:09
Group: Banned
Where does this component save its settings? I can't find a foo_simplaylist_manager.dll.cfg
I had installed it and now I want to remove it. Please help.
Frank Bicking
post May 3 2011, 22:46
QUOTE (kerpondile @ May 3 2011, 09:35) *
Fixed for the next beta, thanks for the great report.
QUOTE (Robertina @ May 3 2011, 22:09) *
There are no global settings that would require a configuration file.
Settings of UI elements opened as popup windows are managed by the default UI.
So they are stored in foo_ui_std.dll.cfg, I guess, with all other DUI settings.
auditorium
post May 4 2011, 01:24
Is possible to eliminate default Playlist Manager from the "View" menu when use SimPlaylist Manager?
I think it is useless to be two elements with almost the same function.
Thank you.
Robertina
post May 4 2011, 07:17
Group: Banned
QUOTE (Frank Bicking @ May 3 2011, 10:46) *
So they are stored in foo_ui_std.dll.cfg, ...
Thank you. Columns in the format yyyy-mm-dd hh:mm:ss (first added, last modified, last played and so on) seem not to be properly automatic resized on my system. After the installation I opened the SPM from the View menu and resized its window to 1193 x 690 pixel. I added one of these columns and it shows its content truncated (example: 2008-03-14 19:... is displayed). Closing and re-opening the SPM doesn't adjust this. Note: due to the high number of playlists my SPM has a vertical scroll bar.
Starting the SPM as a Popup window again and activating all columns top down from the menu: with the adding of the column "Lossless ratio" a horizontal scroll bar appears and the column "Playlist name" disappears (width is set to zero), whereas other columns absorb more width than they would need.
Default user interface, SimPlaylist Manager 1.0 beta 1, foobar2000 v1.1.6, XP SP3
rafib
post May 6 2011, 17:44
Hey, first of all - great component! Lots of potential to do awesome stuff with the playlists..
I would LOVE to be able to have folders and separators, much like Firefoxs' bookmark manager.
I know a TreeView is a lot of implementation, but what do you think ?
q-stankovic
post May 14 2011, 21:37
rafib, a tree view has some side effects. One about foo_plorg you can see here in facets thread. Also the "next playlist" and "previous playlist" commands in foobar2000s main menu as well as in some third-party components like foo_scheduler can lead to irritation.
I have to second what auditorium said. I like that the simplaylist search doesn't have an extra mainmenu entriy but is called by the normal "search" command
q-stankovic
post May 14 2011, 23:15
(please merge into my post before)
Frank what do you think about an advanced option that switches between two modes: 1. simplaylist search/simplaylist has their own entries in main menu or 2. the commands "search" and "playlist manager" are related to the sim-implementation for ui-element as well as for standalone window. Now both parts (sim playlist manager and search) are acting different with the side effect that cui users can't use the simplaylist search.
It is maybe the wrong thread to ask but because of the topic the right occasion: Any chance to see a Sim Library Search? Would be great!
Another point: the autoplaylist column shows autoplaylist - what else? But it would be also useful to indicate other locked playlists like: read-only, podcatcher, last.fm radio and so on.
This post has been edited by q-stankovic: May 14 2011, 23:17
q-stankovic
post Jun 20 2011, 22:23
I have no idea what "sort by playing" should achieve. I really don't have any effect. I expected something like playing playlist will br moved at the top but i see nothing.
Frank Bicking
post Jun 27 2011, 16:48
Post #15
QUOTE (Robertina @ May 4 2011, 08:17) *
Columns in the format yyyy-mm-dd hh:mm:ss (first added, last modified, last played and so on) seem not to be properly automatic resized on my system. (...)
Like in my other components, my idea of automatic column width adjustment is not to change the column sizes according to the displayed contents. Instead, columns are resized so that the full width of the UI element is used. When the element size changes, columns that typically display text of the same size, like statistics with their dates or numbers, remain unchanged if another column such as "name" can be resized instead.
QUOTE (auditorium @ May 4 2011, 02:24) *
While components can define their own actions for edit menu commands, removing or replacing entries in other menus is not possible.
QUOTE (q-stankovic @ May 15 2011, 00:15) *
Did not know those existed, should work now if their playlist locks return a name.
QUOTE (q-stankovic @ Jun 20 2011, 23:23) *
Implemented - it indeed didn't do anything before.
White_Shadow
post Sep 2 2011, 11:10
Post #16
I found a little bug.
Because I'm exchanging my mp3-files with lossless flacs I'm sometimes controlling the lossless ratio of my media library. Since your Playlist Manager is able to do that, I'm taking this way.
But yesterday I compared the value with the built-in metadata viewer and this is, what I got: (Highlighted in sepia)
I found also that the "played" column displays a number which is about two lesser than the built-in metadata viewer.
[Edit:] Sorry! I meant it the other way round: The number in the "played" column is about two bigger.
This post has been edited by White_Shadow: Sep 2 2011, 11:13
prateek88
post Apr 28 2012, 20:00
Post #17
Hi there, i want to add my selected track to add to a particular playlist using a shortcut key, say i press ctrl+q after selecting a track and it gets added to 'Instrumental favs" playlist without any confirmation dialogue box. Is it possible? unsure.gif
Blueinferno
post Dec 26 2012, 13:12
Post #18
is there a way to add SimPlaylist as a columns UI panel? i'm looking for a playlist manager that allows me to select multiple playlists at the same time and have the contents displayed in playlist view, which the standard playlist switcher doesn't provide. it's possible in simplaylist but i can only invoke it as a pop-up window.
ColdChemical
post Jan 22 2013, 04:11
Post #19
QUOTE (Blueinferno @ Dec 26 2012, 07:12) *
I would also love to know if there's a way to integrate this into columnsUI. Also, is there a way to sort the listed playlists (by clicking on the column headings, for example)?
RSS Lo-Fi Version Time is now: 1st April 2015 - 01:28
