BASSMIDI MIDI synthesiser for Windows XP/Vista/7, A new SoundFont based MIDI synth for Win7/Vista/XP
mudlord
post Mar 23 2011, 14:33
Group: Developer (Donating)
Features:
* Dynamic sample caching
* Unlimited polyphony
* SoundFont chaining/stacking
MIDI note events.
MIDI program events.
Channel pressure.
Pitch wheel.
Bank change MSB. (CC#0)
Modulation. (CC#1)
Volume. (CC#7)
Panning. (CC#10)
Expression. (CC#11)
Sustain pedal. (CC#64)
Soft pedal. (CC#67)
Reverb send level. (CC#91)
Chorus send level. (CC#93)
Stop all sounds. (CC#120)
Release all keys. (CC#123)
Pitch wheel range. (RPN 0)
Fine tuning. (RPN 1)
Coarse tuning. (RPN 2)
This post has been edited by mudlord: Aug 3 2012, 00:57
raygrote
post Sep 5 2011, 17:54
I agree with you. They would be nice to have but aren't necessary. Besides, I use XM Play for my rendering, so bassmidi is only there for the sequencing. I can deal with certain things not sounding exactly the same while I'm sequencing it.
- mudlord   BASSMIDI MIDI synthesiser for Windows XP/Vista/7   Mar 23 2011, 14:33
- - romor   Thanks kode54 How should I add Colossus? It...   Mar 29 2011, 08:50
|- - mudlord   QUOTE (romor @ Mar 29 2011, 02:50) Thanks...   Mar 31 2011, 08:27
- - RichNagel   Hi Mudlord and Kode54, Man... I've been looki...   Mar 31 2011, 07:51
- - mudlord   I guess the reason why it knocks out MIDI Yoke, is...   Mar 31 2011, 08:24
|- - RichNagel   QUOTE (mudlord @ Mar 31 2011, 02:24) I gu...   Mar 31 2011, 18:40
- - romor   great thanks for the tip I used in the past MIDI ...   Mar 31 2011, 08:56
- - romor   also allow me to throw another thing I forgot to p...   Mar 31 2011, 10:33
- - mudlord   Same feature, because of exact same synth library ...   Mar 31 2011, 10:59
- - mudlord   I posted a updated driver a while back on my site,...   Apr 3 2011, 00:25
- - Vagabond   If I have a Creative sound card and use the Creati...   Apr 3 2011, 02:00
- - mudlord   If you play around with MIDI's a fair bit, sur...   Apr 3 2011, 07:33
- - Vagabond   Thanks! Now to figure out how to remove Micros...   Apr 3 2011, 20:08
|- - mudlord   QUOTE (Vagabond @ Apr 3 2011, 14:08) Than...   Apr 4 2011, 11:19
|- - RichNagel   QUOTE (mudlord @ Apr 4 2011, 05:19) And w...   Apr 4 2011, 12:21
|- - Vagabond   QUOTE (mudlord @ Apr 4 2011, 05:19) QUOTE...   Apr 4 2011, 17:35
|- - mudlord   QUOTE (Vagabond @ Apr 4 2011, 10:35) QUOT...   Apr 5 2011, 11:08
|- - Vagabond   QUOTE (mudlord @ Apr 5 2011, 05:08) QUOTE...   Apr 7 2011, 01:07
- - tima   This is a great idea! I've been using loop...   Apr 5 2011, 06:14
|- - mudlord   QUOTE (tima @ Apr 4 2011, 23:14) There ar...   Apr 5 2011, 11:10
- - mudlord   Actually, might have a solution to the MIDI sticki...   Apr 6 2011, 08:57
- - mudlord   Uploaded new version. Don't blame me if your A...   Apr 7 2011, 11:59
|- - RichNagel   QUOTE (mudlord @ Apr 7 2011, 05:59) Uploa...   Apr 7 2011, 13:35
- - mudlord   Wow, only those? I was expecting much, much worse ...   Apr 7 2011, 13:42
|- - RichNagel   QUOTE (mudlord @ Apr 7 2011, 07:42) Wow, ...   Apr 7 2011, 14:08
- - mudlord   Lets see..... QUOTE C:\Test\BASS.dll ......   Apr 7 2011, 15:06
