foo_vst: VST 2.4 adapter, Multi-instance, multichannel, and seamless; Now back in development
Yegor
post Nov 13 2010, 22:07
Foobar2000 VST 2.4 adapter
by Yegor Petrov
How to use it (video)
Description, usage, changelog and other info is in Hydrogenaudio Wiki.
Version 0.9.0.3 download: Attached File  foo_vst_0903.zip ( 125.6K ) Number of downloads: 64834
Alternative ZIP of the same DLL: Attached File  foo_vst.zip ( 126.75K ) Number of downloads: 6982
Yegor's latest source (2011-08-31; see p. 13): foo_vst_src.zip ( 180.35K )
This software is provided 'as-is', without any express or implied warranty.
In no event will the author be held liable for any damages arising from the use of this software.
VST is a trademark of Steinberg Media Technologies GmbH
This post has been edited by Yegor: Jan 19 2013, 19:48
Reason for edit: adding alternative download for those whose unpacker complains about the original
Yegor
post Dec 23 2010, 18:31
0.7.0
Serious bugfixes.
Relative paths in the portable mode.
In general, it's the first version to support the portable mode. It may sound strange because fb2k provides transparent storage for its components, but in this case it's necessary to read configuration at the stage where fb2k services aren't available yet. Depending on the installation, the adapter uses either the registry or a file in the player's directory.
This post has been edited by Entrase: Dec 23 2010, 23:34
- Entrase   foo_vst: VST 2.4 adapter   Nov 13 2010, 22:07
- - Sandrine   QUOTE (Entrase @ Nov 13 2010, 23:07) This...   Nov 13 2010, 22:55
- - Canar   Excellent! Finally a VST adapter that feels li...   Nov 13 2010, 22:58
|- - Robertina   QUOTE (Canar @ Nov 13 2010, 10:58) Finall...   Nov 15 2010, 02:44
|- - riboge   QUOTE (Robertina @ Nov 14 2010, 20:44) QU...   Nov 16 2010, 22:57
|- - Robertina   QUOTE (riboge @ Nov 16 2010, 10:57) You s...   Nov 17 2010, 05:26
- - klonuo   Looks fine here and great plus for design (setting...   Nov 13 2010, 23:18
- - mudlord   Very nice work. Makes my stuff redundant but oh w...   Nov 14 2010, 01:13
- - thuan   The way VST supposed to be used in foobar. Very ni...   Nov 14 2010, 02:34
- - Alexander Ostuni   Fantastaic. I have a recording studio and own a lo...   Nov 14 2010, 07:05
- - Alexander Ostuni   Hi, what I found out so far. Smoth integration v...   Nov 14 2010, 07:19
- - Entrase   QUOTE then restarted foobar (is this necessary?)Un...   Nov 14 2010, 07:36
- - thuan   It's just crashed on me, I submitted the crash...   Nov 14 2010, 11:38
|- - Entrase   QUOTE (thuan @ Nov 14 2010, 15:38) I subm...   Nov 14 2010, 11:53
|- - Canar   QUOTE (Entrase @ Nov 14 2010, 06:53) I...   Nov 14 2010, 18:09
|- - Entrase   Ok. Let's keep it I'm just afraid that my...   Nov 14 2010, 18:12
|- - Zin-Uru   QUOTE (Entrase @ Nov 14 2010, 18:12) Ok. ...   Nov 14 2010, 18:40
- - thuan   I think if you set it up then forget about it it...   Nov 14 2010, 12:30
- - Entrase   Exactly! And I'm the first kind of user :-...   Nov 14 2010, 12:34
- - Zin-Uru   Thank you! Very actual plugin. Will try.   Nov 14 2010, 14:44
- - lvqcl   Jusr release stable version with new version numbe...   Nov 14 2010, 19:21
- - Steve Forte Rio   Plugin crashes very often when using iZotope Ozone...   Nov 15 2010, 10:16
