R128GAIN: An EBU R128 compliant loudness scanner
pbelkner
post Jan 5 2011, 19:38
I've just uploaded on sourceforge a first version of r128gain, an EBU R128 (http://tech.ebu.ch/loudness) compliant loudness scanner:
http://sourceforge.net/projects/r128gain/files/
  • process single files (tracks):
    • In order to just scan and analyze one file (WAV, FLAC or WV):
      r128gain <file>
    • In order to scan, analyze and tag one file (currently only FLAC, result will be in <directory>):
      r128gain <file> <directory>
    • In order to scan, analyze one file (WAV, WV) and encode and tag into FLAC (result will be in <directory>):
      r128gain <file> <directory> flac
  • recursively process directories (the content of a directory is considered an album):
    • In order to just recursively scan and analyze a directory:
      r128gain <directory>
    • In order to recursively scan, analyze and tag a directory:
      r128gain <directory> <directory>
      r128gain <directory>/* <directory>
    • In order to recursively scan, analyze a directory and encode and tag into FLAC:
      r128gain <directory> <directory> flac
      r128gain <directory>/* <directory> flac
Tagging is currently supported only for FLAC:
  • REPLAYGAIN_REFERENCE_LOUDNESS: always -23 LUFS (corresponding to EBU R128)
  • REPLAYGAIN_TRACK_GAIN: loudness difference to -23 LUFS in LU measured for this track
  • REPLAYGAIN_TRACK_PEAK: true peak measured at 192 kHz for this track
  • REPLAYGAIN_ALBUM_GAIN: loudness difference to -23 LUFS in LU measured for the whole album
  • REPLAYGAIN_ALBUM_PEAK: true peak measured at 192 kHz for the whole album
These tags should be honored by each Replay Gain compliant media player.
Fandango
post Jan 11 2011, 23:14
I have a proposal.
New standard tag fields:
EBU_R128_REFERENCE_LOUDNESS
EBU_R128_TRACK_GAIN
EBU_R128_TRACK_PEAK
EBU_R128_ALBUM_GAIN
EBU_R128_ALBUM_PEAK
or R128GAIN_*, EBUR128_*, ...
Replay Gain tag fields should become optional, only activated by a command line option. So no loss there if people want to test your implementation without having an EBU R128 DSP plugin.
Without independent tag fields the authors of such plugins cannot start supporting EBU R128 gain control in their Replay Gain plugins.
Notat
post Jan 12 2011, 04:11
QUOTE (Fandango @ Jan 11 2011, 15:14) *
Why not? There is a simple and reasonably accurate mapping between R128 and Replay Gain metrics.
This post has been edited by Notat: Jan 12 2011, 04:14
Fandango
post Jan 13 2011, 16:21
QUOTE (Notat @ Jan 12 2011, 04:11) *
As I've seen it now whether it is accurate enough is subject to debate.
Independent tag fields make such discussions superflous at least for people who want to have both and are willing to rescan their music once. Most importantly switching between EBU R128 and Replay Gain would not require rescanning the audio when both values are stored alongside. The implementing mapping itself is also probably an obstacle for some plugin developers (especially commerical ones where time is money) although I believe most people here would embrace it as a task.
And as I said storing EBU R128 information in a Replay Gain compatible format and tag fields should still be made available as an option. But if r128gain will never adopt its own tag fields with a relevant format then there's no appeal for loudness equalization plugin developers to adopt this method, since there's nothing to work with. EBU R128 will be too compatible to be distinct, and it will never stand a chance against Replay Gain.
This post has been edited by Fandango: Jan 13 2011, 16:36
2Bdecided
post Jan 13 2011, 17:20
ReplayGain developer
QUOTE (Fandango @ Jan 13 2011, 15:21) *
I'm not sure why you'd want to do that. The whole point of anchoring ReplayGain to a known reference was so that an improved calculation could be introduced at any point without breaking anything (as could user defined values). Once an improved calculation is available, there's no reason to use the old (original) one, so no reason to have two sets of tags.
If the EBU defines a new set of tags and pushes for their adoption, then I can see that this could happen. But failing this, the existing RG tags, populated with values from another calculation (e.g. EBU R128), provide a perfectly good solution.