|- - RichNagel   Hehe, well at least it realizes they are packed LO...   Apr 7 2011, 15:26
- - mudlord   Yep, thats the main thing. I still need to fix up...   Apr 8 2011, 05:37
- - mudlord   Finally managed to reproduce the issues people are...   Apr 11 2011, 08:55
|- - RichNagel   @Mudlord, Just a status-report, the new version (...   Apr 15 2011, 05:49
- - mudlord   yay!   Apr 17 2011, 11:37
|- - RichNagel   Hey Mudlord, Is something up with your web site? ...   Apr 19 2011, 23:39
|- - mudlord   QUOTE (RichNagel @ Apr 19 2011, 16:39) He...   Apr 20 2011, 04:12
- - romor   it seems your IP address is blocked for some reaso...   Apr 20 2011, 02:08
- - tpijag   Connection and download fine here. Correction: Th...   Apr 20 2011, 02:30
- - romor   I don't know, try contacting them http://www.e...   Apr 20 2011, 04:48
- - mudlord   Hmmm I wonder why its on the list..... tima's...   Apr 20 2011, 05:38
- - romor   don't think that single user can make IP black...   Apr 20 2011, 06:00
- - mudlord   Newly updated content is now: http://www.virustota...   Apr 20 2011, 06:20
- - romor   If someone submitted report (which includes attach...   Apr 20 2011, 07:17
- - mudlord   Sent some reports to ESET. Waiting on them.   Apr 20 2011, 08:04
|- - RichNagel   The new one downloads just fine It was weird tho...   Apr 20 2011, 11:53
- - mudlord   Yay, I am just glad every major bug is now elimina...   Apr 20 2011, 13:05
|- - RichNagel   QUOTE (mudlord @ Apr 20 2011, 07:05) Just...   Apr 20 2011, 14:28
- - mudlord   I use foo_midi, so I personally find that a non-is...   Apr 20 2011, 16:13
|- - RichNagel   QUOTE (mudlord @ Apr 20 2011, 10:13) I us...   Apr 21 2011, 04:01
- - mudlord   Maybe we should go back to force restarting your s...   Apr 21 2011, 05:13
|- - RichNagel   QUOTE (mudlord @ Apr 20 2011, 23:13) Oh h...   Apr 21 2011, 05:24
- - mudlord   Oh...that certainly complicates things. I posted i...   Apr 21 2011, 05:25
- - Vagabond   In case anyone ventures here about changing MIDI I...   Apr 22 2011, 17:10
- - tima   QUOTE (mudlord @ Apr 19 2011, 22:12) Long...   Apr 23 2011, 20:40
- - mudlord   QUOTE I have not reported you to anyone. I have no...   Apr 27 2011, 05:21
- - mudlord   unrelated: been busy on new dialogs and options fo...   Apr 28 2011, 05:09
- - mudlord   uploaded 1.06 with volume control abilities as req...   Apr 29 2011, 17:25
|- - RichNagel   QUOTE (mudlord @ Apr 29 2011, 11:25) uplo...   Apr 30 2011, 01:20
|- - RichNagel   XMPlay MIDI Plugin/BASSMIDI/BASSMIDI Driver MIDI I...   May 7 2011, 03:16
- - mudlord   Uploaded 2.0 to github on frontpage. The changelo...   May 19 2011, 18:52
- - Dynamic   Thanks to all concerned. It's been years since...   May 21 2011, 07:29
|- - RichNagel   QUOTE (Dynamic @ May 21 2011, 01:29) I ho...   May 22 2011, 04:24
|- - Dynamic   QUOTE (RichNagel @ May 22 2011, 03:24) Ga...   May 28 2011, 22:25
|- - RichNagel   QUOTE (Dynamic @ May 28 2011, 16:25) Than...   May 29 2011, 01:55
- - E.J.   Thanks for this. It's great stuff. Are there ...   May 21 2011, 18:05
|- - mudlord   QUOTE (E.J. @ May 21 2011, 11:05) Thanks ...   May 22 2011, 13:26
|- - kode54   QUOTE (E.J. @ May 21 2011, 10:05) Are the...   May 29 2011, 00:31
