SimPlaylist (foo_simplaylist), Playlist view with album art
Frank Bicking
post May 2 2011, 02:28
This new playlist view includes multiple grouping levels, album art, automatic column resizing, smooth scrolling, a unique scrolling mode that pins the topmost group header, clickable rating columns for tags and playback statistics, and a separate playlist search UI element.
SimPlaylist is meant for users who want the same look and feel as the original playlist view with some additional features, but without the typical configuration overhead that comes with other components.
Download
Documentation
Known issues:
This post has been edited by Frank Bicking: Mar 14 2013, 16:58
Reason for edit: Axed old beta changelog.
Frank Bicking
post May 2 2011, 20:25
Thanks for all feedback. I will skip feature requests for now and focus on usage questions and issues.
QUOTE (thuan @ May 2 2011, 09:43) *
If I choose group preset Artist / cover / album, Disc sub group does not have a horizontal line, is that intended?
Yes, to better distinguish them from first level subgroups.
Also what determines the dim state of text, I can't seem to figure that out.
I have added two documentation sections on column and group colors.
QUOTE (NinjaN @ May 2 2011, 12:36) *
However, I seem to have a problem with sorting the playlist entries...
I configured the following string as "sorting pattern": (...)
This setting doesn't seem to have any effect.
This sort order is used when you click on a group column.
QUOTE (herojoker @ May 2 2011, 12:59) *
I'm confirming the album art problem for multi cd albums. It occurs only and whenever multiple subgroups are shown; then the place where the album art should be remains empty (white, clickable box).
Looks like a limitation of foobar2000's own album art loader.
Album list has the same issue when you select an album with multiple discs.
NullString
post May 3 2011, 03:24
QUOTE (Frank Bicking @ May 2 2011, 16:25) *
I also have a problem with sorting.
As group header I use the default Artist - Album / Cover and I use the %Path:_sort% for sorting.
but, for some tracks I get the %path_sort% sorting all messed up.
The first 4 tracks displayed are here:
M:\Music\Progressive\Opeth\1995 - Orchid\07. Opeth - The Apostle In Triumph.mp3
M:\Music\Progressive\Opeth\1996 - Morningrise\01. Opeth - Advent.mp3
M:\Music\Progressive\Opeth\1998 - My Arms Your Hearse\05. Opeth - The Amen Corner.mp3
M:\Music\Progressive\Opeth\1998 - My Arms Your Hearse\06. Opeth - Demon Of The Fall.mp3
M:\Music\Progressive\Opeth\1998 - My Arms Your Hearse\07. Opeth - Credence.mp3
M:\Music\Progressive\Opeth\2001 - Blackwater Park\01. Opeth - The Leper Affinity.mp3
M:\Music\Progressive\Opeth\2001 - Blackwater Park\02. Opeth - Bleak.mp3
M:\Music\Progressive\Opeth\1995 - Orchid\01. Opeth - In The Mist She Was Standing.mp3
If I click the group header, or if I use the Edit/Sort by file path, it gets sorted correctly, but then when I change selecton on the tracks with facets 1.0, I lose the sorting and I get the tracks in the wrong order again.
All the tracks have the same album artist, with the same casing, same album and same date and should be grouped acordingly. Also, for now, it only has happened to the "Opeth" folder.
I reloaded tag info from files, rewrote the file tags and still nothing.
If you need more feedback please ask.
Also, this playlist view+covers is running blazing fast! it's great. Thanks a lot!
Frank Bicking
post May 3 2011, 15:25
Beta 3 released, details in the first post. Thanks for all reports.
QUOTE (NullString @ May 3 2011, 04:24) *
(...) when I change selecton on the tracks with facets 1.0, I lose the sorting and I get the tracks in the wrong order again.
Probably related to a bug fixed in Facets 1.0 beta 2.
QUOTE (zradu @ May 3 2011, 08:24) *
Bug report: when use facets with simplaylist (...)
Please use the send report button from the crash dialog. There is no need to paste logs here.
QUOTE (kerpondile @ May 3 2011, 08:54) *
One functionality is missing which is available in the standard foobar playlist: Ctrl+Shift+Up/Down of moving items.
Unfortunately, those are already used for multi-selection purposes.
This post has been edited by Frank Bicking: May 3 2011, 15:48
NullString
post May 4 2011, 01:12
QUOTE (Frank Bicking @ May 3 2011, 11:25) *
You were right. Thanks!
