OptimFROG version 4.910b [2011-02-10]
madoka@ex-sounds
post Feb 13 2011, 06:10
New release* (stable beta) for OptimFROG Lossless, DualStream, and IEEE Float, SFX module, and SDK:
OptimFROG_All_Windows_x86_4910b.zip (691 kB)
Updated input plug-in for foobar2000 v1.1.x, with cue sheet support (source code included):
foo_input_ofr_130.zip (250 kB)
* Release for all the other supported platforms within two weeks.
URL: http://losslessaudio.org/
Change Log:
What is new in this version (4.910b):
- fully backward compatible with previous versions
- slightly better compression for highnew, extranew, bestnew modes, and also for --maximumcompression
- parsing WAV files with invalid data chunk size in WAV header using --incorrectheader (for foobar2000 and other command line format converters using pipes who cannot compute the WAV file length in advance and generate a 4 GB header instead)
- many internal source code improvements
- [other] updated foobar2000 input plug-in for foobar2000 1.1.x
- [other] updated OptimFROG SDK to version 1.300 (included here)
<name>madoka</name>
<uri>http://codecs.ex-sounds.net/</uri>
Case
post Feb 15 2011, 21:10
Group: Developer (Donating)
It seems --incorrectheader option isn't working as it should. The encoder still errors out with message "description: size of data is too large". You must use temporary files until the option is fixed.
- madoka@ex-sounds   OptimFROG version 4.910b [2011-02-10]   Feb 13 2011, 06:10
- - shadowking   Whoa ! I am so glad Ghido is back.   Feb 13 2011, 10:18
- - Steve Forte Rio   Great news   Feb 13 2011, 22:01
- - _mē_   I was absolutely sure that Windows on ARM was goin...   Feb 14 2011, 16:24
- - _mē_   So who will be the first to benchmark it?   Feb 14 2011, 17:43
- - madoka@ex-sounds   Ugh, Bit comparison results are Differences found ...   Feb 14 2011, 18:05
- - Case   Your settings are wrong. You can't use --raw w...   Feb 14 2011, 18:55
|- - madoka@ex-sounds   QUOTE (Case @ Feb 14 2011, 09:55) Your se...   Feb 15 2011, 05:27
- - dv1989   It looks as though Case is on the right track. Not...   Feb 15 2011, 15:37
|- - madoka@ex-sounds   QUOTE (dv1989 @ Feb 15 2011, 06:37) It lo...   Feb 15 2011, 18:59
- - eevan   I'm also having trouble with pipe encoding fro...   Feb 15 2011, 16:02
- - romor   I reported same foobar behaviour with Speex encode...   Feb 15 2011, 16:57
- - Case   It seems --incorrectheader option isn't workin...   Feb 15 2011, 21:10
- - _mē_   Since nobody was willing to test ofr, I did a quic...   Feb 15 2011, 21:37
- - _mē_   Tested 2 more tracks: Funkadelic - Maggot Brain CO...   Feb 16 2011, 10:51
|- - bbrabant   I also tried Optimfrog pipe encoding with foobar. ...   Feb 16 2011, 21:04
- - [JAZ]   This looks worse than anticipated. The difference ...   Feb 16 2011, 21:09
|- - soiaf   QUOTE ([JAZ] @ Feb 16 2011, 21:09...   Feb 16 2011, 23:01
|- - bbrabant   QUOTE ([JAZ] @ Feb 16 2011, 23:09...   Feb 17 2011, 14:26
- - [JAZ]   doh! I had read the Hexadecimal representatio...   Feb 17 2011, 19:17
- - RazorBoy143   I solved the problem by using the --headersize opt...   Mar 14 2011, 14:30
|- - Ljubo44   QUOTE (RazorBoy143 @ Mar 14 2011, 15:30) ...   Oct 18 2011, 23:51
- - RazorBoy143   Checked the CPU usage while OptimFROG tracks were ...   Mar 15 2011, 02:13
|- - _mē_   QUOTE (RazorBoy143 @ Mar 15 2011, 02:13) ...   Mar 15 2011, 08:12
|- - RazorBoy143   RE: Monkey's Audio and its reliability QUOTE ...   Apr 13 2011, 14:34
- - Mardel   Hi! I tested a little with TAK. OptimFrog wi...   Mar 17 2011, 14:17
- - Mardel   Ok. Now I tested with a single album (Arch Enemy -...   Mar 17 2011, 15:47
- - Ljubo44   I have another question. When ofr.exe encode DTS C...   Oct 19 2011, 17:48
- - lvqcl   And what's the length of the original and deco...   Oct 19 2011, 18:33
- - Ljubo44   Same lenght, same number of samples. Bit compare t...   Oct 19 2011, 19:19
- - lvqcl   QUOTE Same lenght, same number of samples. Bit com...   Oct 19 2011, 19:55
RSS Lo-Fi Version Time is now: 28th April 2015 - 19:38
