Multiformat listening test @ ~64kbps: Results, Results and post-test discussion
IgorC
post Apr 12 2011, 00:40
The test is finished, results are available here:
http://listening-tests.hydrogenaudio.org/igorc/results.html
Summary: CELT/Opus won, Apple HE-AAC is better than Nero HE-AAC, and Vorbis has caught up with Nero HE-AAC.
Alex B
post Apr 12 2011, 14:14
For comparison I uploaded a rar package of my "chunky" folder. it contains the reorganized result files and phong's chunky (Windows version). The command line I used is in the instructions.txt file
I had to partially rename the result files to reorganize them into the sample folders. In addition I needed to change all r.wav strings inside the result files to .wav before chunky could work. I batch processed the files with Notepad++. I believe it was a "safe" edit.
The package is here: http://www.hydrogenaudio.org/forums/index....showtopic=88033
This post has been edited by Alex B: Apr 12 2011, 14:45
Garf
post Apr 12 2011, 14:49
Mad Scientist
Group: Admin
QUOTE (Alex B @ Apr 12 2011, 15:14) *
I had to partially rename the result files to reorganize them into the sample folders. In addition I needed to change all r.wav strings in filenames to .wav before chunky could work. I batch processed the files with Notepad++. I believe it was a "safe" edit.
Thanks, I didn't have the triaged results here, so this was welcome. By the way, chunky has quite dangerous behavior: by default, it squashes all listeners together per sample for the overall results. In other words, its discarding most of the information in the test, as if only a single listener did all samples! The per-sample results don't suffer from that, so those should be fine.
Edit: Whoops, I indeed missed some results that should have been discarded.
This post has been edited by Garf: Apr 12 2011, 15:18
- IgorC   Multiformat listening test @ ~64kbps: Results   Apr 12 2011, 00:40
- - Garf   If someone can assist with a bitrate table or per-...   Apr 12 2011, 01:02
- - Garf   Oh, and given that Opus is open sourced, if one of...   Apr 12 2011, 01:06
- - AllanP   I just wonder one thing, when the Vorbis encoder w...   Apr 12 2011, 01:14
|- - Garf   QUOTE (AllanP @ Apr 12 2011, 02:14) I jus...   Apr 12 2011, 01:15
|- - AllanP   QUOTE (Garf @ Apr 12 2011, 02:15) You can...   Apr 12 2011, 01:22
- - romor   Congratulation to CELT/Opus! I wanted to com...   Apr 12 2011, 03:08
- - IgorC   I think the results of lessthanjoey and AlexB are ...   Apr 12 2011, 03:50
- - googlebot   I'm stunned by the CELT/Opus results! I wo...   Apr 12 2011, 08:06
|- - NullC   QUOTE (googlebot @ Apr 11 2011, 23:06) I...   Apr 14 2011, 05:00
|- - saratoga   QUOTE (NullC @ Apr 14 2011, 00:00) We als...   Apr 14 2011, 06:29
||- - NullC   QUOTE (saratoga @ Apr 13 2011, 22:29) Is ...   Apr 14 2011, 08:30
|- - Garf   QUOTE (NullC @ Apr 14 2011, 06:00) Low-la...   Apr 14 2011, 12:19
|- - jmvalin   QUOTE (Garf @ Apr 14 2011, 07:19) Is the ...   Apr 14 2011, 14:04
|- - NullC   QUOTE (Garf @ Apr 14 2011, 03:19) QUOTE (...   Apr 14 2011, 17:47
|- - C.R.Helmrich   QUOTE (NullC @ Apr 14 2011, 18:47) The sw...   Apr 14 2011, 23:39
|- - jmvalin   QUOTE (C.R.Helmrich @ Apr 14 2011, 18:39)...   Apr 15 2011, 05:49
- - Alex B   Thanks guys! Interesting results. One note t...   Apr 12 2011, 12:59
|- - Garf   QUOTE (Alex B @ Apr 12 2011, 13:59) I got...   Apr 12 2011, 13:53
