Converter: problem piping to speexenc
romor
post Feb 4 2011, 17:31
I tried speex for some of my audiobooks and very satisfied with the results. Speexdrop works fine, so does CLI, but I have problem with foobar converter (latest speexenc from rarewares)
Example parameter setting: -w --vbr - %d
Problem:
Encoder stream format: 32000Hz / 1ch / 16bps
Command line: "C:\Program Files\encoders\speexenc.exe" -w --vbr - "out.spx"
Working folder: C:\temp\audiobooks\
An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters)
Now if I use temporary input file "%s" instead pipe "-", conversion is done fine, but not on the fly. However speexenc accepts piping just fine:
sox in.wav -p | speexenc.exe -w --vbr -V - out.spx
Any comments?
scripts: http://goo.gl/M1qVLQ
kode54
post Mar 30 2011, 12:50
Group: Admin
Is the Speex encoder designed to accept weird WAV files? Foobar2000 emits piped WAV files with a 0xFFFFFFFF length for both the RIFF chunk and the data chunk, since knowing the lengths ahead of time would require decoding the files twice, as the reported lengths on some files are not exact, or may even be rounded. (For instance, WMA, due to limitations of the ASF container, reports lengths rounded down to the nearest millisecond. Even WMA Lossless.)
romor
post Mar 31 2011, 05:42
QUOTE (kode54 @ Mar 30 2011, 12:50) *
I don't know such technicalities, but am curious how does speexenc handle sox piping then. And it's not only sox - output from other decoders (like flac.exe etc) which supports writing to stdout is handled just fine
RSS Lo-Fi Version Time is now: 31st July 2015 - 00:23
