2 Pages V  < 1 2
foo_dsp_convolver, Gapless convolver
romor
post Jan 5 2011, 01:12
Post #26
same, unfortunately
scripts: http://goo.gl/M1qVLQ
lvqcl
post Jan 5 2011, 01:29
Post #27
Well, I have no idea why such things happen. You can continue to use 0.3.5, or delete fftw-wisdom.dat to disable FFTW support.
(You can also try empty fftw-wisdom.dat, but I don't think it will help).
Sandrine
post Apr 3 2011, 01:06
Post #28
Pardon my ignorance, but what is that wisdom-thingie? I know about wisdom teeth, but that's about it.
lvqcl
post Apr 3 2011, 01:33
Post #29
If you don't want to use FFTW library, you don't need it. (FFTW library offers very fast FFT routines but using it may or may not be legal).
In other words, you probably don't need it.
Rollin
post Jul 30 2011, 13:02
Post #30
When foobar is in portable mode and impulses files located in foobar2000 directory, convolver version 0.3.8/0.4.0 gives error "Error during loading of impulse file: Object not found". It seems relative paths don't work. WinXP SP3, foobar2000 1.1.7. Impulses folder path "D:\foobar2000\ConvolverImpulses\De-Emphasis\"
This post has been edited by Rollin: Jul 30 2011, 13:03
lvqcl
post Jul 30 2011, 14:08
Post #31
Please post a screenshot with its settings.
Rollin
post Jul 30 2011, 14:30
Post #32
QUOTE (lvqcl @ Jul 30 2011, 17:08) *
Convolver's settings?
And convolver is the only active dsp.
lvqcl
post Jul 30 2011, 16:13
Post #33
Thanks for the report. I can reproduce this problem on WinXP but not on Win7.
I'll add a workaround for it.
sshd
post Jul 14 2012, 00:41
Post #34
This is truly a wonderful plugin as it allows me to use foobar2000 as an active crossover (along with foo_mm).
The official convolver cannot do this as it is limited to two channels only.
There is an alternative through foo_vst and ConvolverVST, but ConvolverVST can only have one configuration which is shared between all vst hosts. I use ConvolverVST with a minimum delay crossover for movies and youtube. foobar2000 on the other hand is using a very long filter with time domain correction, that causes major lip-sync problems in movies.
I do however have three suggestions for improvements:
1. Let user specify multiple FIR filters with different sample rates and detect the input sample rate. This will eliminate the need for a resampler in the DSP chain.
2. Support assymetric channel config (e.g. 2 in, 6 out) through the .cfg format rather than .wav. This will eliminate the need for a matrix mixer like foo_mm.
3. A checkbox to disable gapless mode. When comparing the effect of two filters with a keyboard shortcut, it is rather nice to be able to hear that it has switched.
Thanks again.
lvqcl
post Jul 14 2012, 12:41
Post #35
1) maybe, in some (distant?) future
2) unlikely, because this plugin is just a generic convolver, not up/downmixer or crossover filter.
3) ??? "gapless" means that it doesn't add extra samples at the beginning and the end of tracks (as opposed to foo_convolve).
sshd
post Jul 14 2012, 22:52
Post #36
2. You do not need a special convolver for a crossover. A generic will do just fine. I believe the .cfg file definition is for a generic convolver. It is widely supported by ConvolverVST, brutefir and more.
It is really quite simple. In comes stereo split into 2x3 - high, mid and low. These 2x3 channels goes through the 6 channel convolver and there you have a crossover. But it is not a problem as such, since the plugin works perfectly with foo_mm.
AndreaT
post Jul 16 2012, 10:55
Post #37
Hello SSHD, I see you mentioned foo_mm as sa good Xover.
Where can I download it?
I looked for it, but I could find it so far.
Many thanks
Regards, Andrea.
sshd
post Jul 16 2012, 19:38
Post #38
foo_mm is a Matrix Mixer you can use to convert 2 channels to 2x3 channels - not as crossover.
http://skipyrich.com/wiki/Index.php/Foobar2000:Matrix_Mixer
AndreaT
post Jul 20 2012, 17:59
Post #39
Thank you SSHD, I misunderstood.
Regards, Andrea
romor
post Aug 16 2012, 20:45
Post #40
If I use any impulse with this component and then try to use foo_yac, it fails with:
Can't apply filter: .\filter\44\some_impulse.wav
With "official" convolver (by Peter or Garf, not sure) this issue is not present, so I'm reporting here
lvqcl
post Aug 17 2012, 15:31
Post #41
Ver. 0.4.6 should fix it.
lvqcl
post Feb 10 2013, 13:04
Post #42
0.4.7 - possible cause of crash fixed.
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 27th January 2015 - 15:04
