Facets (foo_facets), Media library viewer
Frank Bicking
post May 2 2011, 02:27
This update is a complete rewrite of the original component. Highlights include album art views, a new filter toolbar for easy access to frequently used searches, automatic column width adjustment, smooth scrolling, playlist content browsing, editable autoplaylists, additional statistics, refined looks, and performance improvements.
Please give feedback on the import of previous settings, new features, as well as any problems you encounter.
Download
Documentation
Release notes
Change log
This post has been edited by Frank Bicking: Mar 14 2013, 16:53
bchan
post May 9 2011, 06:58
Hi. I've been using Facets for the past couple days and it is really excellent. However, I've been having trouble getting Facets' interaction with playlists to work the way I'd like, despite trying all combinations of Facets' Library view settings.
Typically, I navigate the library to select a few albums I'd like to listen to, in sequence. I'd like to be able to navigate to the desired albums and easily put them into a single playlist for playback.
I can do this if I set the selection action setting to "none" (i.e., I don't use the selection playlist at all) and set the double-click action setting to "add to current playlist" (assuming I have an empty playlist ready to go). I just navigate through the library, double-clicking the albums I'd like to hear.
This works fine, but prevents me from seeing a selection playlist as I navigate through the library, which ideally I'd like to do. (If I re-enable the selection playlist by using the default settings, then the double-click action sends the selected album to the currently-activated playlist--i.e., the selection playlist itself. If I want to add an album to the currently-playing playlist, I have to select the album first, then select the currently-playing playlist, then right-click the album and select "add to current playlist." Feels like a lot of work.)
I guess what I'd really like is the ability to send/add songs to the currently-playing playlist rather than the currently-activated playlist. I'd like to use the selection playlist in a preview-only capacity, rather than as a container for actually-playing songs. Meanwhile, I'd like a separate playlist to serve as the container of the albums to be played.
Does this make sense at all? Am I asking for something stupid or impossible? Can anyone recommend a combination of settings and usage that might work better for me? Thanks!
TomBarlow
post May 9 2011, 10:49
ist it possible with the Filter, that more than one genre is shown, for example "folk" and "Folkrock" ?
Try something like %genre% HAS folk AND %genre% HAS folkrock. Or if you just want to know if something has multiple genres, "$greater($meta_num(genre),1)" PRESENT might work.
You could add an extra facet pane that shows tracks, and put single click action to none. It works well for me. Don't forget you can sort by a different column (e.g. artist|album|track). IMO this makes more sense if you just want somewhere to preview the selected tracks. Things should only go into a playlist if you're going to play them - that might just be me.
Would you consider adding an option to allow an instance of Facets to work with just one or several folders of the media library?
You could make up your own filters, like %path% HAS Audiobooks or something.
bchan
post May 9 2011, 16:56
QUOTE (TomBarlow @ May 9 2011, 04:49) *
Great suggestion--this works well for me. Thanks much.
- Frank Bicking   Facets (foo_facets)   May 2 2011, 02:27
- - shakey_snake   Working great so far...   May 2 2011, 02:33
- - marc2003   that was unexpected..... very cool. one little i...   May 2 2011, 02:52
- - zradu   1. Posible bug: when select 'Layout editing mo...   May 2 2011, 06:10
- - klonuo   Thank you, it's great to see active developmen...   May 2 2011, 07:16
- - hejiamei   why not supply the columns UI? foo_ui_columns i...   May 2 2011, 07:56
