6 Pages V   1 2 3 > »
Closed TopicStart new topic
foobar2000 v1.1.6 beta, 2011-04-22: 1.1.6 final out
Case
post Mar 20 2011, 11:40
Group: Developer (Donating)
Edit on 2011-03-25:
foobar2000 v1.1.6 beta 2 is out.
  • foobar2000 now uses " / " string as multi-artist delimiter in ID3v2.3 artist fields.
  • Added an advanced preferences option to toggle between treating TPE2 as BAND or ALBUM ARTIST.
foobar2000 v1.1.6 beta 1 was just released.
  • Improved performance when playing very short tracks.
  • Improved tag compatibility with other software.
    • “Album artist” is mapped to ID3v2 TPE2 like in WMP/iTunes.
    • Support for iTunes “itunescompilation” tags, in MP3/ID3v2 and MP4.
    • ID3v2.3 tags are now written by default since version 2.4 seems to be widely ignored by software vendors.
    • Added support for multi-value WMA tags.
    • Special work-around for "AC/DC" artist in ID3v2.3.
  • Improved reading of MP3 encoding information headers written by alpha versions of LAME.
  • ReplayGain scanner now uses libebur128 for improved accuracy.
Download - Change Log
[edit]
Split Discussions not related to beta:
Muzack needs help with monitoring problem
Godrick asks an unrelated question about the Album list
Unrelated feature request #1
Clarifying the changes made with reading the ITUNESCOMPILATION frame
Rewriting tags rewrites "all" tag fields?
This post has been edited by shakey_snake: Apr 8 2011, 16:33
q-stankovic
post Mar 20 2011, 12:40
If you look back in many discussions here it is surprisingly to see that this release is lead to achieve more compliance with other programs instead of more compliance with specifications. However, very senseful to to be compliant with the "real" and de-facto standard. Good decision.
This post has been edited by q-stankovic: Mar 20 2011, 13:23
nosgah
post Mar 20 2011, 12:58
I'm just as surprised as the poster above...
Why the change of heart? Has the user-base been decreasing?
klonuo
post Mar 20 2011, 13:02
QUOTE (Case @ Mar 20 2011, 12:40) *
[*]Improved tag compatibility with other software.
It seems that remapping MP3s should be considered. But, don't be too reckless wink.gif http://www.hydrogenaudio.org/forums/index....showtopic=83831
[*]ReplayGain scanner now uses libebur128 for improved accuracy.
Maybe installer could detect foo_r128scan, and disable it as redundant
And there is no option for selecting old RG scanner, hm...
chiwou
post Mar 20 2011, 14:04
How can I use the "new" %album artist% tag?
I have some files with a %band% tag, but it doesn't show if I use %album artist% and if I use %band% it doesn't show the %artist% tag if %band% isn't present
lvqcl
Note that libeburl128 treats mono files as 1-channel file, and old fb2k replaygain - as stereo with left channel == right channel.
So, mono files will be ~3dB louder.
Kuraj
post Mar 20 2011, 14:43
YES!
I applaud this update VERY MUCH!
marc2003
post Mar 20 2011, 14:44
QUOTE (Case @ Mar 20 2011, 10:40) *
[*]ID3v2.3 tags are now written by default since version 2.4 seems to be widely ignored by software vendors.
whilst this is a good idea for new installs, i didn't like the way my setting was changed from 2.4 to 2.3 automatically when upgrading. i hope this won't happen with all future updates.
Peter
post Mar 20 2011, 14:58
foobar2000 developer
Group: Admin
QUOTE (marc2003 @ Mar 20 2011, 14:44) *
This was introduced with the assumption that average users don't really know or care what the differences between these ID3v2 revisions are. If you have good reasons to use ID3v2.4, I'd like to hear them.
Case
post Mar 20 2011, 15:00
QUOTE (chiwou @ Mar 20 2011, 15:04) *
Reload info from tags as instructed at the bottom of this page.
Alex B
post Mar 20 2011, 15:06
The ID3v2 tagging changes are at least interesting. If the new system works fine it'll save me from doing the additional step of changing the format to 2.3 with Mp3tag (in my experience the old compatibility mode didn't maintain all externally tagged tags correctly).
I am not so sure if I like the Replay Gain scanner change. I have been quite happy with the old implementation during the last few years. I did some limited testing with the R128 component over a month ago and I noticed some differences in the results that were not exactly to my liking, but I did not have time to further investigate the issue and take part in the discussions. I did not expect it to replace the old implementation.
Prodoc
post Mar 20 2011, 15:16
While I understand that compatibility is important, I'm sad to see that classical music is being ignored completely by the change to using TPE2 for the ALBUM ARTIST. It was already ignored by other vendors, now foobar can be added to that list. Where am I expected to store the orchestra now?