- - Entrase   QUOTE Or do I fail to see something in my first co...   Nov 15 2010, 11:03
- - Steve Forte Rio   QUOTE Thanks. But please use something like pasteb...   Nov 15 2010, 13:33
|- - GeSomeone   QUOTE (Steve Forte Rio @ Nov 15 2010, 14...   Nov 15 2010, 15:03
- - rx32555   VST + winamp_dsp_bridge (dfx) = Nice sound Th...   Nov 15 2010, 23:13
|- - kode54   QUOTE (rx32555 @ Nov 15 2010, 15:13) VST ...   Nov 15 2010, 23:27
|- - rx32555   QUOTE (kode54 @ Nov 15 2010, 18:27) QUOTE...   Nov 16 2010, 03:27
- - Mr.Duck   Nice plugin. I'm using it for this crossfeed.....   Nov 16 2010, 04:23
- - Entrase   Here is a new version. It only contains core bugfi...   Nov 16 2010, 07:18
|- - klonuo   QUOTE (Entrase @ Nov 16 2010, 07:18) Acon...   Nov 19 2010, 02:21
- - thuan   Tested it, still crash with http://refinedaudiomet...   Nov 16 2010, 07:29
|- - Entrase   At this stage it'll be more useful if you tell...   Nov 16 2010, 08:43
- - thuan   Well I only got it crashed with HDPHX and you expl...   Nov 16 2010, 09:30
- - kode54   Maybe that configuration button could be disabled ...   Nov 16 2010, 14:15
- - Entrase   If it wasn't about some major changes in the c...   Nov 16 2010, 15:04
- - Mr.Duck   QUOTE (Entrase @ Nov 16 2010, 07:18) Here...   Nov 16 2010, 18:36
|- - Entrase   I can't get it crashing at all. May be you...   Nov 16 2010, 18:47
- - Mr.Duck   I moved the VST file from the foobar root folder i...   Nov 16 2010, 20:35
- - noiselab   Will there be support for 64-bit VSTs?   Nov 18 2010, 20:27
|- - Sandrine   QUOTE (noiselab @ Nov 18 2010, 21:27) Wil...   Nov 18 2010, 21:01
|- - Entrase   I'm afraid no. 1. Foobar2000 is 32-bit applica...   Nov 18 2010, 21:09
|- - SevenTwo   QUOTE (noiselab @ Nov 18 2010, 20:27) Wil...   Nov 22 2010, 00:46
- - kode54   The only way to support 64-bit VST effects would b...   Nov 19 2010, 01:00
- - thuan   Depends, if you like different implementation get ...   Nov 19 2010, 03:26
- - klonuo   If you are replying to my post, there is misunders...   Nov 19 2010, 03:49
|- - Entrase   I don't know how to deal with it yet But sure...   Nov 19 2010, 08:15
- - Entrase   Bad news. I've spent some time trying to figur...   Nov 19 2010, 14:43
- - Canar   One possible solution for VST-based visualization ...   Nov 19 2010, 16:36
- - Entrase   Is this time-coded PCM data?   Nov 19 2010, 17:03
- - Canar   I'm not entirely sure what you mean by "t...   Nov 19 2010, 19:09
|- - Entrase   I've misunderstood you. Yes, that should be po...   Nov 19 2010, 20:37
|- - mudlord   QUOTE (Canar @ Nov 19 2010, 13:09) I...   Nov 20 2010, 12:26
- - Entrase   That's pointless. Foobar's DSP chain bit d...   Nov 22 2010, 07:28
|- - Marsu42   I just tried it and it is very nice to have the ab...   Nov 22 2010, 22:44
|- - thuan   QUOTE (Entrase @ Nov 22 2010, 13:28) That...   Nov 23 2010, 03:38
- - Entrase   QUOTE Maybe you could implement direct menu shortc...   Nov 23 2010, 05:58
- - thuan   QUOTE (thuan @ Nov 23 2010, 09:38) Higher...   Nov 23 2010, 06:33
- - Entrase   QUOTE it should be better if it can be done like t...   Nov 23 2010, 06:41
- - klonuo   QUOTE (Entrase @ Nov 13 2010, 22:07) Mult...   Nov 23 2010, 14:46
- - pjofoobar   Hi Entrase, your VST plug in is great ! It loa...   Nov 23 2010, 14:54