- - gfngfgf   FYI, foobar2000 1.1.7b1 (Win7 x64) crashes when I ...   May 2 2011, 08:12
- - a3aan   Great. Facets is one of the essential plug-ins for...   May 2 2011, 09:59
- - gurubhai   A pleasant surprise, thanks !   May 2 2011, 10:31
- - muzack   thanks for this improved component. makes me drop ...   May 2 2011, 14:06
- - Bollerkopp   Indeed... what a surprise. Works really great. And...   May 2 2011, 14:38
- - Shinsou   EDIT: don't know about other guys but it's...   May 2 2011, 14:42
- - Alexander Ostuni   Hi, thanks very much, facets is the most importan...   May 2 2011, 16:55
- - tpijag   Foobar 1.1/7 xp What I am seeing with column widt...   May 2 2011, 17:13
|- - Sandrine   QUOTE (tpijag @ May 2 2011, 18:13) Draggi...   May 2 2011, 22:05
- - NEMO7538   I think I have found a couple of bugs : If you use...   May 2 2011, 18:07
- - Lashiec   Very nice update! Smooth scrolling is already ...   May 2 2011, 18:08
- - el-jaguar   Really really nice, thanks a lot. A question: Is ...   May 2 2011, 18:12
- - Erich_2   SimPlaylist Manager together with new Facets 1.0 b...   May 2 2011, 19:44
- - q-stankovic   Great to see that development of this wonderful co...   May 2 2011, 19:49
- - NullString   Thanks for the update! Is it possible to keep...   May 3 2011, 00:11
- - kerpondile   Great update! Would it be possible to have ke...   May 3 2011, 10:20
|- - Frank Bicking   Beta 2 released, see the first post for details. ...   May 3 2011, 15:07
- - TomBarlow   This is great, I love the album art. Thanks! ...   May 3 2011, 11:21
- - NEMO7538   QUOTE (Bollerkopp @ May 2 2011, 15:38) I...   May 3 2011, 15:01
- - tpijag   QUOTE Bug: Splitter resizing broken when system se...   May 3 2011, 17:21
- - auditorium   First of all, I want to thank Frank Bicking for th...   May 3 2011, 18:36
- - phool   QUOTE (q-stankovic @ May 2 2011, 20...   May 3 2011, 20:31
- - Erich_2   BUG or misunderstanding: Double-Click action ...   May 3 2011, 21:06
- - smkk   Thanks for updating this wonderful plugin. Good to...   May 3 2011, 21:07
- - auditorium   It would be nice column formatted to display as ra...   May 3 2011, 21:08
|- - Peter Feerick   QUOTE (auditorium @ May 4 2011, 06:08) It...   May 6 2011, 04:22
- - Cutter   Thanks for the update. Is it possible to disable s...   May 3 2011, 21:23
- - marc2003   a little request: could images be centred vertical...   May 4 2011, 00:10
- - mrinferno   seriously Frank ...wow! I love it. Nothing b...   May 4 2011, 01:40
- - Remedial Sound   Nice job with the improvements, thanks! Cou...   May 4 2011, 02:48
- - -AdZero-   Thanks for this new version Franck. For the momen...   May 4 2011, 06:38
|- - -AdZero-   QUOTE (-AdZero- @ May 4 2011, 06...   May 5 2011, 21:44
|- - -AdZero-   Is there any news about the bugs I mentioned in my...   May 11 2011, 20:28
- - swiffer   hey very great plugin and working quite well so fa...   May 4 2011, 06:56
- - ua freeman   #1 sorting: lower - upper key sensitivity why??? ...   May 4 2011, 10:11
- - joedimagio   Firstly I want to apologize in advance if what I a...   May 4 2011, 11:50
- - muzack   I noticed blank pics (not replaced with the defaul...   May 4 2011, 12:40
- - TomBarlow   It looks like artists with multiple albums don...   May 4 2011, 12:51
|- - marc2003   ^i don't have problems with artists with multi...   May 4 2011, 16:49
- - TomBarlow   Oh nice one. I just added 'C:\Documents ...   May 4 2011, 17:42
- - shakey_snake   Totally off topic: I've always found foo_disc...   May 4 2011, 20:35
- - Erich_2   Request: It would be nice when clicking in a facet...   May 5 2011, 08:53
- - joedimagio   @ Muzak: My jpegs are all 500 to 2000 square so I ...   May 5 2011, 12:13
- - marc2003   ignore the $crc32 thing. that's just some...   May 5 2011, 13:08
- - foofun   Request: "Rating (data base)" column (in...   May 5 2011, 13:11
- - zradu   Problem with sorting (Facets 1.0 beta 2 + SimPlayl...   May 5 2011, 15:52
- - Dodecahedron   This is really an interesting surprise! Howeve...   May 5 2011, 16:57