|- - RichNagel   @Kode54, It doesn't look like Mudlord has log...   May 29 2011, 17:24
- - mudlord   Started uploading a few recordings from the synth....   May 22 2011, 23:19
|- - RichNagel   QUOTE (mudlord @ May 22 2011, 17:19) Star...   May 23 2011, 02:39
|- - RichNagel   QUOTE (mudlord @ May 22 2011, 17:19) Migh...   May 23 2011, 04:30
- - mudlord   A workaround is in the source now.... I do not vis...   May 31 2011, 06:40
|- - RichNagel   QUOTE (mudlord @ May 31 2011, 00:40) A wo...   May 31 2011, 17:40
- - mudlord   The installer will be compiled when things in my l...   Jun 6 2011, 08:37
|- - RichNagel   No problem, Mudlord. I hope everything works out ...   Jun 6 2011, 16:09
- - mudlord   Shit settled down, so I looked at some stuff. Not...   Jun 15 2011, 04:42
|- - RichNagel   QUOTE (mudlord @ Jun 14 2011, 22:42) Not ...   Jun 25 2011, 04:28
- - mudlord   I am personally curious how that ass solved it in ...   Jun 25 2011, 10:29
|- - RichNagel   QUOTE (mudlord @ Jun 25 2011, 04:29) I am...   Jun 25 2011, 17:16
|- - mudlord   Yes, using a heavily modified XG VSTi, allow for a...   Jun 25 2011, 20:42
- - mudlord   Yay: http://blog.bits-in-motion.com/2009/05/vis......   Jun 27 2011, 23:37
- - mudlord   http://www.vgmusic.com/phpBB3/viewtopic.ph...=1201...   Jul 3 2011, 11:17
- - mudlord   added 2.01/2.02 changelog is at usual spot.   Jul 10 2011, 07:08
- - raygrote   Hi, Just came across this driver awhile ago, and I...   Aug 13 2011, 22:30
- - mudlord   Are you sure there is a voice limit like that? In ...   Aug 19 2011, 06:31
- - raygrote   Hi, Thank you for replying. In the newest version ...   Aug 19 2011, 07:08
- - mudlord   So newest plugin has a increased voice limit? neve...   Aug 21 2011, 01:59
|- - PaVliQ   Great. I have installed it on several machines on ...   Sep 5 2011, 16:47
- - raygrote   I agree with you. They would be nice to have but a...   Sep 5 2011, 17:54
- - mudlord   I really need to get my ass in gear and fixing som...   Sep 8 2011, 11:57
- - bennetng   I am using win7 x64 and BASSMIDI driver version 2....   Sep 17 2011, 17:58
- - mudlord   Known bug. Keep pestering us about it with a bugr...   Sep 18 2011, 05:56
- - raygrote   Interesting bug there. My problem with volume is o...   Sep 19 2011, 00:36
- - mudlord   When was volume changing last working?   Sep 19 2011, 13:03
- - raygrote   Hmm, I don't know. I never had to use it since...   Sep 19 2011, 21:10
- - mudlord   Oh, weird, will need to look at it. In the meantim...   Sep 20 2011, 02:42
|- - bennetng   QUOTE (mudlord @ Sep 20 2011, 09:42) Oh, ...   Sep 20 2011, 12:29
- - Batman321   How do I uninstall it?   Sep 20 2011, 18:48
- - raygrote   Hi, there is an uninstall option in all programs, ...   Sep 21 2011, 01:06
- - HunterZ   What happened to Mudlord's account and the pro...   Sep 21 2011, 15:25
- - mudlord   I'm migrating the source code and binaries to ...   Sep 21 2011, 21:21
- - HunterZ   QUOTE (mudlord @ Sep 21 2011, 12:21) I...   Sep 21 2011, 21:42
- - mudlord   Sorry bout that. Source for bassmididrv is here: h...   Sep 21 2011, 21:44
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 19th April 2015 - 10:11
