Vinyl -> Digital
Aleron Ives
post Dec 13 2010, 02:23
After a bit of searching, I failed to find any specific answers, so I hope I'm not repeating a commonly-asked question. I'm planning to make digital recordings from vinyl by using the line-in jack on my PC with a Sound Blaster Audigy 2 sound card. I was planning to use Audacity to do the recording, and I was wondering if there is any real purpose to using 24 bit and/or a high sample rate like 88,200 or 96,000 Hz when originally recording. The final destination will be typical 16 bit 44,100 Hz, but if I decide to try do do click/pop or noise removal, is there any benefit from doing such work at a higher quality and then reducing the sample rate and bit depth later, rather than doing all the manipulation at an initial setting of 16/44? The only topic on this subject that I found was this one:
http://www.hydrogenaudio.org/forums/index....showtopic=61758
Also, Audacity allows you to record with 32 bit float as well, but I'm quite sure that my sound card doesn't support it. Is there any way to verify that the sound card actually does output 24 bit when you're recording at that depth? If there is, I haven't found any way to configure it, except in the media player supplied by Creative, which allows you to select the bit depth for recording (but presumably only for it, not for other programs like Audacity). Any assistance would be greatly appreciated.
LocrianGroove
post Dec 15 2010, 04:36
Has anyone done any testing to determine the minimum number of bits required for a digital recording to sound the same as a vinyl recording? We've been doing the calculations based on the SNR of the medium (e.g. 12 bits for a ~72 dB SNR), but has anyone determined a threshold for transparency via listening tests? Does anyone think they can hear stuff below the noise floor?
cliveb
post Dec 15 2010, 10:44
WaveRepair developer
QUOTE (LocrianGroove @ Dec 15 2010, 03:36) *
I just did a very casual test using small section of a typical vinyl rip that I did some time back. The original rip was made at 16 bits with an M-Audio AP2496 soundcard. (The turntable/arm/cartridge/preamp was Linn LP12/Ittok/Karma/Naim NAC42.5). The LP was a fairly typical album from my collection - not a test record or "audiophile" pressing, but a normal album in good condition. I deliberately chose a section that was fairly quiet (final part of a tune with delicate piano and tinking cymbals).
I prepared the reduced bit depth samples by cutting the amplitude by 6dB and then raising it back by 6dB. Each such cut/boost cycle gives a 1 bit reduction (as near as makes no odds). I did all this at 16 bit without dither to provoke approximately the same sort of quantisation noise you'd get with native recording at those bit depths.
It was trivially easy to hear the difference between 16 bit and 11 bit - ABX log follows:
foo_abx v1.2 report
foobar2000 v0.8.3
2010/12/15 09:23:00
File A: file://C:\clive\audio\The Guest Stars\Out At Night\x11.wav
File B: file://C:\clive\audio\The Guest Stars\Out At Night\x16.wav
09:23:00 : Test started.
09:23:33 : 01/01  50.0%
09:23:37 : 02/02  25.0%
09:23:40 : 03/03  12.5%
09:23:48 : 04/04  6.3%
09:23:55 : 05/05  3.1%
09:23:59 : 06/06  1.6%
09:24:03 : 07/07  0.8%
09:24:06 : 08/08  0.4%
09:24:12 : 09/09  0.2%
09:24:18 : 10/10  0.1%
09:24:20 : Test finished.
Total: 10/10 (0.1%)
I could not tell the difference in an ABX between the 16 bit and 12 bit versions. Note that I was doing this test on a laptop with a not especially sophisticated audio path, using fairly run of the mill headphones (Sennheiser 435). Therefore I think it is conceivable that it might be possible to distinguish the 12 bit version with better playback equipment and/or other music samples.
So: how does this answer the question of the minimum number of bits needed to transparently record an LP? Well, my argument is that if there is no difference between 12 and 16 bits, adding still more isn't going to help. My conclusion is that 13 bits is probably enough to faithfully record typical vinyl sources, although you'd then have to be very careful about recording levels to ensure you actually made use of all 13 bits.