I realize it's a problem for the other vendors to fix, but that won't happen. Using foobar as the ideal tagging application has now been made history because all classical music will now be listed under the orchestra instead of the composer on audio devices. Luckily this can at least be fixed manually for foobar but still...
TomBarlow
post Mar 20 2011, 15:23
Does the AC/DC workaround only work for AC/DC or any artist or tag with a / in? I have quite a few other artists and albums with slashes.
QUOTE (Prodoc @ Mar 20 2011, 14:16) *
I use %performer% - I don't know what frame that lives in. I put %composer%; %conductor%; %performer% in %album artist%, if %performer% is multi-valued then I just put it as a comma separated list in %album artist%. Oh and %artist% = %composer% for compatibility with last.fm. I know I'm not following the ID3 standard but it works for me.
This post has been edited by shakey_snake: Mar 20 2011, 15:42
Reason for edit: Posts merged.
marc2003
post Mar 20 2011, 15:38
QUOTE (Peter @ Mar 20 2011, 13:58) *
mainly to have the / support in tags. i don't have any AC/DC in my collection but i do have other artists with a /. and to answer Tom's question above, the workaround only works for AC/DC.
i only ever use foobar2000 on my PC and my portable supports id3v2.4 also.
This post has been edited by marc2003: Mar 20 2011, 15:41
shakey_snake
post Mar 20 2011, 15:39
Post #15
Group: FB2K Moderator
QUOTE (TomBarlow @ Mar 20 2011, 10:23) *
...such as?
This post has been edited by shakey_snake: Mar 20 2011, 15:40
elevatorladylevitateme
Alex B
post Mar 20 2011, 15:49
Post #16
De/Vision
http://www.discogs.com/artist/De%2FVision
EDIT:
AC/OT
http://www.discogs.com/artist/AC%2FOT
This post has been edited by Alex B: Mar 20 2011, 15:57
chiwou
Post #17
QUOTE (Case @ Mar 20 2011, 16:00) *
for example
I use grouping in my playlist: %album artist% - %album%
when I listen to some soundtracks with different %artist% I added an %album artist% tag, even if it already had a %band% tag
but even after a "reload" the group won't show the %band% tag (after I removed the %album artist% tag
Kuraj
Post #18
QUOTE (shakey_snake @ Mar 20 2011, 08:39) *
...such as?
Slash
OK, seriously now. Creating a workaround for one particular artist here really sounds like a weird idea, because obviously there will be more artists with a "/" sign in their names, even if you can't recall any.
Because noone ever said you can't have a "/" in your band name tongue.gif
This post has been edited by Kuraj: Mar 20 2011, 15:53
db1989
post Mar 20 2011, 16:12
Post #19
Actually, those who wrote the ID3v2.3 spec said exactly that!
But yeah, a single-instance workaround isn’t a good idea, IMHO. Although it will relieve shakey_snake of the responsibility of having to paste that long list of topics written by confused AC/DC fans smile.gif
Overall, I can see why such changes were implemented, but they wouldn’t be necessary if the ID3v2 standards and various implementations thereof weren’t so discrepant. In a way, it’s laudable that the developers tried to adhere to the standards for so long, but perhaps it just didn’t seem worth it any more.
skexu
post Mar 20 2011, 16:24
Post #20
In polish rap the / is very common for collaborations. Dunno how for other world.
Let me understand, does this fix repair allow these names to be displayed as one and not separating with a semicolon?
Case
post Mar 20 2011, 16:30
Post #21
Peter is planning on removing the AC/DC workaround and instead write different character in place of /. I'm against the change and have suggested him to not treat / as multivalue separator in ID3v2.3 artist field at all and allow it as is. Is anyone against that suggestion?
KarnEvil9
post Mar 20 2011, 16:36
Post #22
QUOTE (shakey_snake @ Mar 20 2011, 06:39) *
...such as?
G//Z/R
My Last.fm Profile: http://www.last.fm/user/_Tarkus_/
skexu
post Mar 20 2011, 16:37
Post #23
Yeah. Can't still get to work few artists. After installation of 1.1.6 editing tags ended for me with "_" instead of "/". Last.fm fan here.
ernstblaauw
post Mar 20 2011, 16:51
Post #24
QUOTE (Case @ Mar 20 2011, 03:40) *
Does this mean foobar also writes to the itunescompilation flag if 'Various Artists' is set in the Album Artist field? Or does foobar only read this flag? For me, writing would be great.
This post has been edited by Frank Bicking: Mar 20 2011, 16:56
Reason for edit: Reduced quote to relevant part.
Frank Bicking
post Mar 20 2011, 17:34
Post #25
QUOTE (ernstblaauw @ Mar 20 2011, 16:51) *
No. It was determined that even iTunes ignores its own flag if album artist is set.
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 30th May 2015 - 14:16
