Playlist History (foo_playlisthistory), playlist history, similar to page history in browsers
kerpondile
post Jan 11 2011, 07:34
foo_playlisthistory enables playlist history in foobar2000, similar to page history in browsers.
The component watches activated playlists and provides the user back and next buttons to navigate the playlist history.
Two commands are provided under the View/Recently activated playlists: Previous playlist and Next playlist.
From 0.1.4 onwards the component includes Restore last removed playlist command in the Edit menu.
Newest version: 0.1.6 / 2011-04-05
Requires foobar 1.1->
For more information, please see the Wiki page.
Links:
Download the latest version: Here
Source: Github.
Wiki: Wiki page.
Please add any comments, I appreciate them!
Sami Salonen
This post has been edited by kerpondile: May 4 2011, 13:20
joh316
post Feb 13 2011, 14:19
Hi:
I need a playlist history clear tool(Edit menu) . that likes the Playlist Manager.
with wsh panel mod 1.41, we can manage the playlist,such as remove ,restore ,dup,hide,rename,new autoplaylist(Inc UI).reorder.
however,we can't clear the history after remo......
joh316
kerpondile
post Feb 14 2011, 07:44
QUOTE (joh316 @ Feb 13 2011, 15:19) *
Hi:
joh316
I'm not sure what you want, could you give me a use case? How would you use this feature?
joh316
post Feb 15 2011, 03:48
ok,
(my poor english)
your program foo_history,can restore last removed playlist in Edit menu.
pulldown View menu,there is a "playlist manager",this is not a plugin.
it can do almost every thing about playlist. if playlists are deleted ,right click the panel,a submenu called "restore" apeared.
is this restore menu,include a "Clear history". then,restore is unavirable.
So I just want this"Clear history" add to the "Edit Menu"
////why i want this menu?
as, CUI playlist switch,can'tmake background transparenty . many user try to use wsh_panel_mode,to design a" playlist switch" ,the wsh_panel_mode author add many functions about playlist,such as fb.playlistCount,fb.Moveplaylist(a,b) ..... Howerer,it is difficult to make a function :Clear history.
joh316
kerpondile
post Feb 15 2011, 17:29
Now I understand what you mean.
However, I think the feature is something that is not very useful to normal users. I don't understand why would anyone want to remove the "removed playlists history". It's not like they consume a lot of space. And if they want to do it (not very often, I assume?), it perfectly possible using playlist manager.
I think it's wrong to put too much into one component, at least if it's not useful to many users.
Of course, making a component implementing the feature you talked about should be very straightforward. Maybe you could even implement it yourself? I can provide further tips on that if you want. Maybe you event want to make "support library" for your wsh panel functions?
joh316
post Feb 16 2011, 07:05
Sorry,
the" restore" menu also in the end of CUI playlist switcher,if we do any delete acction. in this restore menu include a "clear history"
,just likes the playlist manager.
why I need clear instead of restore?
in CUI or playlist manager,when we restore a removed playlist, foobar will ask us the new name,and always restore to the end of playlist.
I think ,this is not a clever job.
Now, in wsh pannel, we use Array to manage the playlists, I use hide instead of Remove command, restore = unhide, the advantage is all manager by
array function. eg. when I hide a playlist at position 4, unhide it will be at 4 too, not at the end. and need't type new name. so I need't restore command,because I usually need not to delete the playlist, only hide them. If I really decide to delete a playlist , I wish it be unrecoverable. when restored, new name maybe the old one.
Library , I never use this low efficiency thing, I prefer to Explorler Tree plugin.
//______
If possible ,please write a " Edit / Clear playlist history " only for me first.when I delete a playlist ,I will add Clear playlist history command under it.
- kerpondile   Playlist History (foo_playlisthistory)   Jan 11 2011, 07:34
- - Falstaff   Thanx for sharing this, i'll test this new com...   Jan 11 2011, 17:37
- - Robertina   Thank you very much, kerpondile ! Robertina.   Jan 11 2011, 18:45
- - matav   nice component but when i heard the name i had a d...   Jan 11 2011, 20:14
|- - kerpondile   @matav Yes, the component name might be a bit misl...   Jan 12 2011, 10:49
|- - foosion   QUOTE (kerpondile @ Jan 12 2011, 10:49) A...   Jan 12 2011, 13:32
- - matav   QUOTE (kerpondile @ Jan 12 2011, 10:49) I...   Jan 13 2011, 08:58
- - Robertina   QUOTE (kerpondile @ Jan 11 2011, 22:49) I...   Jan 14 2011, 04:10
|- - kerpondile   Hi all! OK, I've released new version wit...   Jan 14 2011, 07:45
|- - Robertina   QUOTE (kerpondile @ Jan 13 2011, 19:45) O...   Jan 14 2011, 11:24
|- - kerpondile   Thanks! I really appreciate it. btw, Just rel...   Jan 18 2011, 07:55
- - Jny   useful, thanks   Jan 18 2011, 20:41
- - fuffi   QUOTE (kerpondile @ Jan 11 2011, 07:34) f...   Feb 4 2011, 12:16
- - joh316   Hi: I need a playlist history clear tool(Edit men...   Feb 13 2011, 14:19
|- - kerpondile   QUOTE (joh316 @ Feb 13 2011, 15:19) Hi: ...   Feb 14 2011, 07:44
|- - joh316   ok, (my poor english) your program foo_history,can...   Feb 15 2011, 03:48
|- - kerpondile   Now I understand what you mean. However, I think ...   Feb 15 2011, 17:29
|- - joh316   Sorry, the" restore" menu also in the en...   Feb 16 2011, 07:05
|- - kerpondile   With "Library" I mean "Software lib...   Feb 16 2011, 09:43
|- - joh316   Thanks for replying. Maybe I will try SDK, but I t...   Feb 17 2011, 06:44
- - tg2k3   Finding this component is like god hearing my pray...   May 3 2011, 01:34
- - kerpondile   Updated the component. Basically just rebuilt with...   May 4 2011, 13:57
- - TakuSkan   Is there some simple title formatting using tabs t...   Jun 3 2012, 11:14
- - db1989   How about $tab?   Jun 3 2012, 11:31
|- - TakuSkan   QUOTE (db1989 @ Jun 3 2012, 03:31) How ab...   Jun 3 2012, 12:26
- - JisSey   Hello Please, could you tell me how to insert a l...   Aug 21 2012, 09:39
- - Emerelle   Jissey, this seems to be a WSH script panel - the ...   Aug 21 2012, 13:20
RSS Lo-Fi Version Time is now: 1st September 2015 - 11:19
