libebur128 - (yet another) EBU R 128 implementation
Raiden
post Jan 12 2011, 17:08
inspired by the wonderful work in this thread, I wrote my own implementation of the EBU R 128 standard.
It is written in plain ANSI C and designed as a library, so you can use it in your own code. It's licensed under the MIT license.
I've also implemented a simple scanning tool, which outputs something like this:
$ ./r128-sndfile -l -p both ~/music/bad\ loop\ -\ Luo/*.flac
-12.81 LUFS, LRA: 14.16 LU, sample peak: 0.89151001, true peak: 0.99826229, /home/jan/music/bad loop - Luo/bad loop - Luo - 01 Nio.flac
-11.15 LUFS, LRA: 8.26 LU, sample peak: 0.89163208, true peak: 0.99095666, /home/jan/music/bad loop - Luo/bad loop - Luo - 02 Eri Valeire.flac
-10.14 LUFS, LRA: 11.79 LU, sample peak: 0.89154053, true peak: 0.99171823, /home/jan/music/bad loop - Luo/bad loop - Luo - 03 Kauniit Ihmiset.flac
-11.31 LUFS, LRA: 11.75 LU, sample peak: 0.89157104, true peak: 0.92898595, /home/jan/music/bad loop - Luo/bad loop - Luo - 04 Mmin.flac
-26.13 LUFS, LRA: 14.87 LU, sample peak: 0.25204468, true peak: 0.25203928, /home/jan/music/bad loop - Luo/bad loop - Luo - 05 3b Or T.flac
-14.10 LUFS, LRA: 11.40 LU, sample peak: 0.89151001, true peak: 1.02603507, /home/jan/music/bad loop - Luo/bad loop - Luo - 06 Kannas Nsp.flac
-11.75 LUFS, LRA: 13.34 LU, sample peak: 0.89163208, true peak: 1.02603507
There is also ReplayGain tagging, using a reference level of -18 LUFS to match RG's loudness:
r128-mpg123 -t album [FILE|DIRECTORY]...
r128-mpg123 -t track [FILE|DIRECTORY]...
Download current version here.
This post has been edited by Raiden: Feb 27 2011, 22:29
googlebot
post Jan 12 2011, 18:58
IMHO, you should both think about contributing your work directly to SoX.
pbelkner
post Jan 13 2011, 09:38
First of all congratulations, Raiden, for the great solution!
QUOTE (googlebot @ Jan 12 2011, 19:58) *
Maybe part of R128GAIN can become part of SoX because the main part of the R128 algorithm is already implemented as a SoX effect.
On the other hand it is not obvious to me how calculating the album gain would fit yet into the SoX commanline syntax. Maybe someone has a good idea.
- Raiden   libebur128 - (yet another) EBU R 128 implementation   Jan 12 2011, 17:08
- - googlebot   While I'm really a big proponent of modern cod...   Jan 12 2011, 18:01
- - googlebot   IMHO, you should both think about contributing you...   Jan 12 2011, 18:58
|- - pbelkner   First of all congratulations, Raiden, for the grea...   Jan 13 2011, 09:38
|- - googlebot   QUOTE (pbelkner @ Jan 13 2011, 09:38) On ...   Jan 13 2011, 11:32
- - mudlord   Nice nice work. QUOTE IMHO, you should both think...   Jan 12 2011, 20:14
|- - pbelkner   QUOTE (mudlord @ Jan 12 2011, 21:14) Why,...   Jan 13 2011, 09:45
- - Raiden   QUOTE (googlebot @ Jan 12 2011, 18:01) Th...   Jan 12 2011, 20:14
- - googlebot   Great! Even gets the 6-channel case right in c...   Jan 12 2011, 20:28
- - mudlord   Hmmm, shouldn't ebur128_write_frames be ebur...   Jan 12 2011, 21:49
- - Raiden   QUOTE (googlebot @ Jan 12 2011, 20:28) Gr...   Jan 12 2011, 21:52
|- - pbelkner   QUOTE (Raiden @ Jan 12 2011, 22:52) QUOTE...   Jan 13 2011, 09:51
- - Raiden   QUOTE (mudlord @ Jan 12 2011, 21:49) Hmmm...   Jan 12 2011, 22:12
|- - googlebot   QUOTE (Raiden @ Jan 12 2011, 22:12) How d...   Jan 12 2011, 23:07
- - benski   Is there a good mapping between LUFS and ReplayGai...   Jan 12 2011, 22:17
- - Raiden   I've just uploaded version 0.1.2: - fixed a ra...   Jan 14 2011, 10:31