Don't underestimate industry inertia. Don't overestimate the EBU's interest in portable media players etc.
- pbelkner   R128GAIN: An EBU R128 compliant loudness scanner   Jan 5 2011, 19:38
- - googlebot   Didn't try the tool, yet, but had a look at th...   Jan 5 2011, 20:13
|- - pbelkner   QUOTE (googlebot @ Jan 5 2011, 21:13) Did...   Jan 5 2011, 21:32
- - C.R.Helmrich   Wow, thank you so much for this tool! I was al...   Jan 5 2011, 23:23
|- - pbelkner   QUOTE (C.R.Helmrich @ Jan 6 2011, 00:23) ...   Jan 6 2011, 00:46
|- - C.R.Helmrich   QUOTE (pbelkner @ Jan 6 2011, 01:46) It i...   Jan 6 2011, 15:23
|- - pbelkner   QUOTE (C.R.Helmrich @ Jan 6 2011, 16:23) ...   Jan 6 2011, 16:03
|- - googlebot   QUOTE (pbelkner @ Jan 6 2011, 16:03) What...   Jan 7 2011, 21:34
|- - pbelkner   QUOTE (googlebot @ Jan 7 2011, 22:34) I a...   Jan 7 2011, 22:17
|- - googlebot   QUOTE (pbelkner @ Jan 7 2011, 22:17) It s...   Jan 7 2011, 22:35
|- - pbelkner   QUOTE (googlebot @ Jan 7 2011, 23:35) PS ...   Jan 7 2011, 23:21
|- - C.R.Helmrich   QUOTE (pbelkner @ Jan 8 2011, 00:21) Many...   Jan 8 2011, 14:29
|- - pbelkner   QUOTE (C.R.Helmrich @ Jan 8 2011, 15:29) ...   Jan 10 2011, 17:38
|- - pbelkner   QUOTE (pbelkner @ Jan 10 2011, 18:38) The...   Jan 10 2011, 18:01
|- - C.R.Helmrich   Exactly, and if you pull out the "/n" in...   Jan 10 2011, 18:20
- - Fandango   On a completely other note... What about patents? ...   Jan 6 2011, 01:53
|- - mudlord   QUOTE (Fandango @ Jan 5 2011, 18:53) On a...   Jan 6 2011, 13:22
|- - cpchan   QUOTE (mudlord @ Jan 6 2011, 08:22) The o...   Jan 6 2011, 13:44
|- - mudlord   QUOTE (cpchan @ Jan 6 2011, 07:44) QUOTE ...   Jan 6 2011, 13:46
- - Notat   Congratulations on this! I know that BS.1770 ...   Jan 6 2011, 02:37
- - mudlord   What is the license for the tool?   Jan 6 2011, 03:42
- - A_Man_Eating_Duck   i can't for the life of me get this app to jus...   Jan 6 2011, 08:14
|- - pbelkner   QUOTE (A_Man_Eating_Duck @ Jan 6 2011, 09...   Jan 6 2011, 09:34
- - pbelkner   QUOTE (Fandango @ Jan 6 2011, 02:53) On a...   Jan 6 2011, 09:19
|- - mudlord   QUOTE (pbelkner @ Jan 6 2011, 02:19) It...   Jan 6 2011, 13:20
|- - pbelkner   QUOTE (mudlord @ Jan 6 2011, 14:20) QUOTE...   Jan 6 2011, 15:26
|- - Soap   QUOTE (pbelkner @ Jan 6 2011, 09:26) Both...   Jan 6 2011, 15:53
|- - cpchan   QUOTE (Soap @ Jan 6 2011, 10:53) ffmepg i...   Jan 6 2011, 16:09
|- - pbelkner   QUOTE (Soap @ Jan 6 2011, 16:53) QUOTE (p...   Jan 6 2011, 16:13
|- - Soap   QUOTE (pbelkner @ Jan 6 2011, 10:13) QUOT...   Jan 6 2011, 16:21
|- - pbelkner   QUOTE (Soap @ Jan 6 2011, 17:21) QUOTE (p...   Jan 6 2011, 16:49
|- - saratoga   QUOTE (pbelkner @ Jan 6 2011, 10:49) QUOT...   Jan 6 2011, 18:37
|- - cpchan   QUOTE (saratoga @ Jan 6 2011, 13:37) That...   Jan 7 2011, 01:39
