foobar2000 v1.1.6 beta, 2011-04-22: 1.1.6 final out
Case
post Mar 20 2011, 11:40
Group: Developer (Donating)
Edit on 2011-03-25:
foobar2000 v1.1.6 beta 2 is out.
  • foobar2000 now uses " / " string as multi-artist delimiter in ID3v2.3 artist fields.
  • Added an advanced preferences option to toggle between treating TPE2 as BAND or ALBUM ARTIST.
foobar2000 v1.1.6 beta 1 was just released.
  • Improved performance when playing very short tracks.
  • Improved tag compatibility with other software.
    • “Album artist” is mapped to ID3v2 TPE2 like in WMP/iTunes.
    • Support for iTunes “itunescompilation” tags, in MP3/ID3v2 and MP4.
    • ID3v2.3 tags are now written by default since version 2.4 seems to be widely ignored by software vendors.
    • Added support for multi-value WMA tags.
    • Special work-around for "AC/DC" artist in ID3v2.3.
  • Improved reading of MP3 encoding information headers written by alpha versions of LAME.
  • ReplayGain scanner now uses libebur128 for improved accuracy.
Download - Change Log
[edit]
Split Discussions not related to beta:
Muzack needs help with monitoring problem
Godrick asks an unrelated question about the Album list
Unrelated feature request #1
Clarifying the changes made with reading the ITUNESCOMPILATION frame
Rewriting tags rewrites "all" tag fields?
This post has been edited by shakey_snake: Apr 8 2011, 16:33
MuncherOfSpleens
post Mar 20 2011, 23:00
Is there a noticeable performance impact when tagging MP3 files with this new version? I only ask because the old “compatibility mode” had a disclaimer suggesting that it was much slower than the ID3 2.4 setting. If so, I think I’ll stick with 2.4, as I have no need for my MP3s to play nice with iTunes or WMP.
tpijag
post Mar 20 2011, 23:32
QUOTE (MuncherOfSpleens @ Mar 20 2011, 17:00) *
What disclaimer are you talking about? I see nothing of the sort in my Foobar. If you have not need for a 2.3 setting why bother to change?
MuncherOfSpleens
post Mar 21 2011, 22:54
QUOTE (tpijag @ Mar 20 2011, 18:32) *
An ID3 2.3 setting has been available for a long time, under the name “compatibility mode.” However, in older versions that setting had a description along the lines of “Slow, contains workarounds for non standard-compliant players.” In newer versions (like 1.1.5), this message is gone, but the ID3v2.4 tagging is still described as being faster. I’m wondering if the same is true of this new ID3v2.3 setting.
GeSomeone
post Mar 21 2011, 23:35
QUOTE (MuncherOfSpleens @ Mar 21 2011, 23:54) *
You are mixing up 2 things.
It is ID3v2 padding that is described as "faster, maybe incompatible with buggy software".
The ID3v2 writer compatibility mode is (in 1.1.5) described as "non-specification-compliant, activates workarounds for common bugs in other software".
Note that ID3v2.3 or ID3v2.4 are not specifically mentioned in the (1.1.5) settings.
This post has been edited by GeSomeone: Mar 21 2011, 23:36
In theory, there is no difference between theory and practice.
- Case   foobar2000 v1.1.6 beta   Mar 20 2011, 11:40
- - q-stankovic   If you look back in many discussions here it is su...   Mar 20 2011, 12:40
- - nosgah   I'm just as surprised as the poster above... ...   Mar 20 2011, 12:58
- - klonuo   QUOTE (Case @ Mar 20 2011, 12:40) [*]Impr...   Mar 20 2011, 13:02
- - chiwou   How can I use the "new" %album artist% t...   Mar 20 2011, 14:04
|- - Case   QUOTE (chiwou @ Mar 20 2011, 15:04) I hav...   Mar 20 2011, 15:00
|- - chiwou   QUOTE (Case @ Mar 20 2011, 16:00) QUOTE (...   Mar 20 2011, 15:49
- - lvqcl   Note that libeburl128 treats mono files as 1-chann...   Mar 20 2011, 14:04
- - Kuraj   YES! I applaud this update VERY MUCH!   Mar 20 2011, 14:43
- - marc2003   QUOTE (Case @ Mar 20 2011, 10:40) [*]ID3v...   Mar 20 2011, 14:44
|- - Peter   QUOTE (marc2003 @ Mar 20 2011, 14:44) whi...   Mar 20 2011, 14:58
