Quality aspects of ADC, Does quality gear makes a difference?
ktf
post Mar 3 2011, 22:45
Hi all!
Background information (safe to skip rolleyes.gif )
Currently I'm preparing a large archival operation: my musical society has a collection of recordings on compact cassettes from 1980 to 1990, about 140, which I think have to be digitalized to protect them from deteriorating. I have found a nice tape deck (Nakamichi DR-3) but it has to stay at the office of the executive committee. A friend of mine has a nice ADC for this job, a quality portable mixing console with USB out, but it cannot stay at the office as it is more or less public and he doesn't trust everyone there. However, it is too much hassle to bring it every time, as I think this operation will cost about a year: 3 recordings a week. So, I guess I'm stuck with my own ADC: a Creative X-Fi Surround 5.1 USB-card, which is not really made for the job, but I can at least leave it at the office, as it isn't that valuable.
On-topic
That friend of mine that offered me his portable mixing-console with ADC argued that with a cheap ADC all little nuances and details would vanish, so I should look for another solution than using my Creative ADC. That made me think: i'm much more a theoretician than he is, so I was wondering, what makes a high quality ADC? I know the working principle of several ADCs, I can't imagine which link in the chain would be capable of 'erasing details' anyway. How does a non-linearity in an ADC sounds like in practice? And jitter? I guess uncorrelated, random jitter could sound like 'more noise', as it is random. To me it seems a low-quality ADC doesn't add anything but noise and a non-linearity, let alone it could remove things from the signal.
In short: what could a low-quality ADC do with the signal except adding noise? Probably I'm far too short sighted, can anyone enlighten me?
Arnold B. Kruege...
post Mar 8 2011, 13:38
QUOTE (ktf @ Mar 3 2011, 16:45) *
Your friend is drinking the High End Audio Kool Aid. ;-)
Many of us have been down that road.
We've all learned that once audio gear meets certain technical standards, it all sounds the same. What has changed over the years is that the cost and size of audio gear that meets certain standards has decreased dramatically.
In 1970 the university I attended bought a 200KHz sample rate 16 bit ADC/DAC. I seem to recall that it cost about a half million dollars and filled a full height 19 inch rack cabinet. Last year I bought a USB audio interface that outperformed it, and had twice as many channels. I got change from $100. I could fit it in my hand but if I closed my hand the corners of the box showed. But, the box it was in was mostly empty, whereas that 1970 DAC was packed full of circuits.
That made me think: I'm much more a theoretician than he is, so I was wondering, what makes a high quality ADC?
A quality DAC provides basic clean signal processing, IOW low noise and distortion. It is also durable and convenient to use. All failures to provide clean signal processing can be broken down into noise, linear distortion and nonlinear distortion. You may be unfamiliar with the oxymoron-sounding phrase "Linear distortion" but that is just more familiar things like flat frequency response and appropriate phase response.
Elsewhere on HA we've been discussing just that. I don't know how to erase details with equipment that meets fairly ordinary technical standards. About as close as we can get is to bury small signals in noise.
Nonlinearity adds tones to sounds that weren't originally there. The added tones are both harmonics and also sum and difference tones related to the tones in the original recording. The harmonics tend to fit in with the harmonics that are already in the music. The sum+difference tones don't fit in nearly as well, and there's no way to avoid them if the equipment is nonlinear. In small quantities nonlinear distortion tends to alter the balance between fundamental tones and the natural harmonics that are in the music. If small enough, added harmonics can be easily ignored or overlooked. They may even make things sound better to some people. The sum and difference tones don't fit into the natural harmonic structure of the music, and tend to give a sort of sour or gritty sound.
For example, if you want people to overlook modest amounts of nonlinear distortion in a demo, you might use recordings of a solo instruments or a certain kind of voice. There won't be a lot of different concurrent tones in the music, and most of the distortion will come out as harmonics which might be overlooked or even preferred. If you want a listening test that is very critical of nonlinear distortion, you might pick a complex sound like a choir. Choirs are particularly good because their signal is dense in the midrange, but leave a lot of less-used frequencies at the extremes. Any sum and different tones that are created will be more audible when they naturally fall into the frequencies where the basic music is less dense.
And jitter?