- - Zao   Note that "use" in mudlord's post is...   Jan 6 2011, 13:29
|- - cpchan   QUOTE (Zao @ Jan 6 2011, 08:29) If you ev...   Jan 6 2011, 13:48
|- - Zao   QUOTE (cpchan @ Jan 6 2011, 13:48) QUOTE ...   Jan 6 2011, 13:52
|- - cpchan   QUOTE (Zao @ Jan 6 2011, 08:52) If more k...   Jan 6 2011, 13:59
- - Zao   Even if the end artifact is a program, this preven...   Jan 6 2011, 13:47
|- - cpchan   QUOTE (Zao @ Jan 6 2011, 08:47) Even if t...   Jan 6 2011, 13:52
|- - Zao   QUOTE (cpchan @ Jan 6 2011, 13:52) What i...   Jan 6 2011, 13:54
- - Zao   If a developer uses a library with one of the usua...   Jan 6 2011, 14:02
|- - cpchan   QUOTE (Zao @ Jan 6 2011, 09:02) If a deve...   Jan 6 2011, 14:14
- - lvqcl   Please remember that QUOTE (pbelkner @ Jan 6 ...   Jan 6 2011, 14:10
- - Zao   You cannot always dynamically link to a library, a...   Jan 6 2011, 14:16
|- - cpchan   QUOTE (Zao @ Jan 6 2011, 09:16) You canno...   Jan 6 2011, 14:33
|- - mudlord   QUOTE (cpchan @ Jan 6 2011, 08:33) QUOTE ...   Jan 7 2011, 07:19
|- - googlebot   QUOTE (mudlord @ Jan 7 2011, 07:19)To avo...   Jan 7 2011, 10:46
|- - 2Bdecided   QUOTE (googlebot @ Jan 7 2011, 09:46) No ...   Jan 7 2011, 17:45
- - GHammer   Seven of 38 posts on software licensing. Geesh...   Jan 7 2011, 04:39
|- - mudlord   QUOTE (GHammer @ Jan 6 2011, 21:39) Seven...   Jan 7 2011, 07:14
- - romor   Bad talk. You are free to see his posts if you wan...   Jan 7 2011, 15:57
|- - Soap   forget it.   Jan 7 2011, 16:43
|- - staale   Hi, Just wanted to add that we've released ou...   Jan 7 2011, 17:08
- - googlebot   Forget this, too. Else the joke doesn't work o...   Jan 7 2011, 17:02
- - jangk   Hello, back to audio issues again. Thank you pbel...   Jan 7 2011, 17:27
|- - pbelkner   QUOTE (jangk @ Jan 7 2011, 18:27) Am I mi...   Jan 7 2011, 18:13
|- - jangk   QUOTE (pbelkner @ Jan 7 2011, 18:13) QUOT...   Jan 7 2011, 19:13
|- - pbelkner   QUOTE (jangk @ Jan 7 2011, 20:13) Anyhow,...   Jan 7 2011, 19:56
- - mudlord   QUOTE How about you program your own lib or shut u...   Jan 7 2011, 18:57
- - jdoering   Please pardon the noob here; hopefully I'm kee...   Jan 8 2011, 00:28
|- - googlebot   Completely agree! One doesn't really have ...   Jan 8 2011, 01:51
|- - pbelkner   QUOTE (jdoering @ Jan 8 2011, 01:28) But ...   Jan 8 2011, 09:32
- - Notat   I have it on good authority that the calculation c...   Jan 8 2011, 18:42
- - googlebot   A fully standard compliant single-pass outline is ...   Jan 8 2011, 19:40
- - pbelkner   v0.3 released I've just uploaded the new vers...   Jan 9 2011, 18:47
|- - googlebot   QUOTE (pbelkner @ Jan 9 2011, 18:47) CODE...   Jan 12 2011, 20:26
|- - pbelkner   QUOTE (googlebot @ Jan 12 2011, 21:26) QU...   Jan 13 2011, 10:26
- - googlebot   Works perfectly, great job! Even for multichan...   Jan 10 2011, 09:58