|- - marc2003   QUOTE (Peter @ Mar 20 2011, 13:58) If you...   Mar 20 2011, 15:38
- - Alex B   The ID3v2 tagging changes are at least interesting...   Mar 20 2011, 15:06
- - Prodoc   While I understand that compatibility is important...   Mar 20 2011, 15:16
- - TomBarlow   Does the AC/DC workaround only work for AC/DC or a...   Mar 20 2011, 15:23
- - shakey_snake   QUOTE (TomBarlow @ Mar 20 2011, 10:23) Do...   Mar 20 2011, 15:39
|- - Kuraj   QUOTE (shakey_snake @ Mar 20 2011, 08:39)...   Mar 20 2011, 15:49
|- - KarnEvil9   QUOTE (shakey_snake @ Mar 20 2011, 06:39)...   Mar 20 2011, 16:36
- - Alex B   De/Vision http://www.discogs.com/artist/De%2FVisio...   Mar 20 2011, 15:49
- - dv1989   Actually, those who wrote the ID3v2.3 spec said ex...   Mar 20 2011, 16:12
- - skexu   In polish rap the / is very common for collaborati...   Mar 20 2011, 16:24
- - Case   Peter is planning on removing the AC/DC workaround...   Mar 20 2011, 16:30
|- - TomBarlow   QUOTE (Case @ Mar 20 2011, 15:30) Peter i...   Mar 20 2011, 19:40
- - skexu   Yeah. Can't still get to work few artists. Aft...   Mar 20 2011, 16:37
- - ernstblaauw   QUOTE (Case @ Mar 20 2011, 03:40) Support...   Mar 20 2011, 16:51
|- - Frank Bicking   QUOTE (ernstblaauw @ Mar 20 2011, 16:51) ...   Mar 20 2011, 17:34
|- - ernstblaauw   QUOTE (Frank Bicking @ Mar 20 2011, 09:34...   Mar 20 2011, 17:52
||- - Prodoc   QUOTE (ernstblaauw @ Mar 20 2011, 17:52) ...   Mar 20 2011, 18:58
||- - Sandrine   QUOTE (Prodoc @ Mar 20 2011, 18:58) Apple...   Mar 21 2011, 01:44
|||- - shakey_snake   QUOTE (Sandrine @ Mar 20 2011, 20:44) Fro...   Mar 21 2011, 03:06
|||- - Sandrine   QUOTE (shakey_snake @ Mar 21 2011, 03:06)...   Mar 21 2011, 03:46
||- - ernstblaauw   QUOTE (Prodoc @ Mar 20 2011, 10:58) QUOTE...   Mar 21 2011, 23:43
|- - pone   any new hope for distinuishing between COMMENT and...   Mar 21 2011, 03:36
- - NEOhidra   Would you please add a switch to toggle between th...   Mar 20 2011, 17:58
- - tpijag   ernstblaauw Are you having trouble even after fol...   Mar 20 2011, 19:17
- - /mnt   Awesome update. Just wondering if it's possib...   Mar 20 2011, 19:33
- - NullString   if I understand correctly reading the posts above,...   Mar 20 2011, 19:45
- - tedgo   Thanks for the improved tag compatibility But co...   Mar 20 2011, 20:15
- - drbeachboy   I just wrote a ID3v2.3 tag as Album Artist and I g...   Mar 20 2011, 20:27
- - Case   Would the following change to ID3v2.3 tag handling...   Mar 20 2011, 21:13
|- - Melomane   QUOTE (Case @ Mar 20 2011, 21:13) Would t...   Mar 21 2011, 08:46
- - Hakubo   QUOTE (Case @ Mar 20 2011, 23:13) Would t...   Mar 20 2011, 21:55
- - sollniss   I'm using foobar2k because I can write whateve...   Mar 20 2011, 22:16
|- - Prodoc   QUOTE (sollniss @ Mar 20 2011, 22:16) I s...   Mar 20 2011, 23:36
- - romor   Maybe crazy idea like excluding artists by hand, b...   Mar 20 2011, 22:22
- - tpijag   Sollniss, No one said the user can not choose betw...   Mar 20 2011, 22:25
- - MuncherOfSpleens   Is there a noticeable performance impact when tagg...   Mar 20 2011, 23:00
|- - tpijag   QUOTE (MuncherOfSpleens @ Mar 20 2011, 17...   Mar 20 2011, 23:32
|- - MuncherOfSpleens   QUOTE (tpijag @ Mar 20 2011, 18:32) QUOTE...   Mar 21 2011, 22:54
|- - GeSomeone   QUOTE (MuncherOfSpleens @ Mar 21 2011, 23...   Mar 21 2011, 23:35
- - q-stankovic   QUOTE (Hakubo @ Mar 20 2011, 21:55) I thi...   Mar 20 2011, 23:01
- - neothe0ne   If the goal is now to be compliant with other soft...   Mar 20 2011, 23:53
- - durch   If the goal now is to improve tagging compatibilit...   Mar 21 2011, 08:31
- - Zarggg   To make the slash-separation issue in the artist t...   Mar 21 2011, 18:55
- - godrick   To clarify, does Foobar now map a "itunescomp...   Mar 21 2011, 19:07
- - BoraBora   Or maybe use "\\" as separator...   Mar 21 2011, 19:26
