foo_vst: VST 2.4 adapter, Multi-instance, multichannel, and seamless; Now back in development
Yegor
post Nov 13 2010, 22:07
Foobar2000 VST 2.4 adapter
by Yegor Petrov
How to use it (video)
Description, usage, changelog and other info is in Hydrogenaudio Wiki.
Version 0.9.0.3 download: Attached File  foo_vst_0903.zip ( 125.6K ) Number of downloads: 66406
Alternative ZIP of the same DLL: Attached File  foo_vst.zip ( 126.75K ) Number of downloads: 7241
Yegor's latest source (2011-08-31; see p. 13): foo_vst_src.zip ( 180.35K )
This software is provided 'as-is', without any express or implied warranty.
In no event will the author be held liable for any damages arising from the use of this software.
VST is a trademark of Steinberg Media Technologies GmbH
This post has been edited by Yegor: Jan 19 2013, 19:48
Reason for edit: adding alternative download for those whose unpacker complains about the original
Yegor
post Dec 13 2010, 21:23
There is update to 0.6.0. But please keep old version if it works fine for you. Don't forget it's still not very stable.
- Entrase   foo_vst: VST 2.4 adapter   Nov 13 2010, 22:07
- - Sandrine   QUOTE (Entrase @ Nov 13 2010, 23:07) This...   Nov 13 2010, 22:55
- - Canar   Excellent! Finally a VST adapter that feels li...   Nov 13 2010, 22:58
|- - Robertina   QUOTE (Canar @ Nov 13 2010, 10:58) Finall...   Nov 15 2010, 02:44
|- - riboge   QUOTE (Robertina @ Nov 14 2010, 20:44) QU...   Nov 16 2010, 22:57
|- - Robertina   QUOTE (riboge @ Nov 16 2010, 10:57) You s...   Nov 17 2010, 05:26
- - klonuo   Looks fine here and great plus for design (setting...   Nov 13 2010, 23:18
- - mudlord   Very nice work. Makes my stuff redundant but oh w...   Nov 14 2010, 01:13
- - thuan   The way VST supposed to be used in foobar. Very ni...   Nov 14 2010, 02:34
- - Alexander Ostuni   Fantastaic. I have a recording studio and own a lo...   Nov 14 2010, 07:05
- - Alexander Ostuni   Hi, what I found out so far. Smoth integration v...   Nov 14 2010, 07:19
- - Entrase   QUOTE then restarted foobar (is this necessary?)Un...   Nov 14 2010, 07:36
- - thuan   It's just crashed on me, I submitted the crash...   Nov 14 2010, 11:38
|- - Entrase   QUOTE (thuan @ Nov 14 2010, 15:38) I subm...   Nov 14 2010, 11:53
|- - Canar   QUOTE (Entrase @ Nov 14 2010, 06:53) I...   Nov 14 2010, 18:09
|- - Entrase   Ok. Let's keep it I'm just afraid that my...   Nov 14 2010, 18:12
|- - Zin-Uru   QUOTE (Entrase @ Nov 14 2010, 18:12) Ok. ...   Nov 14 2010, 18:40
- - thuan   I think if you set it up then forget about it it...   Nov 14 2010, 12:30
- - Entrase   Exactly! And I'm the first kind of user :-...   Nov 14 2010, 12:34
- - Zin-Uru   Thank you! Very actual plugin. Will try.   Nov 14 2010, 14:44
- - lvqcl   Jusr release stable version with new version numbe...   Nov 14 2010, 19:21
- - Steve Forte Rio   Plugin crashes very often when using iZotope Ozone...   Nov 15 2010, 10:16
- - Entrase   QUOTE Or do I fail to see something in my first co...   Nov 15 2010, 11:03
- - Steve Forte Rio   QUOTE Thanks. But please use something like pasteb...   Nov 15 2010, 13:33
