Is there a Now Playing panel for foobar?
kielmaru
post Jan 26 2011, 10:39
New to foobar and I'm kinda confused.
I can't find a panel for foobar that shows the currently playing songs. Like in WMP, where you just select songs, then play it. But here on foobar, I have to make a playlist for the songs I want to play.
Also, is there any plugin to show lyrics? I found one but it's not working anymore.
Heres what my foobar looks like: http://i.imgur.com/raAEf.png
shakey_snake
post Jan 26 2011, 17:49
Group: FB2K Moderator
The window's titlebar and statusbar show now playing information. You can double-click the statusbar to jump the selection to the currently playing item.
This post has been edited by shakey_snake: Jan 26 2011, 17:50
elevatorladylevitateme
evil roy
post Jan 27 2011, 09:34
I assume you mean something like THIS.
First download the foo_textdisplay component from HERE and install.
Then add it to your UI and config to your liking.
fuflo
post Jan 27 2011, 12:24
nah.. he's talking about 'currently playing tracks'. sort of, single playlist for tracks and then library for browsing...
at least i think he means that and i don't have a solution
kielmaru
post Jan 28 2011, 09:16
QUOTE (fuflo @ Jan 27 2011, 13:24) *
THIS. Basically, the library shows ALL the songs, sorted by albums/artists. Then I would just choose from the library what songs I want to play, then show it on the currently playing songs, in which those chosen songs are not stored as playlists or whatsoever. Like in the late versions of WMP.
marc2003
post Jan 28 2011, 09:31
you can set something like this up with a component called EsPlaylist. it can be configured as a library browser and in the options, you can set it when you double click an album (or any group you set yourself) it sends all the songs to a reserved playlist and starts playing from the first track. it does require a little tinkering in the preferences.
example screenshot grouped by artist
component download: http://foo2k.chottu.net/#esp
kielmaru
post Jan 28 2011, 10:18
QUOTE (marc2003 @ Jan 28 2011, 10:31) *
Also, on an unrelated note, I installed this lyrics grabber component, and it doesnt work and it makes a window pop up an error message when I start foobar. So I want to uninstall that component. But when I went to Preferences to uninstall that component, it's not highlighted and you can't uninstall it. So I tried deleting it on the components folder directory. And it won't, saying that it's protected or something.
shakey_snake
post Jan 28 2011, 16:07
QUOTE (kielmaru @ Jan 28 2011, 03:16) *
Well, instead of "playlists" in foobar only being some off-the-beaten-path storage format, they are an active part of the player.
So the workflows of the two programs go something like this:
WMP: Library-> single list of now playing songs
fb2k: Library-> Sent to a Playlist, possibly creating a new one.
So basically, the same thing.
The advantage in fb2k is that you are no longer limited to having only one playlist available to you at a time. The disadvantage is that you might not be able to easily identify what is playing, or where. In order to do this you simply double click the status bar.
RSS Lo-Fi Version Time is now: 31st March 2015 - 10:06