- Frank Bicking   SimPlaylist (foo_simplaylist)   May 2 2011, 02:28
- - thuan   I love this, took only a few minutes to get used t...   May 2 2011, 07:11
- - foofun   Small suggestion: posibility to edit parameters (n...   May 2 2011, 07:16
- - DenisCool   Looks like there is a problem with non-English art...   May 2 2011, 07:36
- - thuan   If I choose group preset Artist / cover / album, D...   May 2 2011, 08:43
- - NinjaN   Thank you very much for this new component! H...   May 2 2011, 11:36
- - Anomalous   Wow, this is great. There seems to be a problem w...   May 2 2011, 11:56
- - herojoker   I'm confirming the album art problem for multi...   May 2 2011, 11:59
- - Anomalous   Would it be possible to have an option to disable ...   May 2 2011, 12:40
- - Bollerkopp   Wow... this is great. Much better than ESPlaylist ...   May 2 2011, 13:49
- - Shinsou   nice component! Even Rating database has been ...   May 2 2011, 14:31
|- - kerpondile   Indeed, the rating database support is a welcome a...   May 4 2011, 06:25
|- - klonuo   QUOTE (kerpondile @ May 4 2011, 07:25) Ho...   May 4 2011, 06:58
- - hal9001   Nice & fast loading! But for some reason i...   May 2 2011, 16:58
- - marc2003   i think beta2 has blocked all album art from loadi...   May 2 2011, 18:05
- - Frank Bicking   Thanks for all feedback. I will skip feature reque...   May 2 2011, 20:25
|- - NullString   QUOTE (Frank Bicking @ May 2 2011, 16:25)...   May 3 2011, 03:24
||- - Frank Bicking   Beta 3 released, details in the first post. Thanks...   May 3 2011, 15:25
||- - NullString   QUOTE (Frank Bicking @ May 3 2011, 11:25)...   May 4 2011, 01:12
|- - NinjaN   QUOTE (Frank Bicking @ May 2 2011, 14:25)...   May 3 2011, 11:07
- - Sixth Street   Very neat! Can we have collapsible groups/sub...   May 2 2011, 20:25
- - AEcid   can you implement the possibility of hiding the co...   May 2 2011, 20:44
- - Spirit_of_the_ocean   I recognized something strange: I have some music ...   May 2 2011, 21:04
- - Anomalous   Does the art show in the cover art element if you ...   May 2 2011, 21:11
- - zradu   Bug report: when use facets with simplaylist CODE...   May 3 2011, 07:24
- - kerpondile   One functionality is missing which is available in...   May 3 2011, 07:54
- - White_Shadow   Hi! I've some kind of request/bug (not su...   May 3 2011, 10:30
- - AEcid   i have a question. in ESplaylist, my group header ...   May 3 2011, 16:25
- - Harro   It seems that SimPlaylist is not selecting the ...   May 3 2011, 16:52
|- - sylla   QUOTE (Harro @ May 3 2011, 17:52) It seem...   May 3 2011, 17:12
|- - Frank Bicking   QUOTE (AEcid @ May 3 2011, 17:25) in ESpl...   May 3 2011, 17:23
|- - AEcid   QUOTE (Frank Bicking @ May 3 2011, 17:23)...   May 3 2011, 17:35
- - Frank Bicking   For tracks from 2004, 2011, 2008, 1996, 2001: %fi...   May 3 2011, 17:49
|- - AEcid   QUOTE (Frank Bicking @ May 3 2011, 17:49)...   May 3 2011, 18:03
- - Spirit_of_the_ocean   Okay I found the problem. I got an .ogg file with ...   May 3 2011, 18:03
- - smkk   Thanks for this great playlist viewer, really nice...   May 4 2011, 17:31
- - randal1013   this is a wonderful plugin, but i'm a little c...   May 4 2011, 23:42
- - TomBarlow   I think there's a bug with resizing the playli...   May 5 2011, 00:12
- - tg2k3   hey frank, thank you for the incredibly awesome co...   May 5 2011, 13:41
- - zradu   A question: Is the option to have ignore leading ...   May 5 2011, 18:37
- - tpijag   ?? Not sure what you are asking. Testing it might ...   May 5 2011, 18:42
- - foo_peter   Open issues: No album art found in parent fol...   May 5 2011, 20:58
- - Marc27   Maybe a bug? there's an unused space when usin...   May 6 2011, 01:08
- - a3aan   I like this new plug-in. Best thing since Facets ;...   May 7 2011, 16:09
- - metal_termite   Can you add playlist filters/association (Columns ...   May 8 2011, 15:08
|- - r3v0   QUOTE (metal_termite @ May 8 2011, 15:08)...   May 9 2011, 10:58
- - q-stankovic   @Marc27 I like that: it gives a better overview fo...   May 8 2011, 15:28
- - metal_termite   q-stankovic, I do not understand the first few se...   May 8 2011, 16:10
- - q-stankovic   I understand what you mean, but if your autoplayli...   May 8 2011, 16:32
- - thi3nki3p   Bug: pattern: <<<%tagA%>>> %tagB...   May 8 2011, 19:57
