Converting to WMA
OrcaMarinha
post Dec 18 2010, 00:44
Is there a way to convert FLAC to WMA using foobar just like its possible to converto to mp3 ?
mudlord
post Jan 11 2011, 05:36
Group: Developer (Donating)
GUI component?
What do you need? Does it need to be a context menu item? To me, it would make much more sense taking selected entries, decoding to PCM, and then piping them to the WMA encoder. Only issue I can see there then is you need to make BASS/BASSWMA somehow multiinstance usable. But then you support *any* format that FB2K supports...Plus, it should remove the dependancy on bass.dll itself, as it seems BASSWMA's encoder can be called without a BASS instance.
edit: Noticed a issue with your encoder. Seems to crash whenever no parameters are given to it. I assume the encoder was coded in Delphi or Visual Basic? (judging from the error message)
This post has been edited by mudlord: Jan 11 2011, 17:57
- OrcaMarinha   Converting to WMA   Dec 18 2010, 00:44
- - kode54   This topic has instructions for setting up the con...   Dec 18 2010, 02:23
- - Merlin_de   QUOTE (OrcaMarinha @ Dec 18 2010, 00:44) ...   Jan 5 2011, 15:39
|- - nbarzgar   QUOTE (Merlin_de @ Jan 5 2011, 16:39) hel...   Apr 17 2012, 17:33
- - tgckpg   Good! Thanks! I'm using windows 7 and ...   Jan 10 2011, 21:29
- - mudlord   GUI component? What do you need? Does it need to ...   Jan 11 2011, 05:36
- - saivert   It is because he didn't check for parameters i...   Jan 11 2011, 19:47
- - eevan   I tried this tool on x32 Win 7 Ultimate and got th...   Jan 12 2011, 17:59
- - lvqcl   QUOTE I'd like to know if anybody else get the...   Jan 12 2011, 18:37
- - kode54   This is a limitation of the stream format used by ...   Jan 12 2011, 23:25
- - eevan   Thanks for clarification!   Jan 13 2011, 00:38
- - Zin-Uru   Very good! Thank you!   Jan 20 2011, 14:56
- - Zin-Uru   It seems like your encoder does not support 2-pass...   Jan 21 2011, 08:10
- - dazzle   Hi, I have just tried the WMAenc.exe in EAC and i...   Jan 21 2011, 12:09
|- - Merlin_de   QUOTE (Zin-Uru @ Jan 21 2011, 08:10)...   Jan 22 2011, 00:58
|- - dazzle   Thank you for the answer - I just have to use mp3t...   Jan 23 2011, 11:32
- - Steve Forte Rio   Why does encoder can't work without bass libra...   Jan 22 2011, 14:29
|- - Merlin_de   QUOTE (Steve Forte Rio @ Jan 22 2011, 14...   Jan 22 2011, 15:43
- - Steve Forte Rio   It is always more convenient to use only one execu...   Jan 22 2011, 18:08
- - mudlord   Most likely is a wrapper to the encoder/decoder DM...   Jan 22 2011, 22:30
- - Ljubo44   is there any way to convert WAV 24-bit/96kHz 2CH t...   Jan 22 2011, 23:51
|- - Merlin_de   QUOTE (Ljubo44 @ Jan 22 2011, 23:51) is t...   Jan 23 2011, 00:36
- - Ljubo44   on Q98_96_2_24 after encoding i get wma on 337kbps...   Jan 23 2011, 01:36
- - Apesbrain   The only form of WMA that supports 24/96 is WMA Lo...   Jan 23 2011, 02:46
- - mudlord   QUOTE It is always more convenient to use only one...   Jan 23 2011, 13:54
|- - jaro1   QUOTE (mudlord @ Jan 23 2011, 13:54) QUOT...   Jan 29 2011, 15:10
|- - Merlin_de   QUOTE (jaro1 @ Jan 29 2011, 15:10) It wil...   Jan 31 2011, 02:29
- - Merlin_de   WMAenc 0.1.0.2 beta released changelog: - fix cra...   Jan 23 2011, 22:04
- - polemon   Is there a Linux build of WMAenc? I mean something...   Jan 25 2011, 13:32
|- - dv1989   QUOTE (polemon @ Jan 25 2011, 12:32) I...   Jan 25 2011, 13:45
|- - polemon   QUOTE (dv1989 @ Jan 25 2011, 13:45) From ...   Jan 25 2011, 18:30
- - jaro1   Merlin or someone else who knows his command funct...   Feb 20 2011, 11:05
- - lvqcl   Works here: WMAenc.exe -silent -input test.wav -ou...   Feb 20 2011, 11:40
|- - jaro1   In the case of fb2k, nothing has changed, so conve...   Feb 20 2011, 12:41
- - lvqcl   My OS is Win7 x64. Core2 2500 MHz, ~50 x realtime...   Feb 20 2011, 13:28
- - jaro1   So, it seems it could be related to cpu architectu...   Feb 20 2011, 15:50
|- - Merlin_de   QUOTE (jaro1 @ Feb 20 2011, 15:50) So, it...   Feb 20 2011, 17:43
- - lvqcl   What is the speed of WAV->FLAC converting?   Feb 20 2011, 16:51
|- - jaro1   I don't understand, how is Flac related with b...   Feb 20 2011, 19:33
- - lvqcl   A small command-line WMA encoder is available here...   Aug 30 2011, 21:15
- - Nick.C   Excellent - tried it with my 55 sample test set bo...   Aug 30 2011, 21:47
|- - lvqcl   QUOTE (Nick.C @ Aug 31 2011, 00:47) It do...   Aug 31 2011, 15:48
- - jaro1   Wow, many thanks, works fine here. Only short no...   Aug 30 2011, 22:52
RSS Lo-Fi Version Time is now: 31st July 2015 - 17:54