|- - GeSomeone   QUOTE (Steve Forte Rio @ Nov 15 2010, 14...   Nov 15 2010, 15:03
- - rx32555   VST + winamp_dsp_bridge (dfx) = Nice sound Th...   Nov 15 2010, 23:13
|- - kode54   QUOTE (rx32555 @ Nov 15 2010, 15:13) VST ...   Nov 15 2010, 23:27
|- - rx32555   QUOTE (kode54 @ Nov 15 2010, 18:27) QUOTE...   Nov 16 2010, 03:27
- - Mr.Duck   Nice plugin. I'm using it for this crossfeed.....   Nov 16 2010, 04:23
- - Entrase   Here is a new version. It only contains core bugfi...   Nov 16 2010, 07:18
|- - klonuo   QUOTE (Entrase @ Nov 16 2010, 07:18) Acon...   Nov 19 2010, 02:21
- - thuan   Tested it, still crash with http://refinedaudiomet...   Nov 16 2010, 07:29
|- - Entrase   At this stage it'll be more useful if you tell...   Nov 16 2010, 08:43
- - thuan   Well I only got it crashed with HDPHX and you expl...   Nov 16 2010, 09:30
- - kode54   Maybe that configuration button could be disabled ...   Nov 16 2010, 14:15
- - Entrase   If it wasn't about some major changes in the c...   Nov 16 2010, 15:04
- - Mr.Duck   QUOTE (Entrase @ Nov 16 2010, 07:18) Here...   Nov 16 2010, 18:36
|- - Entrase   I can't get it crashing at all. May be you...   Nov 16 2010, 18:47
- - Mr.Duck   I moved the VST file from the foobar root folder i...   Nov 16 2010, 20:35
- - noiselab   Will there be support for 64-bit VSTs?   Nov 18 2010, 20:27
|- - Sandrine   QUOTE (noiselab @ Nov 18 2010, 21:27) Wil...   Nov 18 2010, 21:01
|- - Entrase   I'm afraid no. 1. Foobar2000 is 32-bit applica...   Nov 18 2010, 21:09
|- - SevenTwo   QUOTE (noiselab @ Nov 18 2010, 20:27) Wil...   Nov 22 2010, 00:46
- - kode54   The only way to support 64-bit VST effects would b...   Nov 19 2010, 01:00
- - thuan   Depends, if you like different implementation get ...   Nov 19 2010, 03:26
- - klonuo   If you are replying to my post, there is misunders...   Nov 19 2010, 03:49
|- - Entrase   I don't know how to deal with it yet But sure...   Nov 19 2010, 08:15
- - Entrase   Bad news. I've spent some time trying to figur...   Nov 19 2010, 14:43
- - Canar   One possible solution for VST-based visualization ...   Nov 19 2010, 16:36
- - Entrase   Is this time-coded PCM data?   Nov 19 2010, 17:03
- - Canar   I'm not entirely sure what you mean by "t...   Nov 19 2010, 19:09
|- - Entrase   I've misunderstood you. Yes, that should be po...   Nov 19 2010, 20:37
|- - mudlord   QUOTE (Canar @ Nov 19 2010, 13:09) I...   Nov 20 2010, 12:26
- - Entrase   That's pointless. Foobar's DSP chain bit d...   Nov 22 2010, 07:28
|- - Marsu42   I just tried it and it is very nice to have the ab...   Nov 22 2010, 22:44
|- - thuan   QUOTE (Entrase @ Nov 22 2010, 13:28) That...   Nov 23 2010, 03:38
- - Entrase   QUOTE Maybe you could implement direct menu shortc...   Nov 23 2010, 05:58
- - thuan   QUOTE (thuan @ Nov 23 2010, 09:38) Higher...   Nov 23 2010, 06:33
- - Entrase   QUOTE it should be better if it can be done like t...   Nov 23 2010, 06:41
- - klonuo   QUOTE (Entrase @ Nov 13 2010, 22:07) Mult...   Nov 23 2010, 14:46
- - pjofoobar   Hi Entrase, your VST plug in is great ! It loa...   Nov 23 2010, 14:54
- - Entrase   Yes, klonuo, I'm going to work on multichannel...   Nov 23 2010, 19:05
