foobar2000 v1.1.6 beta, 2011-04-22: 1.1.6 final out
Case
post Mar 20 2011, 11:40
Group: Developer (Donating)
Edit on 2011-03-25:
foobar2000 v1.1.6 beta 2 is out.
  • foobar2000 now uses " / " string as multi-artist delimiter in ID3v2.3 artist fields.
  • Added an advanced preferences option to toggle between treating TPE2 as BAND or ALBUM ARTIST.
foobar2000 v1.1.6 beta 1 was just released.
  • Improved performance when playing very short tracks.
  • Improved tag compatibility with other software.
    • “Album artist” is mapped to ID3v2 TPE2 like in WMP/iTunes.
    • Support for iTunes “itunescompilation” tags, in MP3/ID3v2 and MP4.
    • ID3v2.3 tags are now written by default since version 2.4 seems to be widely ignored by software vendors.
    • Added support for multi-value WMA tags.
    • Special work-around for "AC/DC" artist in ID3v2.3.
  • Improved reading of MP3 encoding information headers written by alpha versions of LAME.
  • ReplayGain scanner now uses libebur128 for improved accuracy.
Download - Change Log
[edit]
Split Discussions not related to beta:
Muzack needs help with monitoring problem
Godrick asks an unrelated question about the Album list
Unrelated feature request #1
Clarifying the changes made with reading the ITUNESCOMPILATION frame
Rewriting tags rewrites "all" tag fields?
This post has been edited by shakey_snake: Apr 8 2011, 16:33
Sandrine
post Mar 26 2011, 05:03
I can't help but notice that replaygain results are very different in this version, sometimes vastly so. I've rescanned a few albums, and the difference is between 0.5-1.0db, and on a 24/96 5.1 DVD-A the difference was even reported as 4db! What am I to make of this?
- Case   foobar2000 v1.1.6 beta   Mar 20 2011, 11:40
- - q-stankovic   If you look back in many discussions here it is su...   Mar 20 2011, 12:40
- - nosgah   I'm just as surprised as the poster above... ...   Mar 20 2011, 12:58
- - klonuo   QUOTE (Case @ Mar 20 2011, 12:40) [*]Impr...   Mar 20 2011, 13:02
- - chiwou   How can I use the "new" %album artist% t...   Mar 20 2011, 14:04
|- - Case   QUOTE (chiwou @ Mar 20 2011, 15:04) I hav...   Mar 20 2011, 15:00
|- - chiwou   QUOTE (Case @ Mar 20 2011, 16:00) QUOTE (...   Mar 20 2011, 15:49
- - lvqcl   Note that libeburl128 treats mono files as 1-chann...   Mar 20 2011, 14:04
- - Kuraj   YES! I applaud this update VERY MUCH!   Mar 20 2011, 14:43
- - marc2003   QUOTE (Case @ Mar 20 2011, 10:40) [*]ID3v...   Mar 20 2011, 14:44
|- - Peter   QUOTE (marc2003 @ Mar 20 2011, 14:44) whi...   Mar 20 2011, 14:58
|- - marc2003   QUOTE (Peter @ Mar 20 2011, 13:58) If you...   Mar 20 2011, 15:38
- - Alex B   The ID3v2 tagging changes are at least interesting...   Mar 20 2011, 15:06
- - Prodoc   While I understand that compatibility is important...   Mar 20 2011, 15:16
- - TomBarlow   Does the AC/DC workaround only work for AC/DC or a...   Mar 20 2011, 15:23
- - shakey_snake   QUOTE (TomBarlow @ Mar 20 2011, 10:23) Do...   Mar 20 2011, 15:39
|- - Kuraj   QUOTE (shakey_snake @ Mar 20 2011, 08:39)...   Mar 20 2011, 15:49
|- - KarnEvil9   QUOTE (shakey_snake @ Mar 20 2011, 06:39)...   Mar 20 2011, 16:36
- - Alex B   De/Vision http://www.discogs.com/artist/De%2FVisio...   Mar 20 2011, 15:49
- - dv1989   Actually, those who wrote the ID3v2.3 spec said ex...   Mar 20 2011, 16:12
- - skexu   In polish rap the / is very common for collaborati...   Mar 20 2011, 16:24
