Diagnosing / repairing infrequent turntable RPM variance, very brief & infrequent speed / pitch changes-Technics SL-B1
Jenni28
post Jan 23 2011, 23:58
This Technics SL-B1 turntable - given by son - has very short (maybe 1 - 2 sec) & infrequent (1 or 2x / LP side??) changes in pitch - quite audible. It's one w/ a pitch / RPM adj wheel & strobe. Maybe this was a seriously cheap unit when new & basically P.O.C. No idea. Never had a pitch problem w/ the direct drive Dual that my son borrowed the cartridge from, but then, it wasn't decades old.
God knows how old this is (S.N. = 001 [kidding] - it's MS1116C161), & could be due to lubrication. Again, I'd expect it to occur more often.
The changes are over so quickly, can't look at the platter / strobe to see if shows anything changing. Have it hooked up to an UPS w/ AVR (automatic volt. regulator). Assuming that works, changes in speed shouldn't be due to voltage variations - but haven't checked voltage changes, much less monitored over 15 - 30 min period.
I believe it's belt driven (not had apart) & problem could be belt slipping, but I'd expect it to occur more often if it was. 99.9% of time, no audible pitch changes.
*** Have noticed the pitch adj (wheel) doesn't hold the speed constant. Could be # of reasons, incl. bad electronic components in rheostat. I used this type table in '70's, & most showed the markings fairly stable. Sure, there was slight variation back & forth, but not from markings dead still to moving at pretty good clip.
The strobe / markings on this Technics start to drift up / down from stationary, then maybe back to stationary for a few min. But I can't tell change in pitch when that happens. It's very touchy - a micro turn of the adj wheel may cause markings on platter to start spinning considerably. One's I used in '60's - '70's had much less sensitive adj wheels. ("You're livin' in the 60's, man!)
Haven't looked at the guts of adj wheel either - if it's mechanical variable rheostat or strictly electronic.
Any suggestions (toss it?)? Thanks.
Jenni28
post Feb 2 2011, 02:49
Yes, eevan / Ivan, some persons from Europe sometimes pronounce his name ee-von (long 'e', as in green). I'm pretty sure they're variations of the same name, but not sure of the derivation or Evan.
- Jenni28   Diagnosing / repairing infrequent turntable RPM variance   Jan 23 2011, 23:58
- - DVDdoug   That's a strange symptom. QUOTE It's ve...   Jan 24 2011, 20:15
- - Jenni28   Thanks. Yes, it's belt. Anyone know where I...   Jan 24 2011, 21:46
|- - DonP   QUOTE (Jenni28 @ Jan 24 2011, 15:46) You ...   Jan 24 2011, 23:05
- - DVDdoug   Another option is to transfer the cartridge to the...   Jan 24 2011, 23:35
- - Jenni28   QUOTE If it uses an idler pulley, then it's no...   Jan 25 2011, 01:50
|- - Glenn Gundlach   You mis-understand the concept of 'direct driv...   Jan 25 2011, 04:39
|- - DonP   QUOTE (Glenn Gundlach @ Jan 24 2011, 22:3...   Jan 25 2011, 13:41
|- - stephan_g   Old thread, I know. QUOTE (Glenn Gundlach @ J...   May 29 2011, 01:29
- - Jenni28   Glenn - I didn't misunderstand the direct driv...   Jan 25 2011, 17:25
|- - cliveb   Apologies for coming in late - I've been away ...   Jan 30 2011, 11:18
- - Jenni28   Thanks Clive, for the link. I wasn't familiar...   Jan 30 2011, 19:04
|- - eevan   QUOTE (Jenni28 @ Jan 30 2011, 19:04) You ...   Jan 30 2011, 21:04
|- - Jenni28   QUOTE (eevan @ Jan 30 2011, 14:04) Use a ...   Jan 31 2011, 15:29
|- - eevan   QUOTE (Jenni28 @ Jan 31 2011, 15:29) Whic...   Feb 1 2011, 22:42
- - Jenni28   Yes, eevan / Ivan, some persons from Europe someti...   Feb 2 2011, 02:49
- - Arnold B. Krueger   QUOTE (Jenni28 @ Jan 23 2011, 17:58) This...   Feb 2 2011, 13:42
|- - Glenn Gundlach   QUOTE (Arnold B. Krueger @ Feb 2 2011, 04...   May 29 2011, 05:46
- - Jenni28   Arnold, yeah, sounds like a grease spot on belt m...   Feb 2 2011, 18:03
- - Arnold B. Krueger   QUOTE (Jenni28 @ Feb 2 2011, 12:03) Arnol...   Feb 3 2011, 14:19
RSS Lo-Fi Version Time is now: 24th May 2015 - 19:10