- - googlebot   Just out of curiosity, where does that 0.4 come fr...   Jan 10 2011, 18:35
|- - jdoering   QUOTE (googlebot @ Jan 10 2011, 09:35) Ju...   Jan 10 2011, 19:27
- - googlebot   Duh. My bad!   Jan 10 2011, 21:40
- - Fandango   I have a proposal. New standard tag fields: EBU_...   Jan 11 2011, 23:14
|- - Notat   QUOTE (Fandango @ Jan 11 2011, 15:14) Wit...   Jan 12 2011, 04:11
|- - Fandango   QUOTE (Notat @ Jan 12 2011, 04:11) QUOTE ...   Jan 13 2011, 16:21
|- - pbelkner   QUOTE (Fandango @ Jan 13 2011, 17:21) But...   Jan 13 2011, 17:01
||- - 2Bdecided   QUOTE (pbelkner @ Jan 13 2011, 16:01) EBU...   Jan 13 2011, 17:24
|- - 2Bdecided   QUOTE (Fandango @ Jan 13 2011, 15:21) Mos...   Jan 13 2011, 17:20
- - Fandango   PS: I'd say that using GAIN in your prefix is ...   Jan 12 2011, 02:02
- - jdoering   I had been hoping that the written tags were being...   Jan 12 2011, 06:40
|- - pbelkner   QUOTE (jdoering @ Jan 12 2011, 07:40) I h...   Jan 12 2011, 10:21
|- - jdoering   QUOTE (pbelkner @ Jan 12 2011, 01:21) QUO...   Jan 12 2011, 21:24
|- - pbelkner   QUOTE (jdoering @ Jan 12 2011, 22:24) I t...   Jan 13 2011, 11:01
- - jdoering   Just compared r128gain output versus ReplayGain fo...   Jan 12 2011, 10:18
- - googlebot   I think you both have a valid point. I also think...   Jan 12 2011, 12:58
|- - pbelkner   QUOTE (googlebot @ Jan 12 2011, 13:58) =...   Jan 12 2011, 13:14
||- - C.R.Helmrich   QUOTE (pbelkner @ Jan 12 2011, 14:14) QUO...   Jan 12 2011, 18:27
|||- - Notat   QUOTE (C.R.Helmrich @ Jan 12 2011, 10:27)...   Jan 13 2011, 02:57
|||- - jdoering   QUOTE (Notat @ Jan 12 2011, 17:57) QUOTE ...   Jan 13 2011, 06:21
|||- - C.R.Helmrich   QUOTE (jdoering @ Jan 13 2011, 07:21) I...   Jan 13 2011, 10:25
|||- - pbelkner   QUOTE (C.R.Helmrich @ Jan 13 2011, 11:25)...   Jan 13 2011, 10:37
||- - 2Bdecided   QUOTE (pbelkner @ Jan 12 2011, 12:14) QUO...   Jan 13 2011, 11:23
||- - Notat   QUOTE (2Bdecided @ Jan 13 2011, 03:23) Yo...   Jan 13 2011, 15:41
|- - pbelkner   QUOTE (googlebot @ Jan 12 2011, 13:58) PS...   Jan 12 2011, 17:07
- - googlebot   How large are the expected differences? Is there a...   Jan 12 2011, 18:46
- - C.R.Helmrich   True. I guess for the averaging we should leave ou...   Jan 12 2011, 19:00
- - Raiden   What is so special about pink noise? How does pink...   Jan 13 2011, 11:44
- - googlebot   Pink noise has equal energy over all octaves. It...   Jan 13 2011, 12:02
- - jangk   Thank you Notat for the link to AES "Loudness...   Jan 13 2011, 13:57
- - benski   I'm with David. I think we should verify the ...   Jan 13 2011, 17:27
- - Fandango   So if the old tags are used, how do I know whether...   Jan 13 2011, 18:22
6 Pages V   1 2 3 > »
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 4th July 2015 - 20:51