- - Raiden   QUOTE (pbelkner @ Jan 13 2011, 09:51) Up ...   Jan 14 2011, 10:40
|- - pbelkner   QUOTE (Raiden @ Jan 14 2011, 11:40) QUOTE...   Jan 14 2011, 10:46
- - Raiden   QUOTE (pbelkner @ Jan 14 2011, 10:46) Tha...   Jan 14 2011, 11:01
- - Raiden   0.1.3 is up! - Added tagging support. You need...   Jan 16 2011, 00:51
- - C.R.Helmrich   I gave this a try yesterday (r128-sndfile, version...   Jan 16 2011, 14:28
|- - pbelkner   QUOTE (C.R.Helmrich @ Jan 16 2011, 15:28)...   Jan 16 2011, 15:07
|- - C.R.Helmrich   QUOTE (C.R.Helmrich @ Jan 16 2011, 15:28)...   Jan 16 2011, 16:13
|- - pbelkner   QUOTE (C.R.Helmrich @ Jan 16 2011, 17:13)...   Jan 16 2011, 16:46
||- - benski   QUOTE (pbelkner @ Jan 16 2011, 10:46) On ...   Jan 16 2011, 20:24
||- - pbelkner   QUOTE (benski @ Jan 16 2011, 21:24) QUOTE...   Jan 16 2011, 20:32
|- - Notat   QUOTE (C.R.Helmrich @ Jan 16 2011, 15:28)...   Jan 16 2011, 21:40
- - Raiden   QUOTE (C.R.Helmrich @ Jan 16 2011, 14:28)...   Jan 16 2011, 17:47
|- - pbelkner   QUOTE (Raiden @ Jan 16 2011, 18:47) I...   Jan 16 2011, 18:49
|- - Notat   QUOTE (Raiden @ Jan 16 2011, 09:47) Yeste...   Jan 16 2011, 21:46
|- - pbelkner   QUOTE (Raiden @ Jan 16 2011, 18:47) Yeste...   Jan 17 2011, 18:22
- - lvqcl   QUOTE now it only calls out coefficients for 48 an...   Jan 16 2011, 21:58
|- - Notat   QUOTE (lvqcl @ Jan 16 2011, 13:58) QUOTE ...   Jan 17 2011, 00:35
- - Raiden   QUOTE (Notat @ Jan 16 2011, 21:46) QUOTE ...   Jan 17 2011, 00:18
- - Raiden   QUOTE (C.R.Helmrich @ Jan 16 2011, 14:28)...   Jan 17 2011, 00:25
- - Raiden   0.1.4 has been uploaded, with the following new fe...   Jan 17 2011, 00:42
|- - verdemar   Thanks, works very well for me. Just thought I...   Jan 17 2011, 21:36
- - benski   Correct. V are gain values and have no relation...   Jan 17 2011, 19:11
|- - pbelkner   QUOTE (benski @ Jan 17 2011, 20:11) Corre...   Jan 19 2011, 16:40
- - Raiden   QUOTE (verdemar @ Jan 17 2011, 21:36) Sub...   Jan 18 2011, 23:53
- - Raiden   Version 0.1.5 has arrived! - I've seperate...   Jan 19 2011, 00:21
- - Raiden   QUOTE (pbelkner @ Jan 19 2011, 16:40) The...   Jan 23 2011, 16:49
- - Raiden   I've uploaded 0.1.6: - The main new feature is...   Jan 23 2011, 17:00
- - hödyr   Any idea why r128-mpg123 does not work for me on W...   Jan 23 2011, 18:17
- - C.R.Helmrich   Thanks for the new version. When I check the same ...   Jan 23 2011, 20:00
- - Raiden   QUOTE (C.R.Helmrich @ Jan 23 2011, 20:00)...   Jan 23 2011, 20:28
- - Raiden   QUOTE (hödyr @ Jan 23 2011, 18:17) Any id...   Jan 23 2011, 20:42
- - Raiden   Version 0.1.7 is just a bug fix: - Handle MP3...   Jan 23 2011, 23:05
- - hödyr   Thanks. Could you fix the build script to run on F...   Jan 24 2011, 11:55
- - Raiden   QUOTE (hödyr @ Jan 24 2011, 11:55) Thanks...   Jan 24 2011, 12:45
- - Raiden   I've uploaded 0.1.8: - Some improvements to th...   Jan 24 2011, 23:50
- - kode54   I've made my own preliminary foo_r128scan comp...   Jan 26 2011, 06:25
- - Raiden   I've uploaded 0.1.9. This is mostly a library ...   Jan 28 2011, 12:14
- - kode54   You made a mistake in ebur128_change_parameters: ...   Jan 29 2011, 02:58
- - C.R.Helmrich   And in ebur128.h it says: QUOTE /* Get short-term...   Jan 29 2011, 17:13
- - Raiden   Thank you for the bug reports! I've upload...   Jan 30 2011, 21:04
- - gjgriffith   Is SSE2 required to run this tool? The only versio...   Jan 31 2011, 02:33
- - Raiden   Here are non SSE builds: http://www-public.tu-bs.d...   Jan 31 2011, 09:51
