Still cannot convert files to WMA with Foobar
superbu
post Feb 2 2011, 05:43
I know numerous people have had this problem -- there are a couple threads dealing with it -- and I've tried everything suggested on this site that has worked for other people. But no matter what I do, I get an error when converting a file to WMA format in Foobar. It looks like it's converting the file just fine, but I get an error message at the end saying, "An error occurred while finalizing the encoding process (Object not found)." However, I can convert files to WMA with dBpoweramp with no problem whatsoever.
I've tried changing the specified encoder to cscript.exe, trying all variations of the command lines suggested. I've also tried the hot fix for WMA from Microsoft. Both suggestions were made in this thread and have worked for other people:
http://www.hydrogenaudio.org/forums/index....47759&st=50
I also tried copying the cscript.exe file into the Foobar folder, as someone suggested. Didn't work.
No matter what happens, I get the error, "An error has occurred while finalizing the encoding process (Object not found)." And no file is created, though an unnamed folder is created if I have Foobar set to create a folder with the artist name.
I am using the latest version of Foobar 1.1.2 on Windows Vista Home Premium 32-bit, with User Account Control turned off. My installed components are ABX Comparator, ALAC Decoder, Album List, Audio CD Writer, CD Audio Decoder, Converter, Default User Interface, File Operations, foobar2000 core, freedb Tagger, Masstagger, Monkey's Audio Decoder, ReplayGain Scanner, Standard DSP Array, Standard Input Array, and ZIP/GZIP/RAR Reader.
Anyone have any ideas?
Spanky Monkey
post Jan 3 2013, 21:41
Managed to get dBpowerAmp converting too now!
Encoder File: C:\Program Files\Illustrate\dBpoweramp\CoreConverter.exe
Extension: wma
Parameters: -infile=%s -outfile=%d -convert_to="Windows Media Audio 9" -codec="Windows Media Audio 9.2" -settings="320 kbps, 44 kHz, stereo CBR" -cbr -errorfile="d:\desktop\Error.log"
The thing to remember is that you need to put -cbr or -vbr at the very end of the options, even though you have already defined this in the options earlier. For some bizarre reason, it just doesn't work if you don't.
There we go, the script above chucks out a WMA 9 standard profile at 320 kbs 44.1 kHz 16 bit CBR.
- superbu   Still cannot convert files to WMA with Foobar   Feb 2 2011, 05:43
- - kode54   Try converting to WAV files of various formats and...   Feb 2 2011, 07:01
|- - superbu   QUOTE (kode54 @ Feb 2 2011, 07:01) Try co...   Feb 3 2011, 07:46
- - superbu   By the way, if it helps to know this, I also canno...   Feb 3 2011, 09:59
- - kode54   I meant to try feeding the resulting WAV files to ...   Feb 3 2011, 11:57
|- - superbu   QUOTE (kode54 @ Feb 3 2011, 11:57) I mean...   Feb 9 2011, 18:07
- - tpijag   QUOTE (superbu @ Feb 3 2011, 02:59) By th...   Feb 3 2011, 17:58
- - lvqcl   QUOTE (superbu)I get an error when converting a fi...   Feb 3 2011, 20:05
|- - superbu   QUOTE (lvqcl @ Feb 3 2011, 20:05) QUOTE (...   Feb 9 2011, 18:05
- - lvqcl   First, download and install Windows Media Encoder....   Feb 9 2011, 18:57
|- - superbu   QUOTE (lvqcl @ Feb 9 2011, 18:57) First, ...   Feb 12 2011, 08:21
|- - eevan   QUOTE (superbu @ Feb 12 2011, 08:21) An e...   Feb 12 2011, 13:11
|- - superbu   QUOTE (eevan @ Feb 12 2011, 13:11) QUOTE ...   Feb 14 2011, 09:10
- - kode54   Have you tried this? (Scan the topic for the lates...   Feb 12 2011, 10:38
|- - superbu   QUOTE (kode54 @ Feb 12 2011, 10:38) Have ...   Feb 14 2011, 09:07
- - lvqcl   Open commamnd prompt window (press Start-> Run,...   Feb 14 2011, 17:06
|- - superbu   QUOTE (lvqcl @ Feb 14 2011, 17:06) Open c...   Feb 17 2011, 07:52
- - lvqcl   Probably Windows Media Encoder was installed incor...   Feb 17 2011, 17:44
|- - superbu   QUOTE (lvqcl @ Feb 17 2011, 17:44) Probab...   Feb 18 2011, 10:34
- - Purple Monkey   Not sure if this may be applicable considering tha...   Feb 18 2011, 16:08
|- - superbu   QUOTE (Purple Monkey @ Feb 18 2011, 16:08...   Feb 23 2011, 07:12
- - Apesbrain   If you are running Win 7 64-bit, did you try this ...   Feb 27 2011, 20:47
|- - superbu   QUOTE (Apesbrain @ Feb 27 2011, 20:47) If...   Mar 5 2011, 21:04
|- - Spanky Monkey   I know this thread hasn't been active for a wh...   Oct 8 2012, 16:19
- - Spanky Monkey   I got WMecoder working with Fb2k!!! I...   Dec 28 2012, 15:02
- - Spanky Monkey   Managed to get dBpowerAmp converting too now! ...   Jan 3 2013, 21:41
- - hollywood_   I apologize for bumping an old thread, however I d...   Jul 12 2013, 05:46
RSS Lo-Fi Version Time is now: 27th May 2015 - 03:10