- - q-stankovic   So far everytime i restart foobar2000 the playlist...   May 8 2011, 22:41
- - Marc27   @q-stankovic I believe the space was meant for dis...   May 9 2011, 02:13
- - auditorium   Possible bug: When I reset the settings page from ...   May 9 2011, 08:14
- - sylla   After changing tags, the groups and subgroups beha...   May 9 2011, 14:38
- - frogworth   This is awesome but I'm getting a major bug wh...   May 9 2011, 15:32
- - frogworth   Thanks for your quick help in personal messages, F...   May 9 2011, 16:28
- - Frank Bicking   Beta 4 out, thanks for all bug reports. QUOTE (Ma...   May 10 2011, 17:54
|- - tg2k3   QUOTE QUOTE (tg2k3 @ May 5 2011, 14:41) I...   May 10 2011, 23:41
|- - frogworth   QUOTE (Frank Bicking @ May 11 2011, 02:54...   May 11 2011, 01:55
- - frogworth   Bug report: ctrl-z doesn't work as expected. ...   May 11 2011, 02:00
- - Fractal_Mortality   Any way we could have the option to bind find as y...   May 11 2011, 04:24
- - smkk   Doubleclicking the statusbar still (beta4) jumps t...   May 11 2011, 15:55
- - mixmart1n   Hey, Thanks for your new component. Just one featu...   May 11 2011, 19:54
- - Rifftide   I too would greatly appreciate the ability to forc...   May 11 2011, 20:47
- - Alexander Ostuni   Grat component,thanks. I have defined ctrl alt m ...   May 11 2011, 21:25
- - shakey_snake   QUOTE (Frank Bicking @ May 1 2011, 21:28)...   May 12 2011, 05:03
- - ZeeJ   May we see some screenshots of the component in ac...   May 12 2011, 17:12
- - tpijag   Doing what, exactly. Why not just load it   May 12 2011, 17:18
- - ZeeJ   Nevermind. I just wanted to see how the playlist l...   May 12 2011, 17:22
- - TomBarlow   Here's mine, with facets as well:   May 12 2011, 17:24
|- - muzack   @TomBarlow how did you get that third green groupi...   May 12 2011, 17:41
- - tpijag   Subgroups Included in some [all] of the preinstall...   May 12 2011, 17:48
- - phibercrack   hi frank, very nice playlist-view, thx very much ...   May 12 2011, 18:00
- - muzack   I overlooked the possibility of multiple lines in ...   May 12 2011, 18:03
|- - sharpedge   Frank! This is wonderful. The component is jus...   May 14 2011, 12:26
- - tpijag   Yes, it is quite cool. For me [Set %Set%]$if(...   May 12 2011, 18:13
- - foofun   In my opinion there is too little space between th...   May 13 2011, 13:38
- - tpijag   Couple options come to mind. Add your own custom ...   May 13 2011, 14:29
- - foofun   Thanks tpijag Or [%tracknumber% ] for track colum...   May 13 2011, 15:06
- - phool   Any possibility of adding the ability of condition...   May 13 2011, 15:09
- - Rifftide   After using it for a few days, I love how elegant ...   May 14 2011, 05:50
- - sharpedge   There is one more thing: I noticed that the resize...   May 14 2011, 14:16
- - q-stankovic   There is something i don't really understand a...   May 14 2011, 19:47
- - lvqcl   QUOTE What does "Sim" mean? simplaylist...   May 14 2011, 19:52
- - q-stankovic   QUOTE (q-stankovic @ May 14 2011, 20...   May 14 2011, 20:15
- - Cutter   The component doesn't seem to display album ar...   May 15 2011, 12:56
|- - The Link   QUOTE (Cutter @ May 15 2011, 12:56) The c...   May 15 2011, 13:05
|- - Cutter   QUOTE (The Link @ May 15 2011, 14:05) QUO...   May 15 2011, 13:18
- - Takaji   I'm a little confused by something. How can I ...   May 17 2011, 03:10
- - TomBarlow   $directory(%path%) might work. For classical ...   May 17 2011, 11:55
- - smkk   Keyboard shortcuts with the modifier keys ctrl+alt...   May 17 2011, 13:38
- - Takaji   Frank, could I request a feature to append items t...   May 18 2011, 16:55
- - servimo   How to display total time in the title of the Albu...   May 19 2011, 13:45
- - marc2003   http://wiki.hydrogenaudio.org/index.php?ti...roup_...   May 19 2011, 13:49
|- - servimo   Thanks!   May 19 2011, 13:57
- - JacksonGrey   Two quick questions for you... 1 Is there any wor...   May 19 2011, 18:31
|- - BoraBora   QUOTE (JacksonGrey @ May 19 2011, 19:31) ...   May 19 2011, 22:34
|- - JacksonGrey   QUOTE (BoraBora @ May 19 2011, 22:34) Her...   May 19 2011, 23:18
- - Takaji   The syntax help link in Simplaylist properties doe...   May 19 2011, 21:18
- - marc2003   %__bitspersample%   May 19 2011, 21:33
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st February 2015 - 15:11