- - Case   Peter is planning on removing the AC/DC workaround...   Mar 20 2011, 16:30
|- - TomBarlow   QUOTE (Case @ Mar 20 2011, 15:30) Peter i...   Mar 20 2011, 19:40
- - skexu   Yeah. Can't still get to work few artists. Aft...   Mar 20 2011, 16:37
- - ernstblaauw   QUOTE (Case @ Mar 20 2011, 03:40) Support...   Mar 20 2011, 16:51
|- - Frank Bicking   QUOTE (ernstblaauw @ Mar 20 2011, 16:51) ...   Mar 20 2011, 17:34
|- - ernstblaauw   QUOTE (Frank Bicking @ Mar 20 2011, 09:34...   Mar 20 2011, 17:52
||- - Prodoc   QUOTE (ernstblaauw @ Mar 20 2011, 17:52) ...   Mar 20 2011, 18:58
||- - Sandrine   QUOTE (Prodoc @ Mar 20 2011, 18:58) Apple...   Mar 21 2011, 01:44
|||- - shakey_snake   QUOTE (Sandrine @ Mar 20 2011, 20:44) Fro...   Mar 21 2011, 03:06
|||- - Sandrine   QUOTE (shakey_snake @ Mar 21 2011, 03:06)...   Mar 21 2011, 03:46
||- - ernstblaauw   QUOTE (Prodoc @ Mar 20 2011, 10:58) QUOTE...   Mar 21 2011, 23:43
|- - pone   any new hope for distinuishing between COMMENT and...   Mar 21 2011, 03:36
- - NEOhidra   Would you please add a switch to toggle between th...   Mar 20 2011, 17:58
- - tpijag   ernstblaauw Are you having trouble even after fol...   Mar 20 2011, 19:17
- - /mnt   Awesome update. Just wondering if it's possib...   Mar 20 2011, 19:33
- - NullString   if I understand correctly reading the posts above,...   Mar 20 2011, 19:45
- - tedgo   Thanks for the improved tag compatibility But co...   Mar 20 2011, 20:15
- - drbeachboy   I just wrote a ID3v2.3 tag as Album Artist and I g...   Mar 20 2011, 20:27
- - Case   Would the following change to ID3v2.3 tag handling...   Mar 20 2011, 21:13
|- - Melomane   QUOTE (Case @ Mar 20 2011, 21:13) Would t...   Mar 21 2011, 08:46
- - Hakubo   QUOTE (Case @ Mar 20 2011, 23:13) Would t...   Mar 20 2011, 21:55
- - sollniss   I'm using foobar2k because I can write whateve...   Mar 20 2011, 22:16
|- - Prodoc   QUOTE (sollniss @ Mar 20 2011, 22:16) I s...   Mar 20 2011, 23:36
- - romor   Maybe crazy idea like excluding artists by hand, b...   Mar 20 2011, 22:22
- - tpijag   Sollniss, No one said the user can not choose betw...   Mar 20 2011, 22:25
- - MuncherOfSpleens   Is there a noticeable performance impact when tagg...   Mar 20 2011, 23:00
|- - tpijag   QUOTE (MuncherOfSpleens @ Mar 20 2011, 17...   Mar 20 2011, 23:32
|- - MuncherOfSpleens   QUOTE (tpijag @ Mar 20 2011, 18:32) QUOTE...   Mar 21 2011, 22:54
|- - GeSomeone   QUOTE (MuncherOfSpleens @ Mar 21 2011, 23...   Mar 21 2011, 23:35
- - q-stankovic   QUOTE (Hakubo @ Mar 20 2011, 21:55) I thi...   Mar 20 2011, 23:01
- - neothe0ne   If the goal is now to be compliant with other soft...   Mar 20 2011, 23:53
- - durch   If the goal now is to improve tagging compatibilit...   Mar 21 2011, 08:31
- - Zarggg   To make the slash-separation issue in the artist t...   Mar 21 2011, 18:55
- - godrick   To clarify, does Foobar now map a "itunescomp...   Mar 21 2011, 19:07
- - BoraBora   Or maybe use "\\" as separator...   Mar 21 2011, 19:26
- - jeremija   Please forgive my ignorance, but doesn't fooba...   Mar 21 2011, 22:38
- - q-stankovic   QUOTE (jeremija @ Mar 21 2011, 22:38) Ple...   Mar 21 2011, 23:36
|- - dv1989   QUOTE (q-stankovic @ Mar 21 2011, 22...   Mar 22 2011, 13:20
|- - fbuser   QUOTE (dv1989 @ Mar 22 2011, 13:20) fooba...   Mar 22 2011, 21:55
- - Phil Meyer   Oh Dear :-( I'm not happy at all with this ne...   Mar 22 2011, 00:45