- - TomBarlow   QUOTE (joedimagio @ May 5 2011, 12:13) So...   May 5 2011, 17:31
- - Bl@ck_warrior   Hi there, It would be great to have the possibili...   May 5 2011, 17:52
- - Cutter   I have the same problem. My Library is filled with...   May 5 2011, 22:09
- - Marc27   Hello, may it be possible to add similar/more comp...   May 5 2011, 23:35
- - tpijag   yes   May 6 2011, 00:01
- - auditorium   Thanks, but look here: From Facets documentation ...   May 6 2011, 06:00
- - Melomane   with XP, instead of stars for rating , squares a...   May 6 2011, 09:54
|- - sylla   QUOTE (Melomane @ May 6 2011, 10:54) with...   May 6 2011, 10:02
|- - Melomane   QUOTE (sylla @ May 6 2011, 11:02) Yes, pr...   May 6 2011, 12:08
|- - shakey_snake   QUOTE (Melomane @ May 6 2011, 07:08) QUOT...   May 6 2011, 14:22
- - Hitchhiker427   Are there any plans to support CUI in the future? ...   May 6 2011, 13:47
|- - robin75   QUOTE (Hitchhiker427 @ May 6 2011, 14:47)...   May 6 2011, 21:03
- - Melomane   shakey_snake, thank you, now i have stars in prope...   May 6 2011, 17:37
- - rafib   Great to see development! Thank you so much.   May 6 2011, 18:18
- - Northpack   It's great to see a new version of foo_facets,...   May 7 2011, 09:44
- - verbajim   Would be nice to have a little X instead of the re...   May 7 2011, 10:32
- - lokioki   So I was updating Foobar's plugins. And shat...   May 7 2011, 14:02
- - Alexander Ostuni   Hi ist it possible with the Filter, that more than...   May 7 2011, 17:18
- - q-stankovic   Maybe it's a little bit to early for a request...   May 8 2011, 14:07
- - LordWarlock   The albumart function needs a thumbnail cache, rig...   May 8 2011, 16:52
- - Marc27   Ok.. I played a bit more with the syntax.. Hum I ...   May 9 2011, 02:27
- - tpijag   Does not make any sense to me. Different visual me...   May 9 2011, 02:44
- - Moth   Good to see this being updated. Thank you very muc...   May 9 2011, 05:32
- - bchan   Hi. I've been using Facets for the past coupl...   May 9 2011, 06:58
|- - TomBarlow   QUOTE ist it possible with the Filter, that more t...   May 9 2011, 10:49
|- - bchan   QUOTE (TomBarlow @ May 9 2011, 04:49) QUO...   May 9 2011, 16:56
- - nosgah   QUOTE (Marc27 @ May 9 2011, 03:27) Ok.. I...   May 9 2011, 09:39
- - BoraBora   These new Facets and SimPlaylist are a dream come ...   May 9 2011, 22:05
- - Marc27   @nosgah Yes I was aware of the option, thanks. @...   May 10 2011, 00:33
- - Hotze   Great job! I really like this plugin, and i th...   May 10 2011, 16:50
- - Rifftide   The performance improvements are extremely noticea...   May 11 2011, 04:58
- - xorgate   Hello and thanks for this wonderful plugin! I...   May 11 2011, 05:58
|- - revenant   Noticed a glitch with these new Facets builds so...   May 11 2011, 07:14
|- - tpijag   QUOTE (revenant @ May 11 2011, 01:14) Not...   May 11 2011, 13:16
- - adam777   Hello Frank, Thanks for this great update to Facet...   May 11 2011, 07:58
- - el-jaguar   In can't change the sorting order of autoplayl...   May 11 2011, 18:22
- - Takaji   Perhaps this has been answered already, but I...   May 12 2011, 01:42
- - Porcus   Just got tipped about this. Like it, but: how do I...   May 12 2011, 17:27
- - tpijag   not sure what you are asking about. What does the ...   May 12 2011, 17:46
|- - Porcus   QUOTE (tpijag @ May 12 2011, 18:46) not s...   May 12 2011, 20:36
- - TomBarlow   You're thinking of the album list. It's no...   May 12 2011, 20:49
|- - Porcus   Thanks, but then: Can I get tree view with facets,...   May 12 2011, 22:02
|- - DustMagnet   No, facets is a set of cascading lists. What you c...   May 12 2011, 23:00
- - tpijag   Is there really a need for that question. Clearly ...   May 12 2011, 22:40
- - SASN   I did some searching but did not find what I was l...   May 13 2011, 13:41
- - marc2003   $left(%artist%,1)   May 13 2011, 13:52
- - SASN   Great! Thanks.   May 13 2011, 14:17
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 5th May 2015 - 15:02