- Aleron Ives   Vinyl -> Digital   Dec 13 2010, 02:23
- - saratoga   I'd probably just record at whatever the highe...   Dec 13 2010, 02:27
- - Aleron Ives   If I select to record at 96/24 in a program like A...   Dec 13 2010, 05:07
|- - saratoga   QUOTE (Aleron Ives @ Dec 12 2010, 23:07) ...   Dec 13 2010, 05:09
- - Juha   Audigy 2 does support 24/96 but, it's same res...   Dec 13 2010, 05:55
|- - Aleron Ives   QUOTE (Juha @ Dec 12 2010, 21:55) Audigy ...   Dec 13 2010, 06:42
|- - Brod   QUOTE (Juha @ Dec 13 2010, 12:55) To test...   Feb 9 2012, 07:26
|- - pdq   QUOTE (Brod @ Feb 9 2012, 02:26) QUOTE (J...   Feb 9 2012, 18:14
|- - greynol   QUOTE (Brod @ Feb 8 2012, 22:26) You...   Feb 9 2012, 18:52
- - rkay5   Hi, I recorded a lot LP's and I have found ...   Dec 13 2010, 07:30
|- - greynol   It was actually primarily directed at the last par...   Dec 14 2010, 20:57
- - greynol   Per our Terms of Service to which you agreed upon ...   Dec 13 2010, 07:39
|- - 2Bdecided   QUOTE (greynol @ Dec 13 2010, 06:39) Per ...   Dec 14 2010, 14:44
- - cliveb   QUOTE (Aleron Ives @ Dec 13 2010, 01:23) ...   Dec 13 2010, 09:53
|- - Aleron Ives   Thanks for all the input so far. I do have a few m...   Dec 13 2010, 21:25
|- - saratoga   QUOTE (Aleron Ives @ Dec 13 2010, 15:25) ...   Dec 13 2010, 21:30
|- - DonP   QUOTE (Aleron Ives @ Dec 13 2010, 15:25) ...   Dec 13 2010, 22:01
|- - cliveb   QUOTE (Aleron Ives @ Dec 13 2010, 20:25) ...   Dec 14 2010, 09:39
|- - DonP   QUOTE (cliveb @ Dec 14 2010, 03:39) Provi...   Dec 14 2010, 13:30
- - greynol   Unless you know that you're going to have a pr...   Dec 13 2010, 22:01
- - Juha   QUOTE Since recording at 24/96 seems to be out of ...   Dec 13 2010, 22:07
- - greynol   I only scanned those links, but didn't see any...   Dec 13 2010, 22:12
- - Juha   QUOTE I think you're probably best off recordi...   Dec 13 2010, 22:15
- - greynol   Ok so they still didn't get it right with the ...   Dec 13 2010, 22:20
- - LocrianGroove   Has anyone done any testing to determine the minim...   Dec 15 2010, 04:36
|- - saratoga   QUOTE (LocrianGroove @ Dec 14 2010, 22:36...   Dec 15 2010, 06:42
|- - cliveb   QUOTE (LocrianGroove @ Dec 15 2010, 03:36...   Dec 15 2010, 10:44
|- - LocrianGroove   QUOTE (cliveb @ Dec 15 2010, 04:44) It wa...   Dec 15 2010, 19:13
- - kraut   QUOTE We've been doing the calculations based ...   Dec 15 2010, 07:11
|- - LocrianGroove   QUOTE (kraut @ Dec 15 2010, 01:11) QUOTE ...   Dec 15 2010, 19:05
- - AndyH-ha   There is the noise level as recorded and the noise...   Dec 15 2010, 08:53
- - Brod   There's no such thing as a dead discussion - t...   Feb 10 2012, 08:46
- - Canar   QUOTE (Brod @ Feb 8 2012, 22:26) QUOTE (J...   Feb 10 2012, 08:51
RSS Lo-Fi Version Time is now: 3rd March 2015 - 15:00