|- - NullC   QUOTE For processing the result .txt files with ch...   Apr 12 2011, 14:48
|- - Garf   QUOTE (NullC @ Apr 12 2011, 15:48) Sounds...   Apr 12 2011, 14:59
||- - Alex B   QUOTE (Garf @ Apr 12 2011, 16:59) But the...   Apr 12 2011, 15:09
|- - Alex B   QUOTE (NullC @ Apr 12 2011, 16:48) Sounds...   Apr 12 2011, 15:02
|- - NullC   QUOTE (Alex B @ Apr 12 2011, 07:02) QUOTE...   Apr 12 2011, 15:17
|- - motion_blur   QUOTE (Alex B @ Apr 12 2011, 16:02) QUOTE...   Apr 12 2011, 16:15
|- - NullC   QUOTE (motion_blur @ Apr 12 2011, 08:15) ...   Apr 12 2011, 17:54
|- - motion_blur   QUOTE (NullC @ Apr 12 2011, 18:54) QUOTE ...   Apr 12 2011, 19:42
- - Alex B   For comparison I uploaded a rar package of my ...   Apr 12 2011, 14:14
|- - Garf   QUOTE (Alex B @ Apr 12 2011, 15:14) For c...   Apr 12 2011, 14:49
- - Alex B   QUOTE (Garf @ Apr 12 2011, 16:59) But the...   Apr 12 2011, 15:35
|- - Garf   QUOTE (Alex B @ Apr 12 2011, 16:35) QUOTE...   Apr 12 2011, 15:42
- - Alex B   Regarding the bitrate table, I guess that CELT/Op...   Apr 12 2011, 16:14
|- - NullC   QUOTE (Alex B @ Apr 12 2011, 08:14) Regar...   Apr 12 2011, 18:10
- - IgorC   Yes, I was too strict. Sorry about it. Some of th...   Apr 12 2011, 18:13
|- - motion_blur   QUOTE (IgorC @ Apr 12 2011, 19:13) Yes, I...   Apr 12 2011, 20:09
|- - NullC   QUOTE (motion_blur @ Apr 12 2011, 12:09) ...   Apr 13 2011, 00:59
|- - motion_blur   QUOTE (NullC @ Apr 13 2011, 01:59) QUOTE ...   Apr 13 2011, 10:06
- - markanini   I figured ratings would vary between testers depen...   Apr 12 2011, 18:52
|- - NullC   QUOTE (markanini @ Apr 12 2011, 09:52) I ...   Apr 12 2011, 20:57
- - lessthanjoey   I've done some more testing with headphones af...   Apr 12 2011, 19:51
- - C.R.Helmrich   Thanks for organizing the tests, guys! Sorry f...   Apr 12 2011, 20:11
|- - motion_blur   QUOTE (C.R.Helmrich @ Apr 12 2011, 21:11)...   Apr 12 2011, 20:41
|- - Garf   QUOTE Please provide the number of valid results (...   Apr 12 2011, 21:44
||- - C.R.Helmrich   Sorry, Christoph, can't reproduce it. What you...   Apr 12 2011, 22:12
||- - Garf   QUOTE (C.R.Helmrich @ Apr 12 2011, 23:12)...   Apr 12 2011, 23:37
||- - motion_blur   QUOTE (C.R.Helmrich @ Apr 12 2011, 23:12)...   Apr 13 2011, 00:41
|- - NullC   QUOTE (C.R.Helmrich @ Apr 12 2011, 11:11)...   Apr 12 2011, 21:47
- - IgorC   motion_blur, You can download the results of all...   Apr 12 2011, 20:21
|- - _mē_   Some presentation suggestions: 1. Codec versions a...   Apr 12 2011, 20:43
|- - IgorC   QUOTE (_mē_ @ Apr 12 2011, 16:43) Some pr...   Apr 12 2011, 20:46
|- - Alex B   QUOTE (_mē_ @ Apr 12 2011, 22:43) 2. Link...   Apr 12 2011, 21:06
||- - Alex B   QUOTE (Alex B @ Apr 12 2011, 23:06) QUOTE...   Apr 13 2011, 11:38
||- - NullC   QUOTE (Alex B @ Apr 13 2011, 02:38) The b...   Apr 13 2011, 12:41
||- - Garf   QUOTE (NullC @ Apr 13 2011, 13:41) QUOTE ...   Apr 13 2011, 12:54
||- - Alex B   QUOTE (NullC @ Apr 13 2011, 14:41) Any id...   Apr 13 2011, 14:46
||- - NullC   QUOTE (Alex B @ Apr 13 2011, 05:46) QUOTE...   Apr 13 2011, 22:48
|- - Garf   QUOTE (_mē_ @ Apr 12 2011, 21:43) Some pr...   Apr 12 2011, 22:24
- - Alex B   Here is the raw data for a bitrate table. The bitr...   Apr 12 2011, 20:30
- - IgorC   Thank you for your help, AlexB. If you can do the ...   Apr 12 2011, 20:44
- - C.R.Helmrich   Christoph, do you mean the slightly washed out bas...   Apr 12 2011, 20:52