- - jeremija   Please forgive my ignorance, but doesn't fooba...   Mar 21 2011, 22:38
- - q-stankovic   QUOTE (jeremija @ Mar 21 2011, 22:38) Ple...   Mar 21 2011, 23:36
|- - dv1989   QUOTE (q-stankovic @ Mar 21 2011, 22...   Mar 22 2011, 13:20
|- - fbuser   QUOTE (dv1989 @ Mar 22 2011, 13:20) fooba...   Mar 22 2011, 21:55
- - Phil Meyer   Oh Dear :-( I'm not happy at all with this ne...   Mar 22 2011, 00:45
|- - kode54   QUOTE (Phil Meyer @ Mar 21 2011, 16:45) W...   Mar 22 2011, 07:59
|- - Phil Meyer   QUOTE (kode54 @ Mar 22 2011, 06:59) Vorbi...   Mar 22 2011, 09:22
- - Nowings69   AC/DC! Thanks for seriously but lets ro...   Mar 22 2011, 07:11
- - lordgibbness   I don't plan on moving back to ID3v2.3 as the ...   Mar 22 2011, 15:28
|- - shakey_snake   QUOTE (lordgibbness @ Mar 22 2011, 10:28)...   Mar 22 2011, 16:19
- - for4saken   I've tagged all my music with Picard (using a ...   Mar 22 2011, 17:18
- - q-stankovic   QUOTE (dv1989 @ Mar 22 2011, 13:20) fooba...   Mar 22 2011, 22:13
|- - Prodoc   QUOTE (q-stankovic @ Mar 22 2011, 22...   Mar 22 2011, 22:55
- - Robertina   QUOTE Improved performance when playing very short...   Mar 23 2011, 04:54
|- - Hank H.   QUOTE (Robertina @ Mar 22 2011, 22:54) Re...   Mar 23 2011, 21:37
- - C3POwen   As if by magic... Comparison of ID3 Standards. Not...   Mar 24 2011, 19:41
- - Case   Beta 2 is available now. ID3v2 tagging compatibili...   Mar 25 2011, 17:00
- - neothe0ne   I'm a little disappointed beta 2 didn't ad...   Mar 25 2011, 22:50
- - Sandrine   I can't help but notice that replaygain result...   Mar 26 2011, 05:03
- - kode54   You are supposed to read the change log and see th...   Mar 26 2011, 05:05
|- - Sandrine   QUOTE (kode54 @ Mar 26 2011, 05:05) You a...   Mar 26 2011, 05:29
- - tpijag   Are you looking for something more detailed than w...   Mar 26 2011, 05:09
|- - kode54   QUOTE (tpijag @ Mar 25 2011, 21:09) Edit:...   Mar 26 2011, 05:28
- - kode54   The difference varies per track. On average, the r...   Mar 26 2011, 06:12
- - q-stankovic   QUOTE (Prodoc @ Mar 22 2011, 23:55) QUOTE...   Mar 27 2011, 23:09
|- - Phil Meyer   QUOTE (q-stankovic @ Mar 27 2011, 22...   Mar 27 2011, 23:21
- - q-stankovic   That won't work after rewriting files either b...   Mar 27 2011, 23:27
- - dr_o_   QUOTE In case an ITUNESCOMPILATION tag is found in...   Mar 28 2011, 16:04
- - shakey_snake   Having any %album artist% value results in "s...   Mar 28 2011, 17:27
- - dr_o_   That was ironic. Of course ALBUM ARTIST is used fo...   Mar 28 2011, 18:13
|- - Zarggg   QUOTE (dr_o_ @ Mar 28 2011, 13:13) It wou...   Mar 28 2011, 22:02
|- - shakey_snake   QUOTE (dr_o_ @ Mar 28 2011, 13:13) btw It...   Mar 28 2011, 22:44
- - GeSomeone   QUOTE ID3v2.3 tags are now written by default, wit...   Mar 28 2011, 21:07
- - tdurjan101   I am having some difficulty with beta 2's mult...   Mar 29 2011, 03:38
|- - shakey_snake   QUOTE (tdurjan101 @ Mar 28 2011, 22:38) F...   Mar 29 2011, 03:50
- - durch   If tdurjan101's observations are true, then I ...   Mar 29 2011, 10:14
|- - GeSomeone   QUOTE (durch @ Mar 29 2011, 11:14) foobar...   Mar 29 2011, 11:22
- - TuNk77   Now that the ReplayGain scanner now uses libebur12...   Mar 29 2011, 15:54
- - Canar   It's funny, as of 1.1, foobar2000 changed to u...   Mar 29 2011, 16:40
- - krafty   QUOTE (tpijag @ Mar 26 2011, 05:09) Are y...   Mar 29 2011, 16:44
- - tpijag   I trust you are not asking for me to find the thre...   Mar 29 2011, 16:47
- - krafty   Absolutely not. Edit: What I suggest is that one ...   Mar 29 2011, 16:50
- - Phil Meyer   Yes, I have a lot of music that sounds like it nee...   Mar 29 2011, 20:18
- - Canar   QUOTE (krafty @ Mar 29 2011, 08:50) It wi...   Mar 29 2011, 20:56
2 Pages V   1 2 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 31st March 2015 - 05:24