|- - gjgriffith   QUOTE (Raiden @ Jan 31 2011, 09:51) Here ...   Jan 31 2011, 19:34
|- - nucelar   QUOTE (gjgriffith @ Jan 31 2011, 19:34) Q...   Feb 3 2011, 11:47
|- - googlebot   The R128 spec defines a measurement of short-term ...   Feb 3 2011, 12:31
|- - nucelar   QUOTE (googlebot @ Feb 3 2011, 12:31) The...   Feb 3 2011, 12:48
- - Raiden   QUOTE (nucelar @ Feb 3 2011, 11:47) First...   Feb 3 2011, 20:55
|- - nucelar   QUOTE (Raiden @ Feb 3 2011, 20:55) It is ...   Feb 4 2011, 12:03
- - Raiden   QUOTE (nucelar @ Feb 4 2011, 12:03) Later...   Feb 5 2011, 18:42
- - Raiden   I've uploaded 0.1.11. There are no changes to ...   Feb 5 2011, 18:51
- - kode54   You may want to take a look at the silly changes I...   Feb 6 2011, 08:50
|- - googlebot   QUOTE (kode54 @ Feb 6 2011, 08:50) You ma...   Feb 6 2011, 09:15
- - Raiden   QUOTE (kode54 @ Feb 6 2011, 08:50) You ma...   Feb 6 2011, 11:42
|- - googlebot   QUOTE (Raiden @ Feb 6 2011, 11:42) I supp...   Feb 6 2011, 11:46
|- - pbelkner   QUOTE (Raiden @ Feb 6 2011, 11:42) Tech 3...   Feb 6 2011, 11:59
- - leirbag   Hi, I have just tested last version (libebur128-0...   Feb 6 2011, 12:28
- - Raiden   Thanks for the report! It was a bug in the com...   Feb 6 2011, 13:38
|- - leirbag   QUOTE (Raiden @ Feb 6 2011, 13:38) Thanks...   Feb 6 2011, 14:14
|- - leirbag   QUOTE (Raiden @ Feb 6 2011, 13:38) Thanks...   Feb 6 2011, 14:19
- - benski   Raiden. For gated loudness of a segment, the EBU ...   Feb 6 2011, 20:51
- - Raiden   QUOTE (benski @ Feb 6 2011, 20:51) For ga...   Feb 6 2011, 22:16
- - benski   And in the example of a 600ms input, it should be ...   Feb 6 2011, 22:36
- - kode54   Ah, right, then. Well, then it would be helpful to...   Feb 7 2011, 00:44
- - Raiden   QUOTE (googlebot @ Feb 6 2011, 11:46) PS ...   Feb 7 2011, 02:06
|- - romor   QUOTE (Raiden @ Feb 7 2011, 02:06) It cou...   Feb 7 2011, 03:08
- - Raiden   QUOTE (benski @ Feb 6 2011, 22:36) And in...   Feb 7 2011, 02:21
|- - benski   QUOTE (Raiden @ Feb 6 2011, 20:21) QUOTE ...   Feb 7 2011, 05:22
- - Raiden   QUOTE (kode54 @ Feb 7 2011, 00:44) Ah, ri...   Feb 7 2011, 02:40
- - Raiden   It is doing window overlap. Otherwise, the block e...   Feb 7 2011, 06:36
|- - benski   QUOTE (Raiden @ Feb 7 2011, 00:36) It is ...   Feb 7 2011, 16:20
- - kode54   The library doesn't like it very much if the s...   Feb 7 2011, 15:06
|- - pbelkner   QUOTE (kode54 @ Feb 7 2011, 15:06) /5*2. ...   Feb 7 2011, 15:20
- - nucelar   Hi raiden, you're last improvements/ additions...   Feb 7 2011, 16:59
- - Raiden   Hi again, I've uploaded 0.2.0: Library: - Rem...   Feb 20 2011, 18:55
|- - habasud   QUOTE (Raiden @ Feb 20 2011, 18:55) Hi ag...   Feb 23 2011, 09:46
- - Raiden   QUOTE (habasud @ Feb 23 2011, 09:46) It t...   Feb 23 2011, 12:38
- - C.R.Helmrich   FYI: EBU tech doc 3343 has been published. Chris   Feb 26 2011, 13:10
- - Raiden   I've uploaded 0.2.1. Library: - removed the e...   Feb 26 2011, 20:20
- - Raiden   And here is 0.2.2, with a single change: - added ...   Feb 27 2011, 22:40
|- - nucelar   QUOTE (Raiden @ Feb 27 2011, 22:40) And h...   Mar 3 2011, 18:01
- - Raiden   QUOTE (nucelar @ Mar 3 2011, 18:01) Hey R...   Mar 3 2011, 22:33
|- - nucelar   Hi! Thanks for the Macports suggestion, i will...   Mar 4 2011, 11:53
- - habasud   ...maybe someone finds it useful to visualize the ...   Mar 4 2011, 12:36
- - Surfi   :: SSE2 Win32 compile doesn't work with comma...   Mar 5 2011, 18:37
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th August 2015 - 05:42
