TAK 2.1.0
TBeck
post Jan 8 2011, 21:04
TAK Developer
Final release of TAK 2.1.0 ((T)om's lossless (A)udio (K)ompressor)
This release brings speed optimizations and multi core support for the encoder. The dedicated LossyWav-codec that was available in the beta releases has been removed.
It consists of:
- TAK Applications 2.1.0.
- TAK Winamp plugin 2.1.0.
- TAK SDK 1.1.1.
- TAK Decoding library 2.1.0.
Download
Download the archive in the upload section: TAK 2.1.0
What's new
Improvements:
- Encoding speed improvements of about 10 to 20 percent (depends on preset and cpu) for cpus with the SSSE3 instruction set. Since SSSE3 (note the three 'S') isn't supported by AMD, only Intel users will benefit from those optimizations.
- The encoder now creates up to four threads to utilize multiple cpu cores. Specify the thread number in the General Options dialog of the GUI-version or with the -tn option of the command line version. By default only one thread is created. You will only notice a speed up, if the encoding speed isn't already limited by the performance of your drives.
Modifications:
- Added the -cpu# switch to the command line version, which lets you control some cpu optimizations.
- The file info function now also shows the name of the codec used to compress the file.
- Moved the verify-option from the details-dialog to the general compression options dialog.
- All dialogs with an Add-files-option locked the source folder until the dialog was closed. Hopefully this is no longer the case.
Known issues:
- If you use pipe decoding and the application reading the pipe is beeing terminated before the whole file has been read, TAKC may get into an endless loop and has to be manually killed with the task manager. I don't think this is a big issue but i will try to fix it in one of the next versions. BTW: Big thanks to shnutils for testing the pipe decoding!
- There seem to be some compatibility issues with pipe decoding to some other applications ("crc1632.exe" has been reported). I will try to fix it in the next release.
Why is it called 2.1 and not 2.0.1?
Usually i increase the second place of the version number if some option has been added which isn't backwards compatible (can not be decoded by earlier versions) but will only take effect, if it is explicitly activated by the user. This was true for the LossyWav-codec that now has been removed. But i didn't want to go down to 2.0.1 because of the possible confusion occuring when i later released another 2.1 which would have nothing in common with the current beta 2.1.
More information
You can find some useful information and speed comparisons in the Beta 3 thread.
Have fun...
Thomas
This post has been edited by TBeck: Jan 9 2011, 04:06
krafty
post Feb 14 2011, 22:35
My wishlist:
A linux version!
tak (a binary)
libtakenc.so (closed-source, hey that works for me...)
and
libtakdec.so (open source, but with restricting license, so everyone can implement it, with authorization and credits due).
This post has been edited by krafty: Feb 14 2011, 22:37
- TBeck   TAK 2.1.0   Jan 8 2011, 21:04
- - Steve Forte Rio   Gteat work! Thank you! And now let's...   Jan 8 2011, 21:31
- - meDveD.spb   BIG THX!   Jan 8 2011, 22:17
- - Steve Forte Rio   QUOTE (TBeck @ Dec 13 2010, 14:01) QUOTE ...   Jan 8 2011, 22:42
- - jc3213   Thanks for your great work! I have been waitin...   Jan 9 2011, 05:02
- - johnsonlam   Thank you very much Thomas! Wish List (only w...   Jan 9 2011, 07:28
- - Steve Forte Rio   I've noticed a quite strange thing. On my sys...   Jan 9 2011, 14:24
- - Corpulencio   Big thanks! Thomas, can you say what number o...   Jan 9 2011, 21:13
- - TBeck   QUOTE (Steve Forte Rio @ Jan 8 2011, 22:4...   Jan 10 2011, 12:50
|- - Destroid   QUOTE (TBeck @ Jan 10 2011, 11:50) There ...   Jan 11 2011, 08:13
|- - johnsonlam   QUOTE (TBeck @ Jan 10 2011, 19:50) 1) Sup...   Jan 13 2011, 04:32
|- - GeSomeone   QUOTE (johnsonlam @ Jan 13 2011, 05:32) Q...   Jan 13 2011, 10:11
|- - johnsonlam   QUOTE (GeSomeone @ Jan 13 2011, 17:11) QU...   Jan 20 2011, 19:41
- - sauvage78   The lack of requests for multichannel is IMHO simp...   Jan 11 2011, 09:20
- - list   Congratulations. And thanks a lot great job...   Jan 29 2011, 14:33
- - zver   Just a fast question; I started using tak few mont...   Jan 31 2011, 02:36
- - Manlord   With every version of TAK you advance one step bey...   Feb 5 2011, 22:52
- - TBeck   QUOTE (johnsonlam @ Jan 13 2011, 04:32) Q...   Feb 14 2011, 22:28
|- - zver   QUOTE (TBeck @ Feb 14 2011, 13:28) QUOTE ...   Feb 15 2011, 07:20
- - krafty   My wishlist: A linux version! tak (a binary)...   Feb 14 2011, 22:35
|- - sl1pkn07   QUOTE (krafty @ Feb 14 2011, 22:35) My wi...   Nov 27 2011, 21:54
- - greynol   Thomas is well aware of any and all comments/discu...   Feb 14 2011, 23:16
RSS Lo-Fi Version Time is now: 27th April 2015 - 13:24