- - Entrase   Yes, klonuo, I'm going to work on multichannel...   Nov 23 2010, 19:05
- - Entrase   Coming soon... :)   Nov 25 2010, 16:39
- - thuan   What about no reload track switch, I'm waiting...   Nov 25 2010, 16:52
|- - Entrase   QUOTE (thuan @ Nov 25 2010, 20:52) What a...   Nov 29 2010, 09:36
|- - thuan   @Entrase: Thanks, but I hear a small click when re...   Nov 29 2010, 11:08
- - klonuo   @Entrase: maybe you should leave routing as is, be...   Nov 25 2010, 19:23
- - Entrase   QUOTE What about no reload track switch, I'm w...   Nov 25 2010, 20:20
- - Entrase   Update Please re-download the archive. Now you ca...   Nov 27 2010, 20:18
- - Sandrine   Please update the first post with changes instead ...   Nov 27 2010, 20:43
|- - Entrase   QUOTE (Sandrine @ Nov 28 2010, 00:43) Ple...   Nov 27 2010, 21:03
|- - Sandrine   QUOTE (Entrase @ Nov 27 2010, 22:03) QUOT...   Nov 27 2010, 21:51
- - klonuo   QUOTE (Entrase @ Nov 27 2010, 20:18) 16 a...   Nov 27 2010, 22:23
- - klonuo   @Entrase: Try to load same VST twice (in VST listi...   Nov 28 2010, 03:49
|- - Entrase   Yes, I know. Don't do this. It won't be ea...   Nov 28 2010, 06:29
|- - foosion   QUOTE (Entrase @ Nov 28 2010, 06:29) Actu...   Nov 28 2010, 12:27
- - Entrase   I know. But the problem is a little bit deeper. Tr...   Nov 28 2010, 13:11
- - Sandrine   -deleted-   Nov 29 2010, 10:29
- - Entrase   Are you sure about it? Try the same with no DSPs. ...   Nov 29 2010, 21:56
- - thuan   Sure, happened with Isone Pro, my only VST, does n...   Nov 30 2010, 03:55
- - Entrase   Okay, the problem isn't with sample difference...   Nov 30 2010, 08:46
- - Steve Forte Rio   What a...?? QUOTE Failed to load DLL: foo_vst.dll...   Nov 30 2010, 19:07
- - Entrase   Rus: Неверн...   Nov 30 2010, 19:38
|- - Toggie   Ignore, I missed the registry key...   Dec 5 2010, 11:51
- - Melomane   thank you , very nice plugin!   Dec 5 2010, 19:23
|- - Marsu42   QUOTE (Melomane @ Dec 5 2010, 19:23) than...   Dec 6 2010, 14:48
- - larryfine   Thank you. Works fine with Voxengo TubeAmp, Ruby T...   Dec 6 2010, 16:11
- - Entrase   There is update to 0.6.0. But please keep old vers...   Dec 13 2010, 21:23
- - thuan   Thanks for the update, the click on track change s...   Dec 14 2010, 09:46
- - Entrase   This click is caused by the procedure of commiting...   Dec 14 2010, 11:40
|- - thuan   QUOTE (Entrase @ Dec 14 2010, 17:40) This...   Dec 14 2010, 16:59
- - servimo   I now upgrade to v6.0, used the registry cleanup f...   Dec 14 2010, 14:53
- - Entrase   Unfortunately, you've removed all entries with...   Dec 14 2010, 16:41
|- - servimo   QUOTE (Entrase @ Dec 14 2010, 12:41) Unfo...   Dec 16 2010, 15:32
- - garyldavis   QUOTE (Entrase @ Nov 13 2010, 16:07) Fin...   Dec 15 2010, 16:52
- - Entrase   How many inputs/outputs are in VSTs you tried?   Dec 15 2010, 17:28
|- - garyldavis   QUOTE (Entrase @ Dec 15 2010, 11:28) How ...   Dec 16 2010, 17:45
|- - garyldavis   QUOTE (Entrase @ Dec 15 2010, 11:28) How ...   Dec 17 2010, 00:21
- - hidn   must have   Dec 16 2010, 19:26
- - Entrase   0.7.0 Serious bugfixes. Relative paths in the por...   Dec 23 2010, 18:31
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st July 2015 - 06:29
