DSP chain [de]serialization helper, Save and load current DSP chain configs to/from a file
Yegor
post Feb 20 2011, 10:56
DSP chain serialization helper
This helper is useful for sharing of chain presets between different Foobar2000 installations and users.
Hold Shift to access its commands in the Playback menu:
Files produced by the helper have fbcp extension.
The component: Attached File  foo_chain_impexp.zip ( 52.03K ) Number of downloads: 3788
[source code]
This post has been edited by Entrase: Feb 21 2011, 18:44
foosion
post Feb 21 2011, 10:58
Group: FB2K Moderator (Donating)
Sandrine: This component can store a DSP chain configuration in a separate file, whereas the DSP chain management in the foobar2000 preferences stores DSP chains in the foobar2000 configuration. This component can be used to transfer DSP chain configurations between different foobar2000 installations.
Entrase: May I suggest to rename the "DSP chain serializer" menu entry to "DSP chain"? It's simpler and less technical.
Also the menu entries show as "Load..." and "Save as..." in the menu and "Load" and "Save" in the keyboard shortcuts. Is there a reason why you chose to present the names differently? Maybe consider calling them "Import..." and "Export..." to emphasize there is no inherent connection between the current DSP chain and the last loaded/saved file.
Sandrine
post Feb 21 2011, 13:12
QUOTE (foosion @ Feb 21 2011, 10:58) *
Ah, right. For a moment there my memory played tricks on me and I thought that the presets were saved to actual files instead of core.cfg, much like in the kx driver.
RSS Lo-Fi Version Time is now: 18th April 2015 - 15:23