|- - motion_blur   QUOTE (C.R.Helmrich @ Apr 12 2011, 21:52)...   Apr 12 2011, 21:11
|- - C.R.Helmrich   QUOTE (motion_blur @ Apr 12 2011, 22:11) ...   Apr 12 2011, 21:38
|- - motion_blur   QUOTE (C.R.Helmrich @ Apr 12 2011, 22:38)...   Apr 12 2011, 21:56
- - IgorC   I've checked. The decoder on Christoph's s...   Apr 12 2011, 20:54
- - Alex B   Here's the bitrate table: In Excel format: ...   Apr 12 2011, 22:20
|- - saintdev   QUOTE (Alex B @ Apr 12 2011, 14:20) Here...   Apr 12 2011, 23:21
- - NullC   QUOTE (IgorC @ Apr 11 2011, 16:40) The te...   Apr 13 2011, 04:42
|- - Garf   QUOTE (NullC @ Apr 13 2011, 05:42) Hey al...   Apr 13 2011, 08:27
||- - IgorC   QUOTE (Garf @ Apr 13 2011, 04:27) One thi...   Apr 14 2011, 05:57
|- - C.R.Helmrich   Thanks, Garf, for the plot! And thanks, Christ...   Apr 13 2011, 22:46
|- - Garf   QUOTE (C.R.Helmrich @ Apr 13 2011, 23:46)...   Apr 13 2011, 22:57
||- - C.R.Helmrich   QUOTE (Garf @ Apr 13 2011, 23:57) From th...   Apr 13 2011, 23:06
|- - jmvalin   QUOTE (C.R.Helmrich @ Apr 13 2011, 17:46)...   Apr 14 2011, 00:58
|- - Garf   QUOTE (jmvalin @ Apr 14 2011, 01:58) I do...   Apr 14 2011, 09:13
|- - jmvalin   QUOTE (Garf @ Apr 14 2011, 04:13) You are...   Apr 14 2011, 11:41
- - Garf   The result page is now updated with per-sample gra...   Apr 13 2011, 12:41
- - mixminus1   Thanks much to all for their work in both setting ...   Apr 13 2011, 14:55
|- - Garf   QUOTE (mixminus1 @ Apr 13 2011, 15:55) Th...   Apr 13 2011, 15:04
- - mixminus1   :facepalm: Good God... Thanks, Garf, I was scour...   Apr 13 2011, 15:15
- - romor   @Garf: can you please reupload results you posted ...   Apr 13 2011, 16:35
|- - Garf   QUOTE (romor @ Apr 13 2011, 17:35) @Garf:...   Apr 13 2011, 18:59
- - IgorC   AlexB, thank you for bitrate verification. I real...   Apr 13 2011, 17:12
- - pdq   Whether or not classical should be considered to b...   Apr 13 2011, 17:51
|- - IgorC   QUOTE (pdq @ Apr 13 2011, 13:51) Whether ...   Apr 13 2011, 18:01
|- - pdq   QUOTE (IgorC @ Apr 13 2011, 13:01) QUOTE ...   Apr 13 2011, 18:53
- - romor   file: http://people.xiph.org/~greg/opus/ha2011/2.....   Apr 13 2011, 19:28
|- - NullC   QUOTE (romor @ Apr 13 2011, 10:28) file: ...   Apr 13 2011, 19:53
- - IgorC   Bitrate verification on my set of albums: http:/...   Apr 13 2011, 21:45
|- - NullC   QUOTE (IgorC @ Apr 13 2011, 13:45) Bitrat...   Apr 21 2011, 19:15
|- - jmvalin   QUOTE (NullC @ Apr 21 2011, 14:15) QUOTE ...   Apr 21 2011, 19:53
- - Garf   QUOTE Has anyone ever seriously blind-tested e.g. ...   Apr 14 2011, 00:10
|- - C.R.Helmrich   QUOTE (Garf @ Apr 14 2011, 01:10) I'm...   Apr 14 2011, 10:46
- - .alexander.   The second graph seems to be consistent with ...   Apr 15 2011, 12:40
|- - jmvalin   QUOTE (.alexander. @ Apr 15 2011, 07:40) ...   Apr 15 2011, 15:17
- - Xanikseo   QUOTE (IgorC @ Apr 13 2011, 21:45) Bitrat...   Apr 20 2011, 16:34
|- - Garf   QUOTE (Xanikseo @ Apr 20 2011, 17:34) Igo...   Apr 20 2011, 18:02
|- - IgorC   QUOTE (Xanikseo @ Apr 20 2011, 12:34) Igo...   Apr 20 2011, 18:19
|- - Zarggg   QUOTE (Xanikseo @ Apr 20 2011, 11:34) EDI...   Apr 20 2011, 19:09
- - Xanikseo   QUOTE (Zarggg @ Apr 20 2011, 19:09) QUOTE...   Apr 20 2011, 21:20
- - IgorC   NullC, h*tp://www.mediafire.com/?s7i9usu2qr27pcg ...   Apr 21 2011, 23:52
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th July 2015 - 19:15