- - Entrase   Coming soon... :)   Nov 25 2010, 16:39
- - thuan   What about no reload track switch, I'm waiting...   Nov 25 2010, 16:52
|- - Entrase   QUOTE (thuan @ Nov 25 2010, 20:52) What a...   Nov 29 2010, 09:36
|- - thuan   @Entrase: Thanks, but I hear a small click when re...   Nov 29 2010, 11:08
- - klonuo   @Entrase: maybe you should leave routing as is, be...   Nov 25 2010, 19:23
- - Entrase   QUOTE What about no reload track switch, I'm w...   Nov 25 2010, 20:20
- - Entrase   Update Please re-download the archive. Now you ca...   Nov 27 2010, 20:18
- - Sandrine   Please update the first post with changes instead ...   Nov 27 2010, 20:43
|- - Entrase   QUOTE (Sandrine @ Nov 28 2010, 00:43) Ple...   Nov 27 2010, 21:03
|- - Sandrine   QUOTE (Entrase @ Nov 27 2010, 22:03) QUOT...   Nov 27 2010, 21:51
- - klonuo   QUOTE (Entrase @ Nov 27 2010, 20:18) 16 a...   Nov 27 2010, 22:23
- - klonuo   @Entrase: Try to load same VST twice (in VST listi...   Nov 28 2010, 03:49
|- - Entrase   Yes, I know. Don't do this. It won't be ea...   Nov 28 2010, 06:29
|- - foosion   QUOTE (Entrase @ Nov 28 2010, 06:29) Actu...   Nov 28 2010, 12:27
- - Entrase   I know. But the problem is a little bit deeper. Tr...   Nov 28 2010, 13:11
- - Sandrine   -deleted-   Nov 29 2010, 10:29
- - Entrase   Are you sure about it? Try the same with no DSPs. ...   Nov 29 2010, 21:56
- - thuan   Sure, happened with Isone Pro, my only VST, does n...   Nov 30 2010, 03:55
- - Entrase   Okay, the problem isn't with sample difference...   Nov 30 2010, 08:46
- - Steve Forte Rio   What a...?? QUOTE Failed to load DLL: foo_vst.dll...   Nov 30 2010, 19:07
- - Entrase   Rus: Неверн...   Nov 30 2010, 19:38
|- - Toggie   Ignore, I missed the registry key...   Dec 5 2010, 11:51
- - Melomane   thank you , very nice plugin!   Dec 5 2010, 19:23
|- - Marsu42   QUOTE (Melomane @ Dec 5 2010, 19:23) than...   Dec 6 2010, 14:48
- - larryfine   Thank you. Works fine with Voxengo TubeAmp, Ruby T...   Dec 6 2010, 16:11
- - Entrase   There is update to 0.6.0. But please keep old vers...   Dec 13 2010, 21:23
- - thuan   Thanks for the update, the click on track change s...   Dec 14 2010, 09:46
- - Entrase   This click is caused by the procedure of commiting...   Dec 14 2010, 11:40
|- - thuan   QUOTE (Entrase @ Dec 14 2010, 17:40) This...   Dec 14 2010, 16:59
- - servimo   I now upgrade to v6.0, used the registry cleanup f...   Dec 14 2010, 14:53
- - Entrase   Unfortunately, you've removed all entries with...   Dec 14 2010, 16:41
|- - servimo   QUOTE (Entrase @ Dec 14 2010, 12:41) Unfo...   Dec 16 2010, 15:32
- - garyldavis   QUOTE (Entrase @ Nov 13 2010, 16:07) Fin...   Dec 15 2010, 16:52
- - Entrase   How many inputs/outputs are in VSTs you tried?   Dec 15 2010, 17:28
|- - garyldavis   QUOTE (Entrase @ Dec 15 2010, 11:28) How ...   Dec 16 2010, 17:45
|- - garyldavis   QUOTE (Entrase @ Dec 15 2010, 11:28) How ...   Dec 17 2010, 00:21
- - hidn   must have   Dec 16 2010, 19:26
- - Entrase   0.7.0 Serious bugfixes. Relative paths in the por...   Dec 23 2010, 18:31
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th August 2015 - 23:49