|- - kode54   QUOTE (Phil Meyer @ Mar 21 2011, 16:45) W...   Mar 22 2011, 07:59
|- - Phil Meyer   QUOTE (kode54 @ Mar 22 2011, 06:59) Vorbi...   Mar 22 2011, 09:22
- - Nowings69   AC/DC! Thanks for seriously but lets ro...   Mar 22 2011, 07:11
- - lordgibbness   I don't plan on moving back to ID3v2.3 as the ...   Mar 22 2011, 15:28
|- - shakey_snake   QUOTE (lordgibbness @ Mar 22 2011, 10:28)...   Mar 22 2011, 16:19
- - for4saken   I've tagged all my music with Picard (using a ...   Mar 22 2011, 17:18
- - q-stankovic   QUOTE (dv1989 @ Mar 22 2011, 13:20) fooba...   Mar 22 2011, 22:13
|- - Prodoc   QUOTE (q-stankovic @ Mar 22 2011, 22...   Mar 22 2011, 22:55
- - Robertina   QUOTE Improved performance when playing very short...   Mar 23 2011, 04:54
|- - Hank H.   QUOTE (Robertina @ Mar 22 2011, 22:54) Re...   Mar 23 2011, 21:37
- - C3POwen   As if by magic... Comparison of ID3 Standards. Not...   Mar 24 2011, 19:41
- - Case   Beta 2 is available now. ID3v2 tagging compatibili...   Mar 25 2011, 17:00
- - neothe0ne   I'm a little disappointed beta 2 didn't ad...   Mar 25 2011, 22:50
- - Sandrine   I can't help but notice that replaygain result...   Mar 26 2011, 05:03
- - kode54   You are supposed to read the change log and see th...   Mar 26 2011, 05:05
|- - Sandrine   QUOTE (kode54 @ Mar 26 2011, 05:05) You a...   Mar 26 2011, 05:29
- - tpijag   Are you looking for something more detailed than w...   Mar 26 2011, 05:09
|- - kode54   QUOTE (tpijag @ Mar 25 2011, 21:09) Edit:...   Mar 26 2011, 05:28
- - kode54   The difference varies per track. On average, the r...   Mar 26 2011, 06:12
- - q-stankovic   QUOTE (Prodoc @ Mar 22 2011, 23:55) QUOTE...   Mar 27 2011, 23:09
|- - Phil Meyer   QUOTE (q-stankovic @ Mar 27 2011, 22...   Mar 27 2011, 23:21
- - q-stankovic   That won't work after rewriting files either b...   Mar 27 2011, 23:27
- - dr_o_   QUOTE In case an ITUNESCOMPILATION tag is found in...   Mar 28 2011, 16:04
- - shakey_snake   Having any %album artist% value results in "s...   Mar 28 2011, 17:27
- - dr_o_   That was ironic. Of course ALBUM ARTIST is used fo...   Mar 28 2011, 18:13
|- - Zarggg   QUOTE (dr_o_ @ Mar 28 2011, 13:13) It wou...   Mar 28 2011, 22:02
|- - shakey_snake   QUOTE (dr_o_ @ Mar 28 2011, 13:13) btw It...   Mar 28 2011, 22:44
- - GeSomeone   QUOTE ID3v2.3 tags are now written by default, wit...   Mar 28 2011, 21:07
- - tdurjan101   I am having some difficulty with beta 2's mult...   Mar 29 2011, 03:38
|- - shakey_snake   QUOTE (tdurjan101 @ Mar 28 2011, 22:38) F...   Mar 29 2011, 03:50
- - durch   If tdurjan101's observations are true, then I ...   Mar 29 2011, 10:14
|- - GeSomeone   QUOTE (durch @ Mar 29 2011, 11:14) foobar...   Mar 29 2011, 11:22
- - TuNk77   Now that the ReplayGain scanner now uses libebur12...   Mar 29 2011, 15:54
- - Canar   It's funny, as of 1.1, foobar2000 changed to u...   Mar 29 2011, 16:40
- - krafty   QUOTE (tpijag @ Mar 26 2011, 05:09) Are y...   Mar 29 2011, 16:44
- - tpijag   I trust you are not asking for me to find the thre...   Mar 29 2011, 16:47
- - krafty   Absolutely not. Edit: What I suggest is that one ...   Mar 29 2011, 16:50
- - Phil Meyer   Yes, I have a lot of music that sounds like it nee...   Mar 29 2011, 20:18
- - Canar   QUOTE (krafty @ Mar 29 2011, 08:50) It wi...   Mar 29 2011, 20:56
2 Pages V   1 2 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 29th July 2015 - 16:20