Jitter is just another kind of nonlinear distortion. In large amounts low frequency jitter is just vibrato or flutter or wow. Which makes a point - while jitter is commonly obsessed over as applying to digital equipment, we've had tons of it for years in LP recording and playback, as well as analog tape. High frequency jitter can be more like an increase in background noise. High frequency jitter has been around for years as "scrape flutter" in analog tape recorders.
The real kicker is that the best analog playback system has tons more jitter than even a mediocre digital system.
Yes, I just covered that, but much jitter is correlated. It is due to interference caused by the signal itself or outside influences like the power line or frame size in digital media. Making jitter go away in a digital system is very simple. Every CD player's optical pickup delivers a massively jittered signal to its decoding electronics. All you do is buffer it and reclock it and its as pure as the clock you use to reclock it. BTW, adequately clean digital clocks are now about a dime a dozen.
The noise and the nonlinearities could add sounds that mask the detail in the signal. Thing is that even inexpensive DACs such as the one in cheap digital music players such as the Sansa Clip, or the motherboard audio interface in your computer, are now really very good. They are capable of sonic transparency, which is the ability to reproduce sound without adding anything that makes it sound different, even in terms of the smallest things that we can reliably hear, or sense in any way.
- ktf   Quality aspects of ADC   Mar 3 2011, 22:45
- - DVDdoug   The only thing I'd even consider is noise. A...   Mar 3 2011, 23:52
|- - ktf   QUOTE (DVDdoug @ Mar 3 2011, 23:52) The o...   Mar 4 2011, 16:19
- - DonP   One thing that's been an issue in the past is ...   Mar 4 2011, 17:08
- - DVDdoug   QUOTE So, the THD+N (for distortion and non-linear...   Mar 4 2011, 20:51
|- - ktf   QUOTE (DVDdoug @ Mar 4 2011, 20:51) With ...   Mar 4 2011, 23:42
|- - Notat   QUOTE (ktf @ Mar 4 2011, 16:42) It also r...   Apr 5 2011, 15:18
|- - ktf   QUOTE (Notat @ Apr 5 2011, 15:18) Apologi...   Apr 5 2011, 15:23
|- - Notat   In your setup, there are two ground paths between ...   Apr 5 2011, 18:49
|- - Arnold B. Krueger   QUOTE (Notat @ Apr 5 2011, 13:49) In your...   Apr 6 2011, 14:37
- - Arnold B. Krueger   QUOTE (ktf @ Mar 3 2011, 16:45) That frie...   Mar 8 2011, 13:38
|- - ktf   QUOTE (Arnold B. Krueger @ Mar 8 2011, 13...   Mar 8 2011, 18:02
|- - Arnold B. Krueger   QUOTE (ktf @ Mar 8 2011, 12:02) QUOTE (Ar...   Mar 8 2011, 19:09
|- - ktf   QUOTE (Arnold B. Krueger @ Mar 8 2011, 19...   Mar 8 2011, 21:25
||- - Arnold B. Krueger   QUOTE (ktf @ Mar 8 2011, 15:25) QUOTE (Ar...   Mar 8 2011, 22:59
||- - mixminus1   QUOTE (Arnold B. Krueger @ Mar 8 2011, 13...   Mar 8 2011, 23:17
|- - Kees de Visser   QUOTE (Arnold B. Krueger @ Mar 8 2011, 20...   Mar 15 2011, 13:34
|- - Arnold B. Krueger   QUOTE (Kees de Visser @ Mar 15 2011, 08:3...   Mar 24 2011, 12:32
|- - DonP   QUOTE (Arnold B. Krueger @ Mar 24 2011, 06...   Mar 24 2011, 12:53
- - ktf   QUOTE (Arnold B. Krueger @ Mar 8 2011, 22...   Mar 13 2011, 22:49
- - ktf   Today I made some recordings which made me wonder ...   Mar 22 2011, 21:56
|- - Arnold B. Krueger   QUOTE (ktf @ Mar 22 2011, 16:56) I usuall...   Mar 24 2011, 12:51
|- - ktf   Woops, I forgot about this topic. I have set track...   Apr 5 2011, 10:19
- - 2Bdecided   Cleaning and demagnetising the heads, matching the...   Apr 6 2011, 15:14
- - Arnold B. Krueger   QUOTE (ktf @ Mar 3 2011, 17:45) Hi all...   Jun 6 2012, 13:20
RSS Lo-Fi Version Time is now: 4th September 2015 - 02:49
