New version of statistical analysis tool, Removes some limitations, normality assumption
Garf
post Feb 3 2011, 20:54
Mad Scientist
Group: Admin
Some time ago I needed an analysis of some test results and tried to use the bootstrap utility we have used for the listening tests. Unfortunately, the results coming out were bogus. I traced it down to an obscure 64-bit compatibility issue, but going through the code some things bothered me. ff123 improved my initial version significantly, but one of the things that was done was to use a normal distribution approximation for test statistics. If you consider the original version of the utility was exactly written to avoid any assumptions about normality, that's a bit sad.
So I ended up rewriting the whole thing and fixing all outstanding issues. The new version:
  • Works correctly on 64-bit systems
  • Removed all arbitrary limitations of number of samples, codecs, ...
  • p-values are estimated through Monte Carlo resampling instead of normal distribution approximation
  • Blocked and non-blocked analysis fully supported
  • Comparison based on median instead of means supported
  • Possible to (only) compare all samples against the first one
  • Much slower because it's in Python (v2.5+ required)
This is new so it might still contain some bugs. Any feedback appreciated.
Download page
Garf
post Aug 23 2011, 11:37
Mad Scientist
Group: Admin
Because we're interested in the odds that randomly picking will produce a score of k successes or more.
RSS Lo-Fi Version Time is now: 2nd June 2015 - 19:02
